--- ray/src/common/calcomp.h 2024/02/26 18:16:35 2.26 +++ ray/src/common/calcomp.h 2024/09/16 17:31:14 2.27 @@ -1,4 +1,4 @@ -/* RCSid $Id: calcomp.h,v 2.26 2024/02/26 18:16:35 greg Exp $ */ +/* RCSid $Id: calcomp.h,v 2.27 2024/09/16 17:31:14 greg Exp $ */ /* * calcomp.h - header file for expression parser. */ @@ -26,7 +26,7 @@ typedef struct { short nargs; /* # of required arguments */ short atyp; /* assignment type (':' or '=') */ double (*f)(char *); /* pointer to function */ -} LIBR; /* a library function */ +} ELIBR; /* a library function */ typedef struct epnode { union { @@ -39,7 +39,7 @@ typedef struct epnode { char *name; /* variable name */ int nlinks; /* number of references */ struct epnode *def; /* definition */ - LIBR *lib; /* library definition */ + ELIBR *lib; /* library definition */ struct vardef *next; /* next in hash list */ } *ln; /* link */ } v; /* value */ @@ -75,7 +75,7 @@ typedef struct vardef VARDEF; /* a variable definitio extern double (*eoper[])(EPNODE *); extern unsigned long eclock; extern unsigned int esupport; -extern EPNODE *curfunc; +extern EPNODE *ecurfunc; extern int nextc; extern int eofc; /* defined in biggerlib.c */ @@ -105,10 +105,10 @@ extern EPNODE *dfirst(void); extern EPNODE *dnext(void); extern EPNODE *dpop(char *name); extern void dpush(char *nm, EPNODE *ep); -extern void addchan(EPNODE *sp); -extern void getstatement(void); -extern EPNODE *getdefn(void); -extern EPNODE *getchan(void); +extern void eaddchan(EPNODE *sp); +extern void egetstatement(void); +extern EPNODE *egetdefn(void); +extern EPNODE *egetchan(void); /* defined in calexpr.c */ extern EPNODE *eparse(char *expr); extern double eval(char *expr); @@ -119,9 +119,9 @@ extern EPNODE *ekid(EPNODE *ep, int n); extern void initfile(FILE *fp, char *fn, int ln); extern void initstr(char *s, char *fn, int ln); extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp); -extern int scan(void); +extern int escan(void); extern char *long2ascii(long l); -extern void syntax(char *err); +extern void esyntax(char *err); extern void addekid(EPNODE *ep, EPNODE *ek); extern char *getname(void); extern int getinum(void); @@ -141,12 +141,12 @@ extern void funset(char *fname, int nargs, int assign, double (*fptr)(char *)); extern int nargum(void); extern double argument(int n); -extern VARDEF *argf(int n); -extern char *argfun(int n); +extern VARDEF *eargf(int n); +extern char *eargfun(int n); extern double efunc(EPNODE *ep); extern double eargument(EPNODE *ep); -extern LIBR *liblookup(char *fname); -extern void libupdate(char *fn); +extern ELIBR *eliblookup(char *fname); +extern void elibupdate(char *fn); /* defined in calprnt.c */ extern void eprint(EPNODE *ep, FILE *fp); extern void dprint(char *name, FILE *fp);
