root/radiance/ray/src/common/calcomp.h
Revision: 2.27
Committed: Mon Sep 16 17:31:14 2024 UTC (10 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.26: +14 -14 lines
refactor: Changed too-generic symbol names in calcomp.h
# User Rev Content
1 greg 2.27 /* RCSid $Id: calcomp.h,v 2.26 2024/02/26 18:16:35 greg Exp $ */
2 greg 1.1 /*
3     * calcomp.h - header file for expression parser.
4 greg 2.6 */
5 schorsch 2.9 #ifndef _RAD_CALCOMP_H_
6     #define _RAD_CALCOMP_H_
7 schorsch 2.14
8     #include <stdio.h>
9
10 schorsch 2.9 #ifdef __cplusplus
11     extern "C" {
12     #endif
13 greg 2.7
14 greg 2.2 #define VAR 1
15     #define NUM 2
16     #define UMINUS 3
17     #define CHAN 4
18     #define FUNC 5
19     #define ARG 6
20 greg 2.22 #define CLKT 7
21 greg 2.2 #define SYM 8
22 greg 1.4 /* also: '+', '-', '*', '/', '^', '=', ':' */
23 greg 1.1
24     typedef struct {
25     char *fname; /* function name */
26 greg 1.5 short nargs; /* # of required arguments */
27     short atyp; /* assignment type (':' or '=') */
28 greg 2.16 double (*f)(char *); /* pointer to function */
29 greg 2.27 } ELIBR; /* a library function */
30 greg 1.1
31     typedef struct epnode {
32     union {
33     struct epnode *kid; /* first child */
34 greg 2.2 double num; /* number */
35 greg 1.1 char *name; /* symbol name */
36     int chan; /* channel number */
37 greg 2.4 unsigned long tick; /* timestamp */
38 greg 1.1 struct vardef {
39     char *name; /* variable name */
40 greg 2.2 int nlinks; /* number of references */
41 greg 1.1 struct epnode *def; /* definition */
42 greg 2.27 ELIBR *lib; /* library definition */
43 greg 1.1 struct vardef *next; /* next in hash list */
44     } *ln; /* link */
45     } v; /* value */
46 greg 2.21 struct epnode *sibling; /* next child this level */
47 greg 2.25 short type; /* node type */
48     short nkids; /* child count (neg if array) */
49 greg 1.1 } EPNODE; /* an expression node */
50
51     typedef struct vardef VARDEF; /* a variable definition */
52
53 greg 2.25 #define nekids(ep) abs((ep)->nkids)
54
55 schorsch 2.13 #define RMAXWORD 127 /* maximum word/id length */
56 greg 2.2 #define CNTXMARK '`' /* context mark */
57 greg 1.6
58 greg 2.2 #define isid(c) (isalnum(c) || (c) == '_' || \
59 greg 1.6 (c) == '.' || (c) == CNTXMARK)
60
61 greg 2.6 #define evalue(ep) (*eoper[(ep)->type])(ep)
62
63 greg 2.24 #define dfn_name(ep) ((ep)->v.kid->type == SYM ? \
64     (ep)->v.kid->v.name : \
65     (ep)->v.kid->v.kid->v.name)
66
67 greg 2.6 /* flags to set in esupport */
68     #define E_VARIABLE 001
69     #define E_FUNCTION 002
70     #define E_INCHAN 004
71     #define E_OUTCHAN 010
72     #define E_RCONST 020
73     #define E_REDEFW 040
74
75 greg 2.15 extern double (*eoper[])(EPNODE *);
76 greg 2.4 extern unsigned long eclock;
77 greg 2.6 extern unsigned int esupport;
78 greg 2.27 extern EPNODE *ecurfunc;
79 greg 1.1 extern int nextc;
80 greg 2.19 extern int eofc;
81 schorsch 2.14 /* defined in biggerlib.c */
82     extern void biggerlib(void);
83 greg 2.6 /* defined in caldefn.c */
84     extern void fcompile(char *fname);
85     extern void scompile(char *str, char *fname, int ln);
86     extern double varvalue(char *vname);
