root/radiance/ray/src/common/bsdf_m.h
Revision: 3.3
Committed: Sat Feb 19 01:48:59 2011 UTC (14 years, 2 months ago) by greg
Minor changes and fixes -- first working version of BSDF material
1 /* RCSid $Id: bsdf_m.h,v 3.2 2011/02/18 00:41:44 greg Exp $ */
2 /*
3 * bsdf_m.h
4 *
5 * Support for BSDF matrices
6 *
7 * Created by Greg Ward on 2/2/11.
8 *
9 */
10
11 #ifndef _BSDF_M_H_
12 #define _BSDF_M_H_
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17 /* Fixed-position coordinate functions */
18 typedef int b_vecf(FVECT vec, int ndx, double randX, void *c_data);
19 typedef int b_ndxf(const FVECT vec, void *c_data);
20 typedef double b_ohmf(int ndx, void *c_data);
21
22 /* Rectangular matrix format BSDF */
23 typedef struct {
24 int ninc; /* number of incoming directions */
25 int nout; /* number of outgoing directions */
26 void *ib_priv; /* input basis private data */
27 b_vecf *ib_vec; /* get input vector from index */
28 b_ndxf *ib_ndx; /* get input index from vector */
29 b_ohmf *ib_ohm; /* get input proj. SA for index */
30 void *ob_priv; /* output basis private data */
31 b_vecf *ob_vec; /* get output vector from index */
32 b_ndxf *ob_ndx; /* get output index from vector */
33 b_ohmf *ob_ohm; /* get output proj. SA for index */
34 float bsdf[1]; /* scattering data (extends struct) */
35 } SDMat;
36
37 /* Matrix BSDF accessors */
38 #define mBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
39 #define mBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
40 #define mBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
41 #define mBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
42 #define mBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
43 #define mBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
44 #define mBSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
45
46 /* Holder for cumulative distribution (sum of BSDF * projSA) */
47 typedef struct {
48 SD_CDIST_BASE; /* base fields; must come first */
49 int indx; /* incident angle index */
50 void *ob_priv; /* private data for generator */
51 b_vecf *ob_vec; /* outbound vector generator */
52 int calen; /* cumulative array length */
53 unsigned carr[1]; /* cumulative array (extends struct) */
54 } SDMatCDst;
55
56 /* Load a set of BSDF matrices from an open XML file */
57 extern SDError SDloadMtx(SDData *sd, ezxml_t wtl);
58
59 /* Our matrix handling routines */
60 extern SDFunc SDhandleMtx;
61
62 #ifdef __cplusplus
63 }
64 #endif
65 #endif /* ! _BSDF_M_H_ */
