Fixed segmentation error thanks to Roland Schregle
Minor optimizations should not affect results
Eliminated unnecessary copy
Added protection against negative BSDF values
Minor modification should not affect results
Fixed bug in sampling of isotropic tensor trees from surface normal direction
Added extra checks where projected solid angle is undefined
Fixed bug in last bug fix
Removed last memory error caused by stray ray samples
Fixed bug in accounting of diffuse transmitted component
Bug fix in reciprocity code -- caused infinite loop
Hopeful fixes to tensor tree reciprocity and orientation
Fixed bug in Hilbert conversion
Fixed performance issue caused by last change
Fixed floating point epsilon errors in position branch testing
Minor improvements to direct specular sampling
Fixed bug for MING32 and non-square matrices, allowing multiple angle bases
Minor compile fixes
Fixes for Windows and bug fix in bsdf_m.c
Fixed comments and potential bug in BSDF tree traversal
Fixed bugs in variable-resolution isotropic BSDFs
Bug fix in tree consolidation routine
Minor fixes and improvements
Minor fixes
First tested version
First test of variable-res BSDFs
Fixed typo
Initial untested variable-resolution BSDF
Partial implementation of variable-resolution BSDFs
Fixed interface for determining BSDF solid angles
Minor changes and fixes -- first working version of BSDF material
Minor fixes and adjustments
Added missing RCS tags
