--- ray/src/common/calcomp.h 1991/11/12 16:55:05 2.1 +++ ray/src/common/calcomp.h 2003/06/30 19:04:29 2.12 @@ -1,20 +1,21 @@ -/* Copyright (c) 1986 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: calcomp.h,v 2.12 2003/06/30 19:04:29 greg Exp $ */ /* * calcomp.h - header file for expression parser. - * */ - /* EPNODE types */ -#define VAR 1 -#define NUM 2 -#define UMINUS 3 -#define CHAN 4 -#define FUNC 5 -#define ARG 6 -#define TICK 7 -#define SYM 8 +#ifndef _RAD_CALCOMP_H_ +#define _RAD_CALCOMP_H_ +#ifdef __cplusplus +extern "C" { +#endif + +#define VAR 1 +#define NUM 2 +#define UMINUS 3 +#define CHAN 4 +#define FUNC 5 +#define ARG 6 +#define TICK 7 +#define SYM 8 /* also: '+', '-', '*', '/', '^', '=', ':' */ typedef struct { @@ -25,17 +26,17 @@ typedef struct { } LIBR; /* a library function */ typedef struct epnode { - int type; /* node type */ + int type; /* node type */ struct epnode *sibling; /* next child this level */ union { struct epnode *kid; /* first child */ - double num; /* number */ + double num; /* number */ char *name; /* symbol name */ int chan; /* channel number */ - long tick; /* timestamp */ + unsigned long tick; /* timestamp */ struct vardef { char *name; /* variable name */ - int nlinks; /* number of references */ + int nlinks; /* number of references */ struct epnode *def; /* definition */ LIBR *lib; /* library definition */ struct vardef *next; /* next in hash list */ @@ -45,24 +46,114 @@ typedef struct epnode { typedef struct vardef VARDEF; /* a variable definition */ -#define MAXWORD 63 /* maximum word/id length */ -#define CNTXMARK '`' /* context mark */ +#define MAXWORD 127 /* maximum word/id length */ +#define CNTXMARK '`' /* context mark */ -#define isid(c) (isalnum(c) || (c) == '_' || \ +#define isid(c) (isalnum(c) || (c) == '_' || \ (c) == '.' || (c) == CNTXMARK) -extern double eval(), varvalue(), chanvalue(), funvalue(); -extern double argument(), getnum(); +#define evalue(ep) (*eoper[(ep)->type])(ep) + + /* flags to set in esupport */ +#define E_VARIABLE 001 +#define E_FUNCTION 002 +#define E_INCHAN 004 +#define E_OUTCHAN 010 +#define E_RCONST 020 +#define E_REDEFW 040 + extern double (*eoper[])(); -extern int getinum(); -extern char *getname(), *qualname(), *setcontext(), *argfun(); -extern EPNODE *eparse(), *ekid(), *dlookup(), *dpop(), *dfirst(), *dnext(); -extern EPNODE *getdefn(), *getchan(); -extern EPNODE *getE1(), *getE2(), *getE3(), *getE4(), *getE5(), *rconst(); -extern VARDEF *varinsert(), *varlookup(), *argf(); -extern LIBR *liblookup(); -extern long eclock; +extern unsigned long eclock; +extern unsigned int esupport; +extern EPNODE *curfunc; extern int nextc; -extern int errno; -#define evalue(ep) (*eoper[(ep)->type])(ep) + /* defined in caldefn.c */ +extern void fcompile(char *fname); +extern void scompile(char *str, char *fname, int ln); +extern double varvalue(char *vname); +extern double evariable(EPNODE *ep); +extern void varset(char *fname, int assign, double val); +extern void dclear(char *name); +extern void dremove(char *name); +extern int vardefined(char *name); +extern char *setcontext(char *ctx); +extern char *pushcontext(char *ctx); +extern char *popcontext(void); +extern char *qualname(char *nam, int lvl); +extern int incontext(char *qn); +extern void chanout(void (*cs)(int n, double v)); +extern void dcleanup(int lvl); +extern EPNODE *dlookup(char *name); +extern VARDEF *varlookup(char *name); +extern VARDEF *varinsert(char *name); +extern void varfree(VARDEF *ln); +extern EPNODE *dfirst(void); +extern EPNODE *dnext(void); +extern EPNODE *dpop(char *name); +extern void dpush(char *nm, EPNODE *ep); +extern void addchan(EPNODE *sp); +extern void getstatement(); +extern EPNODE *getdefn(); +extern EPNODE *getchan(); + /* defined in calexpr.c */ +extern EPNODE *eparse(char *expr); +extern double eval(char *expr); +extern int epcmp(EPNODE *ep1, EPNODE *ep2); +extern void epfree(EPNODE *epar); +extern EPNODE *ekid(EPNODE *ep, int n); +extern int nekids(EPNODE *ep); +extern void initfile(FILE *fp, char *fn, int ln); +extern void initstr(char *s, char *fn, int ln); +extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp); +extern int scan(void); +extern char *long2ascii(long l); +extern void syntax(char *err); +extern void addekid(EPNODE *ep, EPNODE *ekid); +extern char *getname(void); +extern int getinum(void); +extern double getnum(void); +extern EPNODE *getE1(void); +extern EPNODE *getE2(void); +extern EPNODE *getE3(void); +extern EPNODE *getE4(void); +extern EPNODE *getE5(void); +extern EPNODE *rconst(EPNODE *epar); +extern int isconstvar(EPNODE *ep); +extern int isconstfun(EPNODE *ep); + /* defined in calfunc.c */ +extern int fundefined(char *fname); +extern double funvalue(char *fname, int n, double *a); +extern void funset(char *fname, int nargs, int assign, double (*fptr)()); +extern int nargum(void); +extern double argument(int n); +extern VARDEF *argf(int n); +extern char *argfun(int n); +extern double efunc(EPNODE *ep); +extern LIBR *liblookup(char *fname); +extern void libupdate(char *fn); + /* defined in calprnt.c */ +extern void eprint(EPNODE *ep, FILE *fp); +extern void dprint(char *name, FILE *fp); + /* defined in savestr.c */ +extern char *savestr(char *str); +extern void freestr(char *s); +extern int shash(char *s); + /* defined in ealloc.c */ +extern char *emalloc(unsigned int n); +extern char *ecalloc(unsigned int ne, unsigned int es); +extern char *erealloc(char *cp, unsigned int n); +extern void efree(char *cp); + /* miscellaneous */ +extern void eputs(char *s); +extern void wputs(char *s); +extern void quit(int code); + /* defined by client */ +extern double chanvalue(int n); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_CALCOMP_H_ */ +
