root/Development/ray/src/common/calcomp.h
Revision: 2.21
Committed: Fri Sep 23 19:04:52 2005 UTC (20 years, 3 months ago) by greg
CVS Tags: rad3R9, rad3R8
1 /* RCSid $Id: calcomp.h,v 2.20 2005/05/25 04:44:25 greg Exp $ */
2 /*
3 * calcomp.h - header file for expression parser.
4 */
5 #ifndef _RAD_CALCOMP_H_
6 #define _RAD_CALCOMP_H_
7
8 #include <stdio.h>
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 #define VAR 1
15 #define NUM 2
16 #define UMINUS 3
17 #define CHAN 4
18 #define FUNC 5
19 #define ARG 6
20 #define TICK 7
21 #define SYM 8
22 /* also: '+', '-', '*', '/', '^', '=', ':' */
23
24 typedef struct {
25 char *fname; /* function name */
26 short nargs; /* # of required arguments */
27 short atyp; /* assignment type (':' or '=') */
28 double (*f)(char *); /* pointer to function */
29 } LIBR; /* a library function */
30
31 typedef struct epnode {
32 union {
33 struct epnode *kid; /* first child */
34 double num; /* number */
35 char *name; /* symbol name */
36 int chan; /* channel number */
37 unsigned long tick; /* timestamp */
38 struct vardef {
39 char *name; /* variable name */
40 int nlinks; /* number of references */
41 struct epnode *def; /* definition */
42 LIBR *lib; /* library definition */
43 struct vardef *next; /* next in hash list */
44 } *ln; /* link */
45 } v; /* value */
46 struct epnode *sibling; /* next child this level */
47 int type; /* node type */
48 } EPNODE; /* an expression node */
49
50 typedef struct vardef VARDEF; /* a variable definition */
51
52 #define RMAXWORD 127 /* maximum word/id length */
53 #define CNTXMARK '`' /* context mark */
54
55 #define isid(c) (isalnum(c) || (c) == '_' || \
56 (c) == '.' || (c) == CNTXMARK)
57
58 #define evalue(ep) (*eoper[(ep)->type])(ep)
59
60 /* flags to set in esupport */
61 #define E_VARIABLE 001
62 #define E_FUNCTION 002
63 #define E_INCHAN 004
64 #define E_OUTCHAN 010
65 #define E_RCONST 020
66 #define E_REDEFW 040
67
68 extern double (*eoper[])(EPNODE *);
69 extern unsigned long eclock;
70 extern unsigned int esupport;
71 extern EPNODE *curfunc;
72 extern int nextc;
73 extern int eofc;
74
75 /* defined in biggerlib.c */
76 extern void biggerlib(void);
77
78 /* defined in caldefn.c */
79 extern void fcompile(char *fname);
80 extern void scompile(char *str, char *fname, int ln);
81 extern double varvalue(char *vname);
82 extern double evariable(EPNODE *ep);
83 extern void varset(char *vname, int assign, double val);
84 extern void dclear(char *name);
85 extern void dremove(char *name);
86 extern int vardefined(char *name);
87 extern char *setcontext(char *ctx);
88 extern char *pushcontext(char *ctx);
89 extern char *popcontext(void);
90 extern char *qualname(char *nam, int lvl);
91 extern int incontext(char *qn);
92 extern void chanout(void (*cs)(int n, double v));
93 extern void dcleanup(int lvl);
94 extern EPNODE *dlookup(char *name);
95 extern VARDEF *varlookup(char *name);
96 extern VARDEF *varinsert(char *name);
97 extern void varfree(VARDEF *ln);
98 extern EPNODE *dfirst(void);
99 extern EPNODE *dnext(void);
100 extern EPNODE *dpop(char *name);
101 extern void dpush(char *nm, EPNODE *ep);
102 extern void addchan(EPNODE *sp);
103 extern void getstatement(void);
104 extern EPNODE *getdefn(void);
105 extern EPNODE *getchan(void);
106 /* defined in calexpr.c */
107 extern EPNODE *eparse(char *expr);
108 extern double eval(char *expr);
109 extern int epcmp(EPNODE *ep1, EPNODE *ep2);
110 extern void epfree(EPNODE *epar);
111 extern EPNODE *ekid(EPNODE *ep, int n);
112 extern int nekids(EPNODE *ep);
113 extern void initfile(FILE *fp, char *fn, int ln);
114 extern void initstr(char *s, char *fn, int ln);
115 extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp);
116 extern int scan(void);
117 extern char *long2ascii(long l);
118 extern void syntax(char *err);
119 extern void addekid(EPNODE *ep, EPNODE *ekid);
120 extern char *getname(void);
121 extern int getinum(void);
122 extern double getnum(void);
123 extern EPNODE *getE1(void);
124 extern EPNODE *getE2(void);
125 extern EPNODE *getE3(void);
126 extern EPNODE *getE4(void);
127 extern EPNODE *getE5(void);
128 extern EPNODE *rconst(EPNODE *epar);
129 extern int isconstvar(EPNODE *ep);
130 extern int isconstfun(EPNODE *ep);
131 /* defined in calfunc.c */
132 extern int fundefined(char *fname);
133 extern double funvalue(char *fname, int n, double *a);
134 extern void funset(char *fname, int nargs, int assign,
135 double (*fptr)(char *));
136 extern int nargum(void);
137 extern double argument(int n);
138 extern VARDEF *argf(int n);
139 extern char *argfun(int n);
140 extern double efunc(EPNODE *ep);
141 extern LIBR *liblookup(char *fname);
142 extern void libupdate(char *fn);
143 /* defined in calprnt.c */
144 extern void eprint(EPNODE *ep, FILE *fp);
145 extern void dprint(char *name, FILE *fp);
146 /* defined by client */
147 extern double chanvalue(int n);
148
149
150 #ifdef __cplusplus
151 }
152 #endif
153 #endif /* _RAD_CALCOMP_H_ */
154
