--- ray/src/common/bsdf_t.c 2011/04/27 20:05:15 3.8 +++ ray/src/common/bsdf_t.c 2013/07/04 01:22:47 3.28 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_t.c,v 3.8 2011/04/27 20:05:15 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_t.c,v 3.28 2013/07/04 01:22:47 greg Exp $"; #endif /* * bsdf_t.c @@ -10,6 +10,7 @@ static const char RCSid[] = "$Id: bsdf_t.c,v 3.8 2011/ * */ +#define _USE_MATH_DEFINES #include "rtio.h" #include #include @@ -25,13 +26,18 @@ typedef int SDtreCallback(float val, const double *cmi /* reference width maximum (1.0) */ static const unsigned iwbits = sizeof(unsigned)*4; -static const unsigned iwmax = (1<<(sizeof(unsigned)*4))-1; +static const unsigned iwmax = 1<<(sizeof(unsigned)*4); /* maximum cumulative value */ static const unsigned cumlmax = ~0; + /* constant z-vector */ +static const FVECT zvec = {.0, .0, 1.}; + /* quantization value */ +static double quantum = 1./256.; /* Struct used for our distribution-building callback */ typedef struct { - int nic; /* number of input coordinates */ + short nic; /* number of input coordinates */ + short rev; /* reversing query */ unsigned alen; /* current array length */ unsigned nall; /* number of allocated entries */ unsigned wmin; /* minimum square size so far */ @@ -61,20 +67,20 @@ SDnewNode(int nd, int lg) if (lg < 0) { st = (SDNode *)malloc(sizeof(SDNode) + sizeof(st->u.t[0])*((1<u.t, 0, sizeof(st->u.t[0])<u.v[0])*((1 << nd*lg) - 1)); - - if (st == NULL) { - if (lg < 0) + if (st == NULL) { sprintf(SDerrorDetail, "Cannot allocate %d branch BSDF tree", 1<u.t, 0, sizeof(st->u.t[0])<u.v[0])*((1 << nd*lg) - 1)); + if (st == NULL) { sprintf(SDerrorDetail, "Cannot allocate %d BSDF leaves", 1 << nd*lg); - return NULL; + return NULL; + } } st->ndim = nd; st->log2GR = lg; @@ -85,13 +91,13 @@ SDnewNode(int nd, int lg) static void SDfreeTre(SDNode *st) { - int i; + int n; if (st == NULL) return; - for (i = (st->log2GR < 0) << st->ndim; i--; ) - SDfreeTre(st->u.t[i]); - free((void *)st); + for (n = (st->log2GR < 0) << st->ndim; n--; ) + SDfreeTre(st->u.t[n]); + free(st); } /* Free a variable-resolution BSDF */ @@ -125,13 +131,13 @@ fill_grid_branch(float *dptr, const float *sptr, int n static float * grid_branch_start(SDNode *st, int n) { - unsigned skipsiz = 1 << st->log2GR; + unsigned skipsiz = 1 << (st->log2GR - 1); float *vptr = st->u.v; int i; for (i = st->ndim; i--; skipsiz <<= st->log2GR) if (1<> 1; + vptr += skipsiz; return vptr; } @@ -151,14 +157,14 @@ SDsimplifyTre(SDNode *st) return NULL; /* propogate error up call stack */ match &= (st->u.t[n]->log2GR == st->u.t[0]->log2GR); } - if (match && st->u.t[0]->log2GR >= 0) { - SDNode *stn = SDnewNode(st->ndim, st->u.t[0]->log2GR + 1); + if (match && (match = st->u.t[0]->log2GR) >= 0) { + SDNode *stn = SDnewNode(st->ndim, match + 1); if (stn == NULL) /* out of memory? */ return st; /* transfer values to new grid */ for (n = 1 << st->ndim; n--; ) fill_grid_branch(grid_branch_start(stn, n), - st->u.t[n]->u.v, st->ndim, st->log2GR); + st->u.t[n]->u.v, stn->ndim, stn->log2GR); SDfreeTre(st); /* free old tree */ st = stn; /* return new one */ } @@ -187,17 +193,18 @@ SDsmallestLeaf(const SDNode *st) static double SDiterSum(const float *va, int nd, int shft, const int *imin, const int *imax) { - const unsigned skipsiz = 1 << nd*shft; + const unsigned skipsiz = 1 << --nd*shft; double sum = .0; int i; - + + va += *imin * skipsiz; + if (skipsiz == 1) for (i = *imin; i < *imax; i++) - sum += va[i]; + sum += *va++; else - for (i = *imin; i < *imax; i++) - sum += SDiterSum(va + i*skipsiz, - nd-1, shft, imin+1, imax+1); + for (i = *imin; i < *imax; i++, va += skipsiz) + sum += SDiterSum(va, nd, shft, imin+1, imax+1); return sum; } @@ -205,7 +212,6 @@ SDiterSum(const float *va, int nd, int shft, const int static double SDavgTreBox(const SDNode *st, const double *bmin, const double *bmax) { - int imin[SD_MAXDIM], imax[SD_MAXDIM]; unsigned n; int i; @@ -215,7 +221,7 @@ SDavgTreBox(const SDNode *st, const double *bmin, cons for (i = st->ndim; i--; ) { if (bmin[i] >= 1.) return .0; - if (bmax[i] <= .0) + if (bmax[i] <= 0) return .0; if (bmin[i] >= bmax[i]) return .0; @@ -223,7 +229,6 @@ SDavgTreBox(const SDNode *st, const double *bmin, cons if (st->log2GR < 0) { /* iterate on subtree */ double sum = .0, wsum = 1e-20; double sbmin[SD_MAXDIM], sbmax[SD_MAXDIM], w; - for (n = 1 << st->ndim; n--; ) { w = 1.; for (i = st->ndim; i--; ) { @@ -235,6 +240,10 @@ SDavgTreBox(const SDNode *st, const double *bmin, cons } if (sbmin[i] < .0) sbmin[i] = .0; if (sbmax[i] > 1.) sbmax[i] = 1.; + if (sbmin[i] >= sbmax[i]) { + w = .0; + break; + } w *= sbmax[i] - sbmin[i]; } if (w > 1e-10) { @@ -243,19 +252,22 @@ SDavgTreBox(const SDNode *st, const double *bmin, cons } } return sum / wsum; + } else { /* iterate over leaves */ + int imin[SD_MAXDIM], imax[SD_MAXDIM]; + + n = 1; + for (i = st->ndim; i--; ) { + imin[i] = (bmin[i] <= 0) ? 0 : + (int)((1 << st->log2GR)*bmin[i]); + imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) : + (int)((1 << st->log2GR)*bmax[i] + .999999); + n *= imax[i] - imin[i]; + } + if (n) + return SDiterSum(st->u.v, st->ndim, + st->log2GR, imin, imax) / (double)n; } - n = 1; /* iterate over leaves */ - for (i = st->ndim; i--; ) { - imin[i] = (bmin[i] <= 0) ? 0 - : (int)((1 << st->log2GR)*bmin[i]); - imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) - : (int)((1 << st->log2GR)*bmax[i] + .999999); - n *= imax[i] - imin[i]; - } - if (!n) - return .0; - - return SDiterSum(st->u.v, st->ndim, st->log2GR, imin, imax) / (double)n; + return .0; } /* Recursive call for SDtraverseTre() */ @@ -270,18 +282,19 @@ SDdotravTre(const SDNode *st, const double *pos, int c /* in branches? */ if (st->log2GR < 0) { unsigned skipmask = 0; - csiz *= .5; for (i = st->ndim; i--; ) if (1<ndim; n--; ) + for (n = 1 << st->ndim; n--; ) { if (n & 1<ndim; n--; ) + for (n = 1 << st->ndim; n--; ) { if (!(n & 1<ndim; n--; ) { if (1<log2GR; } - /* fill in unused dimensions */ - for (i = SD_MAXDIM; i-- > st->ndim; ) { - clim[i][0] = 0; clim[i][1] = 1; - } #if (SD_MAXDIM == 4) bmin[0] = cmin[0] + csiz*clim[0][0]; for (cpos[0] = clim[0][0]; cpos[0] < clim[0][1]; cpos[0]++) { bmin[1] = cmin[1] + csiz*clim[1][0]; for (cpos[1] = clim[1][0]; cpos[1] < clim[1][1]; cpos[1]++) { bmin[2] = cmin[2] + csiz*clim[2][0]; - for (cpos[2] = clim[2][0]; cpos[2] < clim[2][1]; cpos[2]++) { - bmin[3] = cmin[3] + csiz*(cpos[3] = clim[3][0]); + if (st->ndim == 3) { + cpos[2] = clim[2][0]; n = cpos[0]; - for (i = 1; i < st->ndim; i++) + for (i = 1; i < 3; i++) n = (n << st->log2GR) + cpos[i]; - for ( ; cpos[3] < clim[3][1]; cpos[3]++) { + for ( ; cpos[2] < clim[2][1]; cpos[2]++) { rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr); if (rv < 0) return rv; - bmin[3] += csiz; + bmin[2] += csiz; } - bmin[2] += csiz; + } else { + for (cpos[2] = clim[2][0]; cpos[2] < clim[2][1]; cpos[2]++) { + bmin[3] = cmin[3] + csiz*(cpos[3] = clim[3][0]); + n = cpos[0]; + for (i = 1; i < 4; i++) + n = (n << st->log2GR) + cpos[i]; + for ( ; cpos[3] < clim[3][1]; cpos[3]++) { + rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr); + if (rv < 0) + return rv; + bmin[3] += csiz; + } + bmin[2] += csiz; + } } bmin[1] += csiz; } @@ -411,29 +433,41 @@ SDlookupTre(const SDNode *st, const double *pos, doubl static float SDqueryTre(const SDTre *sdt, const FVECT outVec, const FVECT inVec, double *hc) { - static const FVECT zvec = {.0, .0, 1.}; - FVECT rOutVec; - double gridPos[4]; + const RREAL *vtmp; + FVECT rOutVec; + double gridPos[4]; switch (sdt->sidef) { /* whose side are you on? */ - case SD_UFRONT: + case SD_FREFL: if ((outVec[2] < 0) | (inVec[2] < 0)) return -1.; break; - case SD_UBACK: + case SD_BREFL: if ((outVec[2] > 0) | (inVec[2] > 0)) return -1.; break; - case SD_XMIT: - if ((outVec[2] > 0) == (inVec[2] > 0)) + case SD_FXMIT: + if (outVec[2] > 0) { + if (inVec[2] > 0) + return -1.; + vtmp = outVec; outVec = inVec; inVec = vtmp; + } else if (inVec[2] < 0) return -1.; break; + case SD_BXMIT: + if (inVec[2] > 0) { + if (outVec[2] > 0) + return -1.; + vtmp = outVec; outVec = inVec; inVec = vtmp; + } else if (outVec[2] < 0) + return -1.; + break; default: return -1.; } /* convert vector coordinates */ if (sdt->st->ndim == 3) { - spinvector(rOutVec, outVec, zvec, -atan2(inVec[1],inVec[0])); + spinvector(rOutVec, outVec, zvec, -atan2(-inVec[1],-inVec[0])); gridPos[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]); SDdisk2square(gridPos+1, rOutVec[0], rOutVec[1]); } else if (sdt->st->ndim == 4) { @@ -465,27 +499,37 @@ build_scaffold(float val, const double *cmin, double c { SDdistScaffold *sp = (SDdistScaffold *)cptr; int wid = csiz*(double)iwmax + .5; + double revcmin[2]; bitmask_t bmin[2], bmax[2]; - cmin += sp->nic; /* skip to output coords */ + if (sp->rev) { /* need to reverse sense? */ + revcmin[0] = 1. - cmin[0] - csiz; + revcmin[1] = 1. - cmin[1] - csiz; + cmin = revcmin; + } else { + cmin += sp->nic; /* else skip to output coords */ + } if (wid < sp->wmin) /* new minimum width? */ sp->wmin = wid; if (wid > sp->wmax) /* new maximum? */ sp->wmax = wid; if (sp->alen >= sp->nall) { /* need more space? */ struct outdir_s *ndarr; - sp->nall += 8192; + sp->nall += 1024; ndarr = (struct outdir_s *)realloc(sp->darr, sizeof(struct outdir_s)*sp->nall); - if (ndarr == NULL) + if (ndarr == NULL) { + sprintf(SDerrorDetail, + "Cannot grow scaffold to %u entries", sp->nall); return -1; /* abort build */ + } sp->darr = ndarr; } /* find Hilbert entry index */ bmin[0] = cmin[0]*(double)iwmax + .5; bmin[1] = cmin[1]*(double)iwmax + .5; - bmax[0] = bmin[0] + wid; - bmax[1] = bmin[1] + wid; + bmax[0] = bmin[0] + wid-1; + bmax[1] = bmin[1] + wid-1; hilbert_box_vtx(2, sizeof(bitmask_t), iwbits, 1, bmin, bmax); sp->darr[sp->alen].hent = hilbert_c2i(2, iwbits, bmin); sp->darr[sp->alen].wid = wid; @@ -498,15 +542,23 @@ build_scaffold(float val, const double *cmin, double c static int sscmp(const void *p1, const void *p2) { - return (int)((*(const struct outdir_s *)p1).hent - - (*(const struct outdir_s *)p2).hent); + unsigned h1 = (*(const struct outdir_s *)p1).hent; + unsigned h2 = (*(const struct outdir_s *)p2).hent; + + if (h1 > h2) + return 1; + if (h1 < h2) + return -1; + return 0; } /* Create a new cumulative distribution for the given input direction */ static SDTreCDst * -make_cdist(const SDTre *sdt, const double *pos) +make_cdist(const SDTre *sdt, const double *invec, int rev) { SDdistScaffold myScaffold; + double pos[4]; + int cmask; SDTreCDst *cd; struct outdir_s *sp; double scale, cursum; @@ -515,14 +567,20 @@ make_cdist(const SDTre *sdt, const double *pos) myScaffold.wmin = iwmax; myScaffold.wmax = 0; myScaffold.nic = sdt->st->ndim - 2; + myScaffold.rev = rev; myScaffold.alen = 0; - myScaffold.nall = 8192; + myScaffold.nall = 512; myScaffold.darr = (struct outdir_s *)malloc(sizeof(struct outdir_s) * myScaffold.nall); if (myScaffold.darr == NULL) return NULL; + /* set up traversal */ + cmask = (1<st, pos, (1<st, pos, cmask, &build_scaffold, &myScaffold) < 0) { free(myScaffold.darr); return NULL; @@ -531,9 +589,13 @@ make_cdist(const SDTre *sdt, const double *pos) cd = (SDTreCDst *)malloc(sizeof(SDTreCDst) + sizeof(cd->carr[0])*myScaffold.alen); if (cd == NULL) { + sprintf(SDerrorDetail, + "Cannot allocate %u entry cumulative distribution", + myScaffold.alen); free(myScaffold.darr); return NULL; } + cd->isodist = (myScaffold.nic == 1); /* sort the distribution */ qsort(myScaffold.darr, cd->calen = myScaffold.alen, sizeof(struct outdir_s), &sscmp); @@ -541,12 +603,19 @@ make_cdist(const SDTre *sdt, const double *pos) /* record input range */ scale = myScaffold.wmin / (double)iwmax; for (i = myScaffold.nic; i--; ) { - cd->clim[i][0] = floor(pos[i]/scale) * scale; + cd->clim[i][0] = floor(pos[i+2*rev]/scale) * scale; cd->clim[i][1] = cd->clim[i][0] + scale; } + if (cd->isodist) { /* avoid issue in SDqueryTreProjSA() */ + cd->clim[1][0] = cd->clim[0][0]; + cd->clim[1][1] = cd->clim[0][1]; + } cd->max_psa = myScaffold.wmax / (double)iwmax; cd->max_psa *= cd->max_psa * M_PI; - cd->sidef = sdt->sidef; + if (rev) + cd->sidef = (sdt->sidef==SD_BXMIT) ? SD_FXMIT : SD_BXMIT; + else + cd->sidef = sdt->sidef; cd->cTotal = 1e-20; /* compute directional total */ sp = myScaffold.darr; for (i = myScaffold.alen; i--; sp++) @@ -573,22 +642,52 @@ SDgetTreCDist(const FVECT inVec, SDComponent *sdc) { const SDTre *sdt; double inCoord[2]; - int vflags; int i; + int mode; SDTreCDst *cd, *cdlast; /* check