root/radiance/ray/src/common/bsdf_t.c
Revision: 3.28
Committed: Thu Jul 4 01:22:47 2013 UTC (12 years, 1 month ago) by greg
Changes since 3.27: +2 -2 lines
Removed last memory error caused by stray ray samples
2 static const char RCSid[] = "$Id: bsdf_t.c,v 3.27 2013/04/23 17:25:23 greg Exp $";
5 * bsdf_t.c
6 *
7 * Definitions for variable-resolution BSDF trees
8 *
9 * Created by Greg Ward on 2/2/11.
10 *
11 */
12
13 #define _USE_MATH_DEFINES
14 #include "rtio.h"
15 #include <stdlib.h>
16 #include <math.h>
17 #include <ctype.h>
18 #include "ezxml.h"
19 #include "bsdf.h"
20 #include "bsdf_t.h"
21 #include "hilbert.h"
22
23 /* Callback function type for SDtraverseTre() */
24 typedef int SDtreCallback(float val, const double *cmin,
25 double csiz, void *cptr);
26
27 /* reference width maximum (1.0) */
28 static const unsigned iwbits = sizeof(unsigned)*4;
29 static const unsigned iwmax = 1<<(sizeof(unsigned)*4);
30 /* maximum cumulative value */
31 static const unsigned cumlmax = ~0;
32 /* constant z-vector */
33 static const FVECT zvec = {.0, .0, 1.};
34 /* quantization value */
35 static double quantum = 1./256.;
36
37 /* Struct used for our distribution-building callback */
38 typedef struct {
39 short nic; /* number of input coordinates */
40 short rev; /* reversing query */
41 unsigned alen; /* current array length */
42 unsigned nall; /* number of allocated entries */
43 unsigned wmin; /* minimum square size so far */
44 unsigned wmax; /* maximum square size */
45 struct outdir_s {
46 unsigned hent; /* entering Hilbert index */
47 int wid; /* this square size */
48 float bsdf; /* BSDF for this square */
49 } *darr; /* output direction array */
50 } SDdistScaffold;
51
52 /* Allocate a new scattering distribution node */
53 static SDNode *
54 SDnewNode(int nd, int lg)
55 {
56 SDNode *st;
57
58 if (nd <= 0) {
59 strcpy(SDerrorDetail, "Zero dimension BSDF node request");
60 return NULL;
61 }
62 if (nd > SD_MAXDIM) {
63 sprintf(SDerrorDetail, "Illegal BSDF dimension (%d > %d)",
64 nd, SD_MAXDIM);
65 return NULL;
66 }
67 if (lg < 0) {
68 st = (SDNode *)malloc(sizeof(SDNode) +
69 sizeof(st->u.t[0])*((1<<nd) - 1));
70 if (st == NULL) {
71 sprintf(SDerrorDetail,
72 "Cannot allocate %d branch BSDF tree", 1<<nd);
73 return NULL;
74 }
75 memset(st->u.t, 0, sizeof(st->u.t[0])<<nd);
76 } else {
77 st = (SDNode *)malloc(sizeof(SDNode) +
78 sizeof(st->u.v[0])*((1 << nd*lg) - 1));
79 if (st == NULL) {
80 sprintf(SDerrorDetail,
81 "Cannot allocate %d BSDF leaves", 1 << nd*lg);
82 return NULL;
83 }
84 }
85 st->ndim = nd;
86 st->log2GR = lg;
87 return st;
88 }
89
90 /* Free an SD tree */
91 static void
92 SDfreeTre(SDNode *st)
93 {
94 int n;
95
96 if (st == NULL)
97 return;
98 for (n = (st->log2GR < 0) << st->ndim; n--; )
99 SDfreeTre(st->u.t[n]);
100 free(st);
101 }
102
103 /* Free a variable-resolution BSDF */
104 static void
105 SDFreeBTre(void *p)
106 {
107 SDTre *sdt = (SDTre *)p;
108
109 if (sdt == NULL)
110 return;
111 SDfreeTre(sdt->st);
112 free(sdt);
113 }
114
115 /* Fill branch's worth of grid values from subtree */
116 static void
117 fill_grid_branch(float *dptr, const float *sptr, int nd, int shft)
118 {
119 unsigned n = 1 << (shft-1);
120
121 if (!--nd) { /* end on the line */
122 memcpy(dptr, sptr, sizeof(*dptr)*n);
123 return;
124 }
125 while (n--) /* recurse on each slice */
126 fill_grid_branch(dptr + (n << shft*nd),
127 sptr + (n << (shft-1)*nd), nd, shft);
128 }
129
130 /* Get pointer at appropriate offset for the given branch */
131 static float *
132 grid_branch_start(SDNode *st, int n)
133 {
134 unsigned skipsiz = 1 << (st->log2GR - 1);
135 float *vptr = st->u.v;
136 int i;
137
138 for (i = st->ndim; i--; skipsiz <<= st->log2GR)
139 if (1<<i & n)
140 vptr += skipsiz;
141 return vptr;
142 }
143
144 /* Simplify (consolidate) a tree by flattening uniform depth regions */
145 static SDNode *
146 SDsimplifyTre(SDNode *st)
147 {
148 int match, n;
149
150 if (st == NULL) /* check for invalid tree */
151 return NULL;
152 if (st->log2GR >= 0) /* grid just returns unaltered */
153 return st;
154 match = 1; /* check if grids below match */
155 for (n = 0; n < 1<<st->ndim; n++) {
156 if ((st->u.t[n] = SDsimplifyTre(st->u.t[n])) == NULL)
