--- ray/src/common/calcomp.h 2003/04/27 06:08:03 2.8 +++ ray/src/common/calcomp.h 2003/06/07 12:50:20 2.10 @@ -1,10 +1,18 @@ -/* RCSid $Id: calcomp.h,v 2.8 2003/04/27 06:08:03 greg Exp $ */ +/* RCSid $Id: calcomp.h,v 2.10 2003/06/07 12:50:20 schorsch Exp $ */ /* * calcomp.h - header file for expression parser. */ +#ifndef _RAD_CALCOMP_H_ +#define _RAD_CALCOMP_H_ +#ifdef __cplusplus +extern "C" { +#endif + #include "copyright.h" +#include + #define VAR 1 #define NUM 2 #define UMINUS 3 @@ -65,85 +73,6 @@ extern unsigned int esupport; extern EPNODE *curfunc; extern int nextc; -#ifdef NOPROTO - -extern void fcompile(); -extern void scompile(); -extern double varvalue(); -extern double evariable(); -extern void varset(); -extern void dclear(); -extern void dremove(); -extern int vardefined(); -extern char *setcontext(); -extern char *pushcontext(); -extern char *popcontext(); -extern char *qualname(); -extern int incontext(); -extern void chanout(); -extern void dcleanup(); -extern EPNODE *dlookup(); -extern VARDEF *varlookup(); -extern VARDEF *varinsert(); -extern void varfree(); -extern EPNODE *dfirst(); -extern EPNODE *dnext(); -extern EPNODE *dpop(); -extern void dpush(); -extern void addchan(); -extern void getstatement(); -extern EPNODE *getdefn(); -extern EPNODE *getchan(); -extern EPNODE *eparse(); -extern double eval(); -extern int epcmp(); -extern void epfree(); -extern EPNODE *ekid(); -extern int nekids(); -extern void initfile(); -extern void initstr(); -extern void getscanpos(); -extern int scan(); -extern char *long2ascii(); -extern void syntax(); -extern void addekid(); -extern char *getname(); -extern int getinum(); -extern double getnum(); -extern EPNODE *getE1(); -extern EPNODE *getE2(); -extern EPNODE *getE3(); -extern EPNODE *getE4(); -extern EPNODE *getE5(); -extern EPNODE *rconst(); -extern int isconstvar(); -extern int isconstfun(); -extern int fundefined(); -extern double funvalue(); -extern void funset(); -extern int nargum(); -extern double argument(); -extern VARDEF *argf(); -extern char *argfun(); -extern double efunc(); -extern LIBR *liblookup(); -extern void libupdate(); -extern void eprint(); -extern void dprint(); -extern char *savestr(); -extern void freestr(); -extern int shash(); -extern char *emalloc(); -extern char *ecalloc(); -extern char *erealloc(); -extern void efree(); -extern void eputs(); -extern void wputs(); -extern void quit(); - -extern double chanvalue(); - -#else /* defined in caldefn.c */ extern void fcompile(char *fname); extern void scompile(char *str, char *fname, int ln); @@ -227,4 +156,9 @@ extern void quit(int code); /* defined by client */ extern double chanvalue(int n); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_CALCOMP_H_ */ +
