root/radiance/ray/src/common/bsdf_m.c
Revision: 3.24
Committed: Mon Sep 10 18:06:08 2012 UTC (12 years, 9 months ago) by greg
Changes since 3.23: +9 -9 lines
Hopeful fixes to tensor tree reciprocity and orientation
2 static const char RCSid[] = "$Id: bsdf_m.c,v 3.23 2012/09/02 15:33:15 greg Exp $";
5 * bsdf_m.c
6 *
7 * Definitions supporting BSDF matrices
8 *
9 * Created by Greg Ward on 2/2/11.
10 * Copyright 2011 Anyhere Software. All rights reserved.
11 *
12 */
13
14 #define _USE_MATH_DEFINES
15 #include "rtio.h"
16 #include <stdlib.h>
17 #include <math.h>
18 #include <ctype.h>
19 #include "ezxml.h"
20 #include "bsdf.h"
21 #include "bsdf_m.h"
22
23 /* Function return codes */
24 #define RC_GOOD 1
25 #define RC_FAIL 0
26 #define RC_FORMERR (-1)
27 #define RC_DATERR (-2)
28 #define RC_UNSUPP (-3)
29 #define RC_INTERR (-4)
30 #define RC_MEMERR (-5)
31
32 #define MAXLATS 46 /* maximum number of latitudes */
33
34 /* BSDF angle specification */
35 typedef struct {
36 char name[64]; /* basis name */
37 int nangles; /* total number of directions */
38 struct {
39 float tmin; /* starting theta */
40 int nphis; /* number of phis (0 term) */
41 } lat[MAXLATS+1]; /* latitudes */
42 } ANGLE_BASIS;
43
44 #define MAXABASES 7 /* limit on defined bases */
45
46 static ANGLE_BASIS abase_list[MAXABASES] = {
47 {
48 "LBNL/Klems Full", 145,
49 { {0., 1},
50 {5., 8},
51 {15., 16},
52 {25., 20},
53 {35., 24},
54 {45., 24},
55 {55., 24},
56 {65., 16},
57 {75., 12},
58 {90., 0} }
59 }, {
60 "LBNL/Klems Half", 73,
61 { {0., 1},
62 {6.5, 8},
63 {19.5, 12},
64 {32.5, 16},
65 {46.5, 20},
66 {61.5, 12},
67 {76.5, 4},
68 {90., 0} }
69 }, {
70 "LBNL/Klems Quarter", 41,
71 { {0., 1},
72 {9., 8},
73 {27., 12},
74 {46., 12},
75 {66., 8},
76 {90., 0} }
77 }
78 };
79
80 static int nabases = 3; /* current number of defined bases */
81
82 static int
83 fequal(double a, double b)
84 {
85 if (b != 0)
86 a = a/b - 1.;
87 return (a <= 1e-6) & (a >= -1e-6);
88 }
89
90 /* Returns the given tag's character content or empty string if none */
91 #ifdef ezxml_txt
92 #undef ezxml_txt
93 static char *
94 ezxml_txt(ezxml_t xml)
95 {
96 if (xml == NULL)
97 return "";
98 return xml->txt;
99 }
100 #endif
101
102 /* Convert error to standard BSDF code */
103 static SDError
104 convert_errcode(int ec)
105 {
106 switch (ec) {
107 case RC_GOOD:
108 return SDEnone;
109 case RC_FORMERR:
110 return SDEformat;
111 case RC_DATERR:
112 return SDEdata;
113 case RC_UNSUPP:
114 return SDEