root/Development/ray/src/common/bsdf_t.c
Revision 3.44 - (view) (download) (annotate) - [select for diffs]
Sun Aug 23 00:56:00 2015 UTC (10 years, 4 months ago) by greg
CVS Tags: rad5R0, rad5R1
Changes since 3.43: +3 -1 lines
Diff to previous 3.43 , to selected 3.19
Added comments for placement of mutex locks to support multi-threading
Revision 3.43 - (view) (download) (annotate) - [select for diffs]
Sat Aug 1 23:27:04 2015 UTC (10 years, 4 months ago) by greg
Changes since 3.42: +2 -2 lines
Diff to previous 3.42 , to selected 3.19
Revision 3.42 - (view) (download) (annotate) - [select for diffs]
Sat Apr 25 19:08:29 2015 UTC (10 years, 8 months ago) by greg
Changes since 3.41: +3 -3 lines
Diff to previous 3.41 , to selected 3.19
Fixed missing assignment of diffuse color
Fri Apr 24 21:02:14 2015 UTC (10 years, 8 months ago) by greg
Changes since 3.40: +5 -5 lines
Diff to previous 3.40 , to selected 3.19
Minor change should not affect behavior
Revision 3.40 - (view) (download) (annotate) - [select for diffs]
Mon Apr 6 18:28:35 2015 UTC (10 years, 8 months ago) by greg
Changes since 3.39: +9 -13 lines
Diff to previous 3.39 , to selected 3.19
Minor optimization
Mon Apr 6 16:00:15 2015 UTC (10 years, 8 months ago) by greg
Changes since 3.38: +4 -4 lines
Diff to previous 3.38 , to selected 3.19
Increased minimum threshold for diffuse scattering extraction to 1%
Sun Apr 5 06:02:43 2015 UTC (10 years, 8 months ago) by greg
Changes since 3.37: +19 -25 lines
Diff to previous 3.37 , to selected 3.19
Improved minimum value clamping
Sun Apr 5 01:32:01 2015 UTC (10 years, 8 months ago) by greg
Changes since 3.36: +335 -82 lines
Diff to previous 3.36 , to selected 3.19
Added color rendering to tensor tree and minor fixes to Klems color rendering
Tue Nov 11 23:33:21 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2P2
Changes since 3.35: +2 -2 lines
Diff to previous 3.35 , to selected 3.19
Fixed segmentation error thanks to Roland Schregle
Mon Mar 24 04:00:45 2014 UTC (11 years, 9 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Diff to previous 3.34 , to selected 3.19
Minor optimizations should not affect results
Sun Mar 23 19:24:11 2014 UTC (11 years, 9 months ago) by greg
Changes since 3.33: +3 -4 lines
Diff to previous 3.33 , to selected 3.19
Eliminated unnecessary copy
Fri Mar 21 17:49:53 2014 UTC (11 years, 9 months ago) by greg
Changes since 3.32: +3 -2 lines
Diff to previous 3.32 , to selected 3.19
Added protection against negative BSDF values
Mon Mar 17 01:53:51 2014 UTC (11 years, 9 months ago) by greg
Changes since 3.31: +4 -4 lines
Diff to previous 3.31 , to selected 3.19
Minor modification should not affect results
Thu Aug 8 05:26:56 2013 UTC (12 years, 4 months ago) by greg
Changes since 3.30: +5 -3 lines
Diff to previous 3.30 , to selected 3.19
Fixed bug in sampling of isotropic tensor trees from surface normal direction
Thu Jul 4 15:14:45 2013 UTC (12 years, 5 months ago) by greg
Changes since 3.29: +2 -2 lines
Diff to previous 3.29 , to selected 3.19
Added extra checks where projected solid angle is undefined
Thu Jul 4 01:24:17 2013 UTC (12 years, 5 months ago) by greg
Changes since 3.28: +7 -5 lines
Diff to previous 3.28 , to selected 3.19
Fixed bug in last bug fix
Thu Jul 4 01:22:47 2013 UTC (12 years, 5 months ago) by greg
Changes since 3.27: +2 -2 lines
Diff to previous 3.27 , to selected 3.19
Removed last memory error caused by stray ray samples
Tue Apr 23 17:25:23 2013 UTC (12 years, 8 months ago) by greg
Changes since 3.26: +5 -2 lines
Diff to previous 3.26 , to selected 3.19
Fixed bug in accounting of diffuse transmitted component
Sat Sep 29 21:18:20 2012 UTC (13 years, 3 months ago) by greg
Changes since 3.25: +2 -2 lines
Diff to previous 3.25 , to selected 3.19
Bug fix in reciprocity code -- caused infinite loop
Mon Sep 10 18:06:08 2012 UTC (13 years, 3 months ago) by greg
Changes since 3.24: +21 -11 lines
Diff to previous 3.24 , to selected 3.19
Hopeful fixes to tensor tree reciprocity and orientation
Sun Sep 2 15:33:15 2012 UTC (13 years, 3 months ago) by greg
Changes since 3.23: +82 -22 lines
Diff to previous 3.23 , to selected 3.19
Mon Aug 22 18:21:05 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 3.22 , to selected 3.19
Fixed bug in Hilbert conversion
Mon Aug 22 14:19:49 2011 UTC (14 years, 4 months ago) by greg
Changes since 3.21: +6 -3 lines
Diff to previous 3.21 , to selected 3.19
Fixed performance issue caused by last change
Mon Aug 22 05:48:39 2011 UTC (14 years, 4 months ago) by greg
Changes since 3.20: +9 -5 lines
Diff to previous 3.20 , to selected 3.19
Fixed floating point epsilon errors in position branch testing
Sun Aug 21 22:38:12 2011 UTC (14 years, 4 months ago) by greg
Changes since 3.19: +3 -3 lines
Diff to previous 3.19
Minor improvements to direct specular sampling
Revision 3.19 - (view) (download) (annotate) - [selected]
Thu Jul 7 15:25:09 2011 UTC (14 years, 5 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18
Fixed bug for MING32 and non-square matrices, allowing multiple angle bases
Tue Jun 28 21:13:46 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.17: +1 -3 lines
Diff to previous 3.17 , to selected 3.19
Minor compile fixes
Thu Jun 9 17:09:39 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.16: +2 -1 lines
Diff to previous 3.16 , to selected 3.19
Fixes for Windows and bug fix in bsdf_m.c
Sun Jun 5 20:27:14 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.15: +20 -13 lines
Diff to previous 3.15 , to selected 3.19
Fixed comments and potential bug in BSDF tree traversal
Fri Jun 3 18:12:58 2011 UTC (14 years, 6 months ago) by greg
Changes since 3.14: +43 -26 lines
Diff to previous 3.14 , to selected 3.19
Fixed bugs in variable-resolution isotropic BSDFs
Wed Jun 1 05:21:18 2011 UTC (14 years, 7 months ago) by greg
Changes since 3.13: +6 -6 lines
Diff to previous 3.13 , to selected 3.19
Bug fix in tree consolidation routine
Wed Jun 1 00:29:40 2011 UTC (14 years, 7 months ago) by greg
Changes since 3.12: +10 -5 lines
Diff to previous 3.12 , to selected 3.19
Sun May 1 16:34:37 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.11: +25 -18 lines
Diff to previous 3.11 , to selected 3.19
Minor fixes and improvements
Thu Apr 28 17:46:25 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.10: +4 -13 lines
Diff to previous 3.10 , to selected 3.19
Minor fixes
Thu Apr 28 04:05:11 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.9: +32 -17 lines
Diff to previous 3.9 , to selected 3.19
First tested version
Wed Apr 27 23:05:51 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.8: +14 -14 lines
Diff to previous 3.8 , to selected 3.19
First test of variable-res BSDFs
Wed Apr 27 20:05:15 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.7: +2 -2 lines
Diff to previous 3.7 , to selected 3.19
Fixed typo
Wed Apr 27 20:03:25 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.6: +467 -32 lines
Diff to previous 3.6 , to selected 3.19
Initial untested variable-resolution BSDF
Sun Apr 24 19:39:21 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.5: +437 -31 lines
Diff to previous 3.5 , to selected 3.19
Partial implementation of variable-resolution BSDFs
Tue Apr 19 21:31:22 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.4: +61 -7 lines
Diff to previous 3.4 , to selected 3.19
Fixed interface for determining BSDF solid angles
Sat Feb 19 01:48:59 2011 UTC (14 years, 10 months ago) by greg
Changes since 3.3: +2 -2 lines
Diff to previous 3.3 , to selected 3.19
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 02:41:55 2011 UTC (14 years, 10 months ago) by greg
Changes since 3.2: +4 -2 lines
Diff to previous 3.2 , to selected 3.19
Minor fixes and adjustments
Fri Feb 18 00:41:44 2011 UTC (14 years, 10 months ago) by greg
Changes since 3.1: +3 -0 lines
Diff to previous 3.1 , to selected 3.19
Added missing RCS tags
Fri Feb 18 00:40:25 2011 UTC (14 years, 10 months ago) by greg
Diff to selected 3.19
