Eliminated expensive and unnecessary spectral curve hallucination
Fix for C++ compilers, which don't like "typedef const struct"
Added mBSDF_chroma() macro
Added comments for placement of mutex locks to support multi-threading
Corrected error in last check-in
Fixed bug in randomization of vectors near surface normal (front or back)
Increased minimum threshold for diffuse scattering extraction to 1%
Added color rendering to tensor tree and minor fixes to Klems color rendering
Support for color BSDF rendering using Klems representation
Added protection against negative BSDF values
Fixed bug in accounting of diffuse transmitted component
Exposed functions and data structures needed by bsdf2klems
Hopeful fixes to tensor tree reciprocity and orientation
Fixed bug in bug fix (thanks to Andy McNeil)
Fixed bug for matrix BSDFs with more than one phi angle around zenith
Minor improvements to direct specular sampling
Removed unnecessary restriction on reciprocity
Fixed bug for MING32 and non-square matrices, allowing multiple angle bases
Minor compile fixes
Fixes for Windows and bug fix in bsdf_m.c
Initial untested variable-resolution BSDF
Fix from last change
Bug fixes to last change
Partial implementation of variable-resolution BSDFs
Fixes to last change -- tested
Fixed interface for determining BSDF solid angles
Fixed issue with coordinate orientation for front transmission
Corrected notion of "front" and "back" to coincide with surface normals
Fixes to BSDF including blurring of angle boundaries
Minor changes and fixes -- first working version of BSDF material
Minor fixes and adjustments
Added missing RCS tags
