| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf_t.c,v 3.14 2011/06/01 05:21:18 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* bsdf_t.c
| 6 |
| 7 |
* Definitions for variable-resolution BSDF trees
| 8 |
| 9 |
* Created by Greg Ward on 2/2/11.
| 10 |
| 11 |
| 12 |
| 13 |
#include "rtio.h"
| 14 |
#include <stdlib.h>
| 15 |
#include <math.h>
| 16 |
#include <ctype.h>
| 17 |
#include "ezxml.h"
| 18 |
#include "bsdf.h"
| 19 |
#include "bsdf_t.h"
| 20 |
#include "hilbert.h"
| 21 |
| 22 |
/* Callback function type for SDtraverseTre() */
| 23 |
typedef int SDtreCallback(float val, const double *cmin,
| 24 |
double csiz, void *cptr);
| 25 |
| 26 |
/* reference width maximum (1.0) */
| 27 |
static const unsigned iwbits = sizeof(unsigned)*4;
| 28 |
static const unsigned iwmax = (1<<(sizeof(unsigned)*4))-1;
| 29 |
/* maximum cumulative value */
| 30 |
static const unsigned cumlmax = ~0;
| 31 |
/* constant z-vector */
| 32 |
static const FVECT zvec = {.0, .0, 1.};
| 33 |
| 34 |
/* Struct used for our distribution-building callback */
| 35 |
typedef struct {
| 36 |
int nic; /* number of input coordinates */
| 37 |
unsigned alen; /* current array length */
| 38 |
unsigned nall; /* number of allocated entries */
| 39 |
unsigned wmin; /* minimum square size so far */
| 40 |
unsigned wmax; /* maximum square size */
| 41 |
struct outdir_s {
| 42 |
unsigned hent; /* entering Hilbert index */
| 43 |
int wid; /* this square size */
| 44 |
float bsdf; /* BSDF for this square */
| 45 |
} *darr; /* output direction array */
| 46 |
} SDdistScaffold;
| 47 |
| 48 |
/* Allocate a new scattering distribution node */
| 49 |
static SDNode *
| 50 |
SDnewNode(int nd, int lg)
| 51 |
| 52 |
SDNode *st;
| 53 |
| 54 |
if (nd <= 0) {
| 55 |
strcpy(SDerrorDetail, "Zero dimension BSDF node request");
| 56 |
return NULL;
| 57 |
| 58 |
if (nd > SD_MAXDIM) {
| 59 |
sprintf(SDerrorDetail, "Illegal BSDF dimension (%d > %d)",
| 60 |
nd, SD_MAXDIM);
| 61 |
return NULL;
| 62 |
| 63 |
if (lg < 0) {
| 64 |
st = (SDNode *)malloc(sizeof(SDNode) +
| 65 |
sizeof(st->u.t[0])*((1<<nd) - 1));
| 66 |
if (st == NULL) {
| 67 |
| 68 |
"Cannot allocate %d branch BSDF tree", 1<<nd);
| 69 |
return NULL;
| 70 |
| 71 |
memset(st->u.t, 0, sizeof(st->u.t[0])<<nd);
| 72 |
} else {
| 73 |
| 74 |
sizeof(st->u.v[0])*((1 << nd*lg) - 1));
| 75 |
if (st == NULL) {
| 76 |
| 77 |
"Cannot allocate %d BSDF leaves", 1 << nd*lg);
| 78 |
return NULL;
| 79 |
| 80 |
| 81 |
st->ndim = nd;
| 82 |
st->log2GR = lg;
| 83 |
return st;
| 84 |
| 85 |
| 86 |
/* Free an SD tree */
| 87 |
static void
| 88 |
SDfreeTre(SDNode *st)
| 89 |
| 90 |
int n;
| 91 |
| 92 |
if (st == NULL)
| 93 |
return;
| 94 |
for (n = (st->log2GR < 0) << st->ndim; n--; )
| 95 |
SDfreeTre(st->u.t[n]);
| 96 |
free(st);
| 97 |
| 98 |
| 99 |
/* Free a variable-resolution BSDF */
| 100 |
static void
| 101 |
SDFreeBTre(void *p)
| 102 |
| 103 |
SDTre *sdt = (SDTre *)p;
| 104 |
| 105 |
if (sdt == NULL)
| 106 |
return;
| 107 |
SDfreeTre(sdt->st);
| 108 |
free(sdt);
| 109 |
| 110 |
| 111 |
/* Fill branch's worth of grid values from subtree */
| 112 |
static void
| 113 |
fill_grid_branch(float *dptr, const float *sptr, int nd, int shft)
| 114 |
| 115 |
unsigned n = 1 << (shft-1);
| 116 |
| 117 |
if (!--nd) { /* end on the line */
| 118 |
memcpy(dptr, sptr, sizeof(*dptr)*n);
| 119 |
return;
| 120 |
| 121 |
while (n--) /* recurse on each slice */
| 122 |
fill_grid_branch(dptr + (n << shft*nd),
| 123 |
sptr + (n << (shft-1)*nd), nd, shft);
| 124 |
| 125 |
| 126 |
/* Get pointer at appropriate offset for the given branch */
| 127 |
static float *
| 128 |
grid_branch_start(SDNode *st, int n)
| 129 |
| 130 |
unsigned skipsiz = 1 << (st->log2GR - 1);
| 131 |
float *vptr = st->u.v;
| 132 |
int i;
| 133 |
| 134 |
for (i = st->ndim; i--; skipsiz <<= st->log2GR)
| 135 |
if (1<<i & n)
| 136 |
vptr += skipsiz;
| 137 |
return vptr;
| 138 |
| 139 |
| 140 |
/* Simplify (consolidate) a tree by flattening uniform depth regions */
| 141 |
static SDNode *
| 142 |
SDsimplifyTre(SDNode *st)
| 143 |
| 144 |
int match, n;
| 145 |
| 146 |
if (st == NULL) /* check for invalid tree */
| 147 |
return NULL;
| 148 |
if (st->log2GR >= 0) /* grid just returns unaltered */
| 149 |
return st;
| 150 |
match = 1; /* check if grids below match */