157 return NULL; /* propogate error up call stack */
158 match &= (st->u.t[n]->log2GR == st->u.t[0]->log2GR);
159 }
160 if (match && (match = st->u.t[0]->log2GR) >= 0) {
161 SDNode *stn = SDnewNode(st->ndim, match + 1);
162 if (stn == NULL) /* out of memory? */
163 return st;
164 /* transfer values to new grid */
165 for (n = 1 << st->ndim; n--; )
166 fill_grid_branch(grid_branch_start(stn, n),
167 st->u.t[n]->u.v, stn->ndim, stn->log2GR);
168 SDfreeTre(st); /* free old tree */
169 st = stn; /* return new one */
170 }
171 return st;
172 }
173
174 /* Find smallest leaf in tree */
175 static double
176 SDsmallestLeaf(const SDNode *st)
177 {
178 if (st->log2GR < 0) { /* tree branches */
179 double lmin = 1.;
180 int n;
181 for (n = 1<<st->ndim; n--; ) {
182 double lsiz = SDsmallestLeaf(st->u.t[n]);
183 if (lsiz < lmin)
184 lmin = lsiz;
185 }
186 return .5*lmin;
187 }
188 /* leaf grid width */
189 return 1. / (double)(1 << st->log2GR);
190 }
191
192 /* Add up N-dimensional hypercube array values over the given box */
193 static double
194 SDiterSum(const float *va, int nd, int shft, const int *imin, const int *imax)
195 {
196 const unsigned skipsiz = 1 << --nd*shft;
197 double sum = .0;
198 int i;
199
200 va += *imin * skipsiz;
201
202 if (skipsiz == 1)
203 for (i = *imin; i < *imax; i++)
204 sum += *va++;
205 else
206 for (i = *imin; i < *imax; i++, va += skipsiz)
207 sum += SDiterSum(va, nd, shft, imin+1, imax+1);
208 return sum;
209 }
210
211 /* Average BSDF leaves over an orthotope defined by the unit hypercube */
212 static double
213 SDavgTreBox(const SDNode *st, const double *bmin, const double *bmax)
214 {
215 unsigned n;
216 int i;
217
218 if (!st)
219 return .0;
220 /* check box limits */
221 for (i = st->ndim; i--; ) {
222 if (bmin[i] >= 1.)
223 return .0;
224 if (bmax[i] <= 0)
225 return .0;
226 if (bmin[i] >= bmax[i])
227 return .0;
228 }
229 if (st->log2GR < 0) { /* iterate on subtree */
230 double sum = .0, wsum = 1e-20;
231 double sbmin[SD_MAXDIM], sbmax[SD_MAXDIM], w;
232 for (n = 1 << st->ndim; n--; ) {
233 w = 1.;
234 for (i = st->ndim; i--; ) {
235 sbmin[i] = 2.*bmin[i];
236 sbmax[i] = 2.*bmax[i];
237 if (n & 1<<i) {
238 sbmin[i] -= 1.;
239 sbmax[i] -= 1.;
240 }
241 if (sbmin[i] < .0) sbmin[i] = .0;
242 if (sbmax[i] > 1.) sbmax[i] = 1.;
243 if (sbmin[i] >= sbmax[i]) {
244 w = .0;
245 break;
246 }
247 w *= sbmax[i] - sbmin[i];
248 }
249 if (w > 1e-10) {
250 sum += w * SDavgTreBox(st->u.t[n], sbmin, sbmax);
251 wsum += w;
252 }
253 }
254 return sum / wsum;
255 } else { /* iterate over leaves */
256 int imin[SD_MAXDIM], imax[SD_MAXDIM];
257
258 n = 1;
259 for (i = st->ndim; i--; ) {
260 imin[i] = (bmin[i] <= 0) ? 0 :
261 (int)((1 << st->log2GR)*bmin[i]);
262 imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) :
263 (int)((1 << st->log2GR)*bmax[i] + .999999);
264 n *= imax[i] - imin[i];
265 }
266 if (n)
267 return SDiterSum(st->u.v, st->ndim,
268 st->log2GR, imin, imax) / (double)n;
269 }
270 return .0;
271 }
272
273 /* Recursive call for SDtraverseTre() */
274 static int
275 SDdotravTre(const SDNode *st, const double *pos, int cmask,
276 SDtreCallback *cf, void *cptr,
277 const double *cmin, double csiz)
278 {
279 int rv, rval = 0;
280 double bmin[SD_MAXDIM];
281 int i, n;
282 /* in branches? */
283 if (st->log2GR < 0) {
284 unsigned skipmask = 0;
285 csiz *= .5;
286 for (i = st->ndim; i--; )
287 if (1<<i & cmask)
288 if (pos[i] < cmin[i] + csiz)
289 for (n = 1 << st->ndim; n--; ) {
290 if (n & 1<<i)
291 skipmask |= 1<<n;
292 }
293 else
294 for (n = 1 << st->ndim; n--; ) {
295 if (!(n & 1<<i))
296 skipmask |= 1<<n;
297 }
298 for (n = 1 << st->ndim; n--; ) {
299 if (1<<n & skipmask)
300 continue;
301 for (i = st->ndim; i--; )
302 if (1<<i & n)
303 bmin[i] = cmin[i] + csiz;
304 else
305 bmin[i] = cmin[i];
306
307 rval += rv = SDdotravTre(st->u.t[n], pos, cmask,
308 cf, cptr, bmin, csiz);
309 if (rv < 0)
310 return rv;
311 }
312 } else { /* else traverse leaves */
313 int clim[SD_MAXDIM][2];
314 int cpos[SD_MAXDIM];
315
316 if (st->log2GR == 0) /* short cut */
317 return (*cf)(st->u.v[0], cmin, csiz, cptr);
318
319 csiz /= (double)(1 << st->log2GR);
320 /* assign coord. ranges */
321 for (i = st->ndim; i--; )
322 if (1<<i & cmask) {
323 clim[i][0] = (pos[i] - cmin[i])/csiz;
324 /* check overflow from f.p. error */
325 clim[i][0] -= clim[i][0] >> st->log2GR;
326 clim[i][1] = clim[i][0] + 1;
327 } else {
328 clim[i][0] = 0;
329 clim[i][1] = 1 << st->log2GR;
330 }
331 #if (SD_MAXDIM == 4)
332 bmin[0] = cmin[0] + csiz*clim[0][0];
333 for (cpos[0] = clim[0][0]; cpos[0] < clim[0][1]; cpos[0]++) {
334 bmin[1] = cmin[1] + csiz*clim[1][0];
335 for (cpos[1] = clim[1][0]; cpos[1] < clim[1][1]; cpos[1]++) {
336 bmin[2] = cmin[2] + csiz*clim[2][0];
337 if (st->ndim == 3) {
338 cpos[2] = clim[2][0];
339 n = cpos[0];
340 for (i = 1; i < 3; i++)
341 n = (n << st->log2GR) + cpos[i];
342 for ( ; cpos[2] < clim[2][1]; cpos[2]++) {
343 rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr);
344 if (rv < 0)
345 return rv;
346 bmin[2] += csiz;
347 }
348 } else {
349 for (cpos[2] = clim[2][0]; cpos[2] < clim[2][1]; cpos[2]++) {
350 bmin[3] = cmin[3] + csiz*(cpos[3] = clim[3][0]);
351 n = cpos[0];
352 for (i = 1; i < 4; i++)
353 n = (n << st->log2GR) + cpos[i];
354 for ( ; cpos[3] < clim[3][1]; cpos[3]++) {
355 rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr);
356 if (rv < 0)
357 return rv;
358 bmin[3] += csiz;
359 }
360 bmin[2] += csiz;
361 }
362 }
363 bmin[1] += csiz;
364 }
365 bmin[0] += csiz;
366 }
367 #else
368 _!_ "broken code segment!"
369 #endif
370 }
371 return rval;
372 }
373
374 /* Traverse a tree, visiting nodes in a slice that fits partial position */
375 static int
376 SDtraverseTre(const SDNode *st, const double *pos, int cmask,
377 SDtreCallback *cf, void *cptr)
378 {
379 static double czero[SD_MAXDIM];
380 int i;
381 /* check arguments */
382 if ((st == NULL) | (cf == NULL))
383 return -1;
384 for (i = st->ndim; i--; )
385 if (1<<i & cmask && (pos[i] < 0) | (pos[i] >= 1.))
386 return -1;
387
388 return SDdotravTre(st, pos, cmask, cf, cptr, czero, 1.);
389 }
390
391 /* Look up tree value at the given grid position */
392 static float
393 SDlookupTre(const SDNode *st, const double *pos, double *hcube)
394 {
395 double spos[SD_MAXDIM];
396 int i, n, t;
397 /* initialize voxel return */
398 if (hcube) {
399 hcube[i = st->ndim] = 1.;
400 while (i--)
401 hcube[i] = .0;
402 }
403 /* climb the tree */
404 while (st->log2GR < 0) {
405 n = 0; /* move to appropriate branch */
406 if (hcube) hcube[st->ndim] *= .5;
407 for (i = st->ndim; i--; ) {
408 spos[i] = 2.*pos[i];
409 t = (spos[i] >= 1.);
410 n |= t<<i;
411 spos[i] -= (double)t;
412 if (hcube) hcube[i] += (double)t * hcube[st->ndim];
413 }
414 st = st->u.t[n]; /* avoids tail recursion */
415 pos = spos;
416 }
417 if (st->log2GR == 0) /* short cut */
418 return st->u.v[0];
419 n = t = 0; /* find grid array index */
420 for (i = st->ndim; i--; ) {
421 n += (int)((1<<st->log2GR)*pos[i]) << t;
422 t += st->log2GR;
423 }
424 if (hcube) { /* compute final hypercube */
425 hcube[st->ndim] /= (double)(1<<st->log2GR);
426 for (i = st->ndim; i--; )
427 hcube[i] += floor((1<<st->log2GR)*pos[i])*hcube[st->ndim];
428 }
429 return st->u.v[n]; /* no interpolation */
430 }
431
432 /* Query BSDF value and sample hypercube for the given vectors */
433 static float
434 SDqueryTre(const SDTre *sdt, const FVECT outVec, const FVECT inVec, double *hc)
435 {
436 const RREAL *vtmp;
437 FVECT rOutVec;
438 double gridPos[4];
439
440 switch (sdt->sidef) { /* whose side are you on? */
441 case SD_FREFL:
442 if ((outVec[2] < 0) | (inVec[2] < 0))
443 return -1.;
444 break;
445 case SD_BREFL:
446 if ((outVec[2] > 0) | (inVec[2] > 0))
447 return -1.;
448 break;
449 case SD_FXMIT:
450 if (outVec[2] > 0) {
451 if (inVec[2] > 0)
452 return -1.;
453 vtmp = outVec; outVec = inVec; inVec = vtmp;
454 } else if (inVec[2] < 0)
455 return -1.;
456 break;
457 case SD_BXMIT:
458 if (inVec[2] > 0) {
459 if (outVec[2] > 0)
460 return -1.;
461 vtmp = outVec; outVec = inVec; inVec = vtmp;
462 } else if (outVec[2] < 0)
463 return -1.;
464 break;
465 default:
466 return -1.;
467 }
468 /* convert vector coordinates */
469 if (sdt->st->ndim == 3) {
470 spinvector(rOutVec, outVec, zvec, -atan2(-inVec[1],-inVec[0]));
471 gridPos[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]);
472 SDdisk2square(gridPos+1, rOutVec[0], rOutVec[1]);
473 } else if (sdt->st->ndim == 4) {
