| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: bsdf_t.c,v 3.53 2021/12/15 01:38:50 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* bsdf_t.c
| 6 |
| 7 |
* Definitions for variable-resolution BSDF trees
| 8 |
| 9 |
* Created by Greg Ward on 2/2/11.
| 10 |
| 11 |
| 12 |
| 13 |
#define _USE_MATH_DEFINES
| 14 |
#include "rtio.h"
| 15 |
#include <stdlib.h>
| 16 |
#include <math.h>
| 17 |
#include <ctype.h>
| 18 |
#include "ezxml.h"
| 19 |
#include "bsdf.h"
| 20 |
#include "bsdf_t.h"
| 21 |
#include "hilbert.h"
| 22 |
| 23 |
/* Callback function type for SDtraverseTre() */
| 24 |
typedef int SDtreCallback(float val, const double *cmin, double csiz,
| 25 |
void *cptr);
| 26 |
/* reference width maximum (1.0) */
| 27 |
static const unsigned iwbits = sizeof(unsigned)*4;
| 28 |
static const unsigned iwmax = 1<<(sizeof(unsigned)*4);
| 29 |
/* maximum cumulative value */
| 30 |
static const unsigned cumlmax = ~0;
| 31 |
/* constant z-vector */
| 32 |
static const FVECT zvec = {.0, .0, 1.};
| 33 |
/* quantization value */
| 34 |
static double quantum = 1./256.;
| 35 |
/* our RGB primaries */
| 36 |
static C_COLOR tt_RGB_prim[3];
| 37 |
static float tt_RGB_coef[3];
| 38 |
| 39 |
static const double czero[SD_MAXDIM];
| 40 |
| 41 |
enum {tt_Y, tt_u, tt_v}; /* tree components (tt_Y==0) */
| 42 |
| 43 |
/* Struct used for our distribution-building callback */
| 44 |
typedef struct {
| 45 |
short nic; /* number of input coordinates */
| 46 |
short rev; /* reversing query */
| 47 |
unsigned alen; /* current array length */
| 48 |
unsigned nall; /* number of allocated entries */
| 49 |
unsigned wmin; /* minimum square size so far */
| 50 |
unsigned wmax; /* maximum square size */
| 51 |
struct outdir_s {
| 52 |
unsigned hent; /* entering Hilbert index */
| 53 |
int wid; /* this square size */
| 54 |
float bsdf; /* BSDF for this square */
| 55 |
} *darr; /* output direction array */
| 56 |
} SDdistScaffold;
| 57 |
| 58 |
/* Allocate a new scattering distribution node */
| 59 |
static SDNode *
| 60 |
SDnewNode(int nd, int lg)
| 61 |
| 62 |
SDNode *st;
| 63 |
| 64 |
if (nd <= 0) {
| 65 |
strcpy(SDerrorDetail, "Zero dimension BSDF node request");
| 66 |
return NULL;
| 67 |
| 68 |
if (nd > SD_MAXDIM) {
| 69 |
sprintf(SDerrorDetail, "Illegal BSDF dimension (%d > %d)",
| 70 |
nd, SD_MAXDIM);
| 71 |
return NULL;
| 72 |
| 73 |
if (lg < 0) {
| 74 |
st = (SDNode *)malloc(sizeof(SDNode) +
| 75 |
sizeof(st->u.t[0])*((1<<nd) - 1));
| 76 |
if (st == NULL) {
| 77 |
| 78 |
"Cannot allocate %d branch BSDF tree", 1<<nd);
| 79 |
return NULL;
| 80 |
| 81 |
memset(st->u.t, 0, sizeof(st->u.t[0])<<nd);
| 82 |
} else {
| 83 |
| 84 |
sizeof(st->u.v[0])*((1 << nd*lg) - 1));
| 85 |
if (st == NULL) {
| 86 |
| 87 |
"Cannot allocate %d BSDF leaves", 1 << nd*lg);
| 88 |
return NULL;
| 89 |
| 90 |
| 91 |
st->ndim = nd;
| 92 |
st->log2GR = lg;
| 93 |
return st;
| 94 |
| 95 |
| 96 |
/* Free an SD tree */
| 97 |
static void
| 98 |
SDfreeTre(SDNode *st)
| 99 |
| 100 |
int n;
| 101 |
| 102 |
if (st == NULL)
| 103 |
return;
| 104 |
for (n = (st->log2GR < 0) << st->ndim; n--; )
| 105 |
SDfreeTre(st->u.t[n]);
| 106 |
free(st);
| 107 |
| 108 |
| 109 |
/* Free a variable-resolution BSDF */
| 110 |
static void
| 111 |
SDFreeBTre(void *p)
| 112 |
| 113 |
SDTre *sdt = (SDTre *)p;
| 114 |
| 115 |
if (sdt == NULL)
| 116 |
return;
| 117 |
SDfreeTre(sdt->stc[tt_Y]);
| 118 |
SDfreeTre(sdt->stc[tt_u]);
| 119 |
SDfreeTre(sdt->stc[tt_v]);
| 120 |
free(sdt);
| 121 |
| 122 |
| 123 |
/* Fill branch's worth of grid values from subtree */
| 124 |
static void
| 125 |
fill_grid_branch(float *dptr, const float *sptr, int nd, int shft)
| 126 |
| 127 |
unsigned n = 1 << (shft-1);
| 128 |
| 129 |
if (!--nd) { /* end on the line */
| 130 |
memcpy(dptr, sptr, sizeof(*dptr)*n);
| 131 |
return;
| 132 |
| 133 |
while (n--) /* recurse on each slice */
| 134 |
fill_grid_branch(dptr + (n << shft*nd),
| 135 |
sptr + (n << (shft-1)*nd), nd, shft);
| 136 |
| 137 |
| 138 |
/* Get pointer at appropriate offset for the given branch */
| 139 |
static float *
| 140 |
grid_branch_start(SDNode *st, int n)
| 141 |
| 142 |
unsigned skipsiz = 1 << (st->log2GR - 1);
| 143 |
float *vptr = st->u.v;
| 144 |
int i;
| 145 |
| 146 |
for (i = st->ndim; i--; skipsiz <<= st->log2GR)
| 147 |
if (1<<i & n)
| 148 |
vptr += skipsiz;
| 149 |
return vptr;
| 150 |
| 151 |
| 152 |
/* Simplify (consolidate) a tree by flattening uniform depth regions */
| 153 |
static SDNode *
| 154 |
SDsimplifyTre(SDNode *st)
| 155 |
| 156 |
int match, n;
| 157 |
| 158 |
if (st == NULL) /* check for invalid tree */
| 159 |
return NULL;
| 160 |
if (st->log2GR >= 0) /* grid just returns unaltered */
| 161 |
return st;
| 162 |
match = 1; /* check if grids below match */
| 163 |
for (n = 0; n < 1<<st->ndim; n++) {
| 164 |
if ((st->u.t[n] = SDsimplifyTre(st->u.t[n])) == NULL)
| 165 |
return NULL; /* propogate error up call stack */
| 166 |
match &= (st->u.t[n]->log2GR == st->u.t[0]->log2GR);
| 167 |
| 168 |
if (match && (match = st->u.t[0]->log2GR) >= 0) {
| 169 |
SDNode *stn = SDnewNode(st->ndim, match + 1);
| 170 |
if (stn == NULL) /* out of memory? */
| 171 |
return st;
| 172 |
/* transfer values to new grid */
| 173 |
for (n = 1 << st->ndim; n--; )
| 174 |
fill_grid_branch(grid_branch_start(stn, n),
| 175 |
st->u.t[n]->u.v, stn->ndim, stn->log2GR);
| 176 |
SDfreeTre(st); /* free old tree */
| 177 |
st = stn; /* return new one */
| 178 |
| 179 |
return st;
| 180 |
| 181 |
| 182 |
/* Assign the given voxel in tree (produces no grid nodes) */
| 183 |
static SDNode *
| 184 |
SDsetVoxel(SDNode *sroot, int nd, const double *tmin, const double tsiz, float val)
| 185 |
| 186 |
double ctrk[SD_MAXDIM];
| 187 |
double csiz = 1.;
| 188 |
SDNode *st;
| 189 |
int i, n;
| 190 |
/* check arguments */
| 191 |
for (i = nd; i-- > 0; )
| 192 |
if ((tmin[i] < .0) | (tmin[i] >= 1.-FTINY))
| 193 |
break;
| 194 |
if ((i >= 0) | (nd <= 0) | (tsiz <= FTINY) | (tsiz > 1.+FTINY) |
| 195 |
(sroot != NULL && sroot->ndim != nd)) {
| 196 |
SDfreeTre(sroot);
| 197 |
return NULL;
| 198 |
| 199 |
if (tsiz >= 1.-FTINY) { /* special case when tree is a leaf */
| 200 |
SDfreeTre(sroot);
| 201 |
if ((sroot = SDnewNode(nd, 0)) != NULL)
| 202 |
sroot->u.v[0] = val;
| 203 |
return sroot;
| 204 |
| 205 |
/* make sure we have branching root */
| 206 |
if (sroot != NULL && sroot->log2GR >= 0) {
| 207 |
SDfreeTre(sroot); sroot = NULL;
| 208 |
| 209 |