| 151 |
for (n = 0; n < 1<<st->ndim; n++) {
| 152 |
if ((st->u.t[n] = SDsimplifyTre(st->u.t[n])) == NULL)
| 153 |
return NULL; /* propogate error up call stack */
| 154 |
match &= (st->u.t[n]->log2GR == st->u.t[0]->log2GR);
| 155 |
| 156 |
if (match && (match = st->u.t[0]->log2GR) >= 0) {
| 157 |
SDNode *stn = SDnewNode(st->ndim, match + 1);
| 158 |
if (stn == NULL) /* out of memory? */
| 159 |
return st;
| 160 |
/* transfer values to new grid */
| 161 |
for (n = 1 << st->ndim; n--; )
| 162 |
fill_grid_branch(grid_branch_start(stn, n),
| 163 |
st->u.t[n]->u.v, stn->ndim, stn->log2GR);
| 164 |
SDfreeTre(st); /* free old tree */
| 165 |
st = stn; /* return new one */
| 166 |
| 167 |
return st;
| 168 |
| 169 |
| 170 |
/* Find smallest leaf in tree */
| 171 |
static double
| 172 |
SDsmallestLeaf(const SDNode *st)
| 173 |
| 174 |
if (st->log2GR < 0) { /* tree branches */
| 175 |
double lmin = 1.;
| 176 |
int n;
| 177 |
for (n = 1<<st->ndim; n--; ) {
| 178 |
double lsiz = SDsmallestLeaf(st->u.t[n]);
| 179 |
if (lsiz < lmin)
| 180 |
lmin = lsiz;
| 181 |
| 182 |
return .5*lmin;
| 183 |
| 184 |
/* leaf grid width */
| 185 |
return 1. / (double)(1 << st->log2GR);
| 186 |
| 187 |
| 188 |
/* Add up N-dimensional hypercube array values over the given box */
| 189 |
static double
| 190 |
SDiterSum(const float *va, int nd, int shft, const int *imin, const int *imax)
| 191 |
| 192 |
const unsigned skipsiz = 1 << --nd*shft;
| 193 |
double sum = .0;
| 194 |
int i;
| 195 |
| 196 |
va += *imin * skipsiz;
| 197 |
| 198 |
if (skipsiz == 1)
| 199 |
for (i = *imin; i < *imax; i++)
| 200 |
sum += *va++;
| 201 |
else
| 202 |
for (i = *imin; i < *imax; i++, va += skipsiz)
| 203 |
sum += SDiterSum(va, nd, shft, imin+1, imax+1);
| 204 |
return sum;
| 205 |
| 206 |
| 207 |
/* Average BSDF leaves over an orthotope defined by the unit hypercube */
| 208 |
static double
| 209 |
SDavgTreBox(const SDNode *st, const double *bmin, const double *bmax)
| 210 |
| 211 |
unsigned n;
| 212 |
int i;
| 213 |
| 214 |
if (!st)
| 215 |
return .0;
| 216 |
/* check box limits */
| 217 |
for (i = st->ndim; i--; ) {
| 218 |
if (bmin[i] >= 1.)
| 219 |
return .0;
| 220 |
if (bmax[i] <= 0)
| 221 |
return .0;
| 222 |
if (bmin[i] >= bmax[i])
| 223 |
return .0;
| 224 |
| 225 |
if (st->log2GR < 0) { /* iterate on subtree */
| 226 |
double sum = .0, wsum = 1e-20;
| 227 |
double sbmin[SD_MAXDIM], sbmax[SD_MAXDIM], w;
| 228 |
for (n = 1 << st->ndim; n--; ) {
| 229 |
w = 1.;
| 230 |
| 231 |
sbmin[i] = 2.*bmin[i];
| 232 |
sbmax[i] = 2.*bmax[i];
| 233 |
if (n & 1<<i) {
| 234 |
sbmin[i] -= 1.;
| 235 |
sbmax[i] -= 1.;
| 236 |
| 237 |
if (sbmin[i] < .0) sbmin[i] = .0;
| 238 |
if (sbmax[i] > 1.) sbmax[i] = 1.;
| 239 |
if (sbmin[i] >= sbmax[i]) {
| 240 |
w = .0;
| 241 |
break;
| 242 |
| 243 |
w *= sbmax[i] - sbmin[i];
| 244 |
| 245 |
if (w > 1e-10) {
| 246 |
sum += w * SDavgTreBox(st->u.t[n], sbmin, sbmax);
| 247 |
wsum += w;
| 248 |
| 249 |
| 250 |
return sum / wsum;
| 251 |
} else { /* iterate over leaves */
| 252 |
int imin[SD_MAXDIM], imax[SD_MAXDIM];
| 253 |
| 254 |
n = 1;
| 255 |
| 256 |
imin[i] = (bmin[i] <= 0) ? 0 :
| 257 |
(int)((1 << st->log2GR)*bmin[i]);
| 258 |
imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) :
| 259 |
(int)((1 << st->log2GR)*bmax[i] + .999999);
| 260 |
n *= imax[i] - imin[i];
| 261 |
| 262 |
if (n)
| 263 |
return SDiterSum(st->u.v, st->ndim,
| 264 |
st->log2GR, imin, imax) / (double)n;
| 265 |
| 266 |
return .0;
| 267 |
| 268 |
| 269 |
/* Recursive call for SDtraverseTre() */
| 270 |
static int
| 271 |
SDdotravTre(const SDNode *st, const double *pos, int cmask,
| 272 |
SDtreCallback *cf, void *cptr,
| 273 |
const double *cmin, double csiz)
| 274 |
| 275 |
int rv, rval = 0;
| 276 |
double bmin[SD_MAXDIM];
| 277 |
int i, n;
| 278 |
/* in branches? */
| 279 |
| 280 |
unsigned skipmask = 0;
| 281 |
csiz *= .5;
| 282 |
| 283 |
if (1<<i & cmask)
| 284 |
if (pos[i] < cmin[i] + csiz)
| 285 |
| 286 |
if (n & 1<<i)
| 287 |
skipmask |= 1<<n;
| 288 |
| 289 |
else
| 290 |
| 291 |
if (!(n & 1<<i))
| 292 |
skipmask |= 1<<n;
| 293 |
| 294 |
| 295 |
if (1<<n & skipmask)
| 296 |
continue;
| 297 |
| 298 |
if (1<<i & n)
| 299 |
bmin[i] = cmin[i] + csiz;
| 300 |
else
| 301 |
bmin[i] = cmin[i];
| 302 |
for (i = SD_MAXDIM; i-- > st->ndim; )
