root/radiance/ray/src/common/bsdf_t.h
Sun Nov 10 17:32:09 2013 UTC (10 years, 7 months ago) by greg
Diff to previous 3.10 , to selected 3.2
Removed stray tab
Sun Sep 2 15:33:15 2012 UTC (11 years, 9 months ago) by greg
Changes since 3.9: +6 -5 lines
Diff to previous 3.9 , to selected 3.2
Sun Aug 21 22:38:12 2011 UTC (12 years, 9 months ago) by greg
Changes since 3.8: +4 -3 lines
Diff to previous 3.8 , to selected 3.2
Minor improvements to direct specular sampling
Fri Jun 3 18:12:58 2011 UTC (13 years ago) by greg
Changes since 3.7: +3 -2 lines
Diff to previous 3.7 , to selected 3.2
Fixed bugs in variable-resolution isotropic BSDFs
Wed Apr 27 20:03:25 2011 UTC (13 years, 1 month ago) by greg
Changes since 3.6: +7 -3 lines
Diff to previous 3.6 , to selected 3.2
Initial untested variable-resolution BSDF
Sun Apr 24 19:39:21 2011 UTC (13 years, 1 month ago) by greg
Changes since 3.5: +20 -1 lines
Diff to previous 3.5 , to selected 3.2
Partial implementation of variable-resolution BSDFs
Tue Apr 19 21:31:22 2011 UTC (13 years, 2 months ago) by greg
Changes since 3.4: +2 -2 lines
Diff to previous 3.4 , to selected 3.2
Fixed interface for determining BSDF solid angles
Fri Apr 8 18:13:48 2011 UTC (13 years, 2 months ago) by greg
Changes since 3.3: +6 -2 lines
Diff to previous 3.3 , to selected 3.2
Sat Feb 19 01:48:59 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 3.2
Minor changes and fixes -- first working version of BSDF material
Revision 3.2 - (view) (download) (annotate) - [selected]
Fri Feb 18 00:41:44 2011 UTC (13 years, 4 months ago) by greg
Changes since 3.1: +1 -0 lines
Added missing RCS tags
Fri Feb 18 00:40:25 2011 UTC (13 years, 4 months ago) by greg
Diff to selected 3.2
