--- ray/src/common/calcomp.h 1991/04/23 12:43:13 1.4 +++ ray/src/common/calcomp.h 1997/08/26 17:15:10 2.5 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ /* SCCSid "$SunId$ LBL" */ @@ -7,34 +7,35 @@ * */ /* EPNODE types */ -#define VAR 1 -#define NUM 2 -#define UMINUS 3 -#define CHAN 4 -#define FUNC 5 -#define ARG 6 -#define TICK 7 -#define SYM 8 +#define VAR 1 +#define NUM 2 +#define UMINUS 3 +#define CHAN 4 +#define FUNC 5 +#define ARG 6 +#define TICK 7 +#define SYM 8 /* also: '+', '-', '*', '/', '^', '=', ':' */ typedef struct { char *fname; /* function name */ - int nargs; /* # of required arguments */ + short nargs; /* # of required arguments */ + short atyp; /* assignment type (':' or '=') */ double (*f)(); /* pointer to function */ } LIBR; /* a library function */ typedef struct epnode { - int type; /* node type */ + int type; /* node type */ struct epnode *sibling; /* next child this level */ union { struct epnode *kid; /* first child */ - double num; /* number */ + double num; /* number */ char *name; /* symbol name */ int chan; /* channel number */ - long tick; /* timestamp */ + unsigned long tick; /* timestamp */ struct vardef { char *name; /* variable name */ - int nlinks; /* number of references */ + int nlinks; /* number of references */ struct epnode *def; /* definition */ LIBR *lib; /* library definition */ struct vardef *next; /* next in hash list */ @@ -44,18 +45,24 @@ typedef struct epnode { typedef struct vardef VARDEF; /* a variable definition */ +#define MAXWORD 127 /* maximum word/id length */ +#define CNTXMARK '`' /* context mark */ + +#define isid(c) (isalnum(c) || (c) == '_' || \ + (c) == '.' || (c) == CNTXMARK) + extern double eval(), varvalue(), chanvalue(), funvalue(); extern double argument(), getnum(); extern double (*eoper[])(); extern int getinum(); -extern char *getname(), *argfun(); +extern char *getname(), *qualname(), *argfun(); +extern char *setcontext(), *pushcontext(), *popcontext(); extern EPNODE *eparse(), *ekid(), *dlookup(), *dpop(), *dfirst(), *dnext(); extern EPNODE *getdefn(), *getchan(); extern EPNODE *getE1(), *getE2(), *getE3(), *getE4(), *getE5(), *rconst(); extern VARDEF *varinsert(), *varlookup(), *argf(); extern LIBR *liblookup(); -extern long eclock; +extern unsigned long eclock; extern int nextc; -extern int errno; -#define evalue(ep) (*eoper[(ep)->type])(ep) +#define evalue(ep) (*eoper[(ep)->type])(ep)
