root/radiance/ray/src/common/calcomp.h
Mon Feb 26 18:16:35 2024 UTC (3 months ago) by greg
Changes since 2.25: +2 -1 lines
Diff to previous 2.25 , to selected 1.3
perf: Added shortcut to avoid extra call in eargument(), which was bottleneck
Fri Feb 23 03:47:57 2024 UTC (3 months, 1 week ago) by greg
Changes since 2.24: +9 -5 lines
Diff to previous 2.24 , to selected 1.3
Tue Sep 26 18:33:14 2023 UTC (8 months, 1 week ago) by greg
Changes since 2.23: +5 -4 lines
Diff to previous 2.23 , to selected 1.3
style: minor code clean-ups
Wed Mar 30 16:00:56 2022 UTC (2 years, 2 months ago) by greg
Diff to previous 2.22 , to selected 1.3
fix: Renamed setcontext() to calcontext() to avoid obscure macOS naming conflict
Thu May 1 16:42:05 2008 UTC (16 years, 1 month ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 2.21 , to selected 1.3
Fri Sep 23 19:04:52 2005 UTC (18 years, 8 months ago) by greg
CVS Tags: rad3R8, rad3R9
Diff to previous 2.20 , to selected 1.3
Wed May 25 04:44:25 2005 UTC (19 years ago) by greg
Diff to previous 2.19 , to selected 1.3
Tue May 17 17:51:51 2005 UTC (19 years ago) by greg
Changes since 2.18: +2 -1 lines
Diff to previous 2.18 , to selected 1.3
Added "eofc" global for specifying an optional EOF character, such as '}'
Thu Apr 29 22:32:11 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.17: +1 -10 lines
Diff to previous 2.17 , to selected 1.3
Removed hazardous //-style comments
Changes since 2.16: +8 -8 lines
Diff to previous 2.16 , to selected 1.3
Mon Aug 4 22:37:53 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.15: +4 -3 lines
Diff to previous 2.15 , to selected 1.3
Mon Aug 4 19:20:26 2003 UTC (20 years, 10 months ago) by greg
Diff to previous 2.14 , to selected 1.3
Added prototype for eoper[] dispatch array
Changes since 2.13: +10 -8 lines
Diff to previous 2.13 , to selected 1.3
Thu Jul 3 22:41:44 2003 UTC (20 years, 11 months ago) by schorsch
Diff to previous 2.12 , to selected 1.3
Mon Jun 30 19:04:29 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 2.11 , to selected 1.3
Changes since 2.10: +1 -4 lines
Diff to previous 2.10 , to selected 1.3
Sat Jun 7 12:50:20 2003 UTC (21 years ago) by schorsch
Changes since 2.9: +3 -1 lines
Diff to previous 2.9 , to selected 1.3
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 2.8: +12 -80 lines
Diff to previous 2.8 , to selected 1.3
*** empty log message ***
Sun Apr 27 06:08:03 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.7 , to selected 1.3
Changes since 2.6: +3 -58 lines
Diff to previous 2.6 , to selected 1.3
Changes since 2.5: +232 -15 lines
Diff to previous 2.5 , to selected 1.3
Tue Aug 26 17:15:10 1997 UTC (26 years, 9 months ago) by gregl
Diff to previous 2.4 , to selected 1.3
increased maximum word length to 127 characters
Fri Feb 17 18:34:41 1995 UTC (29 years, 3 months ago) by greg
Diff to previous 2.3 , to selected 1.3
fixed potential bug in eclock tracking
Thu Apr 8 16:41:34 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.2 , to selected 1.3
added pushcontext() and popcontext() functions
Mon Sep 21 12:01:33 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.1: +16 -17 lines
Diff to previous 2.1 , to selected 1.3
Changes for PC port
Tue Nov 12 16:55:05 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.7 , to selected 1.3
Wed Aug 14 08:28:00 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.6 , to selected 1.3
fixed code relating to long identifiers
Thu Aug 8 11:23:17 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.5: +7 -1 lines
Diff to previous 1.5 , to selected 1.3
added contexts to definition naming
Tue Apr 23 15:44:37 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.4: +2 -1 lines
Diff to previous 1.4 , to selected 1.3
Tue Apr 23 12:43:13 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.3
added ':' defines for constant expressions
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu May 18 08:33:47 1989 UTC (35 years ago) by greg
Changes since 1.2: +0 -4 lines
Diff to previous 1.2
deleted unnecessary CPM ifdef
Mon Apr 10 22:05:56 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +4 -0 lines
Diff to previous 1.1 , to selected 1.3
put in defined() macro for hopeless CP/M compiler
Thu Feb 2 10:34:13 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.3
