--- ray/src/common/calcomp.h 2003/02/25 02:47:21 2.7 +++ ray/src/common/calcomp.h 2003/06/27 06:53:21 2.11 @@ -1,9 +1,14 @@ -/* RCSid $Id: calcomp.h,v 2.7 2003/02/25 02:47:21 greg Exp $ */ +/* RCSid $Id: calcomp.h,v 2.11 2003/06/27 06:53:21 greg Exp $ */ /* * calcomp.h - header file for expression parser. */ +#ifndef _RAD_CALCOMP_H_ +#define _RAD_CALCOMP_H_ +#ifdef __cplusplus +extern "C" { +#endif -#include "copyright.h" +#include #define VAR 1 #define NUM 2 @@ -65,85 +70,6 @@ extern unsigned int esupport; extern EPNODE *curfunc; extern int nextc; -#ifdef NOPROTO - -extern void fcompile(); -extern void scompile(); -extern double varvalue(); -extern double evariable(); -extern void varset(); -extern void dclear(); -extern void dremove(); -extern int vardefined(); -extern char *setcontext(); -extern char *pushcontext(); -extern char *popcontext(); -extern char *qualname(); -extern int incontext(); -extern void chanout(); -extern void dcleanup(); -extern EPNODE *dlookup(); -extern VARDEF *varlookup(); -extern VARDEF *varinsert(); -extern void varfree(); -extern EPNODE *dfirst(); -extern EPNODE *dnext(); -extern EPNODE *dpop(); -extern void dpush(); -extern void addchan(); -extern void getstatement(); -extern EPNODE *getdefn(); -extern EPNODE *getchan(); -extern EPNODE *eparse(); -extern double eval(); -extern int epcmp(); -extern void epfree(); -extern EPNODE *ekid(); -extern int nekids(); -extern void initfile(); -extern void initstr(); -extern void getscanpos(); -extern int scan(); -extern char *long2ascii(); -extern void syntax(); -extern void addekid(); -extern char *getname(); -extern int getinum(); -extern double getnum(); -extern EPNODE *getE1(); -extern EPNODE *getE2(); -extern EPNODE *getE3(); -extern EPNODE *getE4(); -extern EPNODE *getE5(); -extern EPNODE *rconst(); -extern int isconstvar(); -extern int isconstfun(); -extern int fundefined(); -extern double funvalue(); -extern void funset(); -extern int nargum(); -extern double argument(); -extern VARDEF *argf(); -extern char *argfun(); -extern double efunc(); -extern LIBR *liblookup(); -extern void libupdate(); -extern void eprint(); -extern void dprint(); -extern char *savestr(); -extern void freestr(); -extern int shash(); -extern char *emalloc(); -extern char *ecalloc(); -extern char *erealloc(); -extern void efree(); -extern void eputs(); -extern void wputs(); -extern void quit(); - -extern double chanvalue(); - -#else /* defined in caldefn.c */ extern void fcompile(char *fname); extern void scompile(char *str, char *fname, int ln); @@ -158,7 +84,7 @@ extern char *pushcontext(char *ctx); extern char *popcontext(void); extern char *qualname(char *nam, int lvl); extern int incontext(char *qn); -extern void chanout(int (*cs)()); +extern void chanout(void (*cs)(int n, double v)); extern void dcleanup(int lvl); extern EPNODE *dlookup(char *name); extern VARDEF *varlookup(char *name); @@ -227,4 +153,9 @@ extern void quit(int code); /* defined by client */ extern double chanvalue(int n); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_CALCOMP_H_ */ +
