root/radiance/ray/src/common/bsdf_m.h
Wed Sep 11 00:24:03 2019 UTC (5 years, 8 months ago) by greg
Changes since 3.9: +3 -3 lines
Diff to previous 3.9
Reversed order of matrix look-up macros to be more consistent
Fri Jan 5 21:00:24 2018 UTC (7 years, 4 months ago) by greg
Changes since 3.8: +2 -2 lines
Diff to previous 3.8
Fix for C++ compilers, which don't like "typedef const struct"
Thu Aug 27 04:33:31 2015 UTC (9 years, 8 months ago) by greg
CVS Tags: rad5R0, rad5R1
Changes since 3.7: +2 -1 lines
Diff to previous 3.7
Added mBSDF_chroma() macro
Thu Apr 2 16:40:32 2015 UTC (10 years, 1 month ago) by greg
Changes since 3.6: +8 -1 lines
Diff to previous 3.6
Support for color BSDF rendering using Klems representation
Sun Apr 21 22:58:40 2013 UTC (12 years ago) by greg
Changes since 3.5: +48 -1 lines
Diff to previous 3.5
Exposed functions and data structures needed by bsdf2klems
Sun Aug 21 22:38:12 2011 UTC (13 years, 8 months ago) by greg
Changes since 3.4: +3 -3 lines
Diff to previous 3.4
Minor improvements to direct specular sampling
Fri Apr 8 18:13:48 2011 UTC (14 years, 1 month ago) by greg
Changes since 3.3: +9 -5 lines
Diff to previous 3.3
Sat Feb 19 01:48:59 2011 UTC (14 years, 2 months ago) by greg
Diff to previous 3.2
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 00:41:44 2011 UTC (14 years, 2 months ago) by greg
Changes since 3.1: +1 -0 lines
Diff to previous 3.1
Added missing RCS tags
Fri Feb 18 00:40:25 2011 UTC (14 years, 2 months ago) by greg
