root/radiance/ray/src/common/bsdf_m.h
Revision: 3.6
Committed: Sun Apr 21 22:58:40 2013 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R2P1
Changes since 3.5: +48 -1 lines
Exposed functions and data structures needed by bsdf2klems
1 /* RCSid $Id: bsdf_m.h,v 3.5 2011/08/21 22:38:12 greg Exp $ */
2 /*
3 * bsdf_m.h
4 *
5 * Support for BSDF matrices.
6 * Assumes "bsdf.h" already included.
7 * Include after "ezxml.h" for SDloadMtx() declaration.
8 *
9 * Created by Greg Ward on 2/2/11.
10 *
11 */
12
13 #ifndef _BSDF_M_H_
14 #define _BSDF_M_H_
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19 /* Fixed-position coordinate functions */
20 typedef int b_vecf(FVECT vec, double ndxr, void *c_data);
21 typedef int b_ndxf(const FVECT vec, void *c_data);
22 typedef double b_ohmf(int ndx, void *c_data);
23
24 /* Rectangular matrix format BSDF */
25 typedef struct {
26 int ninc; /* number of incoming directions */
27 int nout; /* number of outgoing directions */
28 void *ib_priv; /* input basis private data */
29 b_vecf *ib_vec; /* get input vector from index */
30 b_ndxf *ib_ndx; /* get input index from vector */
31 b_ohmf *ib_ohm; /* get input proj. SA for index */
32 void *ob_priv; /* output basis private data */
33 b_vecf *ob_vec; /* get output vector from index */
34 b_ndxf *ob_ndx; /* get output index from vector */
35 b_ohmf *ob_ohm; /* get output proj. SA for index */
36 float bsdf[1]; /* scattering data (extends struct) */
37 } SDMat;
38
39 /* Matrix BSDF accessors */
40 #define mBSDF_incvec(v,b,ix) (*(b)->ib_vec)(v,ix,(b)->ib_priv)
41 #define mBSDF_incndx(b,v) (*(b)->ib_ndx)(v,(b)->ib_priv)
42 #define mBSDF_incohm(b,i) (*(b)->ib_ohm)(i,(b)->ib_priv)
43 #define mBSDF_outvec(v,b,ox) (*(b)->ob_vec)(v,ox,(b)->ob_priv)
44 #define mBSDF_outndx(b,v) (*(b)->ob_ndx)(v,(b)->ob_priv)
45 #define mBSDF_outohm(b,o) (*(b)->ob_ohm)(o,(b)->ob_priv)
46 #define mBSDF_value(b,i,o) (b)->bsdf[(o)*(b)->ninc + (i)]
47
48 /* Holder for cumulative distribution (sum of BSDF * projSA) */
49 typedef struct SDMatCDst_s {
50 SD_CDIST_BASE(SDMatCDst_s); /* base fields; must come first */
51 int indx; /* incident angle index */
52 void *ob_priv; /* private data for generator */
53 b_vecf *ob_vec; /* outbound vector generator */
54 int calen; /* cumulative array length */
55 unsigned carr[1]; /* cumulative array (extends struct) */
56 } SDMatCDst;
57
58 #ifdef _EZXML_H
59 /* Load a set of BSDF matrices from an open XML file */
60 extern SDError SDloadMtx(SDData *sd, ezxml_t wtl);
61 #endif
62
63 /* Our matrix handling routines */
64 extern SDFunc SDhandleMtx;
65
66 /******** Klems basis declarations for more intimate access ********/
67
68 #define MAXLATS 46 /* maximum number of latitudes */
69
70 /* BSDF angle specification */
71 typedef struct {
72 char name[64]; /* basis name */
73 int nangles; /* total number of directions */
74 struct {
75 float tmin; /* starting theta */
76 int nphis; /* number of phis (0 term) */
77 } lat[MAXLATS+1]; /* latitudes */
78 } ANGLE_BASIS;
79
80 #define MAXABASES 7 /* limit on defined bases */
81
82 extern ANGLE_BASIS abase_list[MAXABASES];
83
84 extern int nabases; /* current number of defined bases */
85
86 /* Get vector for this angle basis index (front exiting) */
87 extern b_vecf fo_getvec;
88
89 /* Get index corresponding to the given vector (front exiting) */
90 extern b_ndxf fo_getndx;
91
92 /* Get projected solid angle for this angle basis index (universal) */
93 extern b_ohmf io_getohm;
94
95 /* Get vector for this angle basis index (back incident) */
96 extern b_vecf bi_getvec;
97
98 /* Get index corresponding to the vector (back incident) */
99 extern b_ndxf bi_getndx;
100
101 /* Get vector for this angle basis index (back exiting) */
102 extern b_vecf bo_getvec;
103
104 /* Get index corresponding to the vector (back exiting) */
105 extern b_ndxf bo_getndx;
106
107 /* Get vector for this angle basis index (front incident) */
108 extern b_vecf fi_getvec;
109
110 /* Get index corresponding to the vector (front incident) */
111 extern b_ndxf fi_getndx;
112
113 #ifdef __cplusplus
114 }
115 #endif
116 #endif /* ! _BSDF_M_H_ */
