root/radiance/ray/src/common/bsdf_t.c
Revision 3.23 - (view) (download) (annotate) - [selected]
Mon Aug 22 18:21:05 2011 UTC (13 years, 8 months ago) by greg
Diff to previous 3.22
Fixed bug in Hilbert conversion
Mon Aug 22 14:19:49 2011 UTC (13 years, 8 months ago) by greg
Changes since 3.21: +6 -3 lines
Diff to previous 3.21 , to selected 3.23
Fixed performance issue caused by last change
Mon Aug 22 05:48:39 2011 UTC (13 years, 8 months ago) by greg
Changes since 3.20: +9 -5 lines
Diff to previous 3.20 , to selected 3.23
Fixed floating point epsilon errors in position branch testing
Sun Aug 21 22:38:12 2011 UTC (13 years, 8 months ago) by greg
Changes since 3.19: +3 -3 lines
Diff to previous 3.19 , to selected 3.23
Minor improvements to direct specular sampling
Thu Jul 7 15:25:09 2011 UTC (13 years, 9 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.23
Fixed bug for MING32 and non-square matrices, allowing multiple angle bases
Tue Jun 28 21:13:46 2011 UTC (13 years, 10 months ago) by greg
Changes since 3.17: +1 -3 lines
Diff to previous 3.17 , to selected 3.23
Minor compile fixes
Thu Jun 9 17:09:39 2011 UTC (13 years, 10 months ago) by greg
Changes since 3.16: +2 -1 lines
Diff to previous 3.16 , to selected 3.23
Fixes for Windows and bug fix in bsdf_m.c
Sun Jun 5 20:27:14 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.15: +20 -13 lines
Diff to previous 3.15 , to selected 3.23
Fixed comments and potential bug in BSDF tree traversal
Fri Jun 3 18:12:58 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.14: +43 -26 lines
Diff to previous 3.14 , to selected 3.23
Fixed bugs in variable-resolution isotropic BSDFs
Wed Jun 1 05:21:18 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.13: +6 -6 lines
Diff to previous 3.13 , to selected 3.23
Bug fix in tree consolidation routine
Wed Jun 1 00:29:40 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.12: +10 -5 lines
Diff to previous 3.12 , to selected 3.23
Sun May 1 16:34:37 2011 UTC (14 years ago) by greg
Changes since 3.11: +25 -18 lines
Diff to previous 3.11 , to selected 3.23
Minor fixes and improvements
Thu Apr 28 17:46:25 2011 UTC (14 years ago) by greg
Changes since 3.10: +4 -13 lines
Diff to previous 3.10 , to selected 3.23
Minor fixes
Thu Apr 28 04:05:11 2011 UTC (14 years ago) by greg
Changes since 3.9: +32 -17 lines
Diff to previous 3.9 , to selected 3.23
First tested version
Wed Apr 27 23:05:51 2011 UTC (14 years ago) by greg
Changes since 3.8: +14 -14 lines
Diff to previous 3.8 , to selected 3.23
First test of variable-res BSDFs
Wed Apr 27 20:05:15 2011 UTC (14 years ago) by greg
Changes since 3.7: +2 -2 lines
Diff to previous 3.7 , to selected 3.23
Fixed typo
Wed Apr 27 20:03:25 2011 UTC (14 years ago) by greg
Changes since 3.6: +467 -32 lines
Diff to previous 3.6 , to selected 3.23
Initial untested variable-resolution BSDF
Sun Apr 24 19:39:21 2011 UTC (14 years ago) by greg
Changes since 3.5: +437 -31 lines
Diff to previous 3.5 , to selected 3.23
Partial implementation of variable-resolution BSDFs
Tue Apr 19 21:31:22 2011 UTC (14 years ago) by greg
Changes since 3.4: +61 -7 lines
Diff to previous 3.4 , to selected 3.23
Fixed interface for determining BSDF solid angles
Sat Feb 19 01:48:59 2011 UTC (14 years, 2 months ago) by greg
Changes since 3.3: +2 -2 lines
Diff to previous 3.3 , to selected 3.23
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 02:41:55 2011 UTC (14 years, 2 months ago) by greg
Changes since 3.2: +4 -2 lines
Diff to previous 3.2 , to selected 3.23
Minor fixes and adjustments
Fri Feb 18 00:41:44 2011 UTC (14 years, 2 months ago) by greg
Changes since 3.1: +3 -0 lines
Diff to previous 3.1 , to selected 3.23
Added missing RCS tags
Fri Feb 18 00:40:25 2011 UTC (14 years, 2 months ago) by greg
Diff to selected 3.23
