root/radiance/ray/src/common/calcomp.h
Revision: 2.10
Committed: Sat Jun 7 12:50:20 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.9: +3 -1 lines
1 /* RCSid $Id: calcomp.h,v 2.9 2003/06/06 16:38:47 schorsch Exp $ */
2 /*
3 * calcomp.h - header file for expression parser.
4 */
5 #ifndef _RAD_CALCOMP_H_
6 #define _RAD_CALCOMP_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15
16 #define VAR 1
17 #define NUM 2
18 #define UMINUS 3
19 #define CHAN 4
20 #define FUNC 5
21 #define ARG 6
22 #define TICK 7
23 #define SYM 8
24 /* also: '+', '-', '*', '/', '^', '=', ':' */
25
26 typedef struct {
27 char *fname; /* function name */
28 short nargs; /* # of required arguments */
29 short atyp; /* assignment type (':' or '=') */
30 double (*f)(); /* pointer to function */
31 } LIBR; /* a library function */
32
33 typedef struct epnode {
34 int type; /* node type */
35 struct epnode *sibling; /* next child this level */
36 union {
37 struct epnode *kid; /* first child */
38 double num; /* number */
39 char *name; /* symbol name */
40 int chan; /* channel number */
41 unsigned long tick; /* timestamp */
42 struct vardef {
43 char *name; /* variable name */
44 int nlinks; /* number of references */
45 struct epnode *def; /* definition */
46 LIBR *lib; /* library definition */
47 struct vardef *next; /* next in hash list */
48 } *ln; /* link */
49 } v; /* value */
50 } EPNODE; /* an expression node */
51
52 typedef struct vardef VARDEF; /* a variable definition */
53
54 #define MAXWORD 127 /* maximum word/id length */
55 #define CNTXMARK '`' /* context mark */
56
57 #define isid(c) (isalnum(c) || (c) == '_' || \
58 (c) == '.' || (c) == CNTXMARK)
59
60 #define evalue(ep) (*eoper[(ep)->type])(ep)
61
62 /* flags to set in esupport */
63 #define E_VARIABLE 001
64 #define E_FUNCTION 002
65 #define E_INCHAN 004
66 #define E_OUTCHAN 010
67 #define E_RCONST 020
68 #define E_REDEFW 040
69
70 extern double (*eoper[])();
71 extern unsigned long eclock;
72 extern unsigned int esupport;
73 extern EPNODE *curfunc;
74 extern int nextc;
75
76 /* defined in caldefn.c */
77 extern void fcompile(char *fname);
78 extern void scompile(char *str, char *fname, int ln);
79 extern double varvalue(char *vname);
80 extern double evariable(EPNODE *ep);
81 extern void varset(char *fname, int assign, double val);
82 extern void dclear(char *name);
83 extern void dremove(char *name);
84 extern int vardefined(char *name);
85 extern char *setcontext(char *ctx);
86 extern char *pushcontext(char *ctx);
87 extern char *popcontext(void);
88 extern char *qualname(char *nam, int lvl);
89 extern int incontext(char *qn);
90 extern void chanout(void (*cs)(int n, double v));
91 extern void dcleanup(int lvl);
92 extern EPNODE *dlookup(char *name);
93 extern VARDEF *varlookup(char *name);
94 extern VARDEF *varinsert(char *name);
95 extern void varfree(VARDEF *ln);
96 extern EPNODE *dfirst(void);
97 extern EPNODE *dnext(void);
98 extern EPNODE *dpop(char *name);
99 extern void dpush(char *nm, EPNODE *ep);
100 extern void addchan(EPNODE *sp);
101 extern void getstatement();
102 extern EPNODE *getdefn();
103 extern EPNODE *getchan();
104 /* defined in calexpr.c */
105 extern EPNODE *eparse(char *expr);
106 extern double eval(char *expr);
107 extern int epcmp(EPNODE *ep1, EPNODE *ep2);
108 extern void epfree(EPNODE *epar);
109 extern EPNODE *ekid(EPNODE *ep, int n);
110 extern int nekids(EPNODE *ep);
111 extern void initfile(FILE *fp, char *fn, int ln);
112 extern void initstr(char *s, char *fn, int ln);
113 extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp);
114 extern int scan(void);
115 extern char *long2ascii(long l);
116 extern void syntax(char *err);
117 extern void addekid(EPNODE *ep, EPNODE *ekid);
118 extern char *getname(void);
119 extern int getinum(void);
120 extern double getnum(void);
121 extern EPNODE *getE1(void);
122 extern EPNODE *getE2(void);
123 extern EPNODE *getE3(void);
124 extern EPNODE *getE4(void);
125 extern EPNODE *getE5(void);
126 extern EPNODE *rconst(EPNODE *epar);
127 extern int isconstvar(EPNODE *ep);
128 extern int isconstfun(EPNODE *ep);
129 /* defined in calfunc.c */
130 extern int fundefined(char *fname);
131 extern double funvalue(char *fname, int n, double *a);
132 extern void funset(char *fname, int nargs, int assign, double (*fptr)());
133 extern int nargum(void);
134 extern double argument(int n);
135 extern VARDEF *argf(int n);
136 extern char *argfun(int n);
137 extern double efunc(EPNODE *ep);
138 extern LIBR *liblookup(char *fname);
139 extern void libupdate(char *fn);
140 /* defined in calprnt.c */
141 extern void eprint(EPNODE *ep, FILE *fp);
142 extern void dprint(char *name, FILE *fp);
143 /* defined in savestr.c */
144 extern char *savestr(char *str);
145 extern void freestr(char *s);
146 extern int shash(char *s);
147 /* defined in ealloc.c */
148 extern char *emalloc(unsigned int n);
149 extern char *ecalloc(unsigned int ne, unsigned int es);
150 extern char *erealloc(char *cp, unsigned int n);
151 extern void efree(char *cp);
152 /* miscellaneous */
153 extern void eputs(char *s);
154 extern void wputs(char *s);
155 extern void quit(int code);
156 /* defined by client */
157 extern double chanvalue(int n);
158
159
160 #ifdef __cplusplus
161 }
162 #endif
163 #endif /* _RAD_CALCOMP_H_ */
164
