root/radiance/ray/src/common/calcomp.h
Revision: 1.4
Committed: Tue Apr 23 12:43:13 1991 UTC (34 years, 1 month ago) by greg
added ':' defines for constant expressions
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * calcomp.h - header file for expression parser.
7 *
8 */
9 /* EPNODE types */
10 #define VAR 1
11 #define NUM 2
12 #define UMINUS 3
13 #define CHAN 4
14 #define FUNC 5
15 #define ARG 6
16 #define TICK 7
17 #define SYM 8
18 /* also: '+', '-', '*', '/', '^', '=', ':' */
19
20 typedef struct {
21 char *fname; /* function name */
22 int nargs; /* # of required arguments */
23 double (*f)(); /* pointer to function */
24 } LIBR; /* a library function */
25
26 typedef struct epnode {
27 int type; /* node type */
28 struct epnode *sibling; /* next child this level */
29 union {
30 struct epnode *kid; /* first child */
31 double num; /* number */
32 char *name; /* symbol name */
33 int chan; /* channel number */
34 long tick; /* timestamp */
35 struct vardef {
36 char *name; /* variable name */
37 int nlinks; /* number of references */
38 struct epnode *def; /* definition */
39 LIBR *lib; /* library definition */
40 struct vardef *next; /* next in hash list */
41 } *ln; /* link */
42 } v; /* value */
43 } EPNODE; /* an expression node */
44
45 typedef struct vardef VARDEF; /* a variable definition */
46
47 extern double eval(), varvalue(), chanvalue(), funvalue();
48 extern double argument(), getnum();
49 extern double (*eoper[])();
50 extern int getinum();
51 extern char *getname(), *argfun();
52 extern EPNODE *eparse(), *ekid(), *dlookup(), *dpop(), *dfirst(), *dnext();
53 extern EPNODE *getdefn(), *getchan();
54 extern EPNODE *getE1(), *getE2(), *getE3(), *getE4(), *getE5(), *rconst();
55 extern VARDEF *varinsert(), *varlookup(), *argf();
56 extern LIBR *liblookup();
57 extern long eclock;
58 extern int nextc;
59 extern int errno;
60
61 #define evalue(ep) (*eoper[(ep)->type])(ep)