if (sroot == NULL && (sroot = SDnewNode(nd, -1)) == NULL)
| 210 |
return NULL;
| 211 |
st = sroot; /* climb/grow tree */
| 212 |
memset(ctrk, 0, sizeof(ctrk));
| 213 |
for ( ; ; ) {
| 214 |
csiz *= .5; /* find appropriate branch */
| 215 |
n = 0;
| 216 |
for (i = nd; i--; )
| 217 |
if (ctrk[i]+csiz <= tmin[i]+FTINY) {
| 218 |
ctrk[i] += csiz;
| 219 |
n |= 1 << i;
| 220 |
| 221 |
/* reached desired voxel? */
| 222 |
if (csiz <= tsiz+FTINY) {
| 223 |
| 224 |
st = st->u.t[n] = SDnewNode(nd, 0);
| 225 |
break;
| 226 |
| 227 |
/* else grow tree as needed */
| 228 |
if (st->u.t[n] != NULL && st->u.t[n]->log2GR >= 0) {
| 229 |
SDfreeTre(st->u.t[n]); st->u.t[n] = NULL;
| 230 |
| 231 |
if (st->u.t[n] == NULL)
| 232 |
st->u.t[n] = SDnewNode(nd, -1);
| 233 |
if ((st = st->u.t[n]) == NULL)
| 234 |
break;
| 235 |
| 236 |
if (st == NULL) {
| 237 |
SDfreeTre(sroot);
| 238 |
return NULL;
| 239 |
| 240 |
st->u.v[0] = val; /* assign leaf and return root */
| 241 |
return sroot;
| 242 |
| 243 |
| 244 |
/* Find smallest leaf in tree */
| 245 |
static double
| 246 |
SDsmallestLeaf(const SDNode *st)
| 247 |
| 248 |
if (st->log2GR < 0) { /* tree branches */
| 249 |
double lmin = 1.;
| 250 |
int n;
| 251 |
for (n = 1<<st->ndim; n--; ) {
| 252 |
double lsiz = SDsmallestLeaf(st->u.t[n]);
| 253 |
if (lsiz < lmin)
| 254 |
lmin = lsiz;
| 255 |
| 256 |
return .5*lmin;
| 257 |
| 258 |
/* leaf grid width */
| 259 |
return 1. / (double)(1 << st->log2GR);
| 260 |
| 261 |
| 262 |
/* Add up N-dimensional hypercube array values over the given box */
| 263 |
static double
| 264 |
SDiterSum(const float *va, int nd, int shft, const int *imin, const int *imax)
| 265 |
| 266 |
const unsigned skipsiz = 1 << --nd*shft;
| 267 |
double sum = .0;
| 268 |
int i;
| 269 |
| 270 |
va += *imin * skipsiz;
| 271 |
| 272 |
if (skipsiz == 1)
| 273 |
for (i = *imin; i < *imax; i++)
| 274 |
sum += *va++;
| 275 |
else
| 276 |
for (i = *imin; i < *imax; i++, va += skipsiz)
| 277 |
sum += SDiterSum(va, nd, shft, imin+1, imax+1);
| 278 |
return sum;
| 279 |
| 280 |
| 281 |
/* Average BSDF leaves over an orthotope defined by the unit hypercube */
| 282 |
static double
| 283 |
SDavgTreBox(const SDNode *st, const double *bmin, const double *bmax)
| 284 |
| 285 |
unsigned n;
| 286 |
int i;
| 287 |
| 288 |
if (!st)
| 289 |
return .0;
| 290 |
/* check box limits */
| 291 |
for (i = st->ndim; i--; ) {
| 292 |
if (bmin[i] >= 1.)
| 293 |
return .0;
| 294 |
if (bmax[i] <= 0)
| 295 |
return .0;
| 296 |
if (bmin[i] >= bmax[i])
| 297 |
return .0;
| 298 |
| 299 |
if (st->log2GR < 0) { /* iterate on subtree */
| 300 |
double sum = .0, wsum = 1e-20;
| 301 |
double sbmin[SD_MAXDIM], sbmax[SD_MAXDIM], w;
| 302 |
for (n = 1 << st->ndim; n--; ) {
| 303 |
w = 1.;
| 304 |
| 305 |
sbmin[i] = 2.*bmin[i];
| 306 |
sbmax[i] = 2.*bmax[i];
| 307 |
if (n & 1<<i) {
| 308 |
sbmin[i] -= 1.;
| 309 |
sbmax[i] -= 1.;
| 310 |
| 311 |
if (sbmin[i] < .0) sbmin[i] = .0;
| 312 |
if (sbmax[i] > 1.) sbmax[i] = 1.;
| 313 |
if (sbmin[i] >= sbmax[i]) {
| 314 |
w = .0;
| 315 |
break;
| 316 |
| 317 |
w *= sbmax[i] - sbmin[i];
| 318 |
| 319 |
if (w > 1e-10) {
| 320 |
sum += w * SDavgTreBox(st->u.t[n], sbmin, sbmax);
| 321 |
wsum += w;
| 322 |
| 323 |
| 324 |
return sum / wsum;
| 325 |
} else { /* iterate over leaves */
| 326 |
int imin[SD_MAXDIM], imax[SD_MAXDIM];
| 327 |
| 328 |
n = 1;
| 329 |
| 330 |
imin[i] = (bmin[i] <= 0) ? 0 :
| 331 |
(int)((1 << st->log2GR)*bmin[i]);
| 332 |
imax[i] = (bmax[i] >= 1.) ? (1 << st->log2GR) :
| 333 |
(int)((1 << st->log2GR)*bmax[i] + .999999);
| 334 |
n *= imax[i] - imin[i];
| 335 |
| 336 |
if (n)
| 337 |
return SDiterSum(st->u.v, st->ndim,
| 338 |
st->log2GR, imin, imax) / (double)n;
| 339 |
| 340 |
return .0;
| 341 |
| 342 |
| 343 |
/* Recursive call for SDtraverseTre() */
| 344 |
static int
| 345 |
SDdotravTre(const SDNode *st, const double *pos, int cmask,
| 346 |
SDtreCallback *cf, void *cptr,
| 347 |
const double *cmin, double csiz)
| 348 |
| 349 |
int rv, rval = 0;
| 350 |
double bmin[SD_MAXDIM];
| 351 |
int i, n;
| 352 |
/* paranoia */
| 353 |
if (st == NULL)
| 354 |
return 0;
| 355 |
/* in branches? */
| 356 |
| 357 |
unsigned skipmask = 0;
| 358 |
csiz *= .5;
| 359 |
| 360 |
if (1<<i & cmask) {
| 361 |
if (pos[i] < cmin[i] + csiz)
| 362 |
| 363 |
if (n & 1<<i)
| 364 |
skipmask |= 1<<n;
| 365 |
| 366 |
else
| 367 |
| 368 |
if (!(n & 1<<i))
| 369 |
skipmask |= 1<<n;
| 370 |
| 371 |
| 372 |
| 373 |
if (1<<n & skipmask)
| 374 |
continue;
| 375 |
| 376 |
if (1<<i & n)
| 377 |
bmin[i] = cmin[i] + csiz;
| 378 |
else
| 379 |
bmin[i] = cmin[i];
| 380 |
| 381 |
rval += rv = SDdotravTre(st->u.t[n], pos, cmask,
| 382 |
cf, cptr, bmin, csiz);
| 383 |
if (rv < 0)
| 384 |
return rv;
| 385 |
| 386 |
} else { /* else traverse leaves */
| 387 |
int clim[SD_MAXDIM][2];
| 388 |
int cpos[SD_MAXDIM];
| 389 |
| 390 |
if (st->log2GR == 0) /* short cut */
| 391 |
return (*cf)(st->u.v[0], cmin, csiz, cptr);
| 392 |
| 393 |
csiz /= (double)(1 << st->log2GR);
| 394 |
/* assign coord. ranges */
| 395 |
| 396 |
if (1<<i & cmask) {
| 397 |
clim[i][0] = (pos[i] - cmin[i])/csiz;
| 398 |
/* check overflow from f.p. error */
| 399 |
clim[i][0] -= clim[i][0] >> st->log2GR;
| 400 |
clim[i][1] = clim[i][0] + 1;
| 401 |
} else {
| 402 |
clim[i][0] = 0;
| 403 |
clim[i][1] = 1 << st->log2GR;
| 404 |
| 405 |
#if (SD_MAXDIM == 4)
| 406 |
bmin[0] = cmin[0] + csiz*clim[0][0];
| 407 |
for (cpos[0] = clim[0][0]; cpos[0] < clim[0][1]; cpos[0]++) {
| 408 |
bmin[1] = cmin[1] + csiz*clim[1][0];
| 409 |
for (cpos[1] = clim[1][0]; cpos[1] < clim[1][1]; cpos[1]++) {
| 410 |
bmin[2] = cmin[2] + csiz*clim[2][0];
| 411 |
if (st->ndim == 3) {
| 412 |
cpos[2] = clim[2][0];
| 413 |
n = cpos[0];
| 414 |
for (i = 1; i < 3; i++)
| 415 |
n = (n << st->log2GR) + cpos[i];
| 416 |
for ( ; cpos[2] < clim[2][1]; cpos[2]++) {
| 417 |
rval += rv = (*cf)(st->u.v[n++], bmin, csiz, cptr);
| 418 |
if (rv < 0)
| 419 |
return rv;
| 420 |
bmin[2] += csiz;
| 421 |
| 422 |
} else {
| 423 |
for (cpos[2] = clim[2][0]; cpos[2] < clim[2][1]; cpos[2]++) {
| 424 |
bmin[3] = cmin[3] + csiz*(cpos[3] = clim[3][0]);
| 425 |
n = cpos[0];
| 426 |
for (i = 1; i < 4; i++)
| 427 |
| 428 |
for ( ; cpos[3] < clim[3][1]; cpos[3]++) {
| 429 |
| 430 |
if (rv < 0)
| 431 |
return rv;
| 432 |
bmin[3] += csiz;
| 433 |
| 434 |
bmin[2] += csiz;
| 435 |
| 436 |
| 437 |
bmin[1] += csiz;
| 438 |
| 439 |
bmin[0] += csiz;
| 440 |
| 441 |
#else
| 442 |
_!_ "broken code segment!"
