root/radiance/ray/src/common/bsdf_m.h
Revision: 3.1
Committed: Fri Feb 18 00:40:25 2011 UTC (14 years, 2 months ago) by greg
1 /*
2 * bsdf_m.h
3 *
4 * Support for BSDF matrices
5 *
6 * Created by Greg Ward on 2/2/11.
7 *
8 */
9
10 #ifndef _BSDF_M_H_
11 #define _BSDF_M_H_
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16 /* Fixed-position coordinate functions */
17 typedef int b_vecf(FVECT vec, int ndx, double randX, void *c_data);
18 typedef int b_ndxf(const FVECT vec, void *c_data);
19 typedef double b_ohmf(int ndx, void *c_data);
20
21 /* Rectangular matrix format BSDF */
22 typedef struct {
23 int ninc; /* number of incoming directions */
24 int nout; /* number of outgoing directions */
25 void *ib_priv; /* input basis private data */
26 b_vecf *ib_vec; /* get input vector from index */
27 b_ndxf *ib_ndx; /* get input index from vector */
28 b_ohmf *ib_ohm; /* get input proj. SA for index */
29 void *ob_priv; /* output basis private data */
30 b_vecf *ob_vec; /* get output vector from index */
31 b_ndxf *ob_ndx; /* get output index from vector */
32 b_ohmf *ob_ohm; /* get output proj. SA for index */
33 float bsdf[1]; /* scattering data (extends struct) */
34 } SDMat;
35
36 /* Matrix BSDF accessors */
37 #define mBSDF_incvec(v,b,i) (*(b)->ib_vec)(v,i,(b)->ib_priv)
38 #define mBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
39 #define mBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
40 #define mBSDF_outvec(v,b,o) (*(b)->ob_vec)(v,o,(b)->ob_priv)
41 #define mBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
42 #define mBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
43 #define mBSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
44
45 /* Holder for cumulative distribution (sum of BSDF * projSA) */
46 typedef struct {
47 SD_CDIST_BASE; /* base fields; must come first */
48 int indx; /* incident angle index */
49 void *ob_priv; /* private data for generator */
50 b_vecf *ob_vec; /* outbound vector generator */
51 int calen; /* cumulative array length */
52 unsigned carr[1]; /* cumulative array (extends struct) */
53 } SDMatCDst;
54
55 /* Load a set of BSDF matrices from an open XML file */
56 extern SDError SDloadMtx(SDData *sd, ezxml_t fl);
57
58 /* Our matrix handling routines */
59 extern SDFunc SDhandleMtx;
60
61 #ifdef __cplusplus
62 }
63 #endif
64 #endif /* ! _BSDF_M_H_ */