87     extern double evariable(EPNODE *ep);
88 greg 2.20 extern void varset(char *vname, int assign, double val);
89 greg 2.6 extern void dclear(char *name);
90     extern void dremove(char *name);
91     extern int vardefined(char *name);
92 greg 2.23 extern char *calcontext(char *ctx);
93 greg 2.6 extern char *pushcontext(char *ctx);
94     extern char *popcontext(void);
95     extern char *qualname(char *nam, int lvl);
96     extern int incontext(char *qn);
97 greg 2.8 extern void chanout(void (*cs)(int n, double v));
98 greg 2.25 extern void doptimize(int activate);
99 greg 2.6 extern void dcleanup(int lvl);
100     extern EPNODE *dlookup(char *name);
101     extern VARDEF *varlookup(char *name);
102     extern VARDEF *varinsert(char *name);
103     extern void varfree(VARDEF *ln);
104     extern EPNODE *dfirst(void);
105     extern EPNODE *dnext(void);
106     extern EPNODE *dpop(char *name);
107     extern void dpush(char *nm, EPNODE *ep);
108 greg 2.27 extern void eaddchan(EPNODE *sp);
109     extern void egetstatement(void);
110     extern EPNODE *egetdefn(void);
111     extern EPNODE *egetchan(void);
112 greg 2.6 /* defined in calexpr.c */
113     extern EPNODE *eparse(char *expr);
114     extern double eval(char *expr);
115     extern int epcmp(EPNODE *ep1, EPNODE *ep2);
116 greg 2.25 extern void epfree(EPNODE *epar, int frep);
117     extern void epoptimize(EPNODE *epar);
118 greg 2.6 extern EPNODE *ekid(EPNODE *ep, int n);
119     extern void initfile(FILE *fp, char *fn, int ln);
120     extern void initstr(char *s, char *fn, int ln);
121     extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp);
122 greg 2.27 extern int escan(void);
123 greg 2.6 extern char *long2ascii(long l);
124 greg 2.27 extern void esyntax(char *err);
125 greg 2.25 extern void addekid(EPNODE *ep, EPNODE *ek);
126 greg 2.6 extern char *getname(void);
127     extern int getinum(void);
128     extern double getnum(void);
129     extern EPNODE *getE1(void);
130     extern EPNODE *getE2(void);
131     extern EPNODE *getE3(void);
132     extern EPNODE *getE4(void);
133     extern EPNODE *getE5(void);
134     extern EPNODE *rconst(EPNODE *epar);
135     extern int isconstvar(EPNODE *ep);
136     extern int isconstfun(EPNODE *ep);
137     /* defined in calfunc.c */
138     extern int fundefined(char *fname);
139     extern double funvalue(char *fname, int n, double *a);
140 greg 2.16 extern void funset(char *fname, int nargs, int assign,
141     double (*fptr)(char *));
142 greg 2.6 extern int nargum(void);
143     extern double argument(int n);
144 greg 2.27 extern VARDEF *eargf(int n);
145     extern char *eargfun(int n);
146 greg 2.6 extern double efunc(EPNODE *ep);
147 greg 2.26 extern double eargument(EPNODE *ep);
148 greg 2.27 extern ELIBR *eliblookup(char *fname);
149     extern void elibupdate(char *fn);
150 greg 2.6 /* defined in calprnt.c */
151     extern void eprint(EPNODE *ep, FILE *fp);
152     extern void dprint(char *name, FILE *fp);
153     /* defined by client */
154     extern double chanvalue(int n);
155
156 schorsch 2.9 #ifdef __cplusplus
157     }
158 greg 2.6 #endif
159 schorsch 2.9 #endif /* _RAD_CALCOMP_H_ */
160