474 SDdisk2square(gridPos, -inVec[0], -inVec[1]);
475 SDdisk2square(gridPos+2, outVec[0], outVec[1]);
476 } else
477 return -1.; /* should be internal error */
478
479 return SDlookupTre(sdt->st, gridPos, hc);
480 }
481
482 /* Compute non-diffuse component for variable-resolution BSDF */
483 static int
484 SDgetTreBSDF(float coef[SDmaxCh], const FVECT outVec,
485 const FVECT inVec, SDComponent *sdc)
486 {
487 /* check arguments */
488 if ((coef == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL)
489 || sdc->dist == NULL)
490 return 0;
491 /* get nearest BSDF value */
492 coef[0] = SDqueryTre((SDTre *)sdc->dist, outVec, inVec, NULL);
493 return (coef[0] >= 0); /* monochromatic for now */
494 }
495
496 /* Callback to build cumulative distribution using SDtraverseTre() */
497 static int
498 build_scaffold(float val, const double *cmin, double csiz, void *cptr)
499 {
500 SDdistScaffold *sp = (SDdistScaffold *)cptr;
501 int wid = csiz*(double)iwmax + .5;
502 double revcmin[2];
503 bitmask_t bmin[2], bmax[2];
504
505 if (sp->rev) { /* need to reverse sense? */
506 revcmin[0] = 1. - cmin[0] - csiz;
507 revcmin[1] = 1. - cmin[1] - csiz;
508 cmin = revcmin;
509 } else {
510 cmin += sp->nic; /* else skip to output coords */
511 }
512 if (wid < sp->wmin) /* new minimum width? */
513 sp->wmin = wid;
514 if (wid > sp->wmax) /* new maximum? */
515 sp->wmax = wid;
516 if (sp->alen >= sp->nall) { /* need more space? */
517 struct outdir_s *ndarr;
518 sp->nall += 1024;
519 ndarr = (struct outdir_s *)realloc(sp->darr,
520 sizeof(struct outdir_s)*sp->nall);
521 if (ndarr == NULL) {
522 sprintf(SDerrorDetail,
523 "Cannot grow scaffold to %u entries", sp->nall);
524 return -1; /* abort build */
525 }
526 sp->darr = ndarr;
527 }
528 /* find Hilbert entry index */
529 bmin[0] = cmin[0]*(double)iwmax + .5;
530 bmin[1] = cmin[1]*(double)iwmax + .5;
531 bmax[0] = bmin[0] + wid-1;
532 bmax[1] = bmin[1] + wid-1;
533 hilbert_box_vtx(2, sizeof(bitmask_t), iwbits, 1, bmin, bmax);
534 sp->darr[sp->alen].hent = hilbert_c2i(2, iwbits, bmin);
535 sp->darr[sp->alen].wid = wid;
536 sp->darr[sp->alen].bsdf = val;
537 sp->alen++; /* on to the next entry */
538 return 0;
539 }
540
541 /* Scaffold comparison function for qsort -- ascending Hilbert index */
542 static int
543 sscmp(const void *p1, const void *p2)
544 {
545 unsigned h1 = (*(const struct outdir_s *)p1).hent;
546 unsigned h2 = (*(const struct outdir_s *)p2).hent;
547
548 if (h1 > h2)
549 return 1;
550 if (h1 < h2)
551 return -1;
552 return 0;
553 }
554
555 /* Create a new cumulative distribution for the given input direction */
556 static SDTreCDst *
557 make_cdist(const SDTre *sdt, const double *invec, int rev)
558 {
559 SDdistScaffold myScaffold;
560 double pos[4];
561 int cmask;
562 SDTreCDst *cd;
563 struct outdir_s *sp;
564 double scale, cursum;
565 int i;
566 /* initialize scaffold */
567 myScaffold.wmin = iwmax;
568 myScaffold.wmax = 0;
569 myScaffold.nic = sdt->st->ndim - 2;
570 myScaffold.rev = rev;
571 myScaffold.alen = 0;
572 myScaffold.nall = 512;
573 myScaffold.darr = (struct outdir_s *)malloc(sizeof(struct outdir_s) *
574 myScaffold.nall);
575 if (myScaffold.darr == NULL)
576 return NULL;
577 /* set up traversal */
578 cmask = (1<<myScaffold.nic) - 1;
579 for (i = myScaffold.nic; i--; )
580 pos[i+2*rev] = invec[i];
581 cmask <<= 2*rev;
582 /* grow the distribution */
583 if (SDtraverseTre(sdt->st, pos, cmask,
584 &build_scaffold, &myScaffold) < 0) {
585 free(myScaffold.darr);
586 return NULL;
587 }
588 /* allocate result holder */
589 cd = (SDTreCDst *)malloc(sizeof(SDTreCDst) +
590 sizeof(cd->carr[0])*myScaffold.alen);
591 if (cd == NULL) {
592 sprintf(SDerrorDetail,
593 "Cannot allocate %u entry cumulative distribution",
594 myScaffold.alen);
595 free(myScaffold.darr);
596 return NULL;
597 }
598 cd->isodist = (myScaffold.nic == 1);
599 /* sort the distribution */
600 qsort(myScaffold.darr, cd->calen = myScaffold.alen,
601 sizeof(struct outdir_s), &sscmp);
602
603 /* record input range */
604 scale = myScaffold.wmin / (double)iwmax;
605 for (i = myScaffold.nic; i--; ) {
606 cd->clim[i][0] = floor(pos[i+2*rev]/scale) * scale;
607 cd->clim[i][1] = cd->clim[i][0] + scale;
608 }
609 if (cd->isodist) { /* avoid issue in SDqueryTreProjSA() */