| 303 |
bmin[i] = .0;
| 304 |
| 305 |
rval += rv = SDdotravTre(st->u.t[n], pos, cmask,
| 306 |
cf, cptr, bmin, csiz);
| 307 |
if (rv < 0)
| 308 |
return rv;
| 309 |
| 310 |
} else { /* else traverse leaves */
| 311 |
int clim[SD_MAXDIM][2];
| 312 |
int cpos[SD_MAXDIM];
| 313 |
| 314 |
if (st->log2GR == 0) /* short cut */
| 315 |
return (*cf)(st->u.v[0], cmin, csiz, cptr);
| 316 |
| 317 |
csiz /= (double)(1 << st->log2GR);
| 318 |
/* assign coord. ranges */
| 319 |
| 320 |
if (1<<i & cmask) {
| 321 |
clim[i][0] = (pos[i] - cmin[i])/csiz;
| 322 |
/* check overflow from f.p. error */
| 323 |
clim[i][0] -= clim[i][0] >> st->log2GR;
| 324 |
clim[i][1] = clim[i][0] + 1;
| 325 |
} else {
| 326 |
clim[i][0] = 0;
| 327 |
clim[i][1] = 1 << st->log2GR;
| 328 |
| 329 |
/* fill in unused dimensions */
| 330 |
for (i = SD_MAXDIM; i-- > st->ndim; ) {
| 331 |
clim[i][0] = 0; clim[i][1] = 1;
| 332 |
| 333 |
#if (SD_MAXDIM == 4)
| 334 |
bmin[0] = cmin[0] + csiz*clim[0][0];
| 335 |
for (cpos[0] = clim[0][0]; cpos[0] < clim[0][1]; cpos[0]++) {
| 336 |
bmin[1] = cmin[1] + csiz*clim[1][0];
| 337 |
for (cpos[1] = clim[1][0]; cpos[1] < clim[1][1]; cpos[1]++) {
| 338 |
bmin[2] = cmin[2] + csiz*clim[2][0];
| 339 |
for (cpos[2] = clim[2][0]; cpos[2] < clim[2][1]; cpos[2]++) {
| 340 |
bmin[3] = cmin[3] + csiz*(cpos[3] = clim[3][0]);
| 341 |
n = cpos[0];
| 342 |
for (i = 1; i < st->ndim; i++)
| 343 |
n = (n << st->log2GR) + cpos[i];
| 344 |
for ( ; cpos[3] < clim[3][1]; cpos[3]++) {
| 345 |
rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr);
| 346 |
if (rv < 0)
| 347 |
return rv;
| 348 |
bmin[3] += csiz;
| 349 |
| 350 |
bmin[2] += csiz;
| 351 |
| 352 |
bmin[1] += csiz;
| 353 |
| 354 |
bmin[0] += csiz;
| 355 |
| 356 |
#else
| 357 |
_!_ "broken code segment!"
| 358 |
#endif
| 359 |
| 360 |
return rval;
| 361 |
| 362 |
| 363 |
/* Traverse a tree, visiting nodes in a slice that fits partial position */
| 364 |
static int
| 365 |
SDtraverseTre(const SDNode *st, const double *pos, int cmask,
| 366 |
SDtreCallback *cf, void *cptr)
| 367 |
| 368 |
static double czero[SD_MAXDIM];
| 369 |
int i;
| 370 |
/* check arguments */
| 371 |
if ((st == NULL) | (cf == NULL))
| 372 |
return -1;
| 373 |
| 374 |
if (1<<i & cmask && (pos[i] < 0) | (pos[i] >= 1.))
| 375 |
return -1;
| 376 |
| 377 |
return SDdotravTre(st, pos, cmask, cf, cptr, czero, 1.);
| 378 |
| 379 |
| 380 |
/* Look up tree value at the given grid position */
| 381 |
static float
| 382 |
SDlookupTre(const SDNode *st, const double *pos, double *hcube)
| 383 |
| 384 |
double spos[SD_MAXDIM];
| 385 |
int i, n, t;
| 386 |
/* initialize voxel return */
| 387 |
if (hcube) {
| 388 |
hcube[i = st->ndim] = 1.;
| 389 |
while (i--)
| 390 |
hcube[i] = .0;
| 391 |
| 392 |
/* climb the tree */
| 393 |
while (st->log2GR < 0) {
| 394 |
n = 0; /* move to appropriate branch */
| 395 |
if (hcube) hcube[st->ndim] *= .5;
| 396 |
| 397 |
spos[i] = 2.*pos[i];
| 398 |
t = (spos[i] >= 1.);
| 399 |
n |= t<<i;
| 400 |
spos[i] -= (double)t;
| 401 |
if (hcube) hcube[i] += (double)t * hcube[st->ndim];
| 402 |
| 403 |
st = st->u.t[n]; /* avoids tail recursion */
| 404 |
pos = spos;
| 405 |
| 406 |
| 407 |
return st->u.v[0];
| 408 |
n = t = 0; /* find grid array index */
| 409 |
| 410 |
n += (int)((1<<st->log2GR)*pos[i]) << t;
| 411 |
t += st->log2GR;
| 412 |
| 413 |
if (hcube) { /* compute final hypercube */
| 414 |
hcube[st->ndim] /= (double)(1<<st->log2GR);
| 415 |
| 416 |
hcube[i] += floor((1<<st->log2GR)*pos[i])*hcube[st->ndim];
| 417 |
| 418 |
return st->u.v[n]; /* no interpolation */
| 419 |
| 420 |
| 421 |
/* Query BSDF value and sample hypercube for the given vectors */
| 422 |
static float
| 423 |
SDqueryTre(const SDTre *sdt, const FVECT outVec, const FVECT inVec, double *hc)
| 424 |
| 425 |
FVECT rOutVec;
| 426 |
double gridPos[4];
| 427 |
| 428 |
switch (sdt->sidef) { /* whose side are you on? */
| 429 |
case SD_UFRONT:
| 430 |
if ((outVec[2] < 0) | (inVec[2] < 0))
| 431 |
return -1.;
| 432 |
break;
| 433 |
case SD_UBACK:
| 434 |
if ((outVec[2] > 0) | (inVec[2] > 0))
| 435 |
return -1.;
| 436 |
break;
| 437 |
case SD_XMIT:
| 438 |
if ((outVec[2] > 0) == (inVec[2] > 0))
| 439 |
return -1.;
| 440 |
break;
| 441 |
default:
| 442 |
return -1.;
| 443 |
| 444 |
