root/radiance/ray/src/common/bsdf_t.h
Revision: 3.13
Committed: Fri Jan 5 21:00:24 2018 UTC (6 years, 3 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Fix for C++ compilers, which don't like "typedef const struct"
1 /* RCSid $Id: bsdf_t.h,v 3.12 2015/04/05 01:32:01 greg Exp $ */
2 /*
3 * bsdf_t.h
4 *
5 * Support for variable-resolution BSDF trees.
6 * Assumes "bsdf.h" already included.
7 * Include after "ezxml.h" for SDloadTre() declaration.
8 *
9 * Created by Greg Ward on 2/2/11.
10 *
11 */
12
13 #ifndef _BSDF_T_H_
14 #define _BSDF_T_H_
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19
20 #define SD_MAXDIM 4 /* maximum expected # dimensions */
21
22 /* Basic node structure for variable-resolution BSDF data */
23 typedef struct SDNode_s {
24 short ndim; /* number of dimensions */
25 short log2GR; /* log(2) of grid resolution (< 0 for tree) */
26 union {
27 struct SDNode_s *t[1]; /* subtree pointers */
28 float v[1]; /* scattering value(s) */
29 } u; /* subtrees or values (extends struct) */
30 } SDNode;
31
32 #define SD_FREFL 1 /* component reflects off front side */
33 #define SD_BREFL 2 /* component reflects off back side */
34 #define SD_FXMIT 3 /* component transmits through front side */
35 #define SD_BXMIT 4 /* component transmits through back side */
36
37 /* Variable-resolution BSDF holder */
38 typedef struct {
39 int sidef; /* which component */
40 SDNode *stc[3]; /* BSDF (Y,u,v) trees */
41 } SDTre;
42
43 /* Holder for cumulative distribution (sum of BSDF * projSA) */
44 typedef struct SDTreCDst_s {
45 /* base fields; must come first */
46 SD_CDIST_BASE(SDTreCDst_s);
47 double clim[2][2]; /* input coordinate limits */
48 double max_psa; /* maximum projected solid angle */
49 short sidef; /* which mode is in play */
50 short isodist; /* isotropic distribution? */
51 int calen; /* cumulative array length */
52 struct {
53 unsigned hndx; /* hilbert index */
54 unsigned cuml; /* cumulative value */
55 } carr[1]; /* cumulative array (extends struct) */
56 } SDTreCDst;
57
58 #ifdef _EZXML_H
59 /* Load a variable-resolution BSDF tree from an open XML file */
60 extern SDError SDloadTre(SDData *sd, ezxml_t wtl);
61 #endif
62
63 /* Our matrix handling routines */
64 extern const SDFunc SDhandleTre;
65
66 #ifdef __cplusplus
67 }
68 #endif
69 #endif /* ! _BSDF_T_H_ */