arguments */ if ((inVec == NULL) | (sdc == NULL) || (sdt = (SDTre *)sdc->dist) == NULL) return NULL; - if (sdt->st->ndim == 3) /* isotropic BSDF? */ + switch (mode = sdt->sidef) { /* check direction */ + case SD_FREFL: + if (inVec[2] < 0) + return NULL; + break; + case SD_BREFL: + if (inVec[2] > 0) + return NULL; + break; + case SD_FXMIT: + if (inVec[2] < 0) + mode = SD_BXMIT; + break; + case SD_BXMIT: + if (inVec[2] > 0) + mode = SD_FXMIT; + break; + default: + return NULL; + } + if (sdt->st->ndim == 3) { /* isotropic BSDF? */ + if (mode != sdt->sidef) /* XXX unhandled reciprocity */ + return &SDemptyCD; inCoord[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]); - else if (sdt->st->ndim == 4) - SDdisk2square(inCoord, -inVec[0], -inVec[1]); - else + } else if (sdt->st->ndim == 4) { + if (mode != sdt->sidef) /* use reciprocity? */ + SDdisk2square(inCoord, inVec[0], inVec[1]); + else + SDdisk2square(inCoord, -inVec[0], -inVec[1]); + } else return NULL; /* should be internal error */ + /* quantize to avoid f.p. errors */ + for (i = sdt->st->ndim - 2; i--; ) + inCoord[i] = floor(inCoord[i]/quantum)*quantum + .5*quantum; cdlast = NULL; /* check for direction in cache list */ for (cd = (SDTreCDst *)sdc->cdList; cd != NULL; - cdlast = cd, cd = (SDTreCDst *)cd->next) { + cdlast = cd, cd = cd->next) { + if (cd->sidef != mode) + continue; for (i = sdt->st->ndim - 2; i--; ) if ((cd->clim[i][0] > inCoord[i]) | (inCoord[i] >= cd->clim[i][1])) @@ -597,10 +696,10 @@ SDgetTreCDist(const FVECT inVec, SDComponent *sdc) break; /* means we have a match */ } if (cd == NULL) /* need to create new entry? */ - cdlast = cd = make_cdist(sdt, inCoord); + cdlast = cd = make_cdist(sdt, inCoord, mode != sdt->sidef); if (cdlast != NULL) { /* move entry to head of cache list */ cdlast->next = cd->next; - cd->next = sdc->cdList; + cd->next = (SDTreCDst *)sdc->cdList; sdc->cdList = (SDCDst *)cd; } return (SDCDst *)cd; /* ready to go */ @@ -629,7 +728,7 @@ SDqueryTreProjSA(double *psa, const FVECT v1, const RR } else { const SDTreCDst *cd = (const SDTreCDst *)SDgetTreCDist(v1, sdc); if (cd == NULL) - return SDEmemory; + cd = &SDemptyCD; myPSA[0] = M_PI * (cd->clim[0][1] - cd->clim[0][0]) * (cd->clim[1][1] - cd->clim[1][0]); myPSA[1] = cd->max_psa; @@ -663,20 +762,22 @@ SDsampTreCDist(FVECT ioVec, double randX, const SDCDst const SDTreCDst *cd = (const SDTreCDst *)cdp; const unsigned target = randX*cumlmax; bitmask_t hndx, hcoord[2]; - double gpos[3]; + double gpos[3], rotangle; int i, iupper, ilower; /* check arguments */ if ((ioVec == NULL) | (cd == NULL)) return SDEargument; + if (!cd->sidef) + return SDEnone; /* XXX should never happen */ if (ioVec[2] > 0) { - if (!(cd->sidef & SD_UFRONT)) + if ((cd->sidef != SD_FREFL) & (cd->sidef != SD_FXMIT)) return SDEargument; - } else if (!