1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: bsdf_t.c,v 3.2 2011/02/18 00:41:44 greg Exp $"; |
3 |
#endif |
4 |
5 |
* bsdf_t.c |
6 |
7 |
* Definitions for variable-resolution BSDF trees |
8 |
9 |
* Created by Greg Ward on 2/2/11. |
10 |
11 |
12 |
13 |
#include "rtio.h" |
14 |
#include <stdlib.h> |
15 |
#include <math.h> |
16 |
#include <ctype.h> |
17 |
#include "ezxml.h" |
18 |
#include "bsdf.h" |
19 |
#include "bsdf_t.h" |
20 |
21 |
/* Allocate a new scattering distribution node */ |
22 |
static SDNode * |
23 |
SDnewNode(int nd, int lg) |
24 |
25 |
SDNode *st; |
26 |
27 |
if (nd <= 0) { |
28 |
strcpy(SDerrorDetail, "Zero dimension BSDF node request"); |
29 |
return NULL; |
30 |
31 |
if (nd > SD_MAXDIM) { |
32 |
sprintf(SDerrorDetail, "Illegal BSDF dimension (%d > %d)", |
33 |
nd, SD_MAXDIM); |
34 |
return NULL; |
35 |
36 |
if (lg < 0) { |
37 |
st = (SDNode *)malloc(sizeof(SDNode) + |
38 |
((1<<nd) - 1)*sizeof(st->u.t[0])); |
39 |
if (st != NULL) |
40 |
memset(st->u.t, 0, (1<<nd)*sizeof(st->u.t[0])); |
41 |
} else |
42 |
43 |
((1 << nd*lg) - 1)*sizeof(st->u.v[0])); |
44 |
45 |
if (st == NULL) { |
46 |
if (lg < 0) |
47 |
sprintf(SDerrorDetail, |
48 |
"Cannot allocate %d branch BSDF tree", nd); |
49 |
else |
50 |
51 |
"Cannot allocate %d BSDF leaves", 1 << nd*lg); |
52 |
return NULL; |
53 |
54 |
st->ndim = nd; |
55 |
st->log2GR = lg; |
56 |
return st; |
57 |
58 |
59 |
/* Free an SD tree */ |
60 |
static void |
61 |
SDfreeTree(void *p) |
62 |
63 |
SDNode *st = (SDNode *)p; |
64 |
int i; |
65 |
66 |
if (st == NULL) |
67 |
return; |
68 |
for (i = (st->log2GR < 0) << st->ndim; i--; ) |
69 |
SDfreeTree(st->u.t[i]); |
70 |
free((void *)st); |
71 |
72 |
73 |
/* Add up N-dimensional hypercube array values over the given box */ |
74 |
static double |
75 |
SDiterSum(const float *va, int nd, int siz, const int *imin, const int *imax) |
76 |
77 |
double sum = .0; |
78 |
unsigned skipsiz = 1; |
79 |
int i; |
80 |
81 |
for (i = nd; --i > 0; ) |
82 |
skipsiz *= siz; |
83 |
if (skipsiz == 1) |
84 |
for (i = *imin; i < *imax; i++) |
85 |
sum += va[i]; |
86 |
else |
87 |
88 |
sum += SDiterSum(va + i*skipsiz, |
89 |
nd-1, siz, imin+1, imax+1); |
90 |
return sum; |
91 |
92 |
93 |
/* Average BSDF leaves over an orthotope defined by the unit hypercube */ |
94 |
static double |
95 |
SDavgBox(const SDNode *st, const double *bmin, const double *bmax) |
96 |
97 |
int imin[SD_MAXDIM], imax[SD_MAXDIM]; |
98 |
unsigned n; |
99 |
int i; |
100 |
101 |
if (!st) |
102 |
return .0; |
103 |
/* check box limits */ |
104 |
for (i = st->ndim; i--; ) { |
105 |
if (bmin[i] >= 1.) |
106 |
return .0; |
107 |
if (bmax[i] <= .0) |
108 |
return .0; |
109 |
if (bmin[i] >= bmax[i]) |
110 |
return .0; |
111 |
112 |
if (st->log2GR < 0) { /* iterate on subtree */ |
113 |
double sum = .0, wsum = 1e-20; |
114 |
double sbmin[SD_MAXDIM], sbmax[SD_MAXDIM], w; |
115 |
116 |
for (n = 1 << st->ndim; n--; ) { |
117 |
w = 1.; |
118 |
119 |
sbmin[i] = 2.*bmin[i]; |
120 |
sbmax[i] = 2.*bmax[i]; |
121 |
if (n & 1<<i) { |
122 |
sbmin[i] -= 1.; |
123 |
sbmax[i] -= 1.; |
124 |
125 |
if (sbmin[i] < .0) sbmin[i] = .0; |
126 |
if (sbmax[i] > 1.) sbmax[i] = 1.; |
127 |
w *= sbmax[i] - sbmin[i]; |
128 |
129 |
if (w > 1e-10) { |
130 |
sum += w * SDavgBox(st->u.t[n], sbmin, sbmax); |
131 |
wsum += w; |
132 |
133 |
134 |
return sum / wsum; |
135 |
136 |
n = 1; /* iterate over leaves */ |
137 |
138 |
imin[i] = (bmin[i] <= .0) ? 0 |
139 |
: (int)((1 << st->log2GR)*bmin[i]); |
140 |
imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) |
141 |
: (int)((1 << st->log2GR)*bmax[i] + .999999); |
142 |
n *= imax[i] - imin[i]; |
143 |
144 |
if (!n) |
145 |
return .0; |
146 |
147 |
return SDiterSum(st->u.v, st->ndim, 1 << st->log2GR, imin, imax) / |
148 |
(double)n; |
149 |
150 |
151 |
/* Load a variable-resolution BSDF tree from an open XML file */ |
152 |
SDError |
153 |
SDloadTre(SDData *sd, ezxml_t fl) |
154 |
155 |
return SDEsupport; |
156 |
157 |
158 |
/* Variable resolution BSDF methods */ |
159 |
const SDFunc SDhandleTre = { |
160 |
NULL, |
161 |
NULL, |
162 |
NULL, |
163 |
NULL, |
164 |
&SDfreeTree, |
165 |