/* convert vector coordinates */
| 445 |
if (sdt->st->ndim == 3) {
| 446 |
spinvector(rOutVec, outVec, zvec, -atan2(-inVec[1],-inVec[0]));
| 447 |
gridPos[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]);
| 448 |
SDdisk2square(gridPos+1, rOutVec[0], rOutVec[1]);
| 449 |
} else if (sdt->st->ndim == 4) {
| 450 |
SDdisk2square(gridPos, -inVec[0], -inVec[1]);
| 451 |
SDdisk2square(gridPos+2, outVec[0], outVec[1]);
| 452 |
} else
| 453 |
return -1.; /* should be internal error */
| 454 |
| 455 |
return SDlookupTre(sdt->st, gridPos, hc);
| 456 |
| 457 |
| 458 |
/* Compute non-diffuse component for variable-resolution BSDF */
| 459 |
static int
| 460 |
SDgetTreBSDF(float coef[SDmaxCh], const FVECT outVec,
| 461 |
const FVECT inVec, SDComponent *sdc)
| 462 |
| 463 |
| 464 |
if ((coef == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL)
| 465 |
|| sdc->dist == NULL)
| 466 |
return 0;
| 467 |
/* get nearest BSDF value */
| 468 |
coef[0] = SDqueryTre((SDTre *)sdc->dist, outVec, inVec, NULL);
| 469 |
return (coef[0] >= 0); /* monochromatic for now */
| 470 |
| 471 |
| 472 |
/* Callback to build cumulative distribution using SDtraverseTre() */
| 473 |
static int
| 474 |
build_scaffold(float val, const double *cmin, double csiz, void *cptr)
| 475 |
| 476 |
SDdistScaffold *sp = (SDdistScaffold *)cptr;
| 477 |
int wid = csiz*(double)iwmax + .5;
| 478 |
bitmask_t bmin[2], bmax[2];
| 479 |
| 480 |
cmin += sp->nic; /* skip to output coords */
| 481 |
if (wid < sp->wmin) /* new minimum width? */
| 482 |
sp->wmin = wid;
| 483 |
if (wid > sp->wmax) /* new maximum? */
| 484 |
sp->wmax = wid;
| 485 |
if (sp->alen >= sp->nall) { /* need more space? */
| 486 |
struct outdir_s *ndarr;
| 487 |
sp->nall += 1024;
| 488 |
ndarr = (struct outdir_s *)realloc(sp->darr,
| 489 |
sizeof(struct outdir_s)*sp->nall);
| 490 |
if (ndarr == NULL) {
| 491 |
| 492 |
"Cannot grow scaffold to %u entries", sp->nall);
| 493 |
return -1; /* abort build */
| 494 |
| 495 |
sp->darr = ndarr;
| 496 |
| 497 |
/* find Hilbert entry index */
| 498 |
bmin[0] = cmin[0]*(double)iwmax + .5;
| 499 |
bmin[1] = cmin[1]*(double)iwmax + .5;
| 500 |
bmax[0] = bmin[0] + wid-1;
| 501 |
bmax[1] = bmin[1] + wid-1;
| 502 |
hilbert_box_vtx(2, sizeof(bitmask_t), iwbits, 1, bmin, bmax);
| 503 |
sp->darr[sp->alen].hent = hilbert_c2i(2, iwbits, bmin);
| 504 |
sp->darr[sp->alen].wid = wid;
| 505 |
sp->darr[sp->alen].bsdf = val;
| 506 |
sp->alen++; /* on to the next entry */
| 507 |
return 0;
| 508 |
| 509 |
| 510 |
/* Scaffold comparison function for qsort -- ascending Hilbert index */
| 511 |
static int
| 512 |
sscmp(const void *p1, const void *p2)
| 513 |
| 514 |
unsigned h1 = (*(const struct outdir_s *)p1).hent;
| 515 |
unsigned h2 = (*(const struct outdir_s *)p2).hent;
| 516 |
| 517 |
if (h1 > h2)
| 518 |
return 1;
| 519 |
if (h1 < h2)
| 520 |
return -1;
| 521 |
return 0;
| 522 |
| 523 |
| 524 |
/* Create a new cumulative distribution for the given input direction */
| 525 |
static SDTreCDst *
| 526 |
make_cdist(const SDTre *sdt, const double *pos)
| 527 |
| 528 |
SDdistScaffold myScaffold;
| 529 |
SDTreCDst *cd;
| 530 |
struct outdir_s *sp;
| 531 |
double scale, cursum;
| 532 |
int i;
| 533 |
/* initialize scaffold */
| 534 |
myScaffold.wmin = iwmax;
| 535 |
myScaffold.wmax = 0;
| 536 |
myScaffold.nic = sdt->st->ndim - 2;
| 537 |
myScaffold.alen = 0;
| 538 |
myScaffold.nall = 512;
| 539 |
myScaffold.darr = (struct outdir_s *)malloc(sizeof(struct outdir_s) *
| 540 |
myScaffold.nall);
| 541 |
if (myScaffold.darr == NULL)
| 542 |
return NULL;
| 543 |
/* grow the distribution */
| 544 |
if (SDtraverseTre(sdt->st, pos, (1<<myScaffold.nic)-1,
| 545 |
&build_scaffold, &myScaffold) < 0) {
| 546 |
free(myScaffold.darr);
| 547 |
return NULL;
| 548 |
| 549 |
/* allocate result holder */
| 550 |
cd = (SDTreCDst *)malloc(sizeof(SDTreCDst) +
| 551 |
sizeof(cd->carr[0])*myScaffold.alen);
| 552 |
if (cd == NULL) {
| 553 |
| 554 |
"Cannot allocate %u entry cumulative distribution",
| 555 |
myScaffold.alen);
| 556 |
| 557 |
return NULL;
| 558 |
| 559 |
cd->isodist = (myScaffold.nic == 1);
| 560 |
/* sort the distribution */
| 561 |
qsort(myScaffold.darr, cd->calen = myScaffold.alen,
| 562 |
sizeof(struct outdir_s), &sscmp);
| 563 |
| 564 |
/* record input range */
| 565 |