| 443 |
#endif
| 444 |
| 445 |
return rval;
| 446 |
| 447 |
| 448 |
/* Traverse a tree, visiting nodes in a slice that fits partial position */
| 449 |
static int
| 450 |
SDtraverseTre(const SDNode *st, const double *pos, int cmask,
| 451 |
SDtreCallback *cf, void *cptr)
| 452 |
| 453 |
int i;
| 454 |
| 455 |
if ((st == NULL) | (cf == NULL))
| 456 |
return -1;
| 457 |
| 458 |
if (1<<i & cmask && (pos[i] < 0) | (pos[i] >= 1.))
| 459 |
return -1;
| 460 |
| 461 |
return SDdotravTre(st, pos, cmask, cf, cptr, czero, 1.);
| 462 |
| 463 |
| 464 |
/* Look up tree value at the given grid position */
| 465 |
static float
| 466 |
SDlookupTre(const SDNode *st, const double *pos, double *hcube)
| 467 |
| 468 |
double spos[SD_MAXDIM];
| 469 |
int i, n, t;
| 470 |
/* initialize voxel return */
| 471 |
if (hcube) {
| 472 |
hcube[i = st->ndim] = 1.;
| 473 |
while (i--)
| 474 |
hcube[i] = .0;
| 475 |
| 476 |
/* climb the tree */
| 477 |
while (st != NULL && st->log2GR < 0) {
| 478 |
n = 0; /* move to appropriate branch */
| 479 |
if (hcube) hcube[st->ndim] *= .5;
| 480 |
| 481 |
spos[i] = 2.*pos[i];
| 482 |
t = (spos[i] >= 1.);
| 483 |
n |= t<<i;
| 484 |
spos[i] -= (double)t;
| 485 |
if (hcube) hcube[i] += (double)t * hcube[st->ndim];
| 486 |
| 487 |
st = st->u.t[n]; /* avoids tail recursion */
| 488 |
pos = spos;
| 489 |
| 490 |
if (st == NULL) /* should never happen? */
| 491 |
return .0;
| 492 |
| 493 |
return st->u.v[0];
| 494 |
n = t = 0; /* find grid array index */
| 495 |
| 496 |
n += (int)((1<<st->log2GR)*pos[i]) << t;
| 497 |
t += st->log2GR;
| 498 |
| 499 |
if (hcube) { /* compute final hypercube */
| 500 |
hcube[st->ndim] /= (double)(1<<st->log2GR);
| 501 |
| 502 |
hcube[i] += floor((1<<st->log2GR)*pos[i])*hcube[st->ndim];
| 503 |
| 504 |
return st->u.v[n]; /* no interpolation */
| 505 |
| 506 |
| 507 |
/* Convert CIE (Y,u',v') color to our RGB */
| 508 |
static void
| 509 |
SDyuv2rgb(double yval, double uprime, double vprime, float rgb[3])
| 510 |
| 511 |
const double dfact = 1./(6.*uprime - 16.*vprime + 12.);
| 512 |
C_COLOR cxy;
| 513 |
| 514 |
c_cset(&cxy, 9.*uprime*dfact, 4.*vprime*dfact);
| 515 |
c_toSharpRGB(&cxy, yval, rgb);
| 516 |
| 517 |
| 518 |
static double
| 519 |
pfrac(double x)
| 520 |
| 521 |
return( x - (int)x );
| 522 |
| 523 |
| 524 |
/* Query BSDF value and sample hypercube for the given vectors */
| 525 |
static int
| 526 |
SDqueryTre(const SDTre *sdt, float *coef,
| 527 |
const FVECT inVec, const FVECT outVec, double *hc)
| 528 |
| 529 |
const RREAL *vtmp;
| 530 |
double hcube[SD_MAXDIM+1];
| 531 |
float yval;
| 532 |
FVECT rOutVec;
| 533 |
RREAL gridPos[4];
| 534 |
double d;
| 535 |
int i;
| 536 |
| 537 |
if (sdt->stc[tt_Y] == NULL) /* paranoia, I hope */
| 538 |
return 0;
| 539 |
| 540 |
switch (sdt->sidef) { /* whose side are you on? */
| 541 |
case SD_FREFL:
| 542 |
if ((outVec[2] < 0) | (inVec[2] < 0))
| 543 |
return 0;
| 544 |
break;
| 545 |
case SD_BREFL:
| 546 |
if ((outVec[2] > 0) | (inVec[2] > 0))
| 547 |
return 0;
| 548 |
break;
| 549 |
case SD_FXMIT:
| 550 |
if (outVec[2] > 0) {
| 551 |
if (inVec[2] > 0)
| 552 |
return 0;
| 553 |
vtmp = outVec; outVec = inVec; inVec = vtmp;
| 554 |
} else if (inVec[2] < 0)
| 555 |
return 0;
| 556 |
break;
| 557 |
case SD_BXMIT:
| 558 |
if (inVec[2] > 0) {
| 559 |
if (outVec[2] > 0)
| 560 |
return 0;
| 561 |
| 562 |
} else if (outVec[2] < 0)
| 563 |
return 0;
| 564 |
break;
| 565 |
default:
| 566 |
return 0;
| 567 |
| 568 |
/* convert vector coordinates */
| 569 |
if (sdt->stc[tt_Y]->ndim == 3) {
| 570 |
spinvector(rOutVec, outVec, zvec, -atan2(-inVec[1],-inVec[0]));
| 571 |
gridPos[0] = (.5-FTINY) -
| 572 |
.5*sqrt(inVec[0]*inVec[0] + inVec[1]*inVec[1]);
| 573 |
disk2square(gridPos+1, rOutVec[0], rOutVec[1]);
| 574 |
} else if (sdt->stc[tt_Y]->ndim == 4) {
| 575 |
disk2square(gridPos, -inVec[0], -inVec[1]);
| 576 |
disk2square(gridPos+2, outVec[0], outVec[1]);
| 577 |
} else
| 578 |
return 0; /* should be internal error */
| 579 |
| 580 |
if (hc == NULL) hc = hcube; /* get BSDF value */
| 581 |
yval = SDlookupTre(sdt->stc[tt_Y], gridPos, hc);
| 582 |
if (coef == NULL) /* just getting hypercube? */
| 583 |
return 1;
| 584 |
d = 0; /* position-specific perturbation */
| 585 |
for (i = sdt->stc[tt_Y]->ndim; i--; )
| 586 |
d += pfrac((2<<i)/(hc[i]+.01687)) - .5;
| 587 |
yval *= 1. + 1e-4*d; /* assumes tolerance is > 0.04% */
| 588 |
if (sdt->stc[tt_u] == NULL || sdt->stc[tt_v] == NULL) {
| 589 |
*coef = yval;
| 590 |
return 1; /* no color */
| 591 |
| 592 |
/* else decode color */
| 593 |
SDyuv2rgb(yval, SDlookupTre(sdt->stc[tt_u], gridPos, NULL),
| 594 |
SDlookupTre(sdt->stc[tt_v], gridPos, NULL), coef);
| 595 |
coef[0] *= tt_RGB_coef[0];
| 596 |
coef[1] *= tt_RGB_coef[1];
| 597 |
coef[2] *= tt_RGB_coef[2];
| 598 |
return 3;
| 599 |
| 600 |
| 601 |
/* Compute non-diffuse component for variable-resolution BSDF */
| 602 |
static int
| 603 |
SDgetTreBSDF(float coef[SDmaxCh], const FVECT outVec,
| 604 |
const FVECT inVec, SDComponent *sdc)
| 605 |
| 606 |
| 607 |
if ((coef == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL)
| 608 |
|| sdc->dist == NULL)
| 609 |
return 0;
| 610 |
/* get nearest BSDF value */
| 611 |
return SDqueryTre((SDTre *)sdc->dist, coef, outVec, inVec, NULL);
| 612 |
| 613 |
| 614 |
/* Callback to build cumulative distribution using SDtraverseTre() */
| 615 |
static int
| 616 |
build_scaffold(float val, const double *cmin, double csiz, void *cptr)
| 617 |
| 618 |
SDdistScaffold *sp = (SDdistScaffold *)cptr;
| 619 |
int wid = csiz*(double)iwmax + .5;
