root/radiance/ray/src/common/calcomp.h
Revision: 2.16
Committed: Mon Aug 4 22:37:53 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.15: +4 -3 lines
1 /* RCSid $Id: calcomp.h,v 2.15 2003/08/04 19:20:26 greg Exp $ */
2 /*
3 * calcomp.h - header file for expression parser.
4 */
5 #ifndef _RAD_CALCOMP_H_
6 #define _RAD_CALCOMP_H_
7
8 #include <stdio.h>
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 #define VAR 1
15 #define NUM 2
16 #define UMINUS 3
17 #define CHAN 4
18 #define FUNC 5
19 #define ARG 6
20 #define TICK 7
21 #define SYM 8
22 /* also: '+', '-', '*', '/', '^', '=', ':' */
23
24 typedef struct {
25 char *fname; /* function name */
26 short nargs; /* # of required arguments */
27 short atyp; /* assignment type (':' or '=') */
28 double (*f)(char *); /* pointer to function */
29 } LIBR; /* a library function */
30
31 typedef struct epnode {
32 int type; /* node type */
33 struct epnode *sibling; /* next child this level */
34 union {
35 struct epnode *kid; /* first child */
36 double num; /* number */
37 char *name; /* symbol name */
38 int chan; /* channel number */
39 unsigned long tick; /* timestamp */
40 struct vardef {
41 char *name; /* variable name */
42 int nlinks; /* number of references */
43 struct epnode *def; /* definition */
44 LIBR *lib; /* library definition */
45 struct vardef *next; /* next in hash list */
46 } *ln; /* link */
47 } v; /* value */
48 } EPNODE; /* an expression node */
49
50 typedef struct vardef VARDEF; /* a variable definition */
51
52 #define RMAXWORD 127 /* maximum word/id length */
53 #define CNTXMARK '`' /* context mark */
54
55 #define isid(c) (isalnum(c) || (c) == '_' || \
56 (c) == '.' || (c) == CNTXMARK)
57
58 #define evalue(ep) (*eoper[(ep)->type])(ep)
59
60 /* flags to set in esupport */
61 #define E_VARIABLE 001
62 #define E_FUNCTION 002
63 #define E_INCHAN 004
64 #define E_OUTCHAN 010
65 #define E_RCONST 020
66 #define E_REDEFW 040
67
68 extern double (*eoper[])(EPNODE *);
69 extern unsigned long eclock;
70 extern unsigned int esupport;
71 extern EPNODE *curfunc;
72 extern int nextc;
73
74 /* defined in biggerlib.c */
75 extern void biggerlib(void);
76
77 /* defined in caldefn.c */
78 extern void fcompile(char *fname);
79 extern void scompile(char *str, char *fname, int ln);
80 extern double varvalue(char *vname);
81 extern double evariable(EPNODE *ep);
82 extern void varset(char *fname, int assign, double val);
83 extern void dclear(char *name);
84 extern void dremove(char *name);
85 extern int vardefined(char *name);
86 extern char *setcontext(char *ctx);
87 extern char *pushcontext(char *ctx);
88 extern char *popcontext(void);
89 extern char *qualname(char *nam, int lvl);
90 extern int incontext(char *qn);
91 extern void chanout(void (*cs)(int n, double v));
92 extern void dcleanup(int lvl);
93 extern EPNODE *dlookup(char *name);
94 extern VARDEF *varlookup(char *name);
95 extern VARDEF *varinsert(char *name);
96 extern void varfree(VARDEF *ln);
97 extern EPNODE *dfirst(void);
98 extern EPNODE *dnext(void);
99 extern EPNODE *dpop(char *name);
100 extern void dpush(char *nm, EPNODE *ep);
101 extern void addchan(EPNODE *sp);
102 extern void getstatement(void);
103 extern EPNODE *getdefn(void);
104 extern EPNODE *getchan(void);
105 /* defined in calexpr.c */
106 extern EPNODE *eparse(char *expr);
107 extern double eval(char *expr);
108 extern int epcmp(EPNODE *ep1, EPNODE *ep2);
109 extern void epfree(EPNODE *epar);
110 extern EPNODE *ekid(EPNODE *ep, int n);
111 extern int nekids(EPNODE *ep);
112 extern void initfile(FILE *fp, char *fn, int ln);
113 extern void initstr(char *s, char *fn, int ln);
114 extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp);
115 extern int scan(void);
116 extern char *long2ascii(long l);
117 extern void syntax(char *err);
118 extern void addekid(EPNODE *ep, EPNODE *ekid);
119 extern char *getname(void);
120 extern int getinum(void);
121 extern double getnum(void);
122 extern EPNODE *getE1(void);
123 extern EPNODE *getE2(void);
124 extern EPNODE *getE3(void);
125 extern EPNODE *getE4(void);
126 extern EPNODE *getE5(void);
127 extern EPNODE *rconst(EPNODE *epar);
128 extern int isconstvar(EPNODE *ep);
129 extern int isconstfun(EPNODE *ep);
130 /* defined in calfunc.c */
131 extern int fundefined(char *fname);
132 extern double funvalue(char *fname, int n, double *a);
133 extern void funset(char *fname, int nargs, int assign,
134 double (*fptr)(char *));
135 extern int nargum(void);
136 extern double argument(int n);
137 extern VARDEF *argf(int n);
138 extern char *argfun(int n);
139 extern double efunc(EPNODE *ep);
140 extern LIBR *liblookup(char *fname);
141 extern void libupdate(char *fn);
142 /* defined in calprnt.c */
143 extern void eprint(EPNODE *ep, FILE *fp);
144 extern void dprint(char *name, FILE *fp);
145 /* defined in savestr.c */
146 extern char *savestr(char *str);
147 extern void freestr(char *s);
148 extern int shash(char *s);
149 /* defined in ealloc.c */
150 extern char *emalloc(unsigned int n);
151 extern char *ecalloc(unsigned int ne, unsigned int es);
152 extern char *erealloc(char *cp, unsigned int n);
153 extern void efree(char *cp);
154 /* defined by client */
155 extern double chanvalue(int n);
156
157
158 #ifdef __cplusplus
159 }
160 #endif
161 #endif /* _RAD_CALCOMP_H_ */
162
