| 1 |
/* RCSid $Id: calcomp.h,v 2.27 2024/09/16 17:31:14 greg Exp $ */
| 2 |
| 3 |
* calcomp.h - header file for expression parser.
| 4 |
| 5 |
#ifndef _RAD_CALCOMP_H_
| 6 |
#define _RAD_CALCOMP_H_
| 7 |
| 8 |
#include <stdio.h>
| 9 |
| 10 |
#ifdef __cplusplus
| 11 |
extern "C" {
| 12 |
#endif
| 13 |
| 14 |
#define VAR 1
| 15 |
#define NUM 2
| 16 |
#define UMINUS 3
| 17 |
#define CHAN 4
| 18 |
#define FUNC 5
| 19 |
#define ARG 6
| 20 |
#define CLKT 7
| 21 |
#define SYM 8
| 22 |
/* also: '+', '-', '*', '/', '^', '=', ':' */
| 23 |
| 24 |
typedef struct {
| 25 |
char *fname; /* function name */
| 26 |
short nargs; /* # of required arguments */
| 27 |
short atyp; /* assignment type (':' or '=') */
| 28 |
double (*f)(char *); /* pointer to function */
| 29 |
} ELIBR; /* a library function */
| 30 |
| 31 |
typedef struct vardef {
| 32 |
char *name; /* variable name */
| 33 |
int nlinks; /* number of references */
| 34 |
struct epnode *def; /* definition */
| 35 |
ELIBR *lib; /* library definition */
| 36 |
struct vardef *next; /* next in hash list */
| 37 |
} VARDEF; /* a variable definition */
| 38 |
| 39 |
typedef struct epnode {
| 40 |
union {
| 41 |
struct epnode *kid; /* first child */
| 42 |
double num; /* number */
| 43 |
char *name; /* symbol name */
| 44 |
int chan; /* channel number */
| 45 |
unsigned long tick; /* timestamp */
| 46 |
VARDEF *ln; /* variable definition link */
| 47 |
} v; /* value */
| 48 |
struct epnode *sibling; /* next child this level */
| 49 |
short type; /* node type */
| 50 |
short nkids; /* child count (neg if array) */
| 51 |
} EPNODE; /* an expression node */
| 52 |
| 53 |
#define nekids(ep) abs((ep)->nkids)
| 54 |
| 55 |
#define RMAXWORD 127 /* maximum word/id length */
| 56 |
#define CNTXMARK '`' /* context mark */
| 57 |
| 58 |
#define isid(c) (isalnum(c) || (c) == '_' || \
| 59 |
(c) == '.' || (c) == CNTXMARK)
| 60 |
| 61 |
#define evalue(ep) (*eoper[(ep)->type])(ep)
| 62 |
| 63 |
#define dfn_name(ep) ((ep)->v.kid->type == SYM ? \
| 64 |
(ep)->v.kid->v.name : \
| 65 |
(ep)->v.kid->v.kid->v.name)
| 66 |
| 67 |
/* flags to set in esupport */
| 68 |
#define E_VARIABLE 001
| 69 |
#define E_FUNCTION 002
| 70 |
#define E_INCHAN 004
| 71 |
#define E_OUTCHAN 010
| 72 |
#define E_RCONST 020
| 73 |
#define E_REDEFW 040
| 74 |
| 75 |
extern double (*eoper[])(EPNODE *);
| 76 |
extern unsigned long eclock;
| 77 |
extern unsigned int esupport;
| 78 |
extern EPNODE *ecurfunc;
| 79 |
extern int nextc;
| 80 |
extern int eofc;
| 81 |
/* defined in biggerlib.c */
| 82 |
extern void biggerlib(void);
| 83 |
/* defined in caldefn.c */
| 84 |
extern void fcompile(char *fname);
| 85 |
extern void scompile(char *str, char *fname, int ln);
| 86 |
extern double varvalue(char *vname);
| 87 |
extern double evariable(EPNODE *ep);
| 88 |
extern void varset(char *vname, int assign, double val);
| 89 |
extern void dclear(char *name);