| 620 |
double revcmin[2];
| 621 |
bitmask_t bmin[2], bmax[2];
| 622 |
| 623 |
if (sp->rev) { /* need to reverse sense? */
| 624 |
revcmin[0] = 1. - cmin[0] - csiz;
| 625 |
revcmin[1] = 1. - cmin[1] - csiz;
| 626 |
cmin = revcmin;
| 627 |
} else {
| 628 |
cmin += sp->nic; /* else skip to output coords */
| 629 |
| 630 |
if (wid < sp->wmin) /* new minimum width? */
| 631 |
sp->wmin = wid;
| 632 |
if (wid > sp->wmax) /* new maximum? */
| 633 |
sp->wmax = wid;
| 634 |
if (sp->alen >= sp->nall) { /* need more space? */
| 635 |
struct outdir_s *ndarr;
| 636 |
sp->nall = (int)(1.5*sp->nall) + 256;
| 637 |
ndarr = (struct outdir_s *)realloc(sp->darr,
| 638 |
sizeof(struct outdir_s)*sp->nall);
| 639 |
if (ndarr == NULL) {
| 640 |
| 641 |
"Cannot grow scaffold to %u entries", sp->nall);
| 642 |
return -1; /* abort build */
| 643 |
| 644 |
sp->darr = ndarr;
| 645 |
| 646 |
/* find Hilbert entry index */
| 647 |
bmin[0] = cmin[0]*(double)iwmax + .5;
| 648 |
bmin[1] = cmin[1]*(double)iwmax + .5;
| 649 |
bmax[0] = bmin[0] + wid-1;
| 650 |
bmax[1] = bmin[1] + wid-1;
| 651 |
hilbert_box_vtx(2, sizeof(bitmask_t), iwbits, 1, bmin, bmax);
| 652 |
sp->darr[sp->alen].hent = hilbert_c2i(2, iwbits, bmin);
| 653 |
sp->darr[sp->alen].wid = wid;
| 654 |
sp->darr[sp->alen].bsdf = val;
| 655 |
sp->alen++; /* on to the next entry */
| 656 |
return 0;
| 657 |
| 658 |
| 659 |
/* Scaffold comparison function for qsort -- ascending Hilbert index */
| 660 |
static int
| 661 |
sscmp(const void *p1, const void *p2)
| 662 |
| 663 |
unsigned h1 = (*(const struct outdir_s *)p1).hent;
| 664 |
unsigned h2 = (*(const struct outdir_s *)p2).hent;
| 665 |
| 666 |
if (h1 > h2)
| 667 |
return 1;
| 668 |
if (h1 < h2)
| 669 |
return -1;
| 670 |
return 0;
| 671 |
| 672 |
| 673 |
/* Create a new cumulative distribution for the given input direction */
| 674 |
static SDTreCDst *
| 675 |
make_cdist(const SDTre *sdt, const double *invec, int rev)
| 676 |
| 677 |
SDdistScaffold myScaffold;
| 678 |
double pos[4];
| 679 |
int cmask;
| 680 |
SDTreCDst *cd;
| 681 |
struct outdir_s *sp;
| 682 |
double scale, cursum;
| 683 |
int i;
| 684 |
/* initialize scaffold */
| 685 |
myScaffold.wmin = iwmax;
| 686 |
myScaffold.wmax = 0;
| 687 |
myScaffold.nic = sdt->stc[tt_Y]->ndim - 2;
| 688 |
myScaffold.rev = rev;
| 689 |
myScaffold.alen = 0;
| 690 |
myScaffold.nall = 512;
| 691 |
myScaffold.darr = (struct outdir_s *)malloc(sizeof(struct outdir_s) *
| 692 |
myScaffold.nall);
| 693 |
if (myScaffold.darr == NULL)
| 694 |
return NULL;
| 695 |
/* set up traversal */
| 696 |
cmask = (1<<myScaffold.nic) - 1;
| 697 |
for (i = myScaffold.nic; i--; )
| 698 |
pos[i+2*rev] = invec[i];
| 699 |
cmask <<= 2*rev;
| 700 |
/* grow the distribution */
| 701 |
if (SDtraverseTre(sdt->stc[tt_Y], pos, cmask,
| 702 |
build_scaffold, &myScaffold) < 0) {
| 703 |
free(myScaffold.darr);
| 704 |
return NULL;
| 705 |
| 706 |
/* allocate result holder */
| 707 |
cd = (SDTreCDst *)malloc(sizeof(SDTreCDst) +
| 708 |
sizeof(cd->carr[0])*myScaffold.alen);
| 709 |
if (cd == NULL) {
| 710 |
| 711 |
"Cannot allocate %u entry cumulative distribution",
| 712 |
myScaffold.alen);
| 713 |
| 714 |
return NULL;
| 715 |
| 716 |
cd->isodist = (myScaffold.nic == 1);
| 717 |
/* sort the distribution */
| 718 |
qsort(myScaffold.darr, cd->calen = myScaffold.alen,
| 719 |
sizeof(struct outdir_s), sscmp);
| 720 |
| 721 |
/* record input range */
| 722 |
scale = myScaffold.wmin / (double)iwmax;
| 723 |
for (i = myScaffold.nic; i--; ) {
| 724 |
cd->clim[i][0] = floor(pos[i+2*rev]/scale) * scale;
| 725 |
cd->clim[i][1] = cd->clim[i][0] + scale;
| 726 |
| 727 |
if (cd->isodist) { /* avoid issue in SDqueryTreProjSA() */
| 728 |
cd->clim[1][0] = cd->clim[0][0];
| 729 |
cd->clim[1][1] = cd->clim[0][1];
| 730 |
| 731 |
cd->max_psa = myScaffold.wmax / (double)iwmax;
| 732 |
cd->max_psa *= cd->max_psa * M_PI;
| 733 |
if (rev)
| 734 |
cd->sidef = (sdt->sidef==SD_BXMIT) ? SD_FXMIT : SD_BXMIT;
| 735 |
else
| 736 |
cd->sidef = sdt->sidef;
| 737 |
cd->cTotal = 1e-20; /* compute directional total */
| 738 |
sp = myScaffold.darr;
| 739 |
for (i = myScaffold.alen; i--; sp++)
| 740 |
cd->cTotal += sp->bsdf * (double)sp->wid * sp->wid;
| 741 |
cursum = .0; /* go back and get cumulative values */
| 742 |
scale = (double)cumlmax / cd->cTotal;
| 743 |
| 744 |
for (i = 0; i < cd->calen; i++, sp++) {
| 745 |
cd->carr[i].hndx = sp->hent;
| 746 |
cd->carr[i].cuml = scale*cursum + .5;
| 747 |
cursum += sp->bsdf * (double)sp->wid * sp->wid;
| 748 |
| 749 |
cd->carr[i].hndx = ~0; /* make final entry */
| 750 |
cd->carr[i].cuml = cumlmax;
| 751 |
cd->cTotal *= M_PI/(double)iwmax/iwmax;
| 752 |
/* all done, clean up and return */
| 753 |
| 754 |
return cd;
| 755 |
| 756 |
| 757 |
/* Find or allocate a cumulative distribution for the given incoming vector */
| 758 |
const SDCDst *
| 759 |
SDgetTreCDist(const FVECT inVec, SDComponent *sdc)
| 760 |
| 761 |
unsigned long cacheLeft = SDmaxCache;
| 762 |
const SDTre *sdt;
| 763 |
RREAL inCoord[2];
| 764 |
int i;
| 765 |
int mode;
| 766 |
SDTreCDst *cd, *cdlast, *cdlimit;
| 767 |
| 768 |
if ((inVec == NULL) | (sdc == NULL) ||
| 769 |
(sdt = (SDTre *)sdc->dist) == NULL)
| 770 |
return NULL;
| 771 |
switch (mode = sdt->sidef) { /* check direction */
| 772 |
case SD_FREFL:
| 773 |
if (inVec[2] < 0)
| 774 |
return NULL;
| 775 |
break;
| 776 |
case SD_BREFL:
| 777 |
if (inVec[2] > 0)
| 778 |
return NULL;
| 779 |
break;
| 780 |
case SD_FXMIT:
| 781 |
if (inVec[2] < 0)
| 782 |
mode = SD_BXMIT;
| 783 |
break;
| 784 |