610 cd->clim[1][0] = cd->clim[0][0];
611 cd->clim[1][1] = cd->clim[0][1];
612 }
613 cd->max_psa = myScaffold.wmax / (double)iwmax;
614 cd->max_psa *= cd->max_psa * M_PI;
615 if (rev)
616 cd->sidef = (sdt->sidef==SD_BXMIT) ? SD_FXMIT : SD_BXMIT;
617 else
618 cd->sidef = sdt->sidef;
619 cd->cTotal = 1e-20; /* compute directional total */
620 sp = myScaffold.darr;
621 for (i = myScaffold.alen; i--; sp++)
622 cd->cTotal += sp->bsdf * (double)sp->wid * sp->wid;
623 cursum = .0; /* go back and get cumulative values */
624 scale = (double)cumlmax / cd->cTotal;
625 sp = myScaffold.darr;
626 for (i = 0; i < cd->calen; i++, sp++) {
627 cd->carr[i].hndx = sp->hent;
628 cd->carr[i].cuml = scale*cursum + .5;
629 cursum += sp->bsdf * (double)sp->wid * sp->wid;
630 }
631 cd->carr[i].hndx = ~0; /* make final entry */
632 cd->carr[i].cuml = cumlmax;
633 cd->cTotal *= M_PI/(double)iwmax/iwmax;
634 /* all done, clean up and return */
635 free(myScaffold.darr);
636 return cd;
637 }
638
639 /* Find or allocate a cumulative distribution for the given incoming vector */
640 const SDCDst *
641 SDgetTreCDist(const FVECT inVec, SDComponent *sdc)
642 {
643 const SDTre *sdt;
644 double inCoord[2];
645 int i;
646 int mode;
647 SDTreCDst *cd, *cdlast;
648 /* check arguments */
649 if ((inVec == NULL) | (sdc == NULL) ||
650 (sdt = (SDTre *)sdc->dist) == NULL)
651 return NULL;
652 switch (mode = sdt->sidef) { /* check direction */
653 case SD_FREFL:
654 if (inVec[2] < 0)
655 return NULL;
656 break;
657 case SD_BREFL:
658 if (inVec[2] > 0)
659 return NULL;
660 break;
661 case SD_FXMIT:
662 if (inVec[2] < 0)
663 mode = SD_BXMIT;
664 break;
665 case SD_BXMIT:
666 if (inVec[2] > 0)
667 mode = SD_FXMIT;
668 break;
669 default:
670 return NULL;
671 }
672 if (sdt->st->ndim == 3) { /* isotropic BSDF? */
673 if (mode != sdt->sidef) /* XXX unhandled reciprocity */
674 return &SDemptyCD;
675 inCoord[0] = .5 - .5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]);
676 } else if (sdt->st->ndim == 4) {
677 if (mode != sdt->sidef) /* use reciprocity? */
678 SDdisk2square(inCoord, inVec[0], inVec[1]);
679 else
680 SDdisk2square(inCoord, -inVec[0], -inVec[1]);
681 } else
682 return NULL; /* should be internal error */
683 /* quantize to avoid f.p. errors */
684 for (i = sdt->st->ndim - 2; i--; )
685 inCoord[i] = floor(inCoord[i]/quantum)*quantum + .5*quantum;
686 cdlast = NULL; /* check for direction in cache list */
687 for (cd = (SDTreCDst *)sdc->cdList; cd != NULL;
688 cdlast = cd, cd = cd->next) {
689 if (cd->sidef != mode)
690 continue;
691 for (i = sdt->st->ndim - 2; i--; )
692 if ((cd->clim[i][0] > inCoord[i]) |
693 (inCoord[i] >= cd->clim[i][1]))
694 break;
695 if (i < 0)
696 break; /* means we have a match */
697 }
698 if (cd == NULL) /* need to create new entry? */
699 cdlast = cd = make_cdist(sdt, inCoord, mode != sdt->sidef);
700 if (cdlast != NULL) { /* move entry to head of cache list */
701 cdlast->next = cd->next;
702 cd->next = (SDTreCDst *)sdc->cdList;
703 sdc->cdList = (SDCDst *)cd;
704 }
705 return (SDCDst *)cd; /* ready to go */
706 }
707
708 /* Query solid angle for vector(s) */
709 static SDError
710 SDqueryTreProjSA(double *psa, const FVECT v1, const RREAL *v2,
711 int qflags, SDComponent *sdc)
712 {
713 double myPSA[2];
714 /* check arguments */
715 if ((psa == NULL) | (v1 == NULL) | (sdc == NULL) ||
716 sdc->dist == NULL)
717 return SDEargument;
718 /* get projected solid angle(s) */
719 if (v2 != NULL) {
720 const SDTre *sdt = (SDTre *)sdc->dist;
721 double hcube[SD_MAXDIM];
722 if (SDqueryTre(sdt, v1, v2, hcube) < 0) {
723 strcpy(SDerrorDetail, "Bad call to SDqueryTreProjSA");
724 return SDEinternal;
725 }
726 myPSA[0] = hcube[sdt->st->ndim];
727 myPSA[1] = myPSA[0] *= myPSA[0] * M_PI;
728 } else {
729 const SDTreCDst *cd = (const SDTreCDst *)SDgetTreCDist(v1, sdc);
730 if (cd == NULL)
731 cd = &SDemptyCD;
732 myPSA[0] = M_PI * (cd->clim[0][1] - cd->clim[0][0]) *
733 (cd->clim[1][1] - cd->clim[1][0]);
734 myPSA[1] = cd->max_psa;
735 }
736 switch (qflags) { /* record based on flag settings */
737 case SDqueryVal:
738 *psa = myPSA[0];
739 break;
740 case SDqueryMax:
741 if (myPSA[1] > *psa)
742 *psa = myPSA[1];
743 break;
744 case SDqueryMin+SDqueryMax:
745 if (myPSA[1] > psa[1])
746 psa[1] = myPSA[1];
747 /* fall through */
748 case SDqueryMin:
749 if (myPSA[0] < psa[0])
750 psa[0] = myPSA[0];
751 break;
752 }
753 return SDEnone;
754 }
755
756 /* Sample cumulative distribution */
757 static SDError
758 SDsampTreCDist(FVECT ioVec, double randX, const SDCDst *cdp)
759 {
760 const unsigned nBitsC = 4*sizeof(bitmask_t);
761 const unsigned nExtraBits = 8*(sizeof(bitmask_t)-sizeof(unsigned));
762 const SDTreCDst *cd = (const SDTreCDst *)cdp;
763 const unsigned target = randX*cumlmax;
764 bitmask_t hndx, hcoord[2];
765 double gpos[3], rotangle;
766 int i, iupper, ilower;
767 /* check arguments */
768 if ((ioVec == NULL) | (cd == NULL))
769 return SDEargument;
770 if (!cd->sidef)
771 return SDEnone; /* XXX should never happen */
772 if (ioVec[2] > 0) {
773 if ((cd->sidef != SD_FREFL) & (cd->sidef != SD_FXMIT))
774 return SDEargument;
775 } else if ((cd->sidef != SD_BREFL) & (cd->sidef != SD_BXMIT))
776 return SDEargument;
777 /* binary search to find position */
778 ilower = 0; iupper = cd->calen;
779 while ((i = (iupper + ilower) >> 1) != ilower)
780 if (target >= cd->carr[i].cuml)
781 ilower = i;
782 else
783 iupper = i;
784 /* localize random position */
785 randX = (randX*cumlmax - cd->carr[ilower].cuml) /
786 (double)(cd->carr[iupper].cuml - cd->carr[ilower].cuml);
787 /* index in longer Hilbert curve */
788 hndx = (randX*cd->carr[iupper].hndx + (1.-randX)*cd->carr[ilower].hndx)
789 * (double)((bitmask_t)1 << nExtraBits);
790 /* convert Hilbert index to vector */
791 hilbert_i2c(2, nBitsC, hndx, hcoord);
792 for (i = 2; i--; )
793 gpos[i] = ((double)hcoord[i] + rand()*(1./(RAND_MAX+.5))) /
794 (double)((bitmask_t)1 << nBitsC);
795 SDsquare2disk(gpos, gpos[0], gpos[1]);
796 /* compute Z-coordinate */
797 gpos[2] = 1. - gpos[0]*gpos[0] - gpos[1]*gpos[1];
798 if (gpos[2] > 0) /* paranoia, I hope */
799 gpos[2] = sqrt(gpos[2]);
800 /* emit from back? */
801 if ((cd->sidef == SD_BREFL) | (cd->sidef == SD_FXMIT))
802 gpos[2] = -gpos[2];
803 if (cd->isodist) { /* rotate isotropic result */
804 rotangle = atan2(-ioVec[1],-ioVec[0]);
805 VCOPY(ioVec, gpos);
806 spinvector(ioVec, ioVec, zvec, rotangle);
807 } else
808 VCOPY(ioVec, gpos);
809 return SDEnone;
810 }
811
812 /* Advance pointer to the next non-white character in the string (or nul) */
813 static int
814 next_token(char **spp)
815 {
816 while (isspace(**spp))
817 ++*spp;
818 return **spp;
819 }
820
821 /* Advance pointer past matching token (or any token if c==0) */
822 #define eat_token(spp,c) (next_token(spp)==(c) ^ !(c) ? *(*(spp))++ : 0)
823
824 /* Count words from this point in string to '}' */
825 static int
826 count_values(char *cp)
827 {
828 int n = 0;
829
830 while (next_token(&cp) != '}' && *cp) {
831 while (!isspace(*cp) & (*cp != ',') & (*cp != '}'))
832 if (!*++cp)
833 break;
834 ++n;
835 eat_token(&cp, ',');
836 }
837 return n;
838 }
839
840 /* Load an array of real numbers, returning total */
841 static int
842 load_values(char **spp, float *va, int n)
843 {
844 float *v = va;
845 char *svnext;
846
847 while (n-- > 0 && (svnext = fskip(*spp)) != NULL) {
848 *v++ = atof(*spp);
849 *spp = svnext;
850 eat_token(spp, ',');
851 }
852 return v - va;
853 }
854
855 /* Load BSDF tree data */
856 static SDNode *
857 load_tree_data(char **spp, int nd)
858 {
859 SDNode *st;
860 int n;
861
862 if (!eat_token(spp, '{')) {
863 strcpy(SDerrorDetail, "Missing '{' in tensor tree");
864 return NULL;
865 }
866 if (next_token(spp) == '{') { /* tree branches */
867 st = SDnewNode(nd, -1);
868 if (st == NULL)
869 return NULL;
870 for (n = 0; n < 1<<nd; n++)
871 if ((st->u.t[n] = load_tree_data(spp, nd)) == NULL) {
872 SDfreeTre(st);
873 return NULL;
874 }
875 } else { /* else load value grid */
876 int bsiz;
877 n = count_values(*spp); /* see how big the grid is */
878 for (bsiz = 0; bsiz < 8*sizeof(size_t); bsiz += nd)
879 if (1<<bsiz == n)
880 break;
881 if (bsiz >= 8*sizeof(size_t)) {
882 strcpy(SDerrorDetail, "Illegal value count in tensor tree");
883 return NULL;
884 }
885 st = SDnewNode(nd, bsiz/nd);
886 if (st == NULL)
887 return NULL;
888 if (load_values(spp, st->u.v, n) != n) {
889 strcpy(SDerrorDetail, "Real format error in tensor tree");