scale = myScaffold.wmin / (double)iwmax;
| 566 |
for (i = myScaffold.nic; i--; ) {
| 567 |
cd->clim[i][0] = floor(pos[i]/scale) * scale;
| 568 |
cd->clim[i][1] = cd->clim[i][0] + scale;
| 569 |
| 570 |
if (cd->isodist) { /* avoid issue in SDqueryTreProjSA() */
| 571 |
cd->clim[1][0] = cd->clim[0][0];
| 572 |
cd->clim[1][1] = cd->clim[0][1];
| 573 |
| 574 |
cd->max_psa = myScaffold.wmax / (double)iwmax;
| 575 |
cd->max_psa *= cd->max_psa * M_PI;
| 576 |
cd->sidef = sdt->sidef;
| 577 |
cd->cTotal = 1e-20; /* compute directional total */
| 578 |
sp = myScaffold.darr;
| 579 |
for (i = myScaffold.alen; i--; sp++)
| 580 |
cd->cTotal += sp->bsdf * (double)sp->wid * sp->wid;
| 581 |
cursum = .0; /* go back and get cumulative values */
| 582 |
scale = (double)cumlmax / cd->cTotal;
| 583 |
| 584 |
for (i = 0; i < cd->calen; i++, sp++) {
| 585 |
cd->carr[i].hndx = sp->hent;
| 586 |
cd->carr[i].cuml = scale*cursum + .5;
| 587 |
cursum += sp->bsdf * (double)sp->wid * sp->wid;
| 588 |
| 589 |
cd->carr[i].hndx = ~0; /* make final entry */
| 590 |
cd->carr[i].cuml = cumlmax;
| 591 |
cd->cTotal *= M_PI/(double)iwmax/iwmax;
| 592 |
/* all done, clean up and return */
| 593 |
| 594 |
return cd;
| 595 |
| 596 |
| 597 |
/* Find or allocate a cumulative distribution for the given incoming vector */
| 598 |
const SDCDst *
| 599 |
SDgetTreCDist(const FVECT inVec, SDComponent *sdc)
| 600 |
| 601 |
const SDTre *sdt;
| 602 |
double inCoord[2];
| 603 |
int vflags;
| 604 |
int i;
| 605 |
SDTreCDst *cd, *cdlast;
| 606 |
| 607 |
if ((inVec == NULL) | (sdc == NULL) ||
| 608 |
(sdt = (SDTre *)sdc->dist) == NULL)
| 609 |
return NULL;
| 610 |
if (sdt->st->ndim == 3) /* isotropic BSDF? */
| 611 |
inCoord[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]);
| 612 |
| 613 |
SDdisk2square(inCoord, -inVec[0], -inVec[1]);
| 614 |
else
| 615 |
return NULL; /* should be internal error */
| 616 |
cdlast = NULL; /* check for direction in cache list */
| 617 |
for (cd = (SDTreCDst *)sdc->cdList; cd != NULL;
| 618 |
cdlast = cd, cd = (SDTreCDst *)cd->next) {
| 619 |
for (i = sdt->st->ndim - 2; i--; )
| 620 |
if ((cd->clim[i][0] > inCoord[i]) |
| 621 |
(inCoord[i] >= cd->clim[i][1]))
| 622 |
break;
| 623 |
if (i < 0)
| 624 |
break; /* means we have a match */
| 625 |
| 626 |
if (cd == NULL) /* need to create new entry? */
| 627 |
cdlast = cd = make_cdist(sdt, inCoord);
| 628 |
if (cdlast != NULL) { /* move entry to head of cache list */
| 629 |
cdlast->next = cd->next;
| 630 |
cd->next = sdc->cdList;
| 631 |
sdc->cdList = (SDCDst *)cd;
| 632 |
| 633 |
return (SDCDst *)cd; /* ready to go */
| 634 |
| 635 |
| 636 |
/* Query solid angle for vector(s) */
| 637 |
static SDError
| 638 |
SDqueryTreProjSA(double *psa, const FVECT v1, const RREAL *v2,
| 639 |
int qflags, SDComponent *sdc)
| 640 |
| 641 |
double myPSA[2];
| 642 |
| 643 |
if ((psa == NULL) | (v1 == NULL) | (sdc == NULL) ||
| 644 |
sdc->dist == NULL)
| 645 |
return SDEargument;
| 646 |
/* get projected solid angle(s) */
| 647 |
if (v2 != NULL) {
| 648 |
const SDTre *sdt = (SDTre *)sdc->dist;
| 649 |
double hcube[SD_MAXDIM];
| 650 |
if (SDqueryTre(sdt, v1, v2, hcube) < 0) {
| 651 |
strcpy(SDerrorDetail, "Bad call to SDqueryTreProjSA");
| 652 |
return SDEinternal;
| 653 |
| 654 |
myPSA[0] = hcube[sdt->st->ndim];
| 655 |
myPSA[1] = myPSA[0] *= myPSA[0] * M_PI;
| 656 |
} else {
| 657 |
const SDTreCDst *cd = (const SDTreCDst *)SDgetTreCDist(v1, sdc);
| 658 |
if (cd == NULL)
| 659 |
return SDEmemory;
| 660 |
myPSA[0] = M_PI * (cd->clim[0][1] - cd->clim[0][0]) *
| 661 |
(cd->clim[1][1] - cd->clim[1][0]);
| 662 |
myPSA[1] = cd->max_psa;
| 663 |
| 664 |
switch (qflags) { /* record based on flag settings */
| 665 |
case SDqueryVal:
| 666 |
*psa = myPSA[0];
| 667 |
break;
| 668 |
case SDqueryMax:
| 669 |
if (myPSA[1] > *psa)
| 670 |
*psa = myPSA[1];
| 671 |
break;
| 672 |
case SDqueryMin+SDqueryMax:
| 673 |
if (myPSA[1] > psa[1])
| 674 |
psa[1] = myPSA[1];
| 675 |
/* fall through */
| 676 |
case SDqueryMin:
| 677 |
if (myPSA[0] < psa[0])
| 678 |
psa[0] = myPSA[0];
| 679 |
break;
| 680 |
| 681 |
return SDEnone;
| 682 |
| 683 |
| 684 |
/* Sample cumulative distribution */
| 685 |
static SDError
| 686 |
SDsampTreCDist(FVECT ioVec, double randX, const SDCDst *cdp)
| 687 |
| 688 |
