--- ray/src/common/bsdf_t.c 2011/04/24 19:39:21 3.6 +++ ray/src/common/bsdf_t.c 2011/08/22 14:19:49 3.22 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_t.c,v 3.6 2011/04/24 19:39:21 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_t.c,v 3.22 2011/08/22 14:19:49 greg Exp $"; #endif /* * bsdf_t.c @@ -10,6 +10,7 @@ static const char RCSid[] = "$Id: bsdf_t.c,v 3.6 2011/ * */ +#define _USE_MATH_DEFINES #include "rtio.h" #include #include @@ -24,15 +25,22 @@ typedef int SDtreCallback(float val, const double *cmi double csiz, void *cptr); /* reference width maximum (1.0) */ +static const unsigned iwbits = sizeof(unsigned)*4; static const unsigned iwmax = (1<<(sizeof(unsigned)*4))-1; + /* maximum cumulative value */ +static const unsigned cumlmax = ~0; + /* constant z-vector */ +static const FVECT zvec = {.0, .0, 1.}; + /* quantization value */ +static double quantum = 1./256.; /* Struct used for our distribution-building callback */ typedef struct { - int wmin; /* minimum square size so far */ - int wmax; /* maximum square size */ int nic; /* number of input coordinates */ - int alen; /* current array length */ - int nall; /* number of allocated entries */ + unsigned alen; /* current array length */ + unsigned nall; /* number of allocated entries */ + unsigned wmin; /* minimum square size so far */ + unsigned wmax; /* maximum square size */ struct outdir_s { unsigned hent; /* entering Hilbert index */ int wid; /* this square size */ @@ -57,21 +65,21 @@ SDnewNode(int nd, int lg) } if (lg < 0) { st = (SDNode *)malloc(sizeof(SDNode) + - ((1<u.t[0])); - if (st != NULL) - memset(st->u.t, 0, sizeof(st->u.t[0])<u.v[0])); - - if (st == NULL) { - if (lg < 0) + sizeof(st->u.t[0])*((1<u.t, 0, sizeof(st->u.t[0])<u.v[0])*((1 << nd*lg) - 1)); + if (st == NULL) { sprintf(SDerrorDetail, "Cannot allocate %d BSDF leaves", 1 << nd*lg); - return NULL; + return NULL; + } } st->ndim = nd; st->log2GR = lg; @@ -82,13 +90,13 @@ SDnewNode(int nd, int lg) static void SDfreeTre(SDNode *st) { - int i; + int n; if (st == NULL) return; - for (i = (st->log2GR < 0) << st->ndim; i--; ) - SDfreeTre(st->u.t[i]); - free((void *)st); + for (n = (st->log2GR < 0) << st->ndim; n--; ) + SDfreeTre(st->u.t[n]); + free(st); } /* Free a variable-resolution BSDF */ @@ -103,23 +111,99 @@ SDFreeBTre(void *p) free(sdt); } +/* Fill branch's worth of grid values from subtree */ +static void +fill_grid_branch(float *dptr, const float *sptr, int nd, int shft) +{ + unsigned n = 1 << (shft-1); + + if (!--nd) { /* end on the line */ + memcpy(dptr, sptr, sizeof(*dptr)*n); + return; + } + while (n--) /* recurse on each slice */ + fill_grid_branch(dptr + (n << shft*nd), + sptr + (n << (shft-1)*nd), nd, shft); +} + +/* Get pointer at appropriate offset for the given branch */ +static float * +grid_branch_start(SDNode *st, int n) +{ + unsigned skipsiz = 1 << (st->log2GR - 1); + float *vptr = st->u.v; + int i; + + for (i = st->ndim; i--; skipsiz <<= st->log2GR) + if (1<log2GR >= 0) /* grid just returns unaltered */ + return st; + match = 1; /* check if grids below match */ + for (n = 0; n < 1<ndim; n++) { + if ((st->u.t[n] = SDsimplifyTre(st->u.t[n])) == NULL) + return