--- ray/src/common/bsdf_m.c 2011/02/23 21:58:31 3.7 +++ ray/src/common/bsdf_m.c 2011/02/24 20:14:26 3.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_m.c,v 3.7 2011/02/23 21:58:31 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_m.c,v 3.8 2011/02/24 20:14:26 greg Exp $"; #endif /* * bsdf_m.c @@ -157,9 +157,9 @@ SDnewMatrix(int ni, int no) /* Free a BSDF matrix */ #define SDfreeMatrix free -/* get vector for this angle basis index */ +/* get vector for this angle basis index (front exiting) */ static int -ab_getvec(FVECT v, int ndx, double randX, void *p) +fo_getvec(FVECT v, int ndx, double randX, void *p) { ANGLE_BASIS *ab = (ANGLE_BASIS *)p; double rx[2]; @@ -181,9 +181,9 @@ ab_getvec(FVECT v, int ndx, double randX, void *p) return RC_GOOD; } -/* get index corresponding to the given vector */ +/* get index corresponding to the given vector (front exiting) */ static int -ab_getndx(const FVECT v, void *p) +fo_getndx(const FVECT v, void *p) { ANGLE_BASIS *ab = (ANGLE_BASIS *)p; int li, ndx; @@ -210,9 +210,9 @@ ab_getndx(const FVECT v, void *p) /* compute square of real value */ static double sq(double x) { return x*x; } -/* get projected solid angle for this angle basis index */ +/* get projected solid angle for this angle basis index (universal) */ static double -ab_getohm(int ndx, void *p) +io_getohm(int ndx, void *p) { static int last_li = -1; static double last_ohm; @@ -235,13 +235,11 @@ ab_getohm(int ndx, void *p) (double)ab->lat[li].nphis; } -/* get reverse vector for this angle basis index */ +/* get vector for this angle basis index (back incident) */ static int -ab_getvecR(FVECT v, int ndx, double randX, void *p) +bi_getvec(FVECT v, int ndx, double randX, void *p) { - int na = (*(ANGLE_BASIS *)p).nangles; - - if (!ab_getvec(v, ndx, randX, p)) + if (!fo_getvec(v, ndx, randX, p)) return RC_FAIL; v[0] = -v[0]; @@ -251,9 +249,9 @@ ab_getvecR(FVECT v, int ndx, double randX, void *p) return RC_GOOD; } -/* get index corresponding to the reverse vector */ +/* get index corresponding to the vector (back incident) */ static int -ab_getndxR(const FVECT v, void *p) +bi_getndx(const FVECT v, void *p) { FVECT v2; @@ -261,9 +259,60 @@ ab_getndxR(const FVECT v, void *p) v2[1] = -v[1]; v2[2] = -v[2]; - return ab_getndx(v2, p); + return fo_getndx(v2, p); } +/* get vector for this angle basis index (back exiting) */ +static int +bo_getvec(FVECT v, int ndx, double randX, void *p) +{ + if (!fo_getvec(v, ndx, randX, p)) + return RC_FAIL; + + v[2] = -v[2]; + + return RC_GOOD; +} + +/* get index corresponding to the vector (back exiting) */ +static int +bo_getndx(const FVECT v, void *p) +{ + FVECT v2; + + v2[0] = v[0]; + v2[1] = v[1]; + v2[2] = -v[2]; + + return fo_getndx(v2, p); +} + +/* get vector for this angle basis index (front incident) */ +static int +fi_getvec(FVECT v, int ndx, double randX, void *p) +{ + if (!fo_getvec(v, ndx, randX, p)) + return RC_FAIL; + + v[0] = -v[0]; + v[1] = -v[1]; + + return RC_GOOD; +} + +/* get index corresponding to the vector (front incident) */ +static int +fi_getndx(const FVECT v, void *p) +{ + FVECT v2; + + v2[0] = -v[0]; + v2[1] = -v[1]; + v2[2] = v[2]; + + return fo_getndx(v2, p); +} + /* load custom BSDF angle basis */ static int load_angle_basis(ezxml_t wab) @@ -362,12 +411,15 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) SDSpectralDF *df; SDMat *dp; char *sdata; - int tback; + int tfront; int inbi, outbi; int i; /* allocate BSDF component */ sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection")); - if ((tback = !strcasecmp(sdata, "Transmission Back")) || + /* + * Remember that front and back are reversed from WINDOW 6 orientations + */ + if ((tfront = !strcasecmp(sdata, "Transmission Back")) || (sd->tf == NULL && !strcasecmp(sdata, "Transmission Front"))) { if (sd->tf != NULL) @@ -424,30 +476,30 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) dp->ib_priv = &abase_list[inbi]; dp->ob_priv = &abase_list[outbi]; if (df == sd->tf) { - if (tback) { - dp->ib_vec = &ab_getvecR; - dp->ib_ndx = &ab_getndxR; - dp->ob_vec = &ab_getvec; - dp->ob_ndx = &ab_getndx; + if (tfront) { + dp->ib_vec = &fi_getvec; + dp->ib_ndx = &fi_getndx; + dp->ob_vec = &bo_getvec; + dp->ob_ndx = &bo_getndx; } else { - dp->ib_vec = &ab_getvec; - dp->ib_ndx = &ab_getndx; - dp->ob_vec = &ab_getvecR; - dp->ob_ndx = &ab_getndxR; + dp->ib_vec = &bi_getvec; + dp->ib_ndx = &bi_getndx; + dp->ob_vec = &fo_getvec; + dp->ob_ndx = &fo_getndx; } } else if (df == sd->rf) { - dp->ib_vec = &ab_getvec; - dp->ib_ndx = &ab_getndx; - dp->ob_vec = &ab_getvec; - dp->ob_ndx = &ab_getndx; + dp->ib_vec = &fi_getvec; + dp->ib_ndx = &fi_getndx; + dp->ob_vec = &fo_getvec; + dp->ob_ndx = &fo_getndx; } else /* df == sd->rb */ { - dp->ib_vec = &ab_getvecR; - dp->ib_ndx = &ab_getndxR; - dp->ob_vec = &ab_getvecR; - dp->ob_ndx = &ab_getndxR; + dp->ib_vec = &bi_getvec; + dp->ib_ndx = &bi_getndx; + dp->ob_vec = &bo_getvec; + dp->ob_ndx = &bo_getndx; } - dp->ib_ohm = &ab_getohm; - dp->ob_ohm = &ab_getohm; + dp->ib_ohm = &io_getohm; + dp->ob_ohm = &io_getohm; df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */ df->comp[0].dist = dp; df->comp[0].func = &SDhandleMtx;