case SD_BXMIT:
| 785 |
if (inVec[2] > 0)
| 786 |
mode = SD_FXMIT;
| 787 |
break;
| 788 |
default:
| 789 |
return NULL;
| 790 |
| 791 |
if (sdt->stc[tt_Y]->ndim == 3) { /* isotropic BSDF? */
| 792 |
if (mode != sdt->sidef) /* XXX unhandled reciprocity */
| 793 |
return &SDemptyCD;
| 794 |
inCoord[0] = (.5-FTINY) -
| 795 |
| 796 |
| 797 |
if (mode != sdt->sidef) /* use reciprocity? */
| 798 |
disk2square(inCoord, inVec[0], inVec[1]);
| 799 |
else
| 800 |
disk2square(inCoord, -inVec[0], -inVec[1]);
| 801 |
} else
| 802 |
return NULL; /* should be internal error */
| 803 |
/* quantize to avoid f.p. errors */
| 804 |
for (i = sdt->stc[tt_Y]->ndim - 2; i--; )
| 805 |
inCoord[i] = floor(inCoord[i]/quantum)*quantum + .5*quantum;
| 806 |
cdlast = cdlimit = NULL; /* check for direction in cache list */
| 807 |
/* PLACE MUTEX LOCK HERE FOR THREAD-SAFE */
| 808 |
for (cd = (SDTreCDst *)sdc->cdList; cd != NULL;
| 809 |
cdlast = cd, cd = cd->next) {
| 810 |
if (cacheLeft) { /* check cache size limit */
| 811 |
long csiz = sizeof(SDTreCDst) +
| 812 |
sizeof(cd->carr[0])*cd->calen;
| 813 |
if (cacheLeft > csiz)
| 814 |
cacheLeft -= csiz;
| 815 |
else {
| 816 |
cdlimit = cdlast;
| 817 |
cacheLeft = 0;
| 818 |
| 819 |
| 820 |
if (cd->sidef != mode)
| 821 |
continue;
| 822 |
| 823 |
if ((cd->clim[i][0] > inCoord[i]) |
| 824 |
(inCoord[i] >= cd->clim[i][1]))
| 825 |
break;
| 826 |
if (i < 0)
| 827 |
break; /* means we have a match */
| 828 |
| 829 |
if (cd == NULL) { /* need to create new entry? */
| 830 |
if (cdlimit != NULL) /* exceeded cache size limit? */
| 831 |
while ((cd = cdlimit->next) != NULL) {
| 832 |
cdlimit->next = cd->next;
| 833 |
free(cd);
| 834 |
| 835 |
cdlast = cd = make_cdist(sdt, inCoord, mode != sdt->sidef);
| 836 |
| 837 |
if (cdlast != NULL) { /* move entry to head of cache list */
| 838 |
cdlast->next = cd->next;
| 839 |
cd->next = (SDTreCDst *)sdc->cdList;
| 840 |
sdc->cdList = (SDCDst *)cd;
| 841 |
| 842 |
/* END MUTEX LOCK */
| 843 |
return (SDCDst *)cd; /* ready to go */
| 844 |
| 845 |
| 846 |
/* Query solid angle for vector(s) */
| 847 |
static SDError
| 848 |
SDqueryTreProjSA(double *psa, const FVECT v1, const RREAL *v2,
| 849 |
int qflags, SDComponent *sdc)
| 850 |
| 851 |
double myPSA[2];
| 852 |
| 853 |
if ((psa == NULL) | (v1 == NULL) | (sdc == NULL) ||
| 854 |
sdc->dist == NULL)
| 855 |
return SDEargument;
| 856 |
/* get projected solid angle(s) */
| 857 |
if (v2 != NULL) {
| 858 |
const SDTre *sdt = (SDTre *)sdc->dist;
| 859 |
| 860 |
if (!SDqueryTre(sdt, NULL, v1, v2, hcube)) {
| 861 |
strcpy(SDerrorDetail, "Bad call to SDqueryTreProjSA");
| 862 |
return SDEinternal;
| 863 |
| 864 |
myPSA[0] = hcube[sdt->stc[tt_Y]->ndim];
| 865 |
myPSA[1] = myPSA[0] *= myPSA[0] * M_PI;
| 866 |
} else {
| 867 |
const SDTreCDst *cd = (const SDTreCDst *)SDgetTreCDist(v1, sdc);
| 868 |
if (cd == NULL)
| 869 |
myPSA[0] = myPSA[1] = 0;
| 870 |
else {
| 871 |
myPSA[0] = M_PI * (cd->clim[0][1] - cd->clim[0][0]) *
| 872 |
(cd->clim[1][1] - cd->clim[1][0]);
| 873 |
myPSA[1] = cd->max_psa;
| 874 |
| 875 |
| 876 |
switch (qflags) { /* record based on flag settings */
| 877 |
case SDqueryVal:
| 878 |
*psa = myPSA[0];
| 879 |
break;
| 880 |
case SDqueryMax:
| 881 |
if (myPSA[1] > *psa)
| 882 |
*psa = myPSA[1];
| 883 |
break;
| 884 |
case SDqueryMin+SDqueryMax:
| 885 |
if (myPSA[1] > psa[1])
| 886 |
psa[1] = myPSA[1];
| 887 |
/* fall through */
| 888 |
case SDqueryMin:
| 889 |
if ((myPSA[0] > 0) & (myPSA[0] < psa[0]))
| 890 |
psa[0] = myPSA[0];
| 891 |
break;
| 892 |
| 893 |
return SDEnone;
| 894 |
| 895 |
| 896 |
/* Sample cumulative distribution */
| 897 |
static SDError
| 898 |
SDsampTreCDist(FVECT ioVec, double randX, const SDCDst *cdp)
| 899 |
| 900 |
const unsigned nBitsC = 4*sizeof(bitmask_t);
| 901 |
const unsigned nExtraBits = 8*(sizeof(bitmask_t)-sizeof(unsigned));
| 902 |
const SDTreCDst *cd = (const SDTreCDst *)cdp;
| 903 |
const unsigned target = randX*cumlmax;
| 904 |
bitmask_t hndx, hcoord[2];
| 905 |
FVECT gpos;
| 906 |
double rotangle;
| 907 |
int i, iupper, ilower;
| 908 |
| 909 |
if ((ioVec == NULL) | (cd == NULL))
| 910 |
return SDEargument;
| 911 |
if (!cd->sidef)
| 912 |
return SDEnone; /* XXX should never happen */
| 913 |
if (ioVec[2] > 0) {
| 914 |
if ((cd->sidef != SD_FREFL) & (cd->sidef != SD_FXMIT))
| 915 |
return SDEargument;
| 916 |
} else if ((cd->sidef != SD_BREFL) & (cd->sidef != SD_BXMIT))
| 917 |
return SDEargument;
| 918 |
/* binary search to find position */
| 919 |
ilower = 0; iupper = cd->calen;
| 920 |
while ((i = (iupper + ilower) >> 1) != ilower)
| 921 |
if (target >= cd->carr[i].cuml)
| 922 |
ilower = i;
| 923 |
else
| 924 |
iupper = i;
| 925 |
/* localize random position */
| 926 |
randX = (randX*cumlmax - cd->carr[ilower].cuml) /
| 927 |
(double)(cd->carr[iupper].cuml - cd->carr[ilower].cuml);
| 928 |
/* index in longer Hilbert curve */
| 929 |
hndx = (randX*cd->carr[iupper].hndx + (1.-randX)*cd->carr[ilower].hndx)
| 930 |
* (double)((bitmask_t)1 << nExtraBits);
| 931 |
/* convert Hilbert index to vector */
| 932 |
hilbert_i2c(2, nBitsC, hndx, hcoord);
| 933 |
for (i = 2; i--; )
| 934 |
gpos[i] = ((double)hcoord[i] + rand()*(1./(RAND_MAX+.5))) /
| 935 |
(double)((bitmask_t)1 << nBitsC);
| 936 |
square2disk(gpos, gpos[0], gpos[1]);
| 937 |
/* compute Z-coordinate */
| 938 |
gpos[2] = 1. - gpos[0]*gpos[0] - gpos[1]*gpos[1];
| 939 |
gpos[2] = sqrt(gpos[2]*(gpos[2]>0));
| 940 |
/* emit from back? */
| 941 |
if ((cd->sidef == SD_BREFL) | (cd->sidef == SD_FXMIT))
| 942 |
gpos[2] = -gpos[2];
| 943 |
