root/radiance/ray/src/common/bsdf_t.c
Revision: 3.35
Committed: Mon Mar 24 04:00:45 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Minor optimizations should not affect results
2 static const char RCSid[] = "$Id: bsdf_t.c,v 3.34 2014/03/23 19:24:11 greg Exp $";
5 * bsdf_t.c
6 *
7 * Definitions for variable-resolution BSDF trees
8 *
9 * Created by Greg Ward on 2/2/11.
10 *
11 */
12
13 #define _USE_MATH_DEFINES
14 #include "rtio.h"
15 #include <stdlib.h>
16 #include <math.h>
17 #include <ctype.h>
18 #include "ezxml.h"
19 #include "bsdf.h"
20 #include "bsdf_t.h"
21 #include "hilbert.h"
22
23 /* Callback function type for SDtraverseTre() */
24 typedef int SDtreCallback(float val, const double *cmin,
25 double csiz, void *cptr);
26
27 /* reference width maximum (1.0) */
28 static const unsigned iwbits = sizeof(unsigned)*4;
29 static const unsigned iwmax = 1<<(sizeof(unsigned)*4);
30 /* maximum cumulative value */
31 static const unsigned cumlmax = ~0;
32 /* constant z-vector */
33 static const FVECT zvec = {.0, .0, 1.};
34 /* quantization value */
35 static double quantum = 1./256.;
36
37 /* Struct used for our distribution-building callback */
38 typedef struct {
39 short nic; /* number of input coordinates */
40 short rev; /* reversing query */
41 unsigned alen; /* current array length */
42 unsigned nall; /* number of allocated entries */
43 unsigned wmin; /* minimum square size so far */
44 unsigned wmax; /* maximum square size */
45 struct outdir_s {
46 unsigned hent; /* entering Hilbert index */
47 int wid; /* this square size */
48 float bsdf; /* BSDF for this square */
49 } *darr; /* output direction array */
50 } SDdistScaffold;
51
52 /* Allocate a new scattering distribution node */
53 static SDNode *
54 SDnewNode(int nd, int lg)
55 {
56 SDNode *st;
57
58 if (nd <= 0) {
59 strcpy(SDerrorDetail, "Zero dimension BSDF node request");
60 return NULL;
61 }
62 if (nd > SD_MAXDIM) {
63 sprintf(SDerrorDetail, "Illegal BSDF dimension (%d > %d)",
64 nd, SD_MAXDIM);
65 return NULL;
66 }
67 if (lg < 0) {
68 st = (SDNode *)malloc(sizeof(SDNode) +
69 sizeof(st->u.t[0])*((1<<nd) - 1));
70 if (st == NULL) {
71 sprintf(SDerrorDetail,
72 "Cannot allocate %d branch BSDF tree", 1<<nd);
73 return NULL;
74 }
75 memset(st->u.t, 0, sizeof(st->u.t[0])<<nd);
76 } else {
77 st = (SDNode *)malloc(sizeof(SDNode) +
78 sizeof(st->u.v[0])*((1 << nd*lg) - 1));
79 if (st == NULL) {
80 sprintf(SDerrorDetail,
81 "Cannot allocate %d BSDF leaves", 1 << nd*lg);
82 return NULL;
83 }
84 }
85 st->ndim = nd;
86 st->log2GR = lg;
87 return st;
88 }
89
90 /* Free an SD tree */
91 static void
92 SDfreeTre(SDNode *st)
93 {
94 int n;
95
96 if (st == NULL)
97 return;
98 for (n = (st->log2GR < 0) << st->ndim; n--; )
99 SDfreeTre(st->u.t[n]);
100 free(st);
101 }
102
103 /* Free a variable-resolution BSDF */
104 static void
105 SDFreeBTre(void *p)
106 {
107 SDTre *sdt = (SDTre *)p;
108
109 if (sdt == NULL)
110 return;
111 SDfreeTre(sdt->st);
112 free(sdt);
113 }
114
115 /* Fill branch's worth of grid values from subtree */
116 static void
117 fill_grid_branch(float *dptr, const float *sptr, int nd, int shft)
118 {
119 unsigned n = 1 << (shft-1);
120
121 if (!--nd) { /* end on the line */
122 memcpy(dptr, sptr, sizeof(*dptr)*n);
123 return;
124 }
125 while (n--) /* recurse on each slice */
126 fill_grid_branch(dptr + (n << shft*nd),
127 sptr + (n << (shft-1)*nd), nd, shft);
128 }
129
130 /* Get pointer at appropriate offset for the given branch */
131 static float *
132 grid_branch_start(SDNode *st, int n)
133 {
134 unsigned skipsiz = 1 << (st->log2GR - 1);
135 float *vptr = st->u.v;
136 int i;
137
138 for (i = st->ndim; i--; skipsiz <<= st->log2GR)
139 if (1<<i & n)
140 vptr += skipsiz;
141 return vptr;
142 }
143
144 /* Simplify (consolidate) a tree by flattening uniform depth regions */
145 static SDNode *
146 SDsimplifyTre(SDNode *st)
147 {
148 int match, n;
149
150 if (st == NULL) /* check for invalid tree */
151 return NULL;
152 if (st->log2GR >= 0) /* grid just returns unaltered */
153 return st;
154 match = 1; /* check if grids below match */
155 for (n = 0; n < 1<<st->ndim; n++) {
156 if ((st->u.t[n] = SDsimplifyTre(st->u.t[n])) == NULL)
157 return NULL; /* propogate error up call stack */