const unsigned nBitsC = 4*sizeof(bitmask_t);
| 689 |
const unsigned nExtraBits = 8*(sizeof(bitmask_t)-sizeof(unsigned));
| 690 |
const SDTreCDst *cd = (const SDTreCDst *)cdp;
| 691 |
const unsigned target = randX*cumlmax;
| 692 |
bitmask_t hndx, hcoord[2];
| 693 |
double gpos[3], rotangle;
| 694 |
int i, iupper, ilower;
| 695 |
| 696 |
if ((ioVec == NULL) | (cd == NULL))
| 697 |
return SDEargument;
| 698 |
if (ioVec[2] > 0) {
| 699 |
if (!(cd->sidef & SD_UFRONT))
| 700 |
return SDEargument;
| 701 |
} else if (!(cd->sidef & SD_UBACK))
| 702 |
return SDEargument;
| 703 |
/* binary search to find position */
| 704 |
ilower = 0; iupper = cd->calen;
| 705 |
while ((i = (iupper + ilower) >> 1) != ilower)
| 706 |
if ((long)target >= (long)cd->carr[i].cuml)
| 707 |
ilower = i;
| 708 |
else
| 709 |
iupper = i;
| 710 |
/* localize random position */
| 711 |
randX = (randX*cumlmax - cd->carr[ilower].cuml) /
| 712 |
(double)(cd->carr[iupper].cuml - cd->carr[ilower].cuml);
| 713 |
/* index in longer Hilbert curve */
| 714 |
hndx = (randX*cd->carr[iupper].hndx + (1.-randX)*cd->carr[ilower].hndx)
| 715 |
* (double)((bitmask_t)1 << nExtraBits);
| 716 |
/* convert Hilbert index to vector */
| 717 |
hilbert_i2c(2, nBitsC, hndx, hcoord);
| 718 |
for (i = 2; i--; )
| 719 |
gpos[i] = ((double)hcoord[i] + rand()*(1./(RAND_MAX+.5))) /
| 720 |
(double)((bitmask_t)1 << nBitsC);
| 721 |
SDsquare2disk(gpos, gpos[0], gpos[1]);
| 722 |
/* compute Z-coordinate */
| 723 |
gpos[2] = 1. - gpos[0]*gpos[0] - gpos[1]*gpos[1];
| 724 |
if (gpos[2] > 0) /* paranoia, I hope */
| 725 |
gpos[2] = sqrt(gpos[2]);
| 726 |
/* emit from back? */
| 727 |
if (ioVec[2] > 0 ^ cd->sidef != SD_XMIT)
| 728 |
gpos[2] = -gpos[2];
| 729 |
if (cd->isodist) { /* rotate isotropic result */
| 730 |
rotangle = atan2(-ioVec[1],-ioVec[0]);
| 731 |
VCOPY(ioVec, gpos);
| 732 |
spinvector(ioVec, ioVec, zvec, rotangle);
| 733 |
} else
| 734 |
VCOPY(ioVec, gpos);
| 735 |
return SDEnone;
| 736 |
| 737 |
| 738 |
/* Advance pointer to the next non-white character in the string (or nul) */
| 739 |
static int
| 740 |
next_token(char **spp)
| 741 |
| 742 |
while (isspace(**spp))
| 743 |
++*spp;
| 744 |
return **spp;
| 745 |
| 746 |
| 747 |
/* Advance pointer past matching token (or any token if c==0) */
| 748 |
#define eat_token(spp,c) (next_token(spp)==(c) ^ !(c) ? *(*(spp))++ : 0)
| 749 |
| 750 |
/* Count words from this point in string to '}' */
| 751 |
static int
| 752 |
count_values(char *cp)
| 753 |
| 754 |
int n = 0;
| 755 |
| 756 |
while (next_token(&cp) != '}' && *cp) {
| 757 |
while (!isspace(*cp) & (*cp != ',') & (*cp != '}'))
| 758 |
if (!*++cp)
| 759 |
break;
| 760 |
++n;
| 761 |
eat_token(&cp, ',');
| 762 |
| 763 |
return n;
| 764 |
| 765 |
| 766 |
/* Load an array of real numbers, returning total */
| 767 |
static int
| 768 |
load_values(char **spp, float *va, int n)
| 769 |
| 770 |
float *v = va;
| 771 |
char *svnext;
| 772 |
| 773 |
while (n-- > 0 && (svnext = fskip(*spp)) != NULL) {
| 774 |
*v++ = atof(*spp);
| 775 |
*spp = svnext;
| 776 |
eat_token(spp, ',');
| 777 |
| 778 |
return v - va;
| 779 |
| 780 |
| 781 |
/* Load BSDF tree data */
| 782 |
static SDNode *
| 783 |
load_tree_data(char **spp, int nd)
| 784 |
| 785 |
SDNode *st;
| 786 |
int n;
| 787 |
| 788 |
if (!eat_token(spp, '{')) {
| 789 |
strcpy(SDerrorDetail, "Missing '{' in tensor tree");
| 790 |
return NULL;
| 791 |
| 792 |
if (next_token(spp) == '{') { /* tree branches */
| 793 |
st = SDnewNode(nd, -1);
| 794 |
if (st == NULL)
| 795 |
return NULL;
| 796 |
for (n = 0; n < 1<<nd; n++)
| 797 |
if ((st->u.t[n] = load_tree_data(spp, nd)) == NULL) {
| 798 |
SDfreeTre(st);
| 799 |
return NULL;
| 800 |
| 801 |
} else { /* else load value grid */
| 802 |
int bsiz;
| 803 |
n = count_values(*spp); /* see how big the grid is */
| 804 |
for (bsiz = 0; bsiz < 8*sizeof(size_t); bsiz += nd)
| 805 |
if (1<<bsiz == n)
| 806 |
break;
| 807 |
if (bsiz >= 8*sizeof(size_t)) {
| 808 |
strcpy(SDerrorDetail, "Illegal value count in tensor tree");
| 809 |
return NULL;
| 810 |
| 811 |
st = SDnewNode(nd, bsiz/nd);
| 812 |
if (st == NULL)
| 813 |
return NULL;
| 814 |
if (load_values(spp, st->u.v, n) != n) {
| 815 |
strcpy(SDerrorDetail, "Real format error in tensor tree");
| 816 |
SDfreeTre(st);
| 817 |
return NULL;