NULL; /* propogate error up call stack */ + match &= (st->u.t[n]->log2GR == st->u.t[0]->log2GR); + } + if (match && (match = st->u.t[0]->log2GR) >= 0) { + SDNode *stn = SDnewNode(st->ndim, match + 1); + if (stn == NULL) /* out of memory? */ + return st; + /* transfer values to new grid */ + for (n = 1 << st->ndim; n--; ) + fill_grid_branch(grid_branch_start(stn, n), + st->u.t[n]->u.v, stn->ndim, stn->log2GR); + SDfreeTre(st); /* free old tree */ + st = stn; /* return new one */ + } + return st; +} + +/* Find smallest leaf in tree */ +static double +SDsmallestLeaf(const SDNode *st) +{ + if (st->log2GR < 0) { /* tree branches */ + double lmin = 1.; + int n; + for (n = 1<ndim; n--; ) { + double lsiz = SDsmallestLeaf(st->u.t[n]); + if (lsiz < lmin) + lmin = lsiz; + } + return .5*lmin; + } + /* leaf grid width */ + return 1. / (double)(1 << st->log2GR); +} + /* Add up N-dimensional hypercube array values over the given box */ static double -SDiterSum(const float *va, int nd, int siz, const int *imin, const int *imax) +SDiterSum(const float *va, int nd, int shft, const int *imin, const int *imax) { + const unsigned skipsiz = 1 << --nd*shft; double sum = .0; - unsigned skipsiz = 1; int i; - - for (i = nd; --i > 0; ) - skipsiz *= siz; + + va += *imin * skipsiz; + if (skipsiz == 1) for (i = *imin; i < *imax; i++) - sum += va[i]; + sum += *va++; else - for (i = *imin; i < *imax; i++) - sum += SDiterSum(va + i*skipsiz, - nd-1, siz, imin+1, imax+1); + for (i = *imin; i < *imax; i++, va += skipsiz) + sum += SDiterSum(va, nd, shft, imin+1, imax+1); return sum; } @@ -127,7 +211,6 @@ SDiterSum(const float *va, int nd, int siz, const int static double SDavgTreBox(const SDNode *st, const double *bmin, const double *bmax) { - int imin[SD_MAXDIM], imax[SD_MAXDIM]; unsigned n; int i; @@ -137,7 +220,7 @@ SDavgTreBox(const SDNode *st, const double *bmin, cons for (i = st->ndim; i--; ) { if (bmin[i] >= 1.) return .0; - if (bmax[i] <= .0) + if (bmax[i] <= 0) return .0; if (bmin[i] >= bmax[i]) return .0; @@ -145,7 +228,6 @@ SDavgTreBox(const SDNode *st, const double *bmin, cons if (st->log2GR < 0) { /* iterate on subtree */ double sum = .0, wsum = 1e-20; double sbmin[SD_MAXDIM], sbmax[SD_MAXDIM], w; - for (n = 1 << st->ndim; n--; ) { w = 1.; for (i = st->ndim; i--; ) { @@ -157,6 +239,10 @@ SDavgTreBox(const SDNode *st, const double *bmin, cons } if (sbmin[i] < .0) sbmin[i] = .0; if (sbmax[i] > 1.) sbmax[i] = 1.; + if (sbmin[i] >= sbmax[i]) { + w = .0; + break; + } w *= sbmax[i] - sbmin[i]; } if (w > 1e-10) { @@ -165,20 +251,22 @@ SDavgTreBox(const SDNode *st, const double *bmin, cons } } return sum / wsum; + } else { /* iterate over leaves */ + int imin[SD_MAXDIM], imax[SD_MAXDIM]; + + n = 1; + for (i = st->ndim; i--; ) { + imin[i] = (bmin[i] <= 0) ? 0 : + (int)((1 << st->log2GR)*bmin[i]); + imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) : + (int)((1 << st->log2GR)*bmax[i] + .999999); + n *= imax[i] - imin[i]; + } + if (n) + return SDiterSum(st->u.v, st->ndim, + st->log2GR, imin, imax) / (double)n; } - n = 1; /* iterate over leaves */ - for (i = st->ndim; i--; ) { - imin[i] = (bmin[i] <= .0) ? 