890 SDfreeTre(st);
891 return NULL;
892 }
893 }
894 if (!eat_token(spp, '}')) {
895 strcpy(SDerrorDetail, "Missing '}' in tensor tree");
896 SDfreeTre(st);
897 return NULL;
898 }
899 eat_token(spp, ',');
900 return st;
901 }
902
903 /* Compute min. proj. solid angle and max. direct hemispherical scattering */
904 static SDError
905 get_extrema(SDSpectralDF *df)
906 {
907 SDNode *st = (*(SDTre *)df->comp[0].dist).st;
908 double stepWidth, dhemi, bmin[4], bmax[4];
909
910 stepWidth = SDsmallestLeaf(st);
911 if (quantum > stepWidth) /* adjust quantization factor */
912 quantum = stepWidth;
913 df->minProjSA = M_PI*stepWidth*stepWidth;
914 if (stepWidth < .03125)
915 stepWidth = .03125; /* 1/32 resolution good enough */
916 df->maxHemi = .0;
917 if (st->ndim == 3) { /* isotropic BSDF */
918 bmin[1] = bmin[2] = .0;
919 bmax[1] = bmax[2] = 1.;
920 for (bmin[0] = .0; bmin[0] < .5-FTINY; bmin[0] += stepWidth) {
921 bmax[0] = bmin[0] + stepWidth;
922 dhemi = SDavgTreBox(st, bmin, bmax);
923 if (dhemi > df->maxHemi)
924 df->maxHemi = dhemi;
925 }
926 } else if (st->ndim == 4) { /* anisotropic BSDF */
927 bmin[2] = bmin[3] = .0;
928 bmax[2] = bmax[3] = 1.;
929 for (bmin[0] = .0; bmin[0] < 1.-FTINY; bmin[0] += stepWidth) {
930 bmax[0] = bmin[0] + stepWidth;
931 for (bmin[1] = .0; bmin[1] < 1.-FTINY; bmin[1] += stepWidth) {
932 bmax[1] = bmin[1] + stepWidth;
933 dhemi = SDavgTreBox(st, bmin, bmax);
934 if (dhemi > df->maxHemi)
935 df->maxHemi = dhemi;
936 }
937 }
938 } else
939 return SDEinternal;
940 /* correct hemispherical value */
941 df->maxHemi *= M_PI;
942 return SDEnone;
943 }
944
945 /* Load BSDF distribution for this wavelength */
946 static SDError
947 load_bsdf_data(SDData *sd, ezxml_t wdb, int ndim)
948 {
949 SDSpectralDF *df;
950 SDTre *sdt;
951 char *sdata;
952 /* allocate BSDF component */
953 sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection"));
954 if (!sdata)
955 return SDEnone;
956 /*
957 * Remember that front and back are reversed from WINDOW 6 orientations
958 */
959 if (!strcasecmp(sdata, "Transmission Front")) {
960 if (sd->tb != NULL)
961 SDfreeSpectralDF(sd->tb);
962 if ((sd->tb = SDnewSpectralDF(1)) == NULL)
963 return SDEmemory;
964 df = sd->tb;
965 } else if (!strcasecmp(sdata, "Transmission Back")) {
966 if (sd->tf != NULL)
967 SDfreeSpectralDF(sd->tf);
968 if ((sd->tf = SDnewSpectralDF(1)) == NULL)
969 return SDEmemory;
970 df = sd->tf;
971 } else if (!strcasecmp(sdata, "Reflection Front")) {
972 if (sd->rb != NULL)
973 SDfreeSpectralDF(sd->rb);
974 if ((sd->rb = SDnewSpectralDF(1)) == NULL)
975 return SDEmemory;
976 df = sd->rb;
977 } else if (!strcasecmp(sdata, "Reflection Back")) {
978 if (sd->rf != NULL)
979 SDfreeSpectralDF(sd->rf);
980 if ((sd->rf = SDnewSpectralDF(1)) == NULL)
981 return SDEmemory;
982 df = sd->rf;
983 } else
984 return SDEnone;
985 /* XXX should also check "ScatteringDataType" for consistency? */
986 /* get angle bases */
987 sdata = ezxml_txt(ezxml_child(wdb,"AngleBasis"));
988 if (!sdata || strcasecmp(sdata, "LBNL/Shirley-Chiu")) {
989 sprintf(SDerrorDetail, "%s angle basis for BSDF '%s'",
990 !sdata ? "Missing" : "Unsupported", sd->name);
991 return !sdata ? SDEformat : SDEsupport;
992 }
993 /* allocate BSDF tree */
994 sdt = (SDTre *)malloc(sizeof(SDTre));
995 if (sdt == NULL)
996 return SDEmemory;
997 if (df == sd->rf)
998 sdt->sidef = SD_FREFL;
999 else if (df == sd->rb)
1000 sdt->sidef = SD_BREFL;
1001 else if (df == sd->tf)
1002 sdt->sidef = SD_FXMIT;
1003 else /* df == sd->tb */
1004 sdt->sidef = SD_BXMIT;
1005 sdt->st = NULL;
1006 df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */
1007 df->comp[0].dist = sdt;
1008 df->comp[0].func = &SDhandleTre;
1009 /* read BSDF data */
1010 sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData"));
1011 if (!sdata || !next_token(&sdata)) {
1012 sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'",
1013 sd->name);
1014 return SDEformat;
1015 }
1016 sdt->st = load_tree_data(&sdata, ndim);
1017 if (sdt->st == NULL)
1018 return SDEformat;
1019 if (next_token(&sdata)) { /* check for unconsumed characters */
1020 sprintf(SDerrorDetail,
1021 "Extra characters at end of ScatteringData in '%s'",
1022 sd->name);
1023 return SDEformat;
1024 }
