--- ray/src/common/calcomp.h 2003/08/04 22:37:53 2.16 +++ ray/src/common/calcomp.h 2008/05/01 16:42:05 2.22 @@ -1,4 +1,4 @@ -/* RCSid $Id: calcomp.h,v 2.16 2003/08/04 22:37:53 greg Exp $ */ +/* RCSid $Id: calcomp.h,v 2.22 2008/05/01 16:42:05 greg Exp $ */ /* * calcomp.h - header file for expression parser. */ @@ -17,7 +17,7 @@ extern "C" { #define CHAN 4 #define FUNC 5 #define ARG 6 -#define TICK 7 +#define CLKT 7 #define SYM 8 /* also: '+', '-', '*', '/', '^', '=', ':' */ @@ -29,8 +29,6 @@ typedef struct { } LIBR; /* a library function */ typedef struct epnode { - int type; /* node type */ - struct epnode *sibling; /* next child this level */ union { struct epnode *kid; /* first child */ double num; /* number */ @@ -45,6 +43,8 @@ typedef struct epnode { struct vardef *next; /* next in hash list */ } *ln; /* link */ } v; /* value */ + struct epnode *sibling; /* next child this level */ + int type; /* node type */ } EPNODE; /* an expression node */ typedef struct vardef VARDEF; /* a variable definition */ @@ -70,6 +70,7 @@ extern unsigned long eclock; extern unsigned int esupport; extern EPNODE *curfunc; extern int nextc; +extern int eofc; /* defined in biggerlib.c */ extern void biggerlib(void); @@ -79,7 +80,7 @@ extern void fcompile(char *fname); extern void scompile(char *str, char *fname, int ln); extern double varvalue(char *vname); extern double evariable(EPNODE *ep); -extern void varset(char *fname, int assign, double val); +extern void varset(char *vname, int assign, double val); extern void dclear(char *name); extern void dremove(char *name); extern int vardefined(char *name); @@ -142,15 +143,6 @@ extern void libupdate(char *fn); /* defined in calprnt.c */ extern void eprint(EPNODE *ep, FILE *fp); extern void dprint(char *name, FILE *fp); - /* defined in savestr.c */ -extern char *savestr(char *str); -extern void freestr(char *s); -extern int shash(char *s); - /* defined in ealloc.c */ -extern char *emalloc(unsigned int n); -extern char *ecalloc(unsigned int ne, unsigned int es); -extern char *erealloc(char *cp, unsigned int n); -extern void efree(char *cp); /* defined by client */ extern double chanvalue(int n);