0 - : (int)((1 << st->log2GR)*bmin[i]); - imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) - : (int)((1 << st->log2GR)*bmax[i] + .999999); - n *= imax[i] - imin[i]; - } - if (!n) - return .0; - - return SDiterSum(st->u.v, st->ndim, 1 << st->log2GR, imin, imax) / - (double)n; + return .0; } /* Recursive call for SDtraverseTre() */ @@ -193,18 +281,19 @@ SDdotravTre(const SDNode *st, const double *pos, int c /* in branches? */ if (st->log2GR < 0) { unsigned skipmask = 0; - csiz *= .5; for (i = st->ndim; i--; ) if (1<ndim; n--; ) + for (n = 1 << st->ndim; n--; ) { if (n & 1<ndim; n--; ) + for (n = 1 << st->ndim; n--; ) { if (!(n & 1<ndim; n--; ) { if (1<log2GR; } - /* fill in unused dimensions */ - for (i = SD_MAXDIM; i-- > st->ndim; ) { - clim[i][0] = 0; clim[i][1] = 1; - } #if (SD_MAXDIM == 4) bmin[0] = cmin[0] + csiz*clim[0][0]; for (cpos[0] = clim[0][0]; cpos[0] < clim[0][1]; cpos[0]++) { bmin[1] = cmin[1] + csiz*clim[1][0]; for (cpos[1] = clim[1][0]; cpos[1] < clim[1][1]; cpos[1]++) { bmin[2] = cmin[2] + csiz*clim[2][0]; - for (cpos[2] = clim[2][0]; cpos[2] < clim[2][1]; cpos[2]++) { - bmin[3] = cmin[3] + csiz*(cpos[3] = clim[3][0]); + if (st->ndim == 3) { + cpos[2] = clim[2][0]; n = cpos[0]; - for (i = 1; i < st->ndim; i++) + for (i = 1; i < 3; i++) n = (n << st->log2GR) + cpos[i]; - for ( ; cpos[3] < clim[3][1]; cpos[3]++) { + for ( ; cpos[2] < clim[2][1]; cpos[2]++) { rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr); if (rv < 0) return rv; - bmin[3] += csiz; + bmin[2] += csiz; } - bmin[2] += csiz; + } else { + for (cpos[2] = clim[2][0]; cpos[2] < clim[2][1]; cpos[2]++) { + bmin[3] = cmin[3] + csiz*(cpos[3] = clim[3][0]); + n = cpos[0]; + for (i = 1; i < 4; i++) + n = (n << st->log2GR) + cpos[i]; + for ( ; cpos[3] < clim[3][1]; cpos[3]++) { + rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr); + if (rv < 0) + return rv; + bmin[3] += csiz; + } + bmin[2] += csiz; + } } bmin[1] += csiz; } @@ -334,15 +432,28 @@ SDlookupTre(const SDNode *st, const double *pos, doubl static float SDqueryTre(const SDTre *sdt, const FVECT outVec, const FVECT inVec, double *hc) { - static const FVECT zvec = {.0, .0, 1.}; FVECT rOutVec; double gridPos[4]; - /* check transmission */ - if (!sdt->isxmit ^ outVec[2] > 0 ^ inVec[2] > 0) + + switch (sdt->sidef) { /* whose side are you on? */ + case SD_UFRONT: + if ((outVec[2] < 0) | (inVec[2] < 0)) + return -1.; + break; + case SD_UBACK: + if ((outVec[2] > 0) | (inVec[2] > 0)) + return -1.; + break; + case SD_XMIT: + if ((outVec[2] > 0) == (inVec[2] > 0)) + return -1.; + break; + default: return -1.; + } /* convert vector coordinates */ if (sdt->st->ndim == 3) { - spinvector(rOutVec, outVec, zvec, -atan2(inVec[1],inVec[0])); + spinvector(rOutVec, outVec, zvec, -atan2(-inVec[1],-inVec[0])); gridPos[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]); SDdisk2square(gridPos+1, rOutVec[0], rOutVec[1]); } else if (sdt->st->ndim == 4) { @@ -383,21 +494,23 @@ build_scaffold(float val, const double *cmin, double c sp->wmax = wid; if (sp->alen >= sp->nall) { /* need more space? */ struct outdir_s *ndarr; - sp->nall += 8192; + sp->nall += 1024; ndarr = (struct outdir_s *)realloc(sp->darr, sizeof(struct outdir_s)*sp->nall); - if (ndarr == NULL) + if (ndarr == NULL) { + sprintf(SDerrorDetail, + "Cannot grow scaffold to %u entries", sp->nall); return -1; /* abort build */ + } sp->darr = ndarr; } /* find Hilbert entry index */ bmin[0] = cmin[0]*(double)iwmax + .5; bmin[1] = cmin[1]*(double)iwmax + .5; - bmax[0] = bmin[0] + wid; - bmax[1] = bmin[1] + wid; - hilbert_box_vtx(2, sizeof(bitmask_t), sizeof(unsigned)*4, - 1, bmin, bmax); - sp->darr[sp->alen].hent = hilbert_c2i(2, sizeof(unsigned)*4, bmin); + bmax[0] = bmin[0] + wid-1; + bmax[1] = bmin[1] + wid-1; + hilbert_box_vtx(2, sizeof(bitmask_t), iwbits, 1, bmin, bmax); + sp->darr[sp->alen].hent = hilbert_c2i(2, iwbits, bmin); sp->darr[sp->alen].wid = wid; sp->darr[sp->alen].bsdf = val; sp->alen++; /* on to the next entry */ @@ -408,15 +521,20 @@ build_scaffold(float val, const double *cmin, double c static int sscmp(const void *p1, const void *p2) { - return (int)((*(const struct outdir_s *)p1).hent - - (*(const struct outdir_s *)p2).hent); + unsigned h1 = (*(const struct outdir_s *)p1).hent; + unsigned h2 = (*(const struct outdir_s *)p2).hent; + + if (h1 > h2) + return 1; + if (h1 < h2) + return -1; + return 0; } /* Create a new cumulative distribution for the given input direction */ static SDTreCDst * make_cdist(const SDTre *sdt, const double *pos) { - const unsigned cumlmax = ~0; SDdistScaffold myScaffold; SDTreCDst *cd; struct outdir_s *sp; @@ -427,7 +545,7 @@ make_cdist(const SDTre *sdt, const double *pos) myScaffold.wmax = 0; myScaffold.nic = sdt->st->ndim - 2; myScaffold.alen = 0; - myScaffold.nall = 8192; + myScaffold.nall = 512; myScaffold.darr = (struct outdir_s *)malloc(sizeof(struct outdir_s) * myScaffold.nall); if (myScaffold.darr == NULL) @@ -442,22 +560,30 @@ make_cdist(const SDTre *sdt, const double *pos) cd = (SDTreCDst *)malloc(sizeof(SDTreCDst) + sizeof(cd->carr[0])*myScaffold.alen); if (cd == NULL) { + sprintf(SDerrorDetail, + "Cannot allocate %u entry cumulative distribution", + myScaffold.alen); free(myScaffold.darr); return NULL; } + cd->isodist = (myScaffold.nic == 1); /* sort the distribution */ qsort(myScaffold.darr, cd->calen = myScaffold.alen, sizeof(struct outdir_s), &sscmp); /* record input range */ - scale = (double)myScaffold.wmin / iwmax; + scale = myScaffold.wmin / (double)iwmax; for (i = myScaffold.nic; i--; ) { - cd->clim[i][0] = floor(pos[i]/scale + .5) * scale; + cd->clim[i][0] = floor(pos[i]/scale) * scale; cd->clim[i][1] = cd->clim[i][0] + scale; } + if (cd->isodist) { /* avoid issue in SDqueryTreProjSA() */ + cd->clim[1][0] = cd->clim[0][0]; + cd->clim[1][1] = cd->clim[0][1]; + } cd->max_psa = myScaffold.wmax / (double)iwmax; cd->max_psa *= cd->max_psa * M_PI; - cd->isxmit = sdt->isxmit; + cd->sidef = sdt->sidef; cd->cTotal = 1e-20; /* compute directional total */ sp = myScaffold.darr; for (i = myScaffold.alen; i--; sp++) @@ -466,6 +592,7 @@ make_cdist(const SDTre *sdt, const double *pos) scale = (double)cumlmax / cd->cTotal; sp = myScaffold.darr; for (i = 0; i < cd->calen; i++, sp++) { + cd->carr[i].hndx = sp->hent; cd->carr[i].cuml = scale*cursum + .5; cursum += sp->bsdf * (double)sp->wid * sp->wid; } @@ -483,22 +610,24 @@ SDgetTreCDist(const FVECT inVec, SDComponent *sdc) { const SDTre *sdt; double inCoord[2]; - int vflags; int i; SDTreCDst *cd, *cdlast; /* check arguments */ if ((inVec == NULL) | (sdc == NULL) || (sdt = (SDTre *)sdc->dist) == NULL) return NULL; - if (sdt->st->ndim == 3) /* isotropic BSDF? */ + if (sdt->st->ndim == 3) { /* isotropic BSDF? */ inCoord[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]); - else if (sdt->st->ndim == 4) + } else if (sdt->st->ndim == 4) { SDdisk2square(inCoord, -inVec[0], -inVec[1]); - else + } else return NULL; /* should be internal error */ + /* quantize to avoid f.p. errors */ + for (i = sdt->st->ndim - 2; i--; ) + inCoord[i] = floor(inCoord[i]/quantum)*quantum + .5*quantum; cdlast = NULL; /* check for direction in cache list */ for (cd = (SDTreCDst *)sdc->cdList; cd != NULL; - cdlast = cd, cd = (SDTreCDst *)cd->next) { + cdlast = cd, cd = cd->next) { for (i = sdt->st->ndim - 2; i--; ) if ((cd->clim[i][0] > inCoord[i]) | (inCoord[i] >= cd->clim[i][1])) @@ -510,7 +639,7 @@ SDgetTreCDist(const FVECT inVec, SDComponent *sdc) cdlast = cd = make_cdist(sdt, inCoord); if (cdlast != NULL) { /* move entry to head of cache list */ cdlast->next = cd->next; - cd->next = sdc->cdList; + cd->next = (SDTreCDst *)sdc->cdList; sdc->cdList = (SDCDst *)cd; } return (SDCDst *)cd; /* ready to go */ @@ -531,9 +660,8 @@ SDqueryTreProjSA(double *psa, const FVECT v1, const RR const SDTre *sdt = (SDTre *)sdc->dist; double hcube[SD_MAXDIM]; if (SDqueryTre(sdt, v1, v2, hcube) < 0) { - if (qflags == SDqueryVal) - *psa = M_PI; - return SDEnone; + strcpy(SDerrorDetail, "Bad call to SDqueryTreProjSA"); + return SDEinternal; } myPSA[0] = hcube[sdt->st->ndim]; myPSA[1] = myPSA[0] *= myPSA[0] * M_PI; @@ -571,24 +699,28 @@ SDsampTreCDist(FVECT ioVec, double randX, const SDCDst { const unsigned nBitsC = 4*sizeof(bitmask_t); const unsigned nExtraBits = 8*(sizeof(bitmask_t)-sizeof(unsigned)); - const unsigned maxval = ~0; const SDTreCDst *cd = (const SDTreCDst *)cdp; - const unsigned target = randX*maxval; + const unsigned target = randX*cumlmax; bitmask_t hndx, hcoord[2]; - double gpos[3]; + double gpos[3], rotangle; int i, iupper, ilower; /* check arguments */ if ((ioVec == NULL) | (cd == NULL)) return SDEargument; + if (ioVec[2] > 0) { + if (!(cd->sidef & SD_UFRONT)) + return SDEargument; + } else if (!(cd->sidef & SD_UBACK)) + return SDEargument; /* binary search to find position */ ilower = 0; iupper = cd->calen; while ((i = (iupper + ilower) >> 1) != ilower) - if ((long)target >= (long)cd->carr[i].cuml) + if (target >= cd->carr[i].cuml) ilower = i; else iupper = i; /* localize random position */ - randX = (randX*maxval - cd->carr[ilower].cuml) / + randX = (randX*cumlmax - cd->carr[ilower].cuml) / (double)(cd->carr[iupper].cuml - cd->carr[ilower].cuml); /* index in longer Hilbert curve */ hndx = (randX*cd->carr[iupper].hndx + (1.