if (cd->isodist) { /* rotate isotropic sample */
| 944 |
rotangle = atan2(-ioVec[1],-ioVec[0]);
| 945 |
spinvector(ioVec, gpos, zvec, rotangle);
| 946 |
} else
| 947 |
VCOPY(ioVec, gpos);
| 948 |
return SDEnone;
| 949 |
| 950 |
| 951 |
/* Advance pointer to the next non-white character in the string (or nul) */
| 952 |
static int
| 953 |
next_token(char **spp)
| 954 |
| 955 |
while (isspace(**spp))
| 956 |
++*spp;
| 957 |
return **spp;
| 958 |
| 959 |
| 960 |
/* Advance pointer past matching token (or any token if c==0) */
| 961 |
#define eat_token(spp,c) ((next_token(spp)==(c)) ^ !(c) ? *(*(spp))++ : 0)
| 962 |
| 963 |
/* Count words from this point in string to '}' */
| 964 |
static int
| 965 |
count_values(char *cp)
| 966 |
| 967 |
int n = 0;
| 968 |
| 969 |
while (next_token(&cp) != '}' && *cp) {
| 970 |
while (!isspace(*cp) & (*cp != ',') & (*cp != '}'))
| 971 |
if (!*++cp)
| 972 |
break;
| 973 |
++n;
| 974 |
eat_token(&cp, ',');
| 975 |
| 976 |
return n;
| 977 |
| 978 |
| 979 |
/* Load an array of real numbers, returning total */
| 980 |
static int
| 981 |
load_values(char **spp, float *va, int n)
| 982 |
| 983 |
float *v = va;
| 984 |
char *svnext;
| 985 |
| 986 |
while (n-- > 0 && (svnext = fskip(*spp)) != NULL) {
| 987 |
if ((*v++ = atof(*spp)) < 0)
| 988 |
v[-1] = 0;
| 989 |
*spp = svnext;
| 990 |
eat_token(spp, ',');
| 991 |
| 992 |
return v - va;
| 993 |
| 994 |
| 995 |
/* Load BSDF tree data */
| 996 |
static SDNode *
| 997 |
load_tree_data(char **spp, int nd)
| 998 |
| 999 |
SDNode *st;
| 1000 |
int n;
| 1001 |
| 1002 |
if (!eat_token(spp, '{')) {
| 1003 |
strcpy(SDerrorDetail, "Missing '{' in tensor tree");
| 1004 |
return NULL;
| 1005 |
| 1006 |
if (next_token(spp) == '{') { /* tree branches */
| 1007 |
st = SDnewNode(nd, -1);
| 1008 |
if (st == NULL)
| 1009 |
return NULL;
| 1010 |
for (n = 0; n < 1<<nd; n++)
| 1011 |
if ((st->u.t[n] = load_tree_data(spp, nd)) == NULL) {
| 1012 |
SDfreeTre(st);
| 1013 |
return NULL;
| 1014 |
| 1015 |
} else { /* else load value grid */
| 1016 |
int bsiz;
| 1017 |
n = count_values(*spp); /* see how big the grid is */
| 1018 |
for (bsiz = 0; bsiz < 8*sizeof(size_t); bsiz += nd)
| 1019 |
if (1<<bsiz == n)
| 1020 |
break;
| 1021 |
if (bsiz >= 8*sizeof(size_t)) {
| 1022 |
strcpy(SDerrorDetail, "Illegal value count in tensor tree");
| 1023 |
return NULL;
| 1024 |
| 1025 |
st = SDnewNode(nd, bsiz/nd);
| 1026 |
if (st == NULL)
| 1027 |
return NULL;
| 1028 |
if (load_values(spp, st->u.v, n) != n) {
| 1029 |
strcpy(SDerrorDetail, "Real format error in tensor tree");
| 1030 |
SDfreeTre(st);
| 1031 |
return NULL;
| 1032 |
| 1033 |
| 1034 |
if (!eat_token(spp, '}')) {
| 1035 |
strcpy(SDerrorDetail, "Missing '}' in tensor tree");
| 1036 |
SDfreeTre(st);
| 1037 |
return NULL;
| 1038 |
| 1039 |
| 1040 |
return st;
| 1041 |
| 1042 |
| 1043 |
/* Compute min. proj. solid angle and max. direct hemispherical scattering */
| 1044 |
static SDError
| 1045 |
get_extrema(SDSpectralDF *df)
| 1046 |
| 1047 |
SDNode *st = (*(SDTre *)df->comp[0].dist).stc[tt_Y];
| 1048 |
double stepWidth, dhemi, bmin[4], bmax[4];
| 1049 |
| 1050 |
stepWidth = SDsmallestLeaf(st);
| 1051 |
if (quantum > stepWidth) /* adjust quantization factor */
| 1052 |
quantum = stepWidth;
| 1053 |
df->minProjSA = M_PI*stepWidth*stepWidth;
| 1054 |
if (stepWidth < .03125)
| 1055 |
stepWidth = .03125; /* 1/32 resolution good enough */
| 1056 |
df->maxHemi = .0;
| 1057 |
if (st->ndim == 3) { /* isotropic BSDF */
| 1058 |
bmin[1] = bmin[2] = .0;
| 1059 |
bmax[1] = bmax[2] = 1.;
| 1060 |
for (bmin[0] = .0; bmin[0] < .5-FTINY; bmin[0] += stepWidth) {
| 1061 |
bmax[0] = bmin[0] + stepWidth;
| 1062 |
dhemi = SDavgTreBox(st, bmin, bmax);
| 1063 |
if (dhemi > df->maxHemi)
| 1064 |
df->maxHemi = dhemi;
| 1065 |
| 1066 |
} else if (st->ndim == 4) { /* anisotropic BSDF */
| 1067 |
bmin[2] = bmin[3] = .0;
| 1068 |
bmax[2] = bmax[3] = 1.;
| 1069 |
for (bmin[0] = .0; bmin[0] < 1.-FTINY; bmin[0] += stepWidth) {
| 1070 |
| 1071 |
for (bmin[1] = .0; bmin[1] < 1.-FTINY; bmin[1] += stepWidth) {
| 1072 |
bmax[1] = bmin[1] + stepWidth;
| 1073 |
| 1074 |
| 1075 |
| 1076 |
| 1077 |
| 1078 |
} else
| 1079 |
return SDEinternal;
| 1080 |
/* correct hemispherical value */
| 1081 |
df->maxHemi *= M_PI;
| 1082 |
return SDEnone;
| 1083 |
| 1084 |
| 1085 |
/* Load BSDF distribution for this wavelength */
| 1086 |
static SDError
| 1087 |
load_bsdf_data(SDData *sd, ezxml_t wdb, int ct, int ndim)
| 1088 |
| 1089 |
SDSpectralDF *df;
| 1090 |
SDTre *sdt;
| 1091 |
char *sdata;
| 1092 |
/* allocate BSDF component */
| 1093 |
sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection"));
| 1094 |
if (!sdata)
| 1095 |
return SDEnone;
| 1096 |
| 1097 |
* Remember that front and back are reversed from WINDOW 6 orientations
| 1098 |
| 1099 |
if (!strcasecmp(sdata, "Transmission Front")) {
| 1100 |
if (sd->tb == NULL && (sd->tb = SDnewSpectralDF(1)) == NULL)
| 1101 |
return SDEmemory;
| 1102 |
df = sd->tb;
| 1103 |
} else if (!strcasecmp(sdata, "Transmission Back")) {
| 1104 |
if (sd->tf == NULL && (sd->tf = SDnewSpectralDF(1)) == NULL)
| 1105 |
return SDEmemory;
| 1106 |
df = sd->tf;
| 1107 |
} else if (!strcasecmp(sdata, "Reflection Front")) {
| 1108 |
if (sd->rb == NULL && (sd->rb = SDnewSpectralDF(1)) == NULL)
| 1109 |
return SDEmemory;
| 1110 |
df = sd->rb;
| 1111 |
} else if (!strcasecmp(sdata, "Reflection Back")) {
| 1112 |
if (sd->rf == NULL && (sd->rf = SDnewSpectralDF(1)) == NULL)
| 1113 |
return SDEmemory;
| 1114 |
df = sd->rf;
| 1115 |
} else
| 1116 |
return SDEnone;