| 818 |
| 819 |
| 820 |
if (!eat_token(spp, '}')) {
| 821 |
strcpy(SDerrorDetail, "Missing '}' in tensor tree");
| 822 |
SDfreeTre(st);
| 823 |
return NULL;
| 824 |
| 825 |
| 826 |
return st;
| 827 |
| 828 |
| 829 |
/* Compute min. proj. solid angle and max. direct hemispherical scattering */
| 830 |
static SDError
| 831 |
get_extrema(SDSpectralDF *df)
| 832 |
| 833 |
SDNode *st = (*(SDTre *)df->comp[0].dist).st;
| 834 |
double stepWidth, dhemi, bmin[4], bmax[4];
| 835 |
| 836 |
stepWidth = SDsmallestLeaf(st);
| 837 |
df->minProjSA = M_PI*stepWidth*stepWidth;
| 838 |
if (stepWidth < .03125)
| 839 |
stepWidth = .03125; /* 1/32 resolution good enough */
| 840 |
df->maxHemi = .0;
| 841 |
if (st->ndim == 3) { /* isotropic BSDF */
| 842 |
bmin[1] = bmin[2] = .0;
| 843 |
bmax[1] = bmax[2] = 1.;
| 844 |
for (bmin[0] = .0; bmin[0] < .5-FTINY; bmin[0] += stepWidth) {
| 845 |
bmax[0] = bmin[0] + stepWidth;
| 846 |
dhemi = SDavgTreBox(st, bmin, bmax);
| 847 |
if (dhemi > df->maxHemi)
| 848 |
df->maxHemi = dhemi;
| 849 |
| 850 |
} else if (st->ndim == 4) { /* anisotropic BSDF */
| 851 |
bmin[2] = bmin[3] = .0;
| 852 |
bmax[2] = bmax[3] = 1.;
| 853 |
for (bmin[0] = .0; bmin[0] < 1.-FTINY; bmin[0] += stepWidth) {
| 854 |
| 855 |
for (bmin[1] = .0; bmin[1] < 1.-FTINY; bmin[1] += stepWidth) {
| 856 |
bmax[1] = bmin[1] + stepWidth;
| 857 |
| 858 |
| 859 |
| 860 |
| 861 |
| 862 |
} else
| 863 |
return SDEinternal;
| 864 |
/* correct hemispherical value */
| 865 |
df->maxHemi *= M_PI;
| 866 |
return SDEnone;
| 867 |
| 868 |
| 869 |
/* Load BSDF distribution for this wavelength */
| 870 |
static SDError
| 871 |
load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim)
| 872 |
| 873 |
SDSpectralDF *df;
| 874 |
SDTre *sdt;
| 875 |
char *sdata;
| 876 |
int i;
| 877 |
/* allocate BSDF component */
| 878 |
sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection"));
| 879 |
if (!sdata)
| 880 |
return SDEnone;
| 881 |
| 882 |
* Remember that front and back are reversed from WINDOW 6 orientations
| 883 |
| 884 |
if (!strcasecmp(sdata, "Transmission")) {
| 885 |
if (sd->tf != NULL)
| 886 |
SDfreeSpectralDF(sd->tf);
| 887 |
if ((sd->tf = SDnewSpectralDF(1)) == NULL)
| 888 |
return SDEmemory;
| 889 |
df = sd->tf;
| 890 |
} else if (!strcasecmp(sdata, "Reflection Front")) {
| 891 |
if (sd->rb != NULL) /* note back-front reversal */
| 892 |
SDfreeSpectralDF(sd->rb);
| 893 |
if ((sd->rb = SDnewSpectralDF(1)) == NULL)
| 894 |
return SDEmemory;
| 895 |
df = sd->rb;
| 896 |
} else if (!strcasecmp(sdata, "Reflection Back")) {
| 897 |
if (sd->rf != NULL) /* note front-back reversal */
| 898 |
SDfreeSpectralDF(sd->rf);
| 899 |
if ((sd->rf = SDnewSpectralDF(1)) == NULL)
| 900 |
return SDEmemory;
| 901 |
df = sd->rf;
| 902 |
} else
| 903 |
return SDEnone;
| 904 |
/* XXX should also check "ScatteringDataType" for consistency? */
| 905 |
/* get angle bases */
| 906 |
sdata = ezxml_txt(ezxml_child(wdb,"AngleBasis"));
| 907 |
if (!sdata || strcasecmp(sdata, "LBNL/Shirley-Chiu")) {
| 908 |
sprintf(SDerrorDetail, "%s angle basis for BSDF '%s'",
| 909 |
!sdata ? "Missing" : "Unsupported", sd->name);
| 910 |
return !sdata ? SDEformat : SDEsupport;
| 911 |
| 912 |
/* allocate BSDF tree */
| 913 |
sdt = (SDTre *)malloc(sizeof(SDTre));
| 914 |
if (sdt == NULL)
| 915 |
return SDEmemory;
| 916 |
if (df == sd->rf)
| 917 |
sdt->sidef = SD_UFRONT;
| 918 |
else if (df == sd->rb)
| 919 |
sdt->sidef = SD_UBACK;
| 920 |
else
| 921 |
sdt->sidef = SD_XMIT;
| 922 |
sdt->st = NULL;
| 923 |
df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */
| 924 |
df->comp[0].dist = sdt;
| 925 |
df->comp[0].func = &SDhandleTre;
| 926 |
/* read BSDF data */
| 927 |
sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData"));
| 928 |
if (!sdata || !next_token(&sdata)) {
| 929 |
sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'",
| 930 |
sd->name);
| 931 |
return SDEformat;
| 932 |
| 933 |
sdt->st = load_tree_data(&sdata, ndim);
| 934 |
if (sdt->st == NULL)
| 935 |
return SDEformat;
| 936 |
if (next_token(&sdata)) { /* check for unconsumed characters */
| 937 |
| 938 |
"Extra characters at end of ScatteringData in '%s'",
| 939 |
sd->name);
| 940 |
return SDEformat;
| 941 |
| 942 |
/* flatten branches where possible */
| 943 |