158 match &= (st->u.t[n]->log2GR == st->u.t[0]->log2GR);
159 }
160 if (match && (match = st->u.t[0]->log2GR) >= 0) {
161 SDNode *stn = SDnewNode(st->ndim, match + 1);
162 if (stn == NULL) /* out of memory? */
163 return st;
164 /* transfer values to new grid */
165 for (n = 1 << st->ndim; n--; )
166 fill_grid_branch(grid_branch_start(stn, n),
167 st->u.t[n]->u.v, stn->ndim, stn->log2GR);
168 SDfreeTre(st); /* free old tree */
169 st = stn; /* return new one */
170 }
171 return st;
172 }
173
174 /* Find smallest leaf in tree */
175 static double
176 SDsmallestLeaf(const SDNode *st)
177 {
178 if (st->log2GR < 0) { /* tree branches */
179 double lmin = 1.;
180 int n;
181 for (n = 1<<st->ndim; n--; ) {
182 double lsiz = SDsmallestLeaf(st->u.t[n]);
183 if (lsiz < lmin)
184 lmin = lsiz;
185 }
186 return .5*lmin;
187 }
188 /* leaf grid width */
189 return 1. / (double)(1 << st->log2GR);
190 }
191
192 /* Add up N-dimensional hypercube array values over the given box */
193 static double
194 SDiterSum(const float *va, int nd, int shft, const int *imin, const int *imax)
195 {
196 const unsigned skipsiz = 1 << --nd*shft;
197 double sum = .0;
198 int i;
199
200 va += *imin * skipsiz;
201
202 if (skipsiz == 1)
203 for (i = *imin; i < *imax; i++)
204 sum += *va++;
205 else
206 for (i = *imin; i < *imax; i++, va += skipsiz)
207 sum += SDiterSum(va, nd, shft, imin+1, imax+1);
208 return sum;
209 }
210
211 /* Average BSDF leaves over an orthotope defined by the unit hypercube */
212 static double
213 SDavgTreBox(const SDNode *st, const double *bmin, const double *bmax)
214 {
215 unsigned n;
216 int i;
217
218 if (!st)
219 return .0;
220 /* check box limits */
221 for (i = st->ndim; i--; ) {
222 if (bmin[i] >= 1.)
223 return .0;
224 if (bmax[i] <= 0)
225 return .0;
226 if (bmin[i] >= bmax[i])
227 return .0;
228 }
229 if (st->log2GR < 0) { /* iterate on subtree */
230 double sum = .0, wsum = 1e-20;
231 double sbmin[SD_MAXDIM], sbmax[SD_MAXDIM], w;
232 for (n = 1 << st->ndim; n--; ) {
233 w = 1.;
234 for (i = st->ndim; i--; ) {
235 sbmin[i] = 2.*bmin[i];
236 sbmax[i] = 2.*bmax[i];
237 if (n & 1<<i) {
238 sbmin[i] -= 1.;
239 sbmax[i] -= 1.;
240 }
241 if (sbmin[i] < .0) sbmin[i] = .0;
242 if (sbmax[i] > 1.) sbmax[i] = 1.;
243 if (sbmin[i] >= sbmax[i]) {
244 w = .0;
245 break;
246 }
247 w *= sbmax[i] - sbmin[i];
248 }
249 if (w > 1e-10) {
250 sum += w * SDavgTreBox(st->u.t[n], sbmin, sbmax);
251 wsum += w;
252 }
253 }
254 return sum / wsum;
255 } else { /* iterate over leaves */
256 int imin[SD_MAXDIM], imax[SD_MAXDIM];
257
258 n = 1;
259 for (i = st->ndim; i--; ) {
260 imin[i] = (bmin[i] <= 0) ? 0 :
261 (int)((1 << st->log2GR)*bmin[i]);
262 imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) :
263 (int)((1 << st->log2GR)*bmax[i] + .999999);
264 n *= imax[i] - imin[i];
265 }
266 if (n)
267 return SDiterSum(st->u.v, st->ndim,
268 st->log2GR, imin, imax) / (double)n;
269 }
270 return .0;
271 }
272
273 /* Recursive call for SDtraverseTre() */
274 static int
275 SDdotravTre(const SDNode *st, const double *pos, int cmask,
276 SDtreCallback *cf, void *cptr,
277 const double *cmin, double csiz)
278 {
279 int rv, rval = 0;
280 double bmin[SD_MAXDIM];
281 int i, n;
282 /* in branches? */
283 if (st->log2GR < 0) {
284 unsigned skipmask = 0;
285 csiz *= .5;
286 for (i = st->ndim; i--; )
287 if (1<<i & cmask) {
288 if (pos[i] < cmin[i] + csiz)
289 for (n = 1 << st->ndim; n--; ) {
290 if (n & 1<<i)
291 skipmask |= 1<<n;
292 }
293 else
294 for (n = 1 << st->ndim; n--; ) {
295 if (!(n & 1<<i))
296 skipmask |= 1<<n;
297 }
298 }
299 for (n = 1 << st->ndim; n--; ) {
300 if (1<<n & skipmask)
301 continue;
302 for (i = st->ndim; i--; )
303 if (1<<i & n)
304 bmin[i] = cmin[i] + csiz;
305 else
306 bmin[i] = cmin[i];
307
308 rval += rv = SDdotravTre(st->u.t[n], pos, cmask,
309 cf, cptr, bmin, csiz);
310 if (rv < 0)
311 return rv;
312 }
313 } else { /* else traverse leaves */
314 int clim[SD_MAXDIM][2];
315 int cpos[SD_MAXDIM];
316
317 if (st->log2GR == 0) /* short cut */
318 return (*cf)(st->u.v[0], cmin, csiz, cptr);
319
320 csiz /= (double)(1 << st->log2GR);
321 /* assign coord. ranges */
322 for (i = st->ndim; i--; )
323 if (1<<i & cmask) {
324 clim[i][0] = (pos[i] - cmin[i])/csiz;
325 /* check overflow from f.p. error */
326 clim[i][0] -= clim[i][0] >> st->log2GR;
327 clim[i][1] = clim[i][0] + 1;
328 } else {
329 clim[i][0] = 0;
330 clim[i][1] = 1 << st->log2GR;
331 }
332 #if (SD_MAXDIM == 4)
333 bmin[0] = cmin[0] + csiz*clim[0][0];
334 for (cpos[0] = clim[0][0]; cpos[0] < clim[0][1]; cpos[0]++) {
335 bmin[1] = cmin[1] + csiz*clim[1][0];
336 for (cpos[1] = clim[1][0]; cpos[1] < clim[1][1]; cpos[1]++) {
337 bmin[2] = cmin[2] + csiz*clim[2][0];
338 if (st->ndim == 3) {
339 cpos[2] = clim[2][0];
340 n = cpos[0];
341 for (i = 1; i < 3; i++)
342 n = (n << st->log2GR) + cpos[i];
343 for ( ; cpos[2] < clim[2][1]; cpos[2]++) {
344 rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr);
345 if (rv < 0)
346 return rv;
347 bmin[2] += csiz;
348 }
349 } else {
350 for (cpos[2] = clim[2][0]; cpos[2] < clim[2][1]; cpos[2]++) {
351 bmin[3] = cmin[3] + csiz*(cpos[3] = clim[3][0]);
352 n = cpos[0];
353 for (i = 1; i < 4; i++)
354 n = (n << st->log2GR) + cpos[i];
355 for ( ; cpos[3] < clim[3][1]; cpos[3]++) {
356 rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr);
357 if (rv < 0)
358 return rv;
359 bmin[3] += csiz;
360 }
361 bmin[2] += csiz;
362 }
363 }
364 bmin[1] += csiz;
365 }
366 bmin[0] += csiz;
367 }
368 #else
369 _!_ "broken code segment!"
370 #endif
371 }
372 return rval;
373 }
374
375 /* Traverse a tree, visiting nodes in a slice that fits partial position */
376 static int
377 SDtraverseTre(const SDNode *st, const double *pos, int cmask,
378 SDtreCallback *cf, void *cptr)
379 {
380 static double czero[SD_MAXDIM];
381 int i;
382 /* check arguments */
383 if ((st == NULL) | (cf == NULL))
384 return -1;
385 for (i = st->ndim; i--; )
386 if (1<<i & cmask && (pos[i] < 0) | (pos[i] >= 1.))
387 return -1;
388
389 return SDdotravTre(st, pos, cmask, cf, cptr, czero, 1.);
390 }
391
392 /* Look up tree value at the given grid position */
393 static float
394 SDlookupTre(const SDNode *st, const double *pos, double *hcube)
395 {
396 double spos[SD_MAXDIM];
397 int i, n, t;
398 /* initialize voxel return */
399 if (hcube) {
400 hcube[i = st->ndim] = 1.;
401 while (i--)
402 hcube[i] = .0;
403 }
404 /* climb the tree */
405 while (st->log2GR < 0) {
406 n = 0; /* move to appropriate branch */
407 if (hcube) hcube[st->ndim] *= .5;
408 for (i = st->ndim; i--; ) {
409 spos[i] = 2.*pos[i];
410 t = (spos[i] >= 1.);
411 n |= t<<i;
412 spos[i] -= (double)t;
413 if (hcube) hcube[i] += (double)t * hcube[st->ndim];
414 }
415 st = st->u.t[n]; /* avoids tail recursion */
416 pos = spos;
417 }
418 if (st->log2GR == 0) /* short cut */
419 return st->u.v[0];
420 n = t = 0; /* find grid array index */
421 for (i = st->ndim; i--; ) {
422 n += (int)((1<<st->log2GR)*pos[i]) << t;
423 t += st->log2GR;
424 }
425 if (hcube) { /* compute final hypercube */
426 hcube[st->ndim] /= (double)(1<<st->log2GR);
427 for (i = st->ndim; i--; )
428 hcube[i] += floor((1<<st->log2GR)*pos[i])*hcube[st->ndim];
429 }
430 return st->u.v[n]; /* no interpolation */
431 }
432
433 /* Query BSDF value and sample hypercube for the given vectors */
434 static float
435 SDqueryTre(const SDTre *sdt, const FVECT outVec, const FVECT inVec, double *hc)
436 {
437 const RREAL *vtmp;
438 FVECT rOutVec;
439 double gridPos[4];
440
441 switch (sdt->sidef) { /* whose side are you on? */
442 case SD_FREFL:
443 if ((outVec[2] < 0) | (inVec[2] < 0))
444 return -1.;
445 break;
446 case SD_BREFL:
447 if ((outVec[2] > 0) | (inVec[2] > 0))
448 return -1.;
449 break;
450 case SD_FXMIT:
451 if (outVec[2] > 0) {
452 if (inVec[2] > 0)
453 return -1.;
454 vtmp = outVec; outVec = inVec; inVec = vtmp;
455 } else if (inVec[2] < 0)
456 return -1.;
457 break;
458 case SD_BXMIT:
459 if (inVec[2] > 0) {
460 if (outVec[2] > 0)
461 return -1.;
462 vtmp = outVec; outVec = inVec; inVec = vtmp;
463 } else if (outVec[2] < 0)
464 return -1.;
465 break;
466 default:
467 return -1.;
468 }
469 /* convert vector coordinates */
470 if (sdt->st->ndim == 3) {
471 spinvector(rOutVec, outVec, zvec, -atan2(-inVec[1],-inVec[0]));
472 gridPos[0] = (.5-FTINY) -
473 .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]);
474 SDdisk2square(gridPos+1, rOutVec[0], rOutVec[1]);
475 } else if (sdt->st->ndim == 4) {
476 SDdisk2square(gridPos, -inVec[0], -inVec[1]);