| 1117 |
/* get angle bases */
| 1118 |
sdata = ezxml_txt(ezxml_child(wdb,"AngleBasis"));
| 1119 |
if (!sdata || strcasecmp(sdata, "LBNL/Shirley-Chiu")) {
| 1120 |
sprintf(SDerrorDetail, "%s angle basis for BSDF '%s'",
| 1121 |
!sdata ? "Missing" : "Unsupported", sd->name);
| 1122 |
return !sdata ? SDEformat : SDEsupport;
| 1123 |
| 1124 |
if (df->comp[0].dist == NULL) { /* need to allocate BSDF tree? */
| 1125 |
sdt = (SDTre *)malloc(sizeof(SDTre));
| 1126 |
if (sdt == NULL)
| 1127 |
return SDEmemory;
| 1128 |
if (df == sd->rf)
| 1129 |
sdt->sidef = SD_FREFL;
| 1130 |
else if (df == sd->rb)
| 1131 |
sdt->sidef = SD_BREFL;
| 1132 |
else if (df == sd->tf)
| 1133 |
sdt->sidef = SD_FXMIT;
| 1134 |
else /* df == sd->tb */
| 1135 |
sdt->sidef = SD_BXMIT;
| 1136 |
sdt->stc[tt_Y] = sdt->stc[tt_u] = sdt->stc[tt_v] = NULL;
| 1137 |
df->comp[0].dist = sdt;
| 1138 |
df->comp[0].func = &SDhandleTre;
| 1139 |
} else {
| 1140 |
sdt = (SDTre *)df->comp[0].dist;
| 1141 |
if (sdt->stc[ct] != NULL) {
| 1142 |
SDfreeTre(sdt->stc[ct]);
| 1143 |
sdt->stc[ct] = NULL;
| 1144 |
| 1145 |
| 1146 |
/* read BSDF data */
| 1147 |
sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData"));
| 1148 |
if (!sdata || !next_token(&sdata)) {
| 1149 |
sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'",
| 1150 |
sd->name);
| 1151 |
return SDEformat;
| 1152 |
| 1153 |
sdt->stc[ct] = load_tree_data(&sdata, ndim);
| 1154 |
if (sdt->stc[ct] == NULL)
| 1155 |
return SDEformat;
| 1156 |
if (next_token(&sdata)) { /* check for unconsumed characters */
| 1157 |
| 1158 |
"Extra characters at end of ScatteringData in '%s'",
| 1159 |
sd->name);
| 1160 |
return SDEformat;
| 1161 |
| 1162 |
/* flatten branches where possible */
| 1163 |
sdt->stc[ct] = SDsimplifyTre(sdt->stc[ct]);
| 1164 |
| 1165 |
return SDEinternal;
| 1166 |
/* compute global quantities for Y */
| 1167 |
return (ct == tt_Y) ? get_extrema(df) : SDEnone;
| 1168 |
| 1169 |
| 1170 |
/* Find minimum value in tree */
| 1171 |
static float
| 1172 |
SDgetTreMin(const SDNode *st)
| 1173 |
| 1174 |
float vmin = FHUGE;
| 1175 |
int n;
| 1176 |
| 1177 |
| 1178 |
| 1179 |
float v = SDgetTreMin(st->u.t[n]);
| 1180 |
if (v < vmin)
| 1181 |
vmin = v;
| 1182 |
| 1183 |
} else {
| 1184 |
for (n = 1<<(st->ndim*st->log2GR); n--; )
| 1185 |
if (st->u.v[n] < vmin)
| 1186 |
vmin = st->u.v[n];
| 1187 |
| 1188 |
return vmin;
| 1189 |
| 1190 |
| 1191 |
/* Subtract the given value from all tree nodes */
| 1192 |
static void
| 1193 |
SDsubtractTreVal(SDNode *st, float val)
| 1194 |
| 1195 |
int n;
| 1196 |
| 1197 |
| 1198 |
| 1199 |
SDsubtractTreVal(st->u.t[n], val);
| 1200 |
} else {
| 1201 |
| 1202 |
if ((st->u.v[n] -= val) < 0)
| 1203 |
st->u.v[n] = .0f;
| 1204 |
| 1205 |
| 1206 |
| 1207 |
/* Subtract minimum Y value from BSDF */
| 1208 |
static double
| 1209 |
subtract_min_Y(SDNode *st)
| 1210 |
| 1211 |
const float vmaxmin = 1.5/M_PI;
| 1212 |
float vmin;
| 1213 |
/* be sure to skip unused portion */
| 1214 |
| 1215 |
int n;
| 1216 |
vmin = vmaxmin;
| 1217 |
| 1218 |
for (n = 0; n < 8; n += 2) {
| 1219 |
| 1220 |
if (v < vmin)
| 1221 |
vmin = v;
| 1222 |
| 1223 |
} else if (st->log2GR) {
| 1224 |
for (n = 1 << (3*st->log2GR - 1); n--; )
| 1225 |
| 1226 |
vmin = st->u.v[n];
| 1227 |
} else
| 1228 |
vmin = st->u.v[0];
| 1229 |
} else /* anisotropic covers entire tree */
| 1230 |
vmin = SDgetTreMin(st);
| 1231 |
| 1232 |
if ((vmin >= vmaxmin) | (vmin <= .01/M_PI))
| 1233 |
return .0; /* not worth bothering about */
| 1234 |
| 1235 |
SDsubtractTreVal(st, vmin);
| 1236 |
| 1237 |
return M_PI * vmin; /* return hemispherical value */
| 1238 |
| 1239 |
| 1240 |
/* Struct used in callback to find RGB extrema */
| 1241 |
typedef struct {
| 1242 |
SDNode **stc; /* original Y, u' & v' trees */
| 1243 |
float rgb[3]; /* RGB value */
| 1244 |
SDNode *new_stu, *new_stv; /* replacement u' & v' trees */
| 1245 |
} SDextRGBs;
| 1246 |
| 1247 |
/* Callback to find minimum RGB from Y value plus CIE (u',v') trees */
| 1248 |
static int
| 1249 |
get_min_RGB(float yval, const double *cmin, double csiz, void *cptr)
| 1250 |
| 1251 |
SDextRGBs *mp = (SDextRGBs *)cptr;
| 1252 |
double cmax[SD_MAXDIM];
| 1253 |
float rgb[3];
| 1254 |
| 1255 |
if (mp->stc[tt_Y]->ndim == 3) {
| 1256 |
if (cmin[0] + .5*csiz >= .5)
| 1257 |
return 0; /* ignore dead half of isotropic */
| 1258 |
} else
| 1259 |
cmax[3] = cmin[3] + csiz;
| 1260 |
cmax[0] = cmin[0] + csiz;
| 1261 |
cmax[1] = cmin[1] + csiz;
| 1262 |
cmax[2] = cmin[2] + csiz;
| 1263 |
/* average RGB color over voxel */
| 1264 |
SDyuv2rgb(yval, SDavgTreBox(mp->stc[tt_u], cmin, cmax),
| 1265 |
SDavgTreBox(mp->stc[tt_v], cmin, cmax), rgb);
| 1266 |
/* track smallest components */
| 1267 |
if (rgb[0] < mp->rgb[0]) mp->rgb[0] = rgb[0];
| 1268 |
if (rgb[1] < mp->rgb[1]) mp->rgb[1] = rgb[1];
| 1269 |
if (rgb[2] < mp->rgb[2]) mp->rgb[2] = rgb[2];
| 1270 |
return 0;
| 1271 |
| 1272 |
| 1273 |
/* Callback to build adjusted u' tree */
| 1274 |
static int
| 1275 |
adjust_utree(float uprime, const double *cmin, double csiz, void *cptr)
| 1276 |
| 1277 |
| 1278 |
| 1279 |
double yval;
| 1280 |
float rgb[3];
| 1281 |
C_COLOR clr;
| 1282 |
| 1283 |
| 1284 |
| 1285 |
| 1286 |
} else
| 1287 |
| 1288 |
| 1289 |
| 1290 |
| 1291 |
| 1292 |
SDyuv2rgb(yval=SDavgTreBox(mp->stc[tt_Y], cmin, cmax), uprime,
| 1293 |
| 1294 |
/* subtract minimum (& clamp) */
| 1295 |
if ((rgb[0] -= mp->rgb[0]) < 1e-5*yval) rgb[0] = 1e-5*yval;
| 1296 |
if ((rgb[1] -= mp->rgb[1]) < 1e-5*yval) rgb[1] = 1e-5*yval;
| 1297 |
