--- ray/src/common/bsdf_m.c 2015/04/08 16:10:47 3.33 +++ ray/src/common/bsdf_m.c 2021/03/27 16:40:46 3.40 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_m.c,v 3.33 2015/04/08 16:10:47 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_m.c,v 3.40 2021/03/27 16:40:46 greg Exp $"; #endif /* * bsdf_m.c @@ -191,6 +191,7 @@ fo_getndx(const FVECT v, void *p) double io_getohm(int ndx, void *p) { + static void *last_p = NULL; static int last_li = -1; static double last_ohm; ANGLE_BASIS *ab = (ANGLE_BASIS *)p; @@ -201,8 +202,9 @@ io_getohm(int ndx, void *p) return -1.; for (li = 0; ndx >= ab->lat[li].nphis; li++) ndx -= ab->lat[li].nphis; - if (li == last_li) /* cached latitude? */ + if ((p == last_p) & (li == last_li)) /* cached latitude? */ return last_ohm; + last_p = p; last_li = li; theta = M_PI/180. * ab->lat[li].tmin; theta1 = M_PI/180. * ab->lat[li+1].tmin; @@ -294,11 +296,11 @@ mBSDF_color(float coef[], const SDMat *dp, int i, int { C_COLOR cxy; - coef[0] = mBSDF_value(dp, i, o); + coef[0] = mBSDF_value(dp, o, i); if (dp->chroma == NULL) return 1; /* grayscale */ - c_decodeChroma(&cxy, dp->chroma[o*dp->ninc + i]); + c_decodeChroma(&cxy, mBSDF_chroma(dp,o,i)); c_toSharpRGB(&cxy, coef[0], coef); coef[0] *= mtx_RGB_coef[0]; coef[1] *= mtx_RGB_coef[1]; @@ -381,7 +383,7 @@ get_extrema(SDSpectralDF *df) for (i = dp->ninc; i--; ) { double hemi = .0; for (o = dp->nout; o--; ) - hemi += ohma[o] * mBSDF_value(dp, i, o); + hemi += ohma[o] * mBSDF_value(dp, o, i); if (hemi > df->maxHemi) df->maxHemi = hemi; } @@ -517,7 +519,7 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int ct, int ro if (rowinc) { int r = i/dp->nout; int c = i - r*dp->nout; - mBSDF_value(dp,r,c) = val; + mBSDF_value(dp,c,r) = val; } else dp->bsdf[i] = val; sdata = sdnext; @@ -622,8 +624,8 @@ subtract_min(C_COLOR *cs, SDMat *sm) coef[c] = (coef[c] - min_coef[c]) / mtx_RGB_coef[c]; if (c_fromSharpRGB(coef, &cxy) > 1e-5) - sm->chroma[o*sm->ninc + i] = c_encodeChroma(&cxy); - mBSDF_value(sm,i,o) -= ymin; + mBSDF_chroma(sm,o,i) = c_encodeChroma(&cxy); + mBSDF_value(sm,o,i) -= ymin; } /* return colored minimum */ for (i = 3; i--; ) @@ -647,8 +649,8 @@ extract_diffuse(SDValue *dv, SDSpectralDF *df) /* subtract minimum value */ dv->cieY = subtract_min(&dv->spec, (SDMat *)df->comp[0].dist); df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */ - /* make sure everything is set */ - c_ccvt(&dv->spec, C_CSXY+C_CSSPEC); + + c_ccvt(&dv->spec, C_CSXY); /* make sure (x,y) is set */ return df; } @@ -707,10 +709,10 @@ SDloadMtx(SDData *sd, ezxml_t wtl) /* separate diffuse components */ sd->rf = extract_diffuse(&sd->rLambFront, sd->rf); sd->rb = extract_diffuse(&sd->rLambBack, sd->rb); - if (sd->tf != NULL) - sd->tf = extract_diffuse(&sd->tLamb, sd->tf); if (sd->tb != NULL) sd->tb = extract_diffuse(&sd->tLamb, sd->tb); + if (sd->tf != NULL) + sd->tf = extract_diffuse(&sd->tLamb, sd->tf); /* return success */ return SDEnone; } @@ -803,10 +805,10 @@ make_cdist(SDMatCDst *cd, const FVECT inVec, SDMat *dp cmtab[0] = .0; for (o = 0; o < cd->calen; o++) { if (rev) - cmtab[o+1] = mBSDF_value(dp, o, cd->indx) * + cmtab[o+1] = mBSDF_value(dp, cd->indx, o) * (*dp->ib_ohm)(o, dp->ib_priv); else - cmtab[o+1] = mBSDF_value(dp, cd->indx, o) * + cmtab[o+1] = mBSDF_value(dp, o, cd->indx) * (*dp->ob_ohm)(o, dp->ob_priv); cmtab[o+1] += cmtab[o]; } @@ -849,6 +851,7 @@ SDgetMtxCDist(const FVECT inVec, SDComponent *sdc) reverse = 1; } cdlast = NULL; /* check for it in cache list */ + /* PLACE MUTEX LOCK HERE FOR THREAD-SAFE */ for (cd = (SDMatCDst *)sdc->cdList; cd != NULL; cdlast = cd, cd = cd->next) if (cd->indx == myCD.indx && (cd->calen == myCD.calen) & @@ -872,6 +875,7 @@ SDgetMtxCDist(const FVECT inVec, SDComponent *sdc) cd->next = (SDMatCDst *)sdc->cdList; sdc->cdList = (SDCDst *)cd; } + /* END MUTEX LOCK */ return (SDCDst *)cd; /* ready to go */ } @@ -904,7 +908,7 @@ SDsampMtxCDist(FVECT ioVec, double randX, const SDCDst } /* Fixed resolution BSDF methods */ -SDFunc SDhandleMtx = { +const SDFunc SDhandleMtx = { &SDgetMtxBSDF, &SDqueryMtxProjSA, &SDgetMtxCDist,
