| 1 |
| 2 |
* bsdf_m.h
| 3 |
| 4 |
* Support for BSDF matrices
| 5 |
| 6 |
* Created by Greg Ward on 2/2/11.
| 7 |
| 8 |
| 9 |
| 10 |
#ifndef _BSDF_M_H_
| 11 |
#define _BSDF_M_H_
| 12 |
| 13 |
#ifdef __cplusplus
| 14 |
extern "C" {
| 15 |
#endif
| 16 |
/* Fixed-position coordinate functions */
| 17 |
typedef int b_vecf(FVECT vec, int ndx, double randX, void *c_data);
| 18 |
typedef int b_ndxf(const FVECT vec, void *c_data);
| 19 |
typedef double b_ohmf(int ndx, void *c_data);
| 20 |
| 21 |
/* Rectangular matrix format BSDF */
| 22 |
typedef struct {
| 23 |
int ninc; /* number of incoming directions */
| 24 |
int nout; /* number of outgoing directions */
| 25 |
void *ib_priv; /* input basis private data */
| 26 |
b_vecf *ib_vec; /* get input vector from index */
| 27 |
b_ndxf *ib_ndx; /* get input index from vector */
| 28 |
b_ohmf *ib_ohm; /* get input proj. SA for index */
| 29 |
void *ob_priv; /* output basis private data */
| 30 |
b_vecf *ob_vec; /* get output vector from index */
| 31 |
b_ndxf *ob_ndx; /* get output index from vector */
| 32 |
b_ohmf *ob_ohm; /* get output proj. SA for index */
| 33 |
float bsdf[1]; /* scattering data (extends struct) */
| 34 |
} SDMat;
| 35 |
| 36 |
/* Matrix BSDF accessors */
| 37 |
#define mBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
| 38 |
#define mBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
| 39 |
#define mBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
| 40 |
#define mBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
| 41 |
#define mBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
| 42 |
#define mBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
| 43 |
#define mBSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
| 44 |
| 45 |
/* Holder for cumulative distribution (sum of BSDF * projSA) */
| 46 |
typedef struct {
| 47 |
SD_CDIST_BASE; /* base fields; must come first */
| 48 |
int indx; /* incident angle index */
| 49 |
void *ob_priv; /* private data for generator */
| 50 |
b_vecf *ob_vec; /* outbound vector generator */
| 51 |
int calen; /* cumulative array length */
| 52 |
unsigned carr[1]; /* cumulative array (extends struct) */
| 53 |
} SDMatCDst;
| 54 |
| 55 |
/* Load a set of BSDF matrices from an open XML file */
| 56 |
extern SDError SDloadMtx(SDData *sd, ezxml_t fl);
| 57 |
| 58 |
/* Our matrix handling routines */
| 59 |
extern SDFunc SDhandleMtx;
| 60 |
| 61 |
#ifdef __cplusplus
| 62 |
| 63 |
#endif
| 64 |
#endif /* ! _BSDF_M_H_ */