477 SDdisk2square(gridPos+2, outVec[0], outVec[1]);
478 } else
479 return -1.; /* should be internal error */
480
481 return SDlookupTre(sdt->st, gridPos, hc);
482 }
483
484 /* Compute non-diffuse component for variable-resolution BSDF */
485 static int
486 SDgetTreBSDF(float coef[SDmaxCh], const FVECT outVec,
487 const FVECT inVec, SDComponent *sdc)
488 {
489 /* check arguments */
490 if ((coef == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL)
491 || sdc->dist == NULL)
492 return 0;
493 /* get nearest BSDF value */
494 coef[0] = SDqueryTre((SDTre *)sdc->dist, outVec, inVec, NULL);
495 return (coef[0] >= 0); /* monochromatic for now */
496 }
497
498 /* Callback to build cumulative distribution using SDtraverseTre() */
499 static int
500 build_scaffold(float val, const double *cmin, double csiz, void *cptr)
501 {
502 SDdistScaffold *sp = (SDdistScaffold *)cptr;
503 int wid = csiz*(double)iwmax + .5;
504 double revcmin[2];
505 bitmask_t bmin[2], bmax[2];
506
507 if (sp->rev) { /* need to reverse sense? */
508 revcmin[0] = 1. - cmin[0] - csiz;
509 revcmin[1] = 1. - cmin[1] - csiz;
510 cmin = revcmin;
511 } else {
512 cmin += sp->nic; /* else skip to output coords */
513 }
514 if (wid < sp->wmin) /* new minimum width? */
515 sp->wmin = wid;
516 if (wid > sp->wmax) /* new maximum? */
517 sp->wmax = wid;
518 if (sp->alen >= sp->nall) { /* need more space? */
519 struct outdir_s *ndarr;
520 sp->nall = (int)(1.5*sp->nall) + 256;
521 ndarr = (struct outdir_s *)realloc(sp->darr,
522 sizeof(struct outdir_s)*sp->nall);
523 if (ndarr == NULL) {
524 sprintf(SDerrorDetail,
525 "Cannot grow scaffold to %u entries", sp->nall);
526 return -1; /* abort build */
527 }
528 sp->darr = ndarr;
529 }
530 /* find Hilbert entry index */
531 bmin[0] = cmin[0]*(double)iwmax + .5;
532 bmin[1] = cmin[1]*(double)iwmax + .5;
533 bmax[0] = bmin[0] + wid-1;
534 bmax[1] = bmin[1] + wid-1;
535 hilbert_box_vtx(2, sizeof(bitmask_t), iwbits, 1, bmin, bmax);
536 sp->darr[sp->alen].hent = hilbert_c2i(2, iwbits, bmin);
537 sp->darr[sp->alen].wid = wid;
538 sp->darr[sp->alen].bsdf = val;
539 sp->alen++; /* on to the next entry */
540 return 0;
541 }
542
543 /* Scaffold comparison function for qsort -- ascending Hilbert index */
544 static int
545 sscmp(const void *p1, const void *p2)
546 {
547 unsigned h1 = (*(const struct outdir_s *)p1).hent;
548 unsigned h2 = (*(const struct outdir_s *)p2).hent;
549
550 if (h1 > h2)
551 return 1;
552 if (h1 < h2)
553 return -1;
554 return 0;
555 }
556
557 /* Create a new cumulative distribution for the given input direction */
558 static SDTreCDst *
559 make_cdist(const SDTre *sdt, const double *invec, int rev)
560 {
561 SDdistScaffold myScaffold;
562 double pos[4];
563 int cmask;
564 SDTreCDst *cd;
565 struct outdir_s *sp;
566 double scale, cursum;
567 int i;
568 /* initialize scaffold */
569 myScaffold.wmin = iwmax;
570 myScaffold.wmax = 0;
571 myScaffold.nic = sdt->st->ndim - 2;
572 myScaffold.rev = rev;
573 myScaffold.alen = 0;
574 myScaffold.nall = 512;
575 myScaffold.darr = (struct outdir_s *)malloc(sizeof(struct outdir_s) *
576 myScaffold.nall);
577 if (myScaffold.darr == NULL)
578 return NULL;
579 /* set up traversal */
580 cmask = (1<<myScaffold.nic) - 1;
581 for (i = myScaffold.nic; i--; )
582 pos[i+2*rev] = invec[i];
583 cmask <<= 2*rev;
584 /* grow the distribution */
585 if (SDtraverseTre(sdt->st, pos, cmask,
586 &build_scaffold, &myScaffold) < 0) {
587 free(myScaffold.darr);
588 return NULL;
589 }
590 /* allocate result holder */
591 cd = (SDTreCDst *)malloc(sizeof(SDTreCDst) +
592 sizeof(cd->carr[0])*myScaffold.alen);
593 if (cd == NULL) {
594 sprintf(SDerrorDetail,
595 "Cannot allocate %u entry cumulative distribution",
596 myScaffold.alen);
597 free(myScaffold.darr);
598 return NULL;
599 }
600 cd->isodist = (myScaffold.nic == 1);
601 /* sort the distribution */
602 qsort(myScaffold.darr, cd->calen = myScaffold.alen,
603 sizeof(struct outdir_s), &sscmp);
604
605 /* record input range */
606 scale = myScaffold.wmin / (double)iwmax;
607 for (i = myScaffold.nic; i--; ) {
608 cd->clim[i][0] = floor(pos[i+2*rev]/scale) * scale;
609 cd->clim[i][1] = cd->clim[i][0] + scale;
610 }
611 if (cd->isodist) { /* avoid issue in SDqueryTreProjSA() */
