root/radiance/ray/src/common/calcomp.h
Revision: 2.11
Committed: Fri Jun 27 06:53:21 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.10: +1 -4 lines
1 /* RCSid $Id: calcomp.h,v 2.10 2003/06/07 12:50:20 schorsch Exp $ */
2 /*
3 * calcomp.h - header file for expression parser.
4 */
5 #ifndef _RAD_CALCOMP_H_
6 #define _RAD_CALCOMP_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #include <stdio.h>
12
13 #define VAR 1
14 #define NUM 2
15 #define UMINUS 3
16 #define CHAN 4
17 #define FUNC 5
18 #define ARG 6
19 #define TICK 7
20 #define SYM 8
21 /* also: '+', '-', '*', '/', '^', '=', ':' */
22
23 typedef struct {
24 char *fname; /* function name */
25 short nargs; /* # of required arguments */
26 short atyp; /* assignment type (':' or '=') */
27 double (*f)(); /* pointer to function */
28 } LIBR; /* a library function */
29
30 typedef struct epnode {
31 int type; /* node type */
32 struct epnode *sibling; /* next child this level */
33 union {
34 struct epnode *kid; /* first child */
35 double num; /* number */
36 char *name; /* symbol name */
37 int chan; /* channel number */
38 unsigned long tick; /* timestamp */
39 struct vardef {
40 char *name; /* variable name */
41 int nlinks; /* number of references */
42 struct epnode *def; /* definition */
43 LIBR *lib; /* library definition */
44 struct vardef *next; /* next in hash list */
45 } *ln; /* link */
46 } v; /* value */
47 } EPNODE; /* an expression node */
48
49 typedef struct vardef VARDEF; /* a variable definition */
50
51 #define MAXWORD 127 /* maximum word/id length */
52 #define CNTXMARK '`' /* context mark */
53
54 #define isid(c) (isalnum(c) || (c) == '_' || \
55 (c) == '.' || (c) == CNTXMARK)
56
57 #define evalue(ep) (*eoper[(ep)->type])(ep)
58
59 /* flags to set in esupport */
60 #define E_VARIABLE 001
61 #define E_FUNCTION 002
62 #define E_INCHAN 004
63 #define E_OUTCHAN 010
64 #define E_RCONST 020
65 #define E_REDEFW 040
66
67 extern double (*eoper[])();
68 extern unsigned long eclock;
69 extern unsigned int esupport;
70 extern EPNODE *curfunc;
71 extern int nextc;
72
73 /* defined in caldefn.c */
74 extern void fcompile(char *fname);
75 extern void scompile(char *str, char *fname, int ln);
76 extern double varvalue(char *vname);
77 extern double evariable(EPNODE *ep);
78 extern void varset(char *fname, int assign, double val);
79 extern void dclear(char *name);
80 extern void dremove(char *name);
81 extern int vardefined(char *name);
82 extern char *setcontext(char *ctx);
83 extern char *pushcontext(char *ctx);
84 extern char *popcontext(void);
85 extern char *qualname(char *nam, int lvl);
86 extern int incontext(char *qn);
87 extern void chanout(void (*cs)(int n, double v));
88 extern void dcleanup(int lvl);
89 extern EPNODE *dlookup(char *name);
90 extern VARDEF *varlookup(char *name);
91 extern VARDEF *varinsert(char *name);
92 extern void varfree(VARDEF *ln);
93 extern EPNODE *dfirst(void);
94 extern EPNODE *dnext(void);
95 extern EPNODE *dpop(char *name);
96 extern void dpush(char *nm, EPNODE *ep);
97 extern void addchan(EPNODE *sp);
98 extern void getstatement();
99 extern EPNODE *getdefn();
100 extern EPNODE *getchan();
101 /* defined in calexpr.c */
102 extern EPNODE *eparse(char *expr);
103 extern double eval(char *expr);
104 extern int epcmp(EPNODE *ep1, EPNODE *ep2);
105 extern void epfree(EPNODE *epar);
106 extern EPNODE *ekid(EPNODE *ep, int n);
107 extern int nekids(EPNODE *ep);
108 extern void initfile(FILE *fp, char *fn, int ln);
109 extern void initstr(char *s, char *fn, int ln);
110 extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp);
111 extern int scan(void);
112 extern char *long2ascii(long l);
113 extern void syntax(char *err);
114 extern void addekid(EPNODE *ep, EPNODE *ekid);
115 extern char *getname(void);
116 extern int getinum(void);
117 extern double getnum(void);
118 extern EPNODE *getE1(void);
119 extern EPNODE *getE2(void);
120 extern EPNODE *getE3(void);
121 extern EPNODE *getE4(void);
122 extern EPNODE *getE5(void);
123 extern EPNODE *rconst(EPNODE *epar);
124 extern int isconstvar(EPNODE *ep);
125 extern int isconstfun(EPNODE *ep);
126 /* defined in calfunc.c */
127 extern int fundefined(char *fname);
128 extern double funvalue(char *fname, int n, double *a);
129 extern void funset(char *fname, int nargs, int assign, double (*fptr)());
130 extern int nargum(void);
131 extern double argument(int n);
132 extern VARDEF *argf(int n);
133 extern char *argfun(int n);
134 extern double efunc(EPNODE *ep);
135 extern LIBR *liblookup(char *fname);
136 extern void libupdate(char *fn);
137 /* defined in calprnt.c */
138 extern void eprint(EPNODE *ep, FILE *fp);
139 extern void dprint(char *name, FILE *fp);
140 /* defined in savestr.c */
141 extern char *savestr(char *str);
142 extern void freestr(char *s);
143 extern int shash(char *s);
144 /* defined in ealloc.c */
145 extern char *emalloc(unsigned int n);
146 extern char *ecalloc(unsigned int ne, unsigned int es);
147 extern char *erealloc(char *cp, unsigned int n);
148 extern void efree(char *cp);
149 /* miscellaneous */
150 extern void eputs(char *s);
151 extern void wputs(char *s);
152 extern void quit(int code);
153 /* defined by client */
154 extern double chanvalue(int n);
155
156
157 #ifdef __cplusplus
158 }
159 #endif
160 #endif /* _RAD_CALCOMP_H_ */
161
