--- ray/src/common/calcomp.h 1997/08/26 17:15:10 2.5 +++ ray/src/common/calcomp.h 2022/03/30 16:00:56 2.23 @@ -1,19 +1,23 @@ -/* Copyright (c) 1992 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: calcomp.h,v 2.23 2022/03/30 16:00:56 greg Exp $ */ /* * calcomp.h - header file for expression parser. - * */ - /* EPNODE types */ +#ifndef _RAD_CALCOMP_H_ +#define _RAD_CALCOMP_H_ + +#include + +#ifdef __cplusplus +extern "C" { +#endif + #define VAR 1 #define NUM 2 #define UMINUS 3 #define CHAN 4 #define FUNC 5 #define ARG 6 -#define TICK 7 +#define CLKT 7 #define SYM 8 /* also: '+', '-', '*', '/', '^', '=', ':' */ @@ -21,12 +25,10 @@ typedef struct { char *fname; /* function name */ short nargs; /* # of required arguments */ short atyp; /* assignment type (':' or '=') */ - double (*f)(); /* pointer to function */ + double (*f)(char *); /* pointer to function */ } LIBR; /* a library function */ typedef struct epnode { - int type; /* node type */ - struct epnode *sibling; /* next child this level */ union { struct epnode *kid; /* first child */ double num; /* number */ @@ -41,28 +43,112 @@ typedef struct epnode { struct vardef *next; /* next in hash list */ } *ln; /* link */ } v; /* value */ + struct epnode *sibling; /* next child this level */ + int type; /* node type */ } EPNODE; /* an expression node */ typedef struct vardef VARDEF; /* a variable definition */ -#define MAXWORD 127 /* maximum word/id length */ +#define RMAXWORD 127 /* maximum word/id length */ #define CNTXMARK '`' /* context mark */ #define isid(c) (isalnum(c) || (c) == '_' || \ (c) == '.' || (c) == CNTXMARK) -extern double eval(), varvalue(), chanvalue(), funvalue(); -extern double argument(), getnum(); -extern double (*eoper[])(); -extern int getinum(); -extern char *getname(), *qualname(), *argfun(); -extern char *setcontext(), *pushcontext(), *popcontext(); -extern EPNODE *eparse(), *ekid(), *dlookup(), *dpop(), *dfirst(), *dnext(); -extern EPNODE *getdefn(), *getchan(); -extern EPNODE *getE1(), *getE2(), *getE3(), *getE4(), *getE5(), *rconst(); -extern VARDEF *varinsert(), *varlookup(), *argf(); -extern LIBR *liblookup(); +#define evalue(ep) (*eoper[(ep)->type])(ep) + + /* flags to set in esupport */ +#define E_VARIABLE 001 +#define E_FUNCTION 002 +#define E_INCHAN 004 +#define E_OUTCHAN 010 +#define E_RCONST 020 +#define E_REDEFW 040 + +extern double (*eoper[])(EPNODE *); extern unsigned long eclock; +extern unsigned int esupport; +extern EPNODE *curfunc; extern int nextc; +extern int eofc; -#define evalue(ep) (*eoper[(ep)->type])(ep) + /* defined in biggerlib.c */ +extern void biggerlib(void); + + /* defined in caldefn.c */ +extern void fcompile(char *fname); +extern void scompile(char *str, char *fname, int ln); +extern double varvalue(char *vname); +extern double evariable(EPNODE *ep); +extern void varset(char *vname, int assign, double val); +extern void dclear(char *name); +extern void dremove(char *name); +extern int vardefined(char *name); +extern char *calcontext(char *ctx); +extern char *pushcontext(char *ctx); +extern char *popcontext(void); +extern char *qualname(char *nam, int lvl); +extern int incontext(char *qn); +extern void chanout(void (*cs)(int n, double v)); +extern void dcleanup(int lvl); +extern EPNODE *dlookup(char *name); +extern VARDEF *varlookup(char *name); +extern VARDEF *varinsert(char *name); +extern void varfree(VARDEF *ln); +extern EPNODE *dfirst(void); +extern EPNODE *dnext(void); +extern EPNODE *dpop(char *name); +extern void dpush(char *nm, EPNODE *ep); +extern void addchan(EPNODE *sp); +extern void getstatement(void); +extern EPNODE *getdefn(void); +extern EPNODE *getchan(void); + /* defined in calexpr.c */ +extern EPNODE *eparse(char *expr); +extern double eval(char *expr); +extern int epcmp(EPNODE *ep1, EPNODE *ep2); +extern void epfree(EPNODE *epar); +extern EPNODE *ekid(EPNODE *ep, int n); +extern int nekids(EPNODE *ep); +extern void initfile(FILE *fp, char *fn, int ln); +extern void initstr(char *s, char *fn, int ln); +extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp); +extern int scan(void); +extern char *long2ascii(long l); +extern void syntax(char *err); +extern void addekid(EPNODE *ep, EPNODE *ekid); +extern char *getname(void); +extern int getinum(void); +extern double getnum(void); +extern EPNODE *getE1(void); +extern EPNODE *getE2(void); +extern EPNODE *getE3(void); +extern EPNODE *getE4(void); +extern EPNODE *getE5(void); +extern EPNODE *rconst(EPNODE *epar); +extern int isconstvar(EPNODE *ep); +extern int isconstfun(EPNODE *ep); + /* defined in calfunc.c */ +extern int fundefined(char *fname); +extern double funvalue(char *fname, int n, double *a); +extern void funset(char *fname, int nargs, int assign, + double (*fptr)(char *)); +extern int nargum(void); +extern double argument(int n); +extern VARDEF *argf(int n); +extern char *argfun(int n); +extern double efunc(EPNODE *ep); +extern LIBR *liblookup(char *fname); +extern void libupdate(char *fn); + /* defined in calprnt.c */ +extern void eprint(EPNODE *ep, FILE *fp); +extern void dprint(char *name, FILE *fp); + /* defined by client */ +extern double chanvalue(int n); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_CALCOMP_H_ */ +