-randX)*cd->carr[ilower].hndx) @@ -599,20 +731,371 @@ SDsampTreCDist(FVECT ioVec, double randX, const SDCDst gpos[i] = ((double)hcoord[i] + rand()*(1./(RAND_MAX+.5))) / (double)((bitmask_t)1 << nBitsC); SDsquare2disk(gpos, gpos[0], gpos[1]); + /* compute Z-coordinate */ gpos[2] = 1. - gpos[0]*gpos[0] - gpos[1]*gpos[1]; if (gpos[2] > 0) /* paranoia, I hope */ gpos[2] = sqrt(gpos[2]); - if (ioVec[2] > 0 ^ !cd->isxmit) + /* emit from back? */ + if (ioVec[2] > 0 ^ cd->sidef != SD_XMIT) gpos[2] = -gpos[2]; - VCOPY(ioVec, gpos); + if (cd->isodist) { /* rotate isotropic result */ + rotangle = atan2(-ioVec[1],-ioVec[0]); + VCOPY(ioVec, gpos); + spinvector(ioVec, ioVec, zvec, rotangle); + } else + VCOPY(ioVec, gpos); return SDEnone; } +/* Advance pointer to the next non-white character in the string (or nul) */ +static int +next_token(char **spp) +{ + while (isspace(**spp)) + ++*spp; + return **spp; +} + +/* Advance pointer past matching token (or any token if c==0) */ +#define eat_token(spp,c) (next_token(spp)==(c) ^ !(c) ? *(*(spp))++ : 0) + +/* Count words from this point in string to '}' */ +static int +count_values(char *cp) +{ + int n = 0; + + while (next_token(&cp) != '}' && *cp) { + while (!isspace(*cp) & (*cp != ',') & (*cp != '}')) + if (!*++cp) + break; + ++n; + eat_token(&cp, ','); + } + return n; +} + +/* Load an array of real numbers, returning total */ +static int +load_values(char **spp, float *va, int n) +{ + float *v = va; + char *svnext; + + while (n-- > 0 && (svnext = fskip(*spp)) != NULL) { + *v++ = atof(*spp); + *spp = svnext; + eat_token(spp, ','); + } + return v - va; +} + +/* Load BSDF tree data */ +static SDNode * +load_tree_data(char **spp, int nd) +{ + SDNode *st; + int n; + + if (!eat_token(spp, '{')) { + strcpy(SDerrorDetail, "Missing '{' in tensor tree"); + return NULL; + } + if (next_token(spp) == '{') { /* tree branches */ + st = SDnewNode(nd, -1); + if (st == NULL) + return NULL; + for (n = 0; n < 1<u.t[n] = load_tree_data(spp, nd)) == NULL) { + SDfreeTre(st); + return NULL; + } + } else { /* else load value grid */ + int bsiz; + n = count_values(*spp); /* see how big the grid is */ + for (bsiz = 0; bsiz < 8*sizeof(size_t); bsiz += nd) + if (1<= 8*sizeof(size_t)) { + strcpy(SDerrorDetail, "Illegal value count in tensor tree"); + return NULL; + } + st = SDnewNode(nd, bsiz/nd); + if (st == NULL) + return NULL; + if (load_values(spp, st->u.v, n) != n) { + strcpy(SDerrorDetail, "Real format error in tensor tree"); + SDfreeTre(st); + return NULL; + } + } + if (!eat_token(spp, '}')) { + strcpy(SDerrorDetail, "Missing '}' in tensor tree"); + SDfreeTre(st); + return NULL; + } + eat_token(spp, ','); + return st; +} + +/* Compute min. proj. solid angle and max. direct hemispherical scattering */ +static SDError +get_extrema(SDSpectralDF *df) +{ + SDNode *st = (*(SDTre *)df->comp[0].dist).st; + double stepWidth, dhemi, bmin[4], bmax[4]; + + stepWidth = SDsmallestLeaf(st); + if (quantum > stepWidth) /* adjust quantization factor */ + quantum = stepWidth; + df->minProjSA = M_PI*stepWidth*stepWidth; + if (stepWidth < .03125) + stepWidth = .03125; /* 1/32 resolution good enough */ + df->maxHemi = .0; + if (st->ndim == 3) { /* isotropic BSDF */ + bmin[1] = bmin[2] = .0; + bmax[1] = bmax[2] = 1.; + for (bmin[0] = .0; bmin[0] < .5-FTINY; bmin[0] += stepWidth) { + bmax[0] = bmin[0] + stepWidth; + dhemi = SDavgTreBox(st, bmin, bmax); + if (dhemi > df->maxHemi) + df->maxHemi = dhemi; + } + } else if (st->ndim == 4) { /* anisotropic BSDF */ + bmin[2] = bmin[3] = .0; + bmax[2] = bmax[3] = 1.; + for (bmin[0] = .0; bmin[0] < 1.