sdt->st = SDsimplifyTre(sdt->st);
| 944 |
| 945 |
return SDEinternal;
| 946 |
return get_extrema(df); /* compute global quantities */
| 947 |
| 948 |
| 949 |
/* Find minimum value in tree */
| 950 |
static float
| 951 |
SDgetTreMin(const SDNode *st)
| 952 |
| 953 |
float vmin = FHUGE;
| 954 |
int n;
| 955 |
| 956 |
| 957 |
| 958 |
float v = SDgetTreMin(st->u.t[n]);
| 959 |
if (v < vmin)
| 960 |
vmin = v;
| 961 |
| 962 |
} else {
| 963 |
for (n = 1<<(st->ndim*st->log2GR); n--; )
| 964 |
if (st->u.v[n] < vmin)
| 965 |
vmin = st->u.v[n];
| 966 |
| 967 |
return vmin;
| 968 |
| 969 |
| 970 |
/* Subtract the given value from all tree nodes */
| 971 |
static void
| 972 |
SDsubtractTreVal(SDNode *st, float val)
| 973 |
| 974 |
int n;
| 975 |
| 976 |
| 977 |
| 978 |
SDsubtractTreVal(st->u.t[n], val);
| 979 |
} else {
| 980 |
| 981 |
if ((st->u.v[n] -= val) < 0)
| 982 |
st->u.v[n] = .0f;
| 983 |
| 984 |
| 985 |
| 986 |
/* Subtract minimum value from BSDF */
| 987 |
static double
| 988 |
subtract_min(SDNode *st)
| 989 |
| 990 |
float vmin;
| 991 |
/* be sure to skip unused portion */
| 992 |
| 993 |
int n;
| 994 |
vmin = 1./M_PI;
| 995 |
| 996 |
for (n = 0; n < 8; n += 2) {
| 997 |
| 998 |
if (v < vmin)
| 999 |
vmin = v;
| 1000 |
| 1001 |
} else if (st->log2GR) {
| 1002 |
for (n = 1 << (3*st->log2GR - 1); n--; )
| 1003 |
| 1004 |
vmin = st->u.v[n];
| 1005 |
} else
| 1006 |
vmin = st->u.v[0];
| 1007 |
} else /* anisotropic covers entire tree */
| 1008 |
vmin = SDgetTreMin(st);
| 1009 |
| 1010 |
if (vmin <= FTINY)
| 1011 |
return .0;
| 1012 |
| 1013 |
SDsubtractTreVal(st, vmin);
| 1014 |
| 1015 |
return M_PI * vmin; /* return hemispherical value */
| 1016 |
| 1017 |
| 1018 |
/* Extract and separate diffuse portion of BSDF */
| 1019 |
static void
| 1020 |
extract_diffuse(SDValue *dv, SDSpectralDF *df)
| 1021 |
| 1022 |
int n;
| 1023 |
| 1024 |
if (df == NULL || df->ncomp <= 0) {
| 1025 |
dv->spec = c_dfcolor;
| 1026 |
dv->cieY = .0;
| 1027 |
return;
| 1028 |
| 1029 |
dv->spec = df->comp[0].cspec[0];
| 1030 |
dv->cieY = subtract_min((*(SDTre *)df->comp[0].dist).st);
| 1031 |
/* in case of multiple components */
| 1032 |
for (n = df->ncomp; --n; ) {
| 1033 |
double ymin = subtract_min((*(SDTre *)df->comp[n].dist).st);
| 1034 |
c_cmix(&dv->spec, dv->cieY, &dv->spec, ymin, &df->comp[n].cspec[0]);
| 1035 |
dv->cieY += ymin;
| 1036 |
| 1037 |
df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */
| 1038 |
/* make sure everything is set */
| 1039 |
c_ccvt(&dv->spec, C_CSXY+C_CSSPEC);
| 1040 |
| 1041 |
| 1042 |
/* Load a variable-resolution BSDF tree from an open XML file */
| 1043 |
SDError
| 1044 |
SDloadTre(SDData *sd, ezxml_t wtl)
| 1045 |
| 1046 |
SDError ec;
| 1047 |
ezxml_t wld, wdb;
| 1048 |
int rank;
| 1049 |
char *txt;
| 1050 |
/* basic checks and tensor rank */
| 1051 |
txt = ezxml_txt(ezxml_child(ezxml_child(wtl,
| 1052 |
"DataDefinition"), "IncidentDataStructure"));
| 1053 |
if (txt == NULL || !*txt) {
| 1054 |
| 1055 |
"BSDF \"%s\": missing IncidentDataStructure",
| 1056 |
sd->name);
| 1057 |
return SDEformat;
| 1058 |
| 1059 |
if (!strcasecmp(txt, "TensorTree3"))
| 1060 |
rank = 3;
| 1061 |
else if (!strcasecmp(txt, "TensorTree4"))
| 1062 |
rank = 4;
| 1063 |
else {
| 1064 |
| 1065 |
"BSDF \"%s\": unsupported IncidentDataStructure",
| 1066 |
sd->name);
| 1067 |
return SDEsupport;
| 1068 |
| 1069 |
/* load BSDF components */
| 1070 |
for (wld = ezxml_child(wtl, "WavelengthData");
| 1071 |
wld != NULL; wld = wld->next) {
| 1072 |
if (strcasecmp(ezxml_txt(ezxml_child(wld,"Wavelength")),
| 1073 |
"Visible"))
| 1074 |
continue; /* just visible for now */
| 1075 |
for (wdb = ezxml_child(wld, "WavelengthDataBlock");
| 1076 |
wdb != NULL; wdb = wdb->next)
| 1077 |
if ((ec = load_bsdf_data(sd, wdb, rank)) != SDEnone)
| 1078 |
return ec;
| 1079 |
| 1080 |
/* separate diffuse components */
| 1081 |
extract_diffuse(&sd->rLambFront, sd->rf);
| 1082 |
extract_diffuse(&sd->rLambBack, sd->rb);
| 1083 |
extract_diffuse(&sd->tLamb, sd->tf);
| 1084 |
/* return success */
| 1085 |
return SDEnone;
| 1086 |
| 1087 |
| 1088 |
/* Variable resolution BSDF methods */
| 1089 |
SDFunc SDhandleTre = {
| 1090 |
&SDgetTreBSDF,
| 1091 |
&SDqueryTreProjSA,
| 1092 |
&SDgetTreCDist,
| 1093 |
&SDsampTreCDist,
| 1094 |
&SDFreeBTre,
| 1095 |
