1 |
greg |
3.11 |
/* RCSid $Id: bsdf_t.h,v 3.10 2012/09/02 15:33:15 greg Exp $ */ |
2 |
greg |
3.1 |
3 |
* bsdf_t.h |
4 |
5 |
greg |
3.4 |
* Support for variable-resolution BSDF trees. |
6 |
* Assumes "bsdf.h" already included. |
7 |
* Include after "ezxml.h" for SDloadTre() declaration. |
8 |
greg |
3.1 |
9 |
* Created by Greg Ward on 2/2/11. |
10 |
11 |
12 |
13 |
#ifndef _BSDF_T_H_ |
14 |
#define _BSDF_T_H_ |
15 |
16 |
#ifdef __cplusplus |
17 |
extern "C" { |
18 |
#endif |
19 |
20 |
#define SD_MAXDIM 4 /* maximum expected # dimensions */ |
21 |
22 |
/* Basic node structure for variable-resolution BSDF data */ |
23 |
typedef struct SDNode_s { |
24 |
short ndim; /* number of dimensions */ |
25 |
short log2GR; /* log(2) of grid resolution (< 0 for tree) */ |
26 |
union { |
27 |
struct SDNode_s *t[1]; /* subtree pointers */ |
28 |
float v[1]; /* scattering value(s) */ |
29 |
} u; /* subtrees or values (extends struct) */ |
30 |
} SDNode; |
31 |
32 |
greg |
3.10 |
#define SD_FREFL 1 /* component reflects off front side */ |
33 |
#define SD_BREFL 2 /* component reflects off back side */ |
34 |
#define SD_FXMIT 3 /* component transmits through front side */ |
35 |
#define SD_BXMIT 4 /* component transmits through back side */ |
36 |
greg |
3.7 |
37 |
greg |
3.6 |
/* Variable-resolution BSDF holder */ |
38 |
typedef struct { |
39 |
greg |
3.7 |
int sidef; /* transmitted component? */ |
40 |
greg |
3.6 |
SDNode *st; /* BSDF tree */ |
41 |
} SDTre; |
42 |
43 |
/* Holder for cumulative distribution (sum of BSDF * projSA) */ |
44 |
greg |
3.9 |
typedef struct SDTreCDst_s { |
45 |
/* base fields; must come first */ |
46 |
SD_CDIST_BASE(SDTreCDst_s); |
47 |
greg |
3.6 |
double clim[2][2]; /* input coordinate limits */ |
48 |
double max_psa; /* maximum projected solid angle */ |
49 |
greg |
3.10 |
short sidef; /* which mode is in play */ |
50 |
greg |
3.8 |
short isodist; /* isotropic distribution? */ |
51 |
greg |
3.6 |
int calen; /* cumulative array length */ |
52 |
struct { |
53 |
unsigned hndx; /* hilbert index */ |
54 |
unsigned cuml; /* cumulative value */ |
55 |
greg |
3.11 |
} carr[1]; /* cumulative array (extends struct) */ |
56 |
greg |
3.6 |
} SDTreCDst; |
57 |
58 |
greg |
3.4 |
#ifdef _EZXML_H |
59 |
greg |
3.1 |
/* Load a variable-resolution BSDF tree from an open XML file */ |
60 |
greg |
3.3 |
extern SDError SDloadTre(SDData *sd, ezxml_t wtl); |
61 |
greg |
3.4 |
#endif |
62 |
greg |
3.1 |
63 |
/* Our matrix handling routines */ |
64 |
greg |
3.5 |
extern SDFunc SDhandleTre; |
65 |
greg |
3.1 |
66 |
67 |
68 |
#endif |
69 |
#endif /* ! _BSDF_T_H_ */ |
