--- ray/src/common/bsdf_m.c 2018/05/10 22:55:35 3.38 +++ ray/src/common/bsdf_m.c 2021/03/27 16:40:46 3.40 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_m.c,v 3.38 2018/05/10 22:55:35 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_m.c,v 3.40 2021/03/27 16:40:46 greg Exp $"; #endif /* * bsdf_m.c @@ -296,11 +296,11 @@ mBSDF_color(float coef[], const SDMat *dp, int i, int { C_COLOR cxy; - coef[0] = mBSDF_value(dp, i, o); + coef[0] = mBSDF_value(dp, o, i); if (dp->chroma == NULL) return 1; /* grayscale */ - c_decodeChroma(&cxy, mBSDF_chroma(dp,i,o)); + c_decodeChroma(&cxy, mBSDF_chroma(dp,o,i)); c_toSharpRGB(&cxy, coef[0], coef); coef[0] *= mtx_RGB_coef[0]; coef[1] *= mtx_RGB_coef[1]; @@ -383,7 +383,7 @@ get_extrema(SDSpectralDF *df) for (i = dp->ninc; i--; ) { double hemi = .0; for (o = dp->nout; o--; ) - hemi += ohma[o] * mBSDF_value(dp, i, o); + hemi += ohma[o] * mBSDF_value(dp, o, i); if (hemi > df->maxHemi) df->maxHemi = hemi; } @@ -519,7 +519,7 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int ct, int ro if (rowinc) { int r = i/dp->nout; int c = i - r*dp->nout; - mBSDF_value(dp,r,c) = val; + mBSDF_value(dp,c,r) = val; } else dp->bsdf[i] = val; sdata = sdnext; @@ -624,8 +624,8 @@ subtract_min(C_COLOR *cs, SDMat *sm) coef[c] = (coef[c] - min_coef[c]) / mtx_RGB_coef[c]; if (c_fromSharpRGB(coef, &cxy) > 1e-5) - mBSDF_chroma(sm,i,o) = c_encodeChroma(&cxy); - mBSDF_value(sm,i,o) -= ymin; + mBSDF_chroma(sm,o,i) = c_encodeChroma(&cxy); + mBSDF_value(sm,o,i) -= ymin; } /* return colored minimum */ for (i = 3; i--; ) @@ -709,10 +709,10 @@ SDloadMtx(SDData *sd, ezxml_t wtl) /* separate diffuse components */ sd->rf = extract_diffuse(&sd->rLambFront, sd->rf); sd->rb = extract_diffuse(&sd->rLambBack, sd->rb); - if (sd->tf != NULL) - sd->tf = extract_diffuse(&sd->tLamb, sd->tf); if (sd->tb != NULL) sd->tb = extract_diffuse(&sd->tLamb, sd->tb); + if (sd->tf != NULL) + sd->tf = extract_diffuse(&sd->tLamb, sd->tf); /* return success */ return SDEnone; } @@ -805,10 +805,10 @@ make_cdist(SDMatCDst *cd, const FVECT inVec, SDMat *dp cmtab[0] = .0; for (o = 0; o < cd->calen; o++) { if (rev) - cmtab[o+1] = mBSDF_value(dp, o, cd->indx) * + cmtab[o+1] = mBSDF_value(dp, cd->indx, o) * (*dp->ib_ohm)(o, dp->ib_priv); else - cmtab[o+1] = mBSDF_value(dp, cd->indx, o) * + cmtab[o+1] = mBSDF_value(dp, o, cd->indx) * (*dp->ob_ohm)(o, dp->ob_priv); cmtab[o+1] += cmtab[o]; }
