--- ray/src/common/bsdf_t.c 2015/04/05 01:32:01 3.37 +++ ray/src/common/bsdf_t.c 2015/04/05 06:02:43 3.38 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_t.c,v 3.37 2015/04/05 01:32:01 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_t.c,v 3.38 2015/04/05 06:02:43 greg Exp $"; #endif /* * bsdf_t.c @@ -1241,8 +1241,9 @@ adjust_utree(float uprime, const double *cmin, double { SDextRGBs *mp = (SDextRGBs *)cptr; double cmax[SD_MAXDIM]; + double yval; float rgb[3]; - int ok; + C_COLOR clr; if (mp->stc[tt_Y]->ndim == 3) { if (cmin[0] + .5*csiz >= .5) @@ -1253,18 +1254,14 @@ adjust_utree(float uprime, const double *cmin, double cmax[1] = cmin[1] + csiz; cmax[2] = cmin[2] + csiz; /* average RGB color over voxel */ - SDyuv2rgb(SDavgTreBox(mp->stc[tt_Y], cmin, cmax), uprime, + SDyuv2rgb(yval=SDavgTreBox(mp->stc[tt_Y], cmin, cmax), uprime, SDavgTreBox(mp->stc[tt_v], cmin, cmax), rgb); - /* subtract minimum */ - ok = (rgb[0] -= mp->rgb[0]) > 1e-5; - ok &= (rgb[1] -= mp->rgb[1]) > 1e-5; - ok &= (rgb[2] -= mp->rgb[2]) > 1e-5; - if (ok) { /* compute new u' for adj. RGB */ - C_COLOR clr; - c_fromSharpRGB(rgb, &clr); - uprime = 4.*clr.cx/(-2.*clr.cx + 12.*clr.cy + 3.); - } else - uprime = 4./3./(-2./3. + 12./3. + 3.); + /* subtract minimum (& clamp) */ + if ((rgb[0] -= mp->rgb[0]) < 1e-5*yval) rgb[0] = 1e-5*yval; + if ((rgb[1] -= mp->rgb[1]) < 1e-5*yval) rgb[1] = 1e-5*yval; + if ((rgb[2] -= mp->rgb[2]) < 1e-5*yval) rgb[2] = 1e-5*yval; + c_fromSharpRGB(rgb, &clr); /* compute new u' for adj. RGB */ + uprime = 4.*clr.cx/(-2.*clr.cx + 12.*clr.cy + 3.); /* assign in new u' tree */ mp->new_stu = SDsetVoxel(mp->new_stu, mp->stc[tt_Y]->ndim, cmin, csiz, uprime); @@ -1277,8 +1274,9 @@ adjust_vtree(float vprime, const double *cmin, double { SDextRGBs *mp = (SDextRGBs *)cptr; double cmax[SD_MAXDIM]; + double yval; float rgb[3]; - int ok; + C_COLOR clr; if (mp->stc[tt_Y]->ndim == 3) { if (cmin[0] + .5*csiz >= .5) @@ -1289,19 +1287,15 @@ adjust_vtree(float vprime, const double *cmin, double cmax[1] = cmin[1] + csiz; cmax[2] = cmin[2] + csiz; /* average RGB color over voxel */ - SDyuv2rgb(SDavgTreBox(mp->stc[tt_Y], cmin, cmax), + SDyuv2rgb(yval=SDavgTreBox(mp->stc[tt_Y], cmin, cmax), SDavgTreBox(mp->stc[tt_u], cmin, cmax), vprime, rgb); - /* subtract minimum */ - ok = (rgb[0] -= mp->rgb[0]) > 1e-5; - ok &= (rgb[1] -= mp->rgb[1]) > 1e-5; - ok &= (rgb[2] -= mp->rgb[2]) > 1e-5; - if (ok) { /* compute new v' for adj. RGB */ - C_COLOR clr; - c_fromSharpRGB(rgb, &clr); - vprime = 9.*clr.cy/(-2.*clr.cx + 12.*clr.cy + 3.); - } else - vprime = 9./3./(-2./3. + 12./3. + 3.); + /* subtract minimum (& clamp) */ + if ((rgb[0] -= mp->rgb[0]) < 1e-5*yval) rgb[0] = 1e-5*yval; + if ((rgb[1] -= mp->rgb[1]) < 1e-5*yval) rgb[1] = 1e-5*yval; + if ((rgb[2] -= mp->rgb[2]) < 1e-5*yval) rgb[2] = 1e-5*yval; + c_fromSharpRGB(rgb, &clr); /* compute new v' for adj. RGB */ + vprime = 9.*clr.cy/(-2.*clr.cx + 12.*clr.cy + 3.); /* assign in new v' tree */ mp->new_stv = SDsetVoxel(mp->new_stv, mp->stc[tt_Y]->ndim, cmin, csiz, vprime);