-FTINY; bmin[0] += stepWidth) { + bmax[0] = bmin[0] + stepWidth; + for (bmin[1] = .0; bmin[1] < 1.-FTINY; bmin[1] += stepWidth) { + bmax[1] = bmin[1] + stepWidth; + dhemi = SDavgTreBox(st, bmin, bmax); + if (dhemi > df->maxHemi) + df->maxHemi = dhemi; + } + } + } else + return SDEinternal; + /* correct hemispherical value */ + df->maxHemi *= M_PI; + return SDEnone; +} + +/* Load BSDF distribution for this wavelength */ +static SDError +load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim) +{ + SDSpectralDF *df; + SDTre *sdt; + char *sdata; + /* allocate BSDF component */ + sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection")); + if (!sdata) + return SDEnone; + /* + * Remember that front and back are reversed from WINDOW 6 orientations + */ + if (!strcasecmp(sdata, "Transmission")) { + if (sd->tf != NULL) + SDfreeSpectralDF(sd->tf); + if ((sd->tf = SDnewSpectralDF(1)) == NULL) + return SDEmemory; + df = sd->tf; + } else if (!strcasecmp(sdata, "Reflection Front")) { + if (sd->rb != NULL) /* note back-front reversal */ + SDfreeSpectralDF(sd->rb); + if ((sd->rb = SDnewSpectralDF(1)) == NULL) + return SDEmemory; + df = sd->rb; + } else if (!strcasecmp(sdata, "Reflection Back")) { + if (sd->rf != NULL) /* note front-back reversal */ + SDfreeSpectralDF(sd->rf); + if ((sd->rf = SDnewSpectralDF(1)) == NULL) + return SDEmemory; + df = sd->rf; + } else + return SDEnone; + /* XXX should also check "ScatteringDataType" for consistency? */ + /* get angle bases */ + sdata = ezxml_txt(ezxml_child(wdb,"AngleBasis")); + if (!sdata || strcasecmp(sdata, "LBNL/Shirley-Chiu")) { + sprintf(SDerrorDetail, "%s angle basis for BSDF '%s'", + !sdata ? "Missing" : "Unsupported", sd->name); + return !sdata ? SDEformat : SDEsupport; + } + /* allocate BSDF tree */ + sdt = (SDTre *)malloc(sizeof(SDTre)); + if (sdt == NULL) + return SDEmemory; + if (df == sd->rf) + sdt->sidef = SD_UFRONT; + else if (df == sd->rb) + sdt->sidef = SD_UBACK; + else + sdt->sidef = SD_XMIT; + sdt->st = NULL; + df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */ + df->comp[0].dist = sdt; + df->comp[0].func = &SDhandleTre; + /* read BSDF data */ + sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData")); + if (!sdata || !next_token(&sdata)) { + sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'", + sd->name); + return SDEformat; + } + sdt->st = load_tree_data(&sdata, ndim); + if (sdt->st == NULL) + return SDEformat; + if (next_token(&sdata)) { /* check for unconsumed characters */ + sprintf(SDerrorDetail, + "Extra characters at end of ScatteringData in '%s'", + sd->name); + return SDEformat; + } + /* flatten branches where possible */ + sdt->st = SDsimplifyTre(sdt->st); + if (sdt->st == NULL) + return SDEinternal; + return get_extrema(df); /* compute global quantities */ +} + +/* Find minimum value in tree */ +static float +SDgetTreMin(const SDNode *st) +{ + float vmin = FHUGE; + int n; + + if (st->log2GR < 0) { + for (n = 1<ndim; n--; ) { + float v = SDgetTreMin(st->u.t[n]); + if (v < vmin) + vmin = v; + } + } else { + for (n = 1<<(st->ndim*st->log2GR); n--; ) + if (st->u.v[n] < vmin) + vmin = st->u.v[n]; + } + return vmin; +} + +/* Subtract the given value from all tree nodes */ +static void +SDsubtractTreVal(SDNode *st, float val) +{ + int n; + + if (st->log2GR < 0) { + for (n = 1<ndim; n--; ) + SDsubtractTreVal(st->u.t[n], val); + } else { + for (n = 1<<(st->ndim*st->log2GR); n--; ) + if ((st->u.v[n] -= val) < 0) + st->u.v[n] = .0f; + } +} + +/* Subtract minimum value from BSDF */ +static double +subtract_min(SDNode *st) +{ + float vmin; + /* be sure to skip unused portion */ + if (st->ndim == 3) { + int n; + vmin = 1./M_PI; + if (st->log2GR < 0) { + for (n = 0; n < 8; n += 2) { + float v = SDgetTreMin(st->u.t[n]); + if (v < vmin) + vmin = v; + } + } else if (st->log2GR) { + for (n = 1 << (3*st->log2GR - 1); n--; ) + if (st->u.v[n] < vmin) + vmin = st->u.v[n]; + } else + vmin = st->u.v[0]; + } else /* anisotropic covers entire tree */ + vmin = SDgetTreMin(st); + + if (vmin <= FTINY) + return .0; + + SDsubtractTreVal(st, vmin); + + return M_PI * vmin; /* return hemispherical value */ +} + +/* Extract and separate diffuse portion of BSDF */ +static void +extract_diffuse(SDValue *dv, SDSpectralDF *df) +{ + int n; + + if (df == NULL || df->ncomp <= 0) { + dv->spec = c_dfcolor; + dv->cieY = .0; + return; + } + dv->spec = df->comp[0].cspec[0]; + dv->cieY = subtract_min((*(SDTre *)df->comp[0].dist).st); + /* in case of multiple components */ + for (n = df->ncomp; --n; ) { + double ymin = subtract_min((*(SDTre *)df->comp[n].dist).st); + c_cmix(&dv->spec, dv->cieY, &dv->spec, ymin, &df->comp[n].cspec[0]); + dv->cieY += ymin; + } + df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */ + /* make sure everything is set */ + c_ccvt(&dv->spec, C_CSXY+C_CSSPEC); +} + /* Load a variable-resolution BSDF tree from an open XML file */ SDError SDloadTre(SDData *sd, ezxml_t wtl) { - return SDEsupport; + SDError ec; + ezxml_t wld, wdb; + int rank; + char *txt; + /* basic checks and tensor rank */ + txt = ezxml_txt(ezxml_child(ezxml_child(wtl, + "DataDefinition"), "IncidentDataStructure")); + if (txt == NULL || !*txt) { + sprintf(SDerrorDetail, + "BSDF \"%s\": missing IncidentDataStructure", + sd->name); + return SDEformat; + } + if (!strcasecmp(txt, "TensorTree3")) + rank = 3; + else if (!strcasecmp(txt, "TensorTree4")) + rank = 4; + else { + sprintf(SDerrorDetail, + "BSDF \"%s\": unsupported IncidentDataStructure", + sd->name); + return SDEsupport; + } + /* load BSDF components */ + for (wld = ezxml_child(wtl, "WavelengthData"); + wld != NULL; wld = wld->next) { + if (strcasecmp(ezxml_txt(ezxml_child(wld,"Wavelength")), + "Visible")) + continue; /* just visible for now */ + for (wdb = ezxml_child(wld, "WavelengthDataBlock"); + wdb != NULL; wdb = wdb->next) + if ((ec = load_bsdf_data(sd, wdb, rank)) != SDEnone) + return ec; + } + /* separate diffuse components */ + extract_diffuse(&sd->rLambFront, sd->rf); + extract_diffuse(&sd->rLambBack, sd->rb); + extract_diffuse(&sd->tLamb, sd->tf); + /* return success */ + return SDEnone; } /* Variable resolution BSDF methods */