612 cd->clim[1][0] = cd->clim[0][0];
613 cd->clim[1][1] = cd->clim[0][1];
614 }
615 cd->max_psa = myScaffold.wmax / (double)iwmax;
616 cd->max_psa *= cd->max_psa * M_PI;
617 if (rev)
618 cd->sidef = (sdt->sidef==SD_BXMIT) ? SD_FXMIT : SD_BXMIT;
619 else
620 cd->sidef = sdt->sidef;
621 cd->cTotal = 1e-20; /* compute directional total */
622 sp = myScaffold.darr;
623 for (i = myScaffold.alen; i--; sp++)
624 cd->cTotal += sp->bsdf * (double)sp->wid * sp->wid;
625 cursum = .0; /* go back and get cumulative values */
626 scale = (double)cumlmax / cd->cTotal;
627 sp = myScaffold.darr;
628 for (i = 0; i < cd->calen; i++, sp++) {
629 cd->carr[i].hndx = sp->hent;
630 cd->carr[i].cuml = scale*cursum + .5;
631 cursum += sp->bsdf * (double)sp->wid * sp->wid;
632 }
633 cd->carr[i].hndx = ~0; /* make final entry */
634 cd->carr[i].cuml = cumlmax;
635 cd->cTotal *= M_PI/(double)iwmax/iwmax;
636 /* all done, clean up and return */
637 free(myScaffold.darr);
638 return cd;
639 }
640
641 /* Find or allocate a cumulative distribution for the given incoming vector */
642 const SDCDst *
643 SDgetTreCDist(const FVECT inVec, SDComponent *sdc)
644 {
645 const SDTre *sdt;
646 double inCoord[2];
647 int i;
648 int mode;
649 SDTreCDst *cd, *cdlast;
650 /* check arguments */
651 if ((inVec == NULL) | (sdc == NULL) ||
652 (sdt = (SDTre *)sdc->dist) == NULL)
653 return NULL;
654 switch (mode = sdt->sidef) { /* check direction */
655 case SD_FREFL:
656 if (inVec[2] < 0)
657 return NULL;
658 break;
659 case SD_BREFL:
660 if (inVec[2] > 0)
661 return NULL;
662 break;
663 case SD_FXMIT:
664 if (inVec[2] < 0)
665 mode = SD_BXMIT;
666 break;
667 case SD_BXMIT:
668 if (inVec[2] > 0)
669 mode = SD_FXMIT;
670 break;
671 default:
672 return NULL;
673 }
674 if (sdt->st->ndim == 3) { /* isotropic BSDF? */
675 if (mode != sdt->sidef) /* XXX unhandled reciprocity */
676 return &SDemptyCD;
677 inCoord[0] = (.5-FTINY) -
678 .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]);
679 } else if (sdt->st->ndim == 4) {
680 if (mode != sdt->sidef) /* use reciprocity? */
681 SDdisk2square(inCoord, inVec[0], inVec[1]);
682 else
683 SDdisk2square(inCoord, -inVec[0], -inVec[1]);
684 } else
685 return NULL; /* should be internal error */
686 /* quantize to avoid f.p. errors */
687 for (i = sdt->st->ndim - 2; i--; )
688 inCoord[i] = floor(inCoord[i]/quantum)*quantum + .5*quantum;
689 cdlast = NULL; /* check for direction in cache list */
690 for (cd = (SDTreCDst *)sdc->cdList; cd != NULL;
691 cdlast = cd, cd = cd->next) {
692 if (cd->sidef != mode)
693 continue;
694 for (i = sdt->st->ndim - 2; i--; )
695 if ((cd->clim[i][0] > inCoord[i]) |
696 (inCoord[i] >= cd->clim[i][1]))
697 break;
698 if (i < 0)
699 break; /* means we have a match */
700 }
701 if (cd == NULL) /* need to create new entry? */
702 cdlast = cd = make_cdist(sdt, inCoord, mode != sdt->sidef);
703 if (cdlast != NULL) { /* move entry to head of cache list */
704 cdlast->next = cd->next;
705 cd->next = (SDTreCDst *)sdc->cdList;
706 sdc->cdList = (SDCDst *)cd;
707 }
708 return (SDCDst *)cd; /* ready to go */
709 }
710
711 /* Query solid angle for vector(s) */
712 static SDError
713 SDqueryTreProjSA(double *psa, const FVECT v1, const RREAL *v2,
714 int qflags, SDComponent *sdc)
715 {
716 double myPSA[2];
717 /* check arguments */
718 if ((psa == NULL) | (v1 == NULL) | (sdc == NULL) ||
719 sdc->dist == NULL)
720 return SDEargument;
721 /* get projected solid angle(s) */
722 if (v2 != NULL) {
723 const SDTre *sdt = (SDTre *)sdc->dist;
724 double hcube[SD_MAXDIM];
725 if (SDqueryTre(sdt, v1, v2, hcube) < 0) {
726 strcpy(SDerrorDetail, "Bad call to SDqueryTreProjSA");
727 return SDEinternal;
728 }
729 myPSA[0] = hcube[sdt->st->ndim];
730 myPSA[1] = myPSA[0] *= myPSA[0] * M_PI;
731 } else {
732 const SDTreCDst *cd = (const SDTreCDst *)SDgetTreCDist(v1, sdc);
733 if (cd == NULL)
734 myPSA[0] = myPSA[1] = 0;
735 else {
736 myPSA[0] = M_PI * (cd->clim[0][1] - cd->clim[0][0]) *
737 (cd->clim[1][1] - cd->clim[1][0]);
738 myPSA[1] = cd->max_psa;
739 }
740 }
741 switch (qflags) { /* record based on flag settings */
742 case SDqueryVal:
743 *psa = myPSA[0];
744 break;
745 case SDqueryMax:
746 if (myPSA[1] > *psa)
747 *psa = myPSA[1];
748 break;
