--- ray/src/common/bsdf_t.c 2012/09/02 15:33:15 3.24 +++ ray/src/common/bsdf_t.c 2012/09/10 18:06:08 3.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_t.c,v 3.24 2012/09/02 15:33:15 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_t.c,v 3.25 2012/09/10 18:06:08 greg Exp $"; #endif /* * bsdf_t.c @@ -499,9 +499,16 @@ build_scaffold(float val, const double *cmin, double c { SDdistScaffold *sp = (SDdistScaffold *)cptr; int wid = csiz*(double)iwmax + .5; + double revcmin[2]; bitmask_t bmin[2], bmax[2]; - cmin += sp->nic * !sp->rev; /* skip to output coords */ + if (sp->rev) { /* need to reverse sense? */ + revcmin[0] = 1. - cmin[0] - csiz; + revcmin[1] = 1. - cmin[1] - csiz; + cmin = revcmin; + } else { + cmin += sp->nic; /* else skip to output coords */ + } if (wid < sp->wmin) /* new minimum width? */ sp->wmin = wid; if (wid > sp->wmax) /* new maximum? */ @@ -667,7 +674,10 @@ SDgetTreCDist(const FVECT inVec, SDComponent *sdc) return &SDemptyCD; inCoord[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]); } else if (sdt->st->ndim == 4) { - SDdisk2square(inCoord, -inVec[0], -inVec[1]); + if (mode != sdt->sidef) /* use reciprocity? */ + SDdisk2square(inCoord, inVec[0], inVec[1]); + else + SDdisk2square(inCoord, -inVec[0], -inVec[1]); } else return NULL; /* should be internal error */ /* quantize to avoid f.p. errors */ @@ -947,25 +957,25 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim) * Remember that front and back are reversed from WINDOW 6 orientations */ if (!strcasecmp(sdata, "Transmission Front")) { - if (sd->tf != NULL) - SDfreeSpectralDF(sd->tf); - if ((sd->tf = SDnewSpectralDF(1)) == NULL) - return SDEmemory; - df = sd->tf; - } else if (!strcasecmp(sdata, "Transmission Back")) { if (sd->tb != NULL) SDfreeSpectralDF(sd->tb); if ((sd->tb = SDnewSpectralDF(1)) == NULL) return SDEmemory; df = sd->tb; + } else if (!strcasecmp(sdata, "Transmission Back")) { + if (sd->tf != NULL) + SDfreeSpectralDF(sd->tf); + if ((sd->tf = SDnewSpectralDF(1)) == NULL) + return SDEmemory; + df = sd->tf; } else if (!strcasecmp(sdata, "Reflection Front")) { - if (sd->rb != NULL) /* note back-front reversal */ + if (sd->rb != NULL) SDfreeSpectralDF(sd->rb); if ((sd->rb = SDnewSpectralDF(1)) == NULL) return SDEmemory; df = sd->rb; } else if (!strcasecmp(sdata, "Reflection Back")) { - if (sd->rf != NULL) /* note front-back reversal */ + if (sd->rf != NULL) SDfreeSpectralDF(sd->rf); if ((sd->rf = SDnewSpectralDF(1)) == NULL) return SDEmemory;
