--- ray/src/common/bsdf_m.c 2011/02/19 01:48:59 3.4 +++ ray/src/common/bsdf_m.c 2011/02/19 23:42:09 3.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_m.c,v 3.4 2011/02/19 01:48:59 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_m.c,v 3.5 2011/02/19 23:42:09 greg Exp $"; #endif /* * bsdf_m.c @@ -346,8 +346,7 @@ get_extrema(SDSpectralDF *df) } free(ohma); /* need incoming solid angles, too? */ - if (dp->ninc < dp->nout || dp->ib_ohm != dp->ob_ohm || - dp->ib_priv != dp->ob_priv) { + if ((dp->ib_ohm != dp->ob_ohm) | (dp->ib_priv != dp->ob_priv)) { double ohm; for (i = dp->ninc; i--; ) if ((ohm = mBSDF_incohm(dp,i)) < df->minProjSA) @@ -419,26 +418,26 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) dp = SDnewMatrix(abase_list[inbi].nangles, abase_list[outbi].nangles); if (dp == NULL) return RC_MEMERR; - dp->ib_priv = (void *)&abase_list[inbi]; - dp->ob_priv = (void *)&abase_list[outbi]; + dp->ib_priv = &abase_list[inbi]; + dp->ob_priv = &abase_list[outbi]; if (df == sd->tf) { - dp->ib_vec = ab_getvecR; - dp->ib_ndx = ab_getndxR; - dp->ob_vec = ab_getvec; - dp->ob_ndx = ab_getndx; + dp->ib_vec = &ab_getvecR; + dp->ib_ndx = &ab_getndxR; + dp->ob_vec = &ab_getvec; + dp->ob_ndx = &ab_getndx; } else if (df == sd->rf) { - dp->ib_vec = ab_getvec; - dp->ib_ndx = ab_getndx; - dp->ob_vec = ab_getvec; - dp->ob_ndx = ab_getndx; + dp->ib_vec = &ab_getvec; + dp->ib_ndx = &ab_getndx; + dp->ob_vec = &ab_getvec; + dp->ob_ndx = &ab_getndx; } else /* df == sd->rb */ { - dp->ib_vec = ab_getvecR; - dp->ib_ndx = ab_getndxR; - dp->ob_vec = ab_getvecR; - dp->ob_ndx = ab_getndxR; + dp->ib_vec = &ab_getvecR; + dp->ib_ndx = &ab_getndxR; + dp->ob_vec = &ab_getvecR; + dp->ob_ndx = &ab_getndxR; } - dp->ib_ohm = ab_getohm; - dp->ob_ohm = ab_getohm; + dp->ib_ohm = &ab_getohm; + dp->ob_ohm = &ab_getohm; df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */ df->comp[0].dist = dp; df->comp[0].func = &SDhandleMtx; @@ -590,54 +589,39 @@ static SDError SDqueryMtxProjSA(double *psa, const FVECT vec, int qflags, const void *dist) { const SDMat *dp = (const SDMat *)dist; - - if (!(qflags & SDqueryInc+SDqueryOut)) + double inc_psa, out_psa; + /* check arguments */ + if ((psa == NULL) | (vec == NULL) | (dp == NULL)) return SDEargument; - if (qflags & SDqueryInc) { - double inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, vec)); - if (inc_psa < .0) - return SDEinternal; - switch (qflags & SDqueryMin+SDqueryMax) { - case SDqueryMax: - if (inc_psa > psa[0]) - psa[0] = inc_psa; - break; - case SDqueryMin+SDqueryMax: - if (inc_psa > psa[1]) - psa[1] = inc_psa; - /* fall through */ - case SDqueryMin: - if (inc_psa < psa[0]) - psa[0] = inc_psa; - break; - case 0: + /* get projected solid angles */ + inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, vec)); + out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, vec)); + + switch (qflags) { /* record based on flag settings */ + case SDqueryVal: + psa[0] = .0; + /* fall through */ + case SDqueryMax: + if (inc_psa > psa[0]) psa[0] = inc_psa; - break; - } + if (out_psa > psa[0]) + psa[0] = out_psa; + break; + case SDqueryMin+SDqueryMax: + if (inc_psa > psa[0]) + psa[1] = inc_psa; + if (out_psa > psa[0]) + psa[1] = out_psa; + /* fall through */ + case SDqueryMin: + if ((inc_psa > .0) & (inc_psa < psa[0])) + psa[0] = inc_psa; + if ((out_psa > .0) & (out_psa < psa[0])) + psa[0] = out_psa; + break; } - if (qflags & SDqueryOut) { - double out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, vec)); - if (out_psa < .0) - return SDEinternal; - switch (qflags & SDqueryMin+SDqueryMax) { - case SDqueryMax: - if (out_psa > psa[0]) - psa[0] = out_psa; - break; - case SDqueryMin+SDqueryMax: - if (out_psa > psa[1]) - psa[1] = out_psa; - /* fall through */ - case SDqueryMin: - if (out_psa < psa[0]) - psa[0] = out_psa; - break; - case 0: - psa[(qflags&SDqueryInc)!=0] = out_psa; - break; - } - } - return SDEnone; + /* make sure it's legal */ + return (psa[0] <= .0) ? SDEinternal : SDEnone; } /* Compute new cumulative distribution from BSDF */ @@ -679,8 +663,8 @@ SDgetMtxCDist(const FVECT inVec, SDComponent *sdc) int reverse; SDMatCDst myCD; SDMatCDst *cd, *cdlast; - - if (dp == NULL) + /* check arguments */ + if ((inVec == NULL) | (dp == NULL)) return NULL; memset(&myCD, 0, sizeof(myCD)); myCD.indx = mBSDF_incndx(dp, inVec); @@ -735,6 +719,9 @@ SDsampMtxCDist(FVECT outVec, double randX, const SDCDs const SDMatCDst *mcd = (const SDMatCDst *)cdp; const unsigned target = randX*maxval; int i, iupper, ilower; + /* check arguments */ + if ((outVec == NULL) | (mcd == NULL)) + return SDEargument; /* binary search to find index */ ilower = 0; iupper = mcd->calen; while ((i = (iupper + ilower) >> 1) != ilower)