749 case SDqueryMin+SDqueryMax:
750 if (myPSA[1] > psa[1])
751 psa[1] = myPSA[1];
752 /* fall through */
753 case SDqueryMin:
754 if ((myPSA[0] > 0) & (myPSA[0] < psa[0]))
755 psa[0] = myPSA[0];
756 break;
757 }
758 return SDEnone;
759 }
760
761 /* Sample cumulative distribution */
762 static SDError
763 SDsampTreCDist(FVECT ioVec, double randX, const SDCDst *cdp)
764 {
765 const unsigned nBitsC = 4*sizeof(bitmask_t);
766 const unsigned nExtraBits = 8*(sizeof(bitmask_t)-sizeof(unsigned));
767 const SDTreCDst *cd = (const SDTreCDst *)cdp;
768 const unsigned target = randX*cumlmax;
769 bitmask_t hndx, hcoord[2];
770 double gpos[3], rotangle;
771 int i, iupper, ilower;
772 /* check arguments */
773 if ((ioVec == NULL) | (cd == NULL))
774 return SDEargument;
775 if (!cd->sidef)
776 return SDEnone; /* XXX should never happen */
777 if (ioVec[2] > 0) {
778 if ((cd->sidef != SD_FREFL) & (cd->sidef != SD_FXMIT))
779 return SDEargument;
780 } else if ((cd->sidef != SD_BREFL) & (cd->sidef != SD_BXMIT))
781 return SDEargument;
782 /* binary search to find position */
783 ilower = 0; iupper = cd->calen;
784 while ((i = (iupper + ilower) >> 1) != ilower)
785 if (target >= cd->carr[i].cuml)
786 ilower = i;
787 else
788 iupper = i;
789 /* localize random position */
790 randX = (randX*cumlmax - cd->carr[ilower].cuml) /
791 (double)(cd->carr[iupper].cuml - cd->carr[ilower].cuml);
792 /* index in longer Hilbert curve */
793 hndx = (randX*cd->carr[iupper].hndx + (1.-randX)*cd->carr[ilower].hndx)
794 * (double)((bitmask_t)1 << nExtraBits);
795 /* convert Hilbert index to vector */
796 hilbert_i2c(2, nBitsC, hndx, hcoord);
797 for (i = 2; i--; )
798 gpos[i] = ((double)hcoord[i] + rand()*(1./(RAND_MAX+.5))) /
799 (double)((bitmask_t)1 << nBitsC);
800 SDsquare2disk(gpos, gpos[0], gpos[1]);
801 /* compute Z-coordinate */
802 gpos[2] = 1. - gpos[0]*gpos[0] - gpos[1]*gpos[1];
803 gpos[2] = sqrt(gpos[2]*(gpos[2]>0));
804 /* emit from back? */
805 if ((cd->sidef == SD_BREFL) | (cd->sidef == SD_FXMIT))
806 gpos[2] = -gpos[2];
807 if (cd->isodist) { /* rotate isotropic sample */
808 rotangle = atan2(-ioVec[1],-ioVec[0]);
809 spinvector(ioVec, gpos, zvec, rotangle);
810 } else
811 VCOPY(ioVec, gpos);
812 return SDEnone;
813 }
814
815 /* Advance pointer to the next non-white character in the string (or nul) */
816 static int
817 next_token(char **spp)
818 {
819 while (isspace(**spp))
820 ++*spp;
821 return **spp;
822 }
823
824 /* Advance pointer past matching token (or any token if c==0) */
825 #define eat_token(spp,c) (next_token(spp)==(c) ^ !(c) ? *(*(spp))++ : 0)
826
827 /* Count words from this point in string to '}' */
828 static int
829 count_values(char *cp)
830 {
831 int n = 0;
832
833 while (next_token(&cp) != '}' && *cp) {
834 while (!isspace(*cp) & (*cp != ',') & (*cp != '}'))
835 if (!*++cp)
836 break;
837 ++n;
838 eat_token(&cp, ',');
839 }
840 return n;
841 }
842
843 /* Load an array of real numbers, returning total */
844 static int
845 load_values(char **spp, float *va, int n)
846 {
847 float *v = va;
848 char *svnext;
849
850 while (n-- > 0 && (svnext = fskip(*spp)) != NULL) {
851 if ((*v++ = atof(*spp)) < 0)
852 v[-1] = 0;
853 *spp = svnext;
854 eat_token(spp, ',');
855 }
856 return v - va;
857 }
858
859 /* Load BSDF tree data */
860 static SDNode *
861 load_tree_data(char **spp, int nd)
862 {
863 SDNode *st;
864 int n;
865
866 if (!eat_token(spp, '{')) {
867 strcpy(SDerrorDetail, "Missing '{' in tensor tree");
868 return NULL;
869 }
870 if (next_token(spp) == '{') { /* tree branches */
871 st = SDnewNode(nd, -1);
872 if (st == NULL)
873 return NULL;
874 for (n = 0; n < 1<<nd; n++)
875 if ((st->u.t[n] = load_tree_data(spp, nd)) == NULL) {
876 SDfreeTre(st);
877 return NULL;
878 }
879 } else { /* else load value grid */
880 int bsiz;
881 n = count_values(*spp); /* see how big the grid is */
882 for (bsiz = 0; bsiz < 8*sizeof(size_t); bsiz += nd)
883 if (1<<bsiz == n)
884 break;
885 if (bsiz >= 8*sizeof(size_t)) {
886 strcpy(SDerrorDetail, "Illegal value count in tensor tree");
887 return NULL;
888 }
889 st = SDnewNode(nd, bsiz/nd);
890 if (st == NULL)
891 return NULL;
892 if (load_values(spp, st->u.v, n) != n) {
893 strcpy(SDerrorDetail, "Real format error in tensor tree");