| 90 |
extern void dremove(char *name);
| 91 |
extern int vardefined(char *name);
| 92 |
extern char *calcontext(char *ctx);
| 93 |
extern char *pushcontext(char *ctx);
| 94 |
extern char *popcontext(void);
| 95 |
extern char *qualname(char *nam, int lvl);
| 96 |
extern int incontext(char *qn);
| 97 |
extern void chanout(void (*cs)(int n, double v));
| 98 |
extern void doptimize(int activate);
| 99 |
extern void dcleanup(int lvl);
| 100 |
extern EPNODE *dlookup(char *name);
| 101 |
extern VARDEF *varlookup(char *name);
| 102 |
extern VARDEF *varinsert(char *name);
| 103 |
extern void varfree(VARDEF *ln);
| 104 |
extern EPNODE *dfirst(void);
| 105 |
extern EPNODE *dnext(void);
| 106 |
extern EPNODE *dpop(char *name);
| 107 |
extern void dpush(char *nm, EPNODE *ep);
| 108 |
extern void eaddchan(EPNODE *sp);
| 109 |
extern void egetstatement(void);
| 110 |
extern EPNODE *egetdefn(void);
| 111 |
extern EPNODE *egetchan(void);
| 112 |
/* defined in calexpr.c */
| 113 |
extern EPNODE *eparse(char *expr);
| 114 |
extern double eval(char *expr);
| 115 |
extern int epcmp(EPNODE *ep1, EPNODE *ep2);
| 116 |
extern void epfree(EPNODE *epar, int frep);
| 117 |
extern void epoptimize(EPNODE *epar);
| 118 |
extern EPNODE *ekid(EPNODE *ep, int n);
| 119 |
extern void initfile(FILE *fp, char *fn, int ln);
| 120 |
extern void initstr(char *s, char *fn, int ln);
| 121 |
extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp);
| 122 |
extern int escan(void);
| 123 |
extern char *long2ascii(long l);
| 124 |
extern void esyntax(char *err);
| 125 |
extern void addekid(EPNODE *ep, EPNODE *ek);
| 126 |
extern char *getname(void);
| 127 |
extern int getinum(void);
| 128 |
extern double getnum(void);
| 129 |
extern EPNODE *getE1(void);
| 130 |
extern EPNODE *getE2(void);
| 131 |
extern EPNODE *getE3(void);
| 132 |
extern EPNODE *getE4(void);
| 133 |
extern EPNODE *getE5(void);
| 134 |
extern EPNODE *rconst(EPNODE *epar);
| 135 |
extern int isconstvar(EPNODE *ep);
| 136 |
extern int isconstfun(EPNODE *ep);
| 137 |
/* defined in calfunc.c */
| 138 |
extern int fundefined(char *fname);
| 139 |
extern double funvalue(char *fname, int n, double *a);
| 140 |
extern void funset(char *fname, int nargs, int assign,
| 141 |
double (*fptr)(char *));
| 142 |
extern int nargum(void);
| 143 |
extern double argument(int n);
| 144 |
extern VARDEF *eargf(int n);
| 145 |
extern char *eargfun(int n);
| 146 |
extern double efunc(EPNODE *ep);
| 147 |
extern double eargument(EPNODE *ep);
| 148 |
extern ELIBR *eliblookup(char *fname);
| 149 |
extern void elibupdate(char *fn);
| 150 |
/* defined in calprnt.c */
| 151 |
extern void eprint(EPNODE *ep, FILE *fp);
| 152 |
extern void dprint(char *name, FILE *fp);
| 153 |
/* defined by client */
| 154 |
extern double chanvalue(int n);
| 155 |
| 156 |
#ifdef __cplusplus
| 157 |
| 158 |
#endif
| 159 |
#endif /* _RAD_CALCOMP_H_ */
| 160 |