1025 /* flatten branches where possible */
1026 sdt->st = SDsimplifyTre(sdt->st);
1027 if (sdt->st == NULL)
1028 return SDEinternal;
1029 return get_extrema(df); /* compute global quantities */
1030 }
1031
1032 /* Find minimum value in tree */
1033 static float
1034 SDgetTreMin(const SDNode *st)
1035 {
1036 float vmin = FHUGE;
1037 int n;
1038
1039 if (st->log2GR < 0) {
1040 for (n = 1<<st->ndim; n--; ) {
1041 float v = SDgetTreMin(st->u.t[n]);
1042 if (v < vmin)
1043 vmin = v;
1044 }
1045 } else {
1046 for (n = 1<<(st->ndim*st->log2GR); n--; )
1047 if (st->u.v[n] < vmin)
1048 vmin = st->u.v[n];
1049 }
1050 return vmin;
1051 }
1052
1053 /* Subtract the given value from all tree nodes */
1054 static void
1055 SDsubtractTreVal(SDNode *st, float val)
1056 {
1057 int n;
1058
1059 if (st->log2GR < 0) {
1060 for (n = 1<<st->ndim; n--; )
1061 SDsubtractTreVal(st->u.t[n], val);
1062 } else {
1063 for (n = 1<<(st->ndim*st->log2GR); n--; )
1064 if ((st->u.v[n] -= val) < 0)
1065 st->u.v[n] = .0f;
1066 }
1067 }
1068
1069 /* Subtract minimum value from BSDF */
1070 static double
1071 subtract_min(SDNode *st)
1072 {
1073 float vmin;
1074 /* be sure to skip unused portion */
1075 if (st->ndim == 3) {
1076 int n;
1077 vmin = 1./M_PI;
1078 if (st->log2GR < 0) {
1079 for (n = 0; n < 8; n += 2) {
1080 float v = SDgetTreMin(st->u.t[n]);
1081 if (v < vmin)
1082 vmin = v;
1083 }
1084 } else if (st->log2GR) {
1085 for (n = 1 << (3*st->log2GR - 1); n--; )
1086 if (st->u.v[n] < vmin)
1087 vmin = st->u.v[n];
1088 } else
1089 vmin = st->u.v[0];
1090 } else /* anisotropic covers entire tree */
1091 vmin = SDgetTreMin(st);
1092
1093 if (vmin <= FTINY)
1094 return .0;
1095
1096 SDsubtractTreVal(st, vmin);
1097
1098 return M_PI * vmin; /* return hemispherical value */
1099 }
1100
1101 /* Extract and separate diffuse portion of BSDF */
1102 static void
1103 extract_diffuse(SDValue *dv, SDSpectralDF *df)
1104 {
1105 int n;
1106
1107 if (df == NULL || df->ncomp <= 0) {
1108 dv->spec = c_dfcolor;
1109 dv->cieY = .0;
1110 return;
1111 }
1112 dv->spec = df->comp[0].cspec[0];
1113 dv->cieY = subtract_min((*(SDTre *)df->comp[0].dist).st);
1114 /* in case of multiple components */
1115 for (n = df->ncomp; --n; ) {
1116 double ymin = subtract_min((*(SDTre *)df->comp[n].dist).st);
1117 c_cmix(&dv->spec, dv->cieY, &dv->spec, ymin, &df->comp[n].cspec[0]);
1118 dv->cieY += ymin;
1119 }
1120 df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */
1121 /* make sure everything is set */
1122 c_ccvt(&dv->spec, C_CSXY+C_CSSPEC);
1123 }
1124
1125 /* Load a variable-resolution BSDF tree from an open XML file */
1126 SDError
1127 SDloadTre(SDData *sd, ezxml_t wtl)
1128 {
1129 SDError ec;
1130 ezxml_t wld, wdb;
1131 int rank;
1132 char *txt;
1133 /* basic checks and tensor rank */
1134 txt = ezxml_txt(ezxml_child(ezxml_child(wtl,
1135 "DataDefinition"), "IncidentDataStructure"));
1136 if (txt == NULL || !*txt) {
1137 sprintf(SDerrorDetail,
1138 "BSDF \"%s\": missing IncidentDataStructure",
1139 sd->name);
1140 return SDEformat;
1141 }
1142 if (!strcasecmp(txt, "TensorTree3"))
1143 rank = 3;
1144 else if (!strcasecmp(txt, "TensorTree4"))
1145 rank = 4;
1146 else {
1147 sprintf(SDerrorDetail,
1148 "BSDF \"%s\": unsupported IncidentDataStructure",
1149 sd->name);
1150 return SDEsupport;
1151 }
1152 /* load BSDF components */
1153 for (wld = ezxml_child(wtl, "WavelengthData");
1154 wld != NULL; wld = wld->next) {
1155 if (strcasecmp(ezxml_txt(ezxml_child(wld,"Wavelength")),
1156 "Visible"))
1157 continue; /* just visible for now */
1158 for (wdb = ezxml_child(wld, "WavelengthDataBlock");
1159 wdb != NULL; wdb = wdb->next)
1160 if ((ec = load_bsdf_data(sd, wdb, rank)) != SDEnone)
1161 return ec;
1162 }
1163 /* separate diffuse components */
1164 extract_diffuse(&sd->rLambFront, sd->rf);
1165 extract_diffuse(&sd->rLambBack, sd->rb);
1166 if (sd->tf != NULL)
1167 extract_diffuse(&sd->tLamb, sd->tf);
1168 if (sd->tb != NULL)
1169 extract_diffuse(&sd->tLamb, sd->tb);
1170 /* return success */
1171 return SDEnone;
1172 }
1173
1174 /* Variable resolution BSDF methods */
1175 SDFunc SDhandleTre = {
1176 &SDgetTreBSDF,
1177 &SDqueryTreProjSA,
1178 &SDgetTreCDist,
1179 &SDsampTreCDist,
1180 &SDFreeBTre,
1181 };