(cd->sidef & SD_UBACK)) + } else if ((cd->sidef != SD_BREFL) & (cd->sidef != SD_BXMIT)) return SDEargument; /* binary search to find position */ ilower = 0; iupper = cd->calen; while ((i = (iupper + ilower) >> 1) != ilower) - if ((long)target >= (long)cd->carr[i].cuml) + if (target >= cd->carr[i].cuml) ilower = i; else iupper = i; @@ -697,9 +798,14 @@ SDsampTreCDist(FVECT ioVec, double randX, const SDCDst if (gpos[2] > 0) /* paranoia, I hope */ gpos[2] = sqrt(gpos[2]); /* emit from back? */ - if (ioVec[2] > 0 ^ cd->sidef != SD_XMIT) + if ((cd->sidef == SD_BREFL) | (cd->sidef == SD_FXMIT)) gpos[2] = -gpos[2]; - VCOPY(ioVec, gpos); + if (cd->isodist) { /* rotate isotropic result */ + rotangle = atan2(-ioVec[1],-ioVec[0]); + VCOPY(ioVec, gpos); + spinvector(ioVec, ioVec, zvec, rotangle); + } else + VCOPY(ioVec, gpos); return SDEnone; } @@ -712,19 +818,21 @@ next_token(char **spp) return **spp; } +/* Advance pointer past matching token (or any token if c==0) */ +#define eat_token(spp,c) (next_token(spp)==(c) ^ !(c) ? *(*(spp))++ : 0) + /* Count words from this point in string to '}' */ static int count_values(char *cp) { int n = 0; - while (next_token(&cp) != '}') { - if (*cp == '{') - return -1; - while (*cp && !isspace(*cp)) - ++cp; + while (next_token(&cp) != '}' && *cp) { + while (!isspace(*cp) & (*cp != ',') & (*cp != '}')) + if (!*++cp) + break; ++n; - cp += (next_token(&cp) == ','); + eat_token(&cp, ','); } return n; } @@ -739,7 +847,7 @@ load_values(char **spp, float *va, int n) while (n-- > 0 && (svnext = fskip(*spp)) != NULL) { *v++ = atof(*spp); *spp = svnext; - *spp += (next_token(spp) == ','); + eat_token(spp, ','); } return v - va; } @@ -751,11 +859,10 @@ load_tree_data(char **spp, int nd) SDNode *st; int n; - if (next_token(spp) != '{') { + if (!eat_token(spp, '{')) { strcpy(SDerrorDetail, "Missing '{' in tensor tree"); return NULL; } - ++*spp; /* in tree, now */ if (next_token(spp) == '{') { /* tree branches */ st = SDnewNode(nd, -1); if (st == NULL) @@ -768,11 +875,7 @@ load_tree_data(char **spp, int nd) } else { /* else load value grid */ int bsiz; n = count_values(*spp); /* see how big the grid is */ - if (n <= 0) { - strcpy(SDerrorDetail, "Bad tensor tree data"); - return NULL; - } - for (bsiz = 0; bsiz < 8*sizeof(size_t)-1; bsiz += nd) + for (bsiz = 0; bsiz < 8*sizeof(size_t); bsiz += nd) if (1<= 8*sizeof(size_t)) { @@ -788,13 +891,12 @@ load_tree_data(char **spp, int nd) return NULL; } } - if (next_token(spp) != '}') { + if (!eat_token(spp, '}')) { strcpy(SDerrorDetail, "Missing '}' in tensor tree"); SDfreeTre(st); return NULL; } - ++*spp; /* walk past close and return */ - *spp += (next_token(spp) == ','); + eat_token(spp, ','); return st; } @@ -806,6 +908,8 @@ get_extrema(SDSpectralDF *df) double stepWidth, dhemi, bmin[4], bmax[4]; stepWidth = SDsmallestLeaf(st); + if (quantum > stepWidth) /* adjust quantization factor */ + quantum = stepWidth; df->minProjSA = M_PI*stepWidth*stepWidth; if (stepWidth < .03125) stepWidth = .03125; /* 1/32 resolution good enough */ @@ -845,7 +949,6 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim) SDSpectralDF *df; SDTre *sdt; char *sdata; - int i; /* allocate BSDF component */ sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection")); if (!sdata) @@ -853,20 +956,26 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim) /* * Remember that front and back are reversed from WINDOW 6 orientations */ - if (!strcasecmp(sdata, "Transmission")) { + if (!strcasecmp(sdata, "Transmission Front")) { + if (sd->tb != NULL) + SDfreeSpectralDF(sd->tb); + if ((sd->tb = SDnewSpectralDF(1)) == NULL) + return SDEmemory; + df = sd->tb; + } else if (!strcasecmp(sdata, "Transmission Back")) { if (sd->tf != NULL) SDfreeSpectralDF(sd->tf); if ((sd->tf = SDnewSpectralDF(1)) == NULL) return SDEmemory; df = sd->tf; } else if (!strcasecmp(sdata, "Reflection Front")) { - if (sd->rb != NULL) /* note back-front reversal */ + if (sd->rb != NULL) SDfreeSpectralDF(sd->rb); if ((sd->rb = SDnewSpectralDF(1)) == NULL) return SDEmemory; df = sd->rb; } else if (!strcasecmp(sdata, "Reflection Back")) { - if (sd->rf != NULL) /* note front-back reversal */ + if (sd->rf != NULL) SDfreeSpectralDF(sd->rf); if ((sd->rf = SDnewSpectralDF(1)) == NULL) return SDEmemory; @@ -886,11 +995,13 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim) if (sdt == NULL) return SDEmemory; if (df == sd->rf) - sdt->sidef = SD_UFRONT; + sdt->sidef = SD_FREFL; else if (df == sd->rb) - sdt->sidef = SD_UBACK; - else - sdt->sidef = SD_XMIT; + sdt->sidef = SD_BREFL; + else if (df == sd->tf) + sdt->sidef = SD_FXMIT; + else /* df == sd->tb */ + sdt->sidef = SD_BXMIT; sdt->st = NULL; df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */ df->comp[0].dist = sdt; @@ -922,7 +1033,7 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim) static float SDgetTreMin(const SDNode *st) { - float vmin = 1./M_PI; + float vmin = FHUGE; int n; if (st->log2GR < 0) { @@ -950,7 +1061,8 @@ SDsubtractTreVal(SDNode *st, float val) SDsubtractTreVal(st->u.t[n], val); } else { for (n = 1<<(st->ndim*st->log2GR); n--; ) - st->u.v[n] -= val; + if ((st->u.v[n] -= val) < 0) + st->u.v[n] = .0f; } } @@ -960,15 +1072,21 @@ subtract_min(SDNode *st) { float vmin; /* be sure to skip unused portion */ - if ((st->ndim == 3) & (st->log2GR < 0)) { - float v; - int i; + if (st->ndim == 3) { + int n; vmin = 1./M_PI; - for (i = 0; i < 4; i++) { - v = SDgetTreMin(st->u.t[i]); - if (v < vmin) - vmin = v; - } + if (st->log2GR < 0) { + for (n = 0; n < 8; n += 2) { + float v = SDgetTreMin(st->u.t[n]); + if (v < vmin) + vmin = v; + } + } else if (st->log2GR) { + for (n = 1 << (3*st->log2GR - 1); n--; ) + if (st->u.v[n] < vmin) + vmin = st->u.v[n]; + } else + vmin = st->u.v[0]; } else /* anisotropic covers entire tree */ vmin = SDgetTreMin(st); @@ -992,7 +1110,7 @@ extract_diffuse(SDValue *dv, SDSpectralDF *df) return; } dv->spec = df->comp[0].cspec[0]; - dv->cieY = subtract_min((*(SDTre *)df->comp[n].dist).st); + dv->cieY = subtract_min((*(SDTre *)df->comp[0].dist).st); /* in case of multiple components */ for (n = df->ncomp; --n; ) { double ymin = subtract_min((*(SDTre *)df->comp[n].dist).st); @@ -1045,7 +1163,10 @@ SDloadTre(SDData *sd, ezxml_t wtl) /* separate diffuse components */ extract_diffuse(&sd->rLambFront, sd->rf); extract_diffuse(&sd->rLambBack, sd->rb); - extract_diffuse(&sd->tLamb, sd->tf); + if (sd->tf != NULL) + extract_diffuse(&sd->tLamb, sd->tf); + if (sd->tb != NULL) + extract_diffuse(&sd->tLamb, sd->tb); /* return success */ return SDEnone; }
