root/radiance/ray/src/common/calcomp.h
Revision: 2.13
Committed: Thu Jul 3 22:41:44 2003 UTC (22 years ago) by schorsch
1 /* RCSid $Id: calcomp.h,v 2.12 2003/06/30 19:04:29 greg Exp $ */
2 /*
3 * calcomp.h - header file for expression parser.
4 */
5 #ifndef _RAD_CALCOMP_H_
6 #define _RAD_CALCOMP_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #define VAR 1
12 #define NUM 2
13 #define UMINUS 3
14 #define CHAN 4
15 #define FUNC 5
16 #define ARG 6
17 #define TICK 7
18 #define SYM 8
19 /* also: '+', '-', '*', '/', '^', '=', ':' */
20
21 typedef struct {
22 char *fname; /* function name */
23 short nargs; /* # of required arguments */
24 short atyp; /* assignment type (':' or '=') */
25 double (*f)(); /* pointer to function */
26 } LIBR; /* a library function */
27
28 typedef struct epnode {
29 int type; /* node type */
30 struct epnode *sibling; /* next child this level */
31 union {
32 struct epnode *kid; /* first child */
33 double num; /* number */
34 char *name; /* symbol name */
35 int chan; /* channel number */
36 unsigned long tick; /* timestamp */
37 struct vardef {
38 char *name; /* variable name */
39 int nlinks; /* number of references */
40 struct epnode *def; /* definition */
41 LIBR *lib; /* library definition */
42 struct vardef *next; /* next in hash list */
43 } *ln; /* link */
44 } v; /* value */
45 } EPNODE; /* an expression node */
46
47 typedef struct vardef VARDEF; /* a variable definition */
48
49 #define RMAXWORD 127 /* maximum word/id length */
50 #define CNTXMARK '`' /* context mark */
51
52 #define isid(c) (isalnum(c) || (c) == '_' || \
53 (c) == '.' || (c) == CNTXMARK)
54
55 #define evalue(ep) (*eoper[(ep)->type])(ep)
56
57 /* flags to set in esupport */
58 #define E_VARIABLE 001
59 #define E_FUNCTION 002
60 #define E_INCHAN 004
61 #define E_OUTCHAN 010
62 #define E_RCONST 020
63 #define E_REDEFW 040
64
65 extern double (*eoper[])();
66 extern unsigned long eclock;
67 extern unsigned int esupport;
68 extern EPNODE *curfunc;
69 extern int nextc;
70
71 /* defined in caldefn.c */
72 extern void fcompile(char *fname);
73 extern void scompile(char *str, char *fname, int ln);
74 extern double varvalue(char *vname);
75 extern double evariable(EPNODE *ep);
76 extern void varset(char *fname, int assign, double val);
77 extern void dclear(char *name);
78 extern void dremove(char *name);
79 extern int vardefined(char *name);
80 extern char *setcontext(char *ctx);
81 extern char *pushcontext(char *ctx);
82 extern char *popcontext(void);
83 extern char *qualname(char *nam, int lvl);
84 extern int incontext(char *qn);
85 extern void chanout(void (*cs)(int n, double v));
86 extern void dcleanup(int lvl);
87 extern EPNODE *dlookup(char *name);
88 extern VARDEF *varlookup(char *name);
89 extern VARDEF *varinsert(char *name);
90 extern void varfree(VARDEF *ln);
91 extern EPNODE *dfirst(void);
92 extern EPNODE *dnext(void);
93 extern EPNODE *dpop(char *name);
94 extern void dpush(char *nm, EPNODE *ep);
95 extern void addchan(EPNODE *sp);
96 extern void getstatement();
97 extern EPNODE *getdefn();
98 extern EPNODE *getchan();
99 /* defined in calexpr.c */
100 extern EPNODE *eparse(char *expr);
101 extern double eval(char *expr);
102 extern int epcmp(EPNODE *ep1, EPNODE *ep2);
103 extern void epfree(EPNODE *epar);
104 extern EPNODE *ekid(EPNODE *ep, int n);
105 extern int nekids(EPNODE *ep);
106 extern void initfile(FILE *fp, char *fn, int ln);
107 extern void initstr(char *s, char *fn, int ln);
108 extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp);
109 extern int scan(void);
110 extern char *long2ascii(long l);
111 extern void syntax(char *err);
112 extern void addekid(EPNODE *ep, EPNODE *ekid);
113 extern char *getname(void);
114 extern int getinum(void);
115 extern double getnum(void);
116 extern EPNODE *getE1(void);
117 extern EPNODE *getE2(void);
118 extern EPNODE *getE3(void);
119 extern EPNODE *getE4(void);
120 extern EPNODE *getE5(void);
121 extern EPNODE *rconst(EPNODE *epar);
122 extern int isconstvar(EPNODE *ep);
123 extern int isconstfun(EPNODE *ep);
124 /* defined in calfunc.c */
125 extern int fundefined(char *fname);
126 extern double funvalue(char *fname, int n, double *a);
127 extern void funset(char *fname, int nargs, int assign, double (*fptr)());
128 extern int nargum(void);
129 extern double argument(int n);
130 extern VARDEF *argf(int n);
131 extern char *argfun(int n);
132 extern double efunc(EPNODE *ep);
133 extern LIBR *liblookup(char *fname);
134 extern void libupdate(char *fn);
135 /* defined in calprnt.c */
136 extern void eprint(EPNODE *ep, FILE *fp);
137 extern void dprint(char *name, FILE *fp);
138 /* defined in savestr.c */
139 extern char *savestr(char *str);
140 extern void freestr(char *s);
141 extern int shash(char *s);
142 /* defined in ealloc.c */
143 extern char *emalloc(unsigned int n);
144 extern char *ecalloc(unsigned int ne, unsigned int es);
145 extern char *erealloc(char *cp, unsigned int n);
146 extern void efree(char *cp);
147 /* miscellaneous */
148 extern void eputs(char *s);
149 extern void wputs(char *s);
150 extern void quit(int code);
151 /* defined by client */
152 extern double chanvalue(int n);
153
154
155 #ifdef __cplusplus
156 }
157 #endif
158 #endif /* _RAD_CALCOMP_H_ */
159