894 SDfreeTre(st);
895 return NULL;
896 }
897 }
898 if (!eat_token(spp, '}')) {
899 strcpy(SDerrorDetail, "Missing '}' in tensor tree");
900 SDfreeTre(st);
901 return NULL;
902 }
903 eat_token(spp, ',');
904 return st;
905 }
906
907 /* Compute min. proj. solid angle and max. direct hemispherical scattering */
908 static SDError
909 get_extrema(SDSpectralDF *df)
910 {
911 SDNode *st = (*(SDTre *)df->comp[0].dist).st;
912 double stepWidth, dhemi, bmin[4], bmax[4];
913
914 stepWidth = SDsmallestLeaf(st);
915 if (quantum > stepWidth) /* adjust quantization factor */
916 quantum = stepWidth;
917 df->minProjSA = M_PI*stepWidth*stepWidth;
918 if (stepWidth < .03125)
919 stepWidth = .03125; /* 1/32 resolution good enough */
920 df->maxHemi = .0;
921 if (st->ndim == 3) { /* isotropic BSDF */
922 bmin[1] = bmin[2] = .0;
923 bmax[1] = bmax[2] = 1.;
924 for (bmin[0] = .0; bmin[0] < .5-FTINY; bmin[0] += stepWidth) {
925 bmax[0] = bmin[0] + stepWidth;
926 dhemi = SDavgTreBox(st, bmin, bmax);
927 if (dhemi > df->maxHemi)
928 df->maxHemi = dhemi;
929 }
930 } else if (st->ndim == 4) { /* anisotropic BSDF */
931 bmin[2] = bmin[3] = .0;
932 bmax[2] = bmax[3] = 1.;
933 for (bmin[0] = .0; bmin[0] < 1.-FTINY; bmin[0] += stepWidth) {
934 bmax[0] = bmin[0] + stepWidth;
935 for (bmin[1] = .0; bmin[1] < 1.-FTINY; bmin[1] += stepWidth) {
936 bmax[1] = bmin[1] + stepWidth;
937 dhemi = SDavgTreBox(st, bmin, bmax);
938 if (dhemi > df->maxHemi)
939 df->maxHemi = dhemi;
940 }
941 }
942 } else
943 return SDEinternal;
944 /* correct hemispherical value */
945 df->maxHemi *= M_PI;
946 return SDEnone;
947 }
948
949 /* Load BSDF distribution for this wavelength */
950 static SDError
951 load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim)
952 {
953 SDSpectralDF *df;
954 SDTre *sdt;
955 char *sdata;
956 /* allocate BSDF component */
957 sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection"));
958 if (!sdata)
959 return SDEnone;
960 /*
961 * Remember that front and back are reversed from WINDOW 6 orientations
962 */
963 if (!strcasecmp(sdata, "Transmission Front")) {
964 if (sd->tb != NULL)
965 SDfreeSpectralDF(sd->tb);
966 if ((sd->tb = SDnewSpectralDF(1)) == NULL)
967 return SDEmemory;
968 df = sd->tb;
969 } else if (!strcasecmp(sdata, "Transmission Back")) {
970 if (sd->tf != NULL)
971 SDfreeSpectralDF(sd->tf);
972 if ((sd->tf = SDnewSpectralDF(1)) == NULL)
973 return SDEmemory;
974 df = sd->tf;
975 } else if (!strcasecmp(sdata, "Reflection Front")) {
976 if (sd->rb != NULL)
977 SDfreeSpectralDF(sd->rb);
978 if ((sd->rb = SDnewSpectralDF(1)) == NULL)
979 return SDEmemory;
980 df = sd->rb;
981 } else if (!strcasecmp(sdata, "Reflection Back")) {
982 if (sd->rf != NULL)
983 SDfreeSpectralDF(sd->rf);
984 if ((sd->rf = SDnewSpectralDF(1)) == NULL)
985 return SDEmemory;
986 df = sd->rf;
987 } else
988 return SDEnone;
989 /* XXX should also check "ScatteringDataType" for consistency? */
990 /* get angle bases */
991 sdata = ezxml_txt(ezxml_child(wdb,"AngleBasis"));
992 if (!sdata || strcasecmp(sdata, "LBNL/Shirley-Chiu")) {
993 sprintf(SDerrorDetail, "%s angle basis for BSDF '%s'",
994 !sdata ? "Missing" : "Unsupported", sd->name);
995 return !sdata ? SDEformat : SDEsupport;
996 }
997 /* allocate BSDF tree */
998 sdt = (SDTre *)malloc(sizeof(SDTre));
999 if (sdt == NULL)
1000 return SDEmemory;
1001 if (df == sd->rf)
1002 sdt->sidef = SD_FREFL;
1003 else if (df == sd->rb)
1004 sdt->sidef = SD_BREFL;
1005 else if (df == sd->tf)
1006 sdt->sidef = SD_FXMIT;
1007 else /* df == sd->tb */
1008 sdt->sidef = SD_BXMIT;
1009 sdt->st = NULL;
1010 df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */
1011 df->comp[0].dist = sdt;
1012 df->comp[0].func = &SDhandleTre;
1013 /* read BSDF data */
1014 sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData"));
1015 if (!sdata || !next_token(&sdata)) {
1016 sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'",
1017 sd->name);
1018 return SDEformat;
1019 }
1020 sdt->st = load_tree_data(&sdata, ndim);
1021 if (sdt->st == NULL)
1022 return SDEformat;
1023 if (next_token(&sdata)) { /* check for unconsumed characters */
1024 sprintf(SDerrorDetail,
1025 "Extra characters at end of ScatteringData in '%s'",
1026 sd->name);
1027 return SDEformat;