if ((rgb[2] -= mp->rgb[2]) < 1e-5*yval) rgb[2] = 1e-5*yval;
| 1298 |
c_fromSharpRGB(rgb, &clr); /* compute new u' for adj. RGB */
| 1299 |
uprime = 4.*clr.cx/(-2.*clr.cx + 12.*clr.cy + 3.);
| 1300 |
/* assign in new u' tree */
| 1301 |
mp->new_stu = SDsetVoxel(mp->new_stu, mp->stc[tt_Y]->ndim,
| 1302 |
cmin, csiz, uprime);
| 1303 |
return -(mp->new_stu == NULL);
| 1304 |
| 1305 |
| 1306 |
/* Callback to build adjusted v' tree */
| 1307 |
static int
| 1308 |
adjust_vtree(float vprime, const double *cmin, double csiz, void *cptr)
| 1309 |
| 1310 |
| 1311 |
| 1312 |
double yval;
| 1313 |
float rgb[3];
| 1314 |
C_COLOR clr;
| 1315 |
| 1316 |
| 1317 |
| 1318 |
| 1319 |
} else
| 1320 |
| 1321 |
| 1322 |
| 1323 |
| 1324 |
| 1325 |
| 1326 |
| 1327 |
vprime, rgb);
| 1328 |
| 1329 |
| 1330 |
| 1331 |
| 1332 |
c_fromSharpRGB(rgb, &clr); /* compute new v' for adj. RGB */
| 1333 |
vprime = 9.*clr.cy/(-2.*clr.cx + 12.*clr.cy + 3.);
| 1334 |
/* assign in new v' tree */
| 1335 |
mp->new_stv = SDsetVoxel(mp->new_stv, mp->stc[tt_Y]->ndim,
| 1336 |
cmin, csiz, vprime);
| 1337 |
return -(mp->new_stv == NULL);
| 1338 |
| 1339 |
| 1340 |
/* Subtract minimum (diffuse) color and return luminance & CIE (x,y) */
| 1341 |
static double
| 1342 |
subtract_min_RGB(C_COLOR *cs, SDNode *stc[])
| 1343 |
| 1344 |
SDextRGBs my_min;
| 1345 |
double ymin;
| 1346 |
| 1347 |
my_min.stc = stc;
| 1348 |
my_min.rgb[0] = my_min.rgb[1] = my_min.rgb[2] = FHUGE;
| 1349 |
my_min.new_stu = my_min.new_stv = NULL;
| 1350 |
/* get minimum RGB value */
| 1351 |
SDtraverseTre(stc[tt_Y], NULL, 0, get_min_RGB, &my_min);
| 1352 |
/* convert to C_COLOR */
| 1353 |
ymin = c_fromSharpRGB(my_min.rgb, cs);
| 1354 |
if ((ymin >= .5*FHUGE) | (ymin <= .01/M_PI))
| 1355 |
return .0; /* close to zero or no tree */
| 1356 |
/* adjust u' & v' trees */
| 1357 |
SDtraverseTre(stc[tt_u], NULL, 0, adjust_utree, &my_min);
| 1358 |
SDtraverseTre(stc[tt_v], NULL, 0, adjust_vtree, &my_min);
| 1359 |
SDfreeTre(stc[tt_u]); SDfreeTre(stc[tt_v]);
| 1360 |
stc[tt_u] = SDsimplifyTre(my_min.new_stu);
| 1361 |
stc[tt_v] = SDsimplifyTre(my_min.new_stv);
| 1362 |
/* subtract Y & return hemispherical */
| 1363 |
SDsubtractTreVal(stc[tt_Y], ymin);
| 1364 |
| 1365 |
return M_PI * ymin;
| 1366 |
| 1367 |
| 1368 |
/* Extract and separate diffuse portion of BSDF */
| 1369 |
static void
| 1370 |
extract_diffuse(SDValue *dv, SDSpectralDF *df)
| 1371 |
| 1372 |
int n;
| 1373 |
SDTre *sdt;
| 1374 |
| 1375 |
if (df == NULL || df->ncomp <= 0) {
| 1376 |
dv->spec = c_dfcolor;
| 1377 |
dv->cieY = .0;
| 1378 |
return;
| 1379 |
| 1380 |
| 1381 |
/* subtract minimum color/grayscale */
| 1382 |
if (sdt->stc[tt_u] != NULL && sdt->stc[tt_v] != NULL) {
| 1383 |
int i = 3*(tt_RGB_coef[1] < .001);
| 1384 |
while (i--) { /* initialize on first call */
| 1385 |
float rgb[3];
| 1386 |
rgb[0] = rgb[1] = rgb[2] = .0f; rgb[i] = 1.f;
| 1387 |
tt_RGB_coef[i] = c_fromSharpRGB(rgb, &tt_RGB_prim[i]);
| 1388 |
| 1389 |
memcpy(df->comp[0].cspec, tt_RGB_prim, sizeof(tt_RGB_prim));
| 1390 |
dv->cieY = subtract_min_RGB(&dv->spec, sdt->stc);
| 1391 |
} else {
| 1392 |
df->comp[0].cspec[0] = dv->spec = c_dfcolor;
| 1393 |
dv->cieY = subtract_min_Y(sdt->stc[tt_Y]);
| 1394 |
| 1395 |
df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */
| 1396 |
| 1397 |
c_ccvt(&dv->spec, C_CSXY); /* make sure (x,y) is set */
| 1398 |
| 1399 |
| 1400 |
/* Load a variable-resolution BSDF tree from an open XML file */
| 1401 |
SDError
| 1402 |
SDloadTre(SDData *sd, ezxml_t wtl)
| 1403 |
| 1404 |
SDError ec;
| 1405 |
ezxml_t wld, wdb;
| 1406 |
int rank;
| 1407 |
char *txt;
| 1408 |
/* basic checks and tensor rank */
| 1409 |
txt = ezxml_txt(ezxml_child(ezxml_child(wtl,
| 1410 |
"DataDefinition"), "IncidentDataStructure"));
| 1411 |
if (txt == NULL || !*txt) {
| 1412 |
| 1413 |
"BSDF \"%s\": missing IncidentDataStructure",
| 1414 |
sd->name);
| 1415 |
return SDEformat;
| 1416 |
| 1417 |
if (!strcasecmp(txt, "TensorTree3"))
| 1418 |
rank = 3;
| 1419 |
else if (!strcasecmp(txt, "TensorTree4"))
| 1420 |
rank = 4;
| 1421 |
else {
| 1422 |
| 1423 |
"BSDF \"%s\": unsupported IncidentDataStructure",
| 1424 |
sd->name);
| 1425 |
return SDEsupport;
| 1426 |
| 1427 |
/* load BSDF components */
| 1428 |
for (wld = ezxml_child(wtl, "WavelengthData");
| 1429 |
wld != NULL; wld = wld->next) {
| 1430 |
const char *cnm = ezxml_txt(ezxml_child(wld,"Wavelength"));
| 1431 |
int ct = -1;
| 1432 |
if (!strcasecmp(cnm, "Visible"))
| 1433 |
ct = tt_Y;
| 1434 |
else if (!strcasecmp(cnm, "CIE-u"))
| 1435 |
ct = tt_u;
| 1436 |
else if (!strcasecmp(cnm, "CIE-v"))
| 1437 |
ct = tt_v;
| 1438 |
else
| 1439 |
continue;
| 1440 |
for (wdb = ezxml_child(wld, "WavelengthDataBlock");
| 1441 |
wdb != NULL; wdb = wdb->next)
| 1442 |
if ((ec = load_bsdf_data(sd, wdb, ct, rank)) != SDEnone)
| 1443 |
return ec;
| 1444 |
| 1445 |
/* separate diffuse components */
| 1446 |
extract_diffuse(&sd->rLambFront, sd->rf);
| 1447 |
extract_diffuse(&sd->rLambBack, sd->rb);
| 1448 |
extract_diffuse(&sd->tLambFront, sd->tf);
| 1449 |
if (sd->tb != NULL) {
| 1450 |
extract_diffuse(&sd->tLambBack, sd->tb);
| 1451 |
if (sd->tf == NULL)
| 1452 |
sd->tLambFront = sd->tLambBack;
| 1453 |
} else if (sd->tf != NULL)
| 1454 |
sd->tLambBack = sd->tLambFront;
| 1455 |
/* return success */
| 1456 |
return SDEnone;
| 1457 |
| 1458 |
| 1459 |
/* Variable resolution BSDF methods */
| 1460 |
const SDFunc SDhandleTre = {
| 1461 |
&SDgetTreBSDF,
| 1462 |
&SDqueryTreProjSA,
| 1463 |
&SDgetTreCDist,
| 1464 |
&SDsampTreCDist,
| 1465 |
&SDFreeBTre,
| 1466 |
