--- ray/src/common/calcomp.h 2003/07/03 22:41:44 2.13 +++ ray/src/common/calcomp.h 2003/07/17 09:21:29 2.14 @@ -1,9 +1,12 @@ -/* RCSid $Id: calcomp.h,v 2.13 2003/07/03 22:41:44 schorsch Exp $ */ +/* RCSid $Id: calcomp.h,v 2.14 2003/07/17 09:21:29 schorsch Exp $ */ /* * calcomp.h - header file for expression parser. */ #ifndef _RAD_CALCOMP_H_ #define _RAD_CALCOMP_H_ + +#include + #ifdef __cplusplus extern "C" { #endif @@ -68,6 +71,9 @@ extern unsigned int esupport; extern EPNODE *curfunc; extern int nextc; + /* defined in biggerlib.c */ +extern void biggerlib(void); + /* defined in caldefn.c */ extern void fcompile(char *fname); extern void scompile(char *str, char *fname, int ln); @@ -93,9 +99,9 @@ extern EPNODE *dnext(void); extern EPNODE *dpop(char *name); extern void dpush(char *nm, EPNODE *ep); extern void addchan(EPNODE *sp); -extern void getstatement(); -extern EPNODE *getdefn(); -extern EPNODE *getchan(); +extern void getstatement(void); +extern EPNODE *getdefn(void); +extern EPNODE *getchan(void); /* defined in calexpr.c */ extern EPNODE *eparse(char *expr); extern double eval(char *expr); @@ -144,10 +150,6 @@ extern char *emalloc(unsigned int n); extern char *ecalloc(unsigned int ne, unsigned int es); extern char *erealloc(char *cp, unsigned int n); extern void efree(char *cp); - /* miscellaneous */ -extern void eputs(char *s); -extern void wputs(char *s); -extern void quit(int code); /* defined by client */ extern double chanvalue(int n);