1028 }
1029 /* flatten branches where possible */
1030 sdt->st = SDsimplifyTre(sdt->st);
1031 if (sdt->st == NULL)
1032 return SDEinternal;
1033 return get_extrema(df); /* compute global quantities */
1034 }
1035
1036 /* Find minimum value in tree */
1037 static float
1038 SDgetTreMin(const SDNode *st)
1039 {
1040 float vmin = FHUGE;
1041 int n;
1042
1043 if (st->log2GR < 0) {
1044 for (n = 1<<st->ndim; n--; ) {
1045 float v = SDgetTreMin(st->u.t[n]);
1046 if (v < vmin)
1047 vmin = v;
1048 }
1049 } else {
1050 for (n = 1<<(st->ndim*st->log2GR); n--; )
1051 if (st->u.v[n] < vmin)
1052 vmin = st->u.v[n];
1053 }
1054 return vmin;
1055 }
1056
1057 /* Subtract the given value from all tree nodes */
1058 static void
1059 SDsubtractTreVal(SDNode *st, float val)
1060 {
1061 int n;
1062
1063 if (st->log2GR < 0) {
1064 for (n = 1<<st->ndim; n--; )
1065 SDsubtractTreVal(st->u.t[n], val);
1066 } else {
1067 for (n = 1<<(st->ndim*st->log2GR); n--; )
1068 if ((st->u.v[n] -= val) < 0)
1069 st->u.v[n] = .0f;
1070 }
1071 }
1072
1073 /* Subtract minimum value from BSDF */
1074 static double
1075 subtract_min(SDNode *st)
1076 {
1077 float vmin;
1078 /* be sure to skip unused portion */
1079 if (st->ndim == 3) {
1080 int n;
1081 vmin = 1./M_PI;
1082 if (st->log2GR < 0) {
1083 for (n = 0; n < 8; n += 2) {
1084 float v = SDgetTreMin(st->u.t[n]);
1085 if (v < vmin)
1086 vmin = v;
1087 }
1088 } else if (st->log2GR) {
1089 for (n = 1 << (3*st->log2GR - 1); n--; )
1090 if (st->u.v[n] < vmin)
1091 vmin = st->u.v[n];
1092 } else
1093 vmin = st->u.v[0];
1094 } else /* anisotropic covers entire tree */
1095 vmin = SDgetTreMin(st);
1096
1097 if (vmin <= FTINY)
1098 return .0;
1099
1100 SDsubtractTreVal(st, vmin);
1101
1102 return M_PI * vmin; /* return hemispherical value */
1103 }
1104
1105 /* Extract and separate diffuse portion of BSDF */
1106 static void
1107 extract_diffuse(SDValue *dv, SDSpectralDF *df)
1108 {
1109 int n;
1110
1111 if (df == NULL || df->ncomp <= 0) {
1112 dv->spec = c_dfcolor;
1113 dv->cieY = .0;
1114 return;
1115 }
1116 dv->spec = df->comp[0].cspec[0];
1117 dv->cieY = subtract_min((*(SDTre *)df->comp[0].dist).st);
1118 /* in case of multiple components */
1119 for (n = df->ncomp; --n; ) {
1120 double ymin = subtract_min((*(SDTre *)df->comp[n].dist).st);
1121 c_cmix(&dv->spec, dv->cieY, &dv->spec, ymin, &df->comp[n].cspec[0]);
1122 dv->cieY += ymin;
1123 }
1124 df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */
1125 /* make sure everything is set */
1126 c_ccvt(&dv->spec, C_CSXY+C_CSSPEC);
1127 }
1128
1129 /* Load a variable-resolution BSDF tree from an open XML file */
1130 SDError
1131 SDloadTre(SDData *sd, ezxml_t wtl)
1132 {
1133 SDError ec;
1134 ezxml_t wld, wdb;
1135 int rank;
1136 char *txt;
1137 /* basic checks and tensor rank */
1138 txt = ezxml_txt(ezxml_child(ezxml_child(wtl,
1139 "DataDefinition"), "IncidentDataStructure"));
1140 if (txt == NULL || !*txt) {
1141 sprintf(SDerrorDetail,
1142 "BSDF \"%s\": missing IncidentDataStructure",
1143 sd->name);
1144 return SDEformat;
1145 }
1146 if (!strcasecmp(txt, "TensorTree3"))
1147 rank = 3;
1148 else if (!strcasecmp(txt, "TensorTree4"))
1149 rank = 4;
1150 else {
1151 sprintf(SDerrorDetail,
1152 "BSDF \"%s\": unsupported IncidentDataStructure",
1153 sd->name);
1154 return SDEsupport;
1155 }
1156 /* load BSDF components */
1157 for (wld = ezxml_child(wtl, "WavelengthData");
1158 wld != NULL; wld = wld->next) {
1159 if (strcasecmp(ezxml_txt(ezxml_child(wld,"Wavelength")),
1160 "Visible"))
1161 continue; /* just visible for now */
1162 for (wdb = ezxml_child(wld, "WavelengthDataBlock");
1163 wdb != NULL; wdb = wdb->next)
1164 if ((ec = load_bsdf_data(sd, wdb, rank)) != SDEnone)
1165 return ec;
1166 }
1167 /* separate diffuse components */
1168 extract_diffuse(&sd->rLambFront, sd->rf);
1169 extract_diffuse(&sd->rLambBack, sd->rb);
1170 if (sd->tf != NULL)
1171 extract_diffuse(&sd->tLamb, sd->tf);
1172 if (sd->tb != NULL)
1173 extract_diffuse(&sd->tLamb, sd->tb);
1174 /* return success */
1175 return SDEnone;
1176 }
1177
1178 /* Variable resolution BSDF methods */
1179 SDFunc SDhandleTre = {
1180 &SDgetTreBSDF,
1181 &SDqueryTreProjSA,
1182 &SDgetTreCDist,
1183 &SDsampTreCDist,
1184 &SDFreeBTre,
1185 };
