--- ray/src/common/calcomp.h 2023/09/26 18:33:14 2.24 +++ ray/src/common/calcomp.h 2024/02/23 03:47:57 2.25 @@ -1,4 +1,4 @@ -/* RCSid $Id: calcomp.h,v 2.24 2023/09/26 18:33:14 greg Exp $ */ +/* RCSid $Id: calcomp.h,v 2.25 2024/02/23 03:47:57 greg Exp $ */ /* * calcomp.h - header file for expression parser. */ @@ -44,11 +44,14 @@ typedef struct epnode { } *ln; /* link */ } v; /* value */ struct epnode *sibling; /* next child this level */ - int type; /* node type */ + short type; /* node type */ + short nkids; /* child count (neg if array) */ } EPNODE; /* an expression node */ typedef struct vardef VARDEF; /* a variable definition */ +#define nekids(ep) abs((ep)->nkids) + #define RMAXWORD 127 /* maximum word/id length */ #define CNTXMARK '`' /* context mark */ @@ -92,6 +95,7 @@ extern char *popcontext(void); extern char *qualname(char *nam, int lvl); extern int incontext(char *qn); extern void chanout(void (*cs)(int n, double v)); +extern void doptimize(int activate); extern void dcleanup(int lvl); extern EPNODE *dlookup(char *name); extern VARDEF *varlookup(char *name); @@ -109,16 +113,16 @@ extern EPNODE *getchan(void); extern EPNODE *eparse(char *expr); extern double eval(char *expr); extern int epcmp(EPNODE *ep1, EPNODE *ep2); -extern void epfree(EPNODE *epar); +extern void epfree(EPNODE *epar, int frep); +extern void epoptimize(EPNODE *epar); extern EPNODE *ekid(EPNODE *ep, int n); -extern int nekids(EPNODE *ep); extern void initfile(FILE *fp, char *fn, int ln); extern void initstr(char *s, char *fn, int ln); extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp); extern int scan(void); extern char *long2ascii(long l); extern void syntax(char *err); -extern void addekid(EPNODE *ep, EPNODE *ekid); +extern void addekid(EPNODE *ep, EPNODE *ek); extern char *getname(void); extern int getinum(void); extern double getnum(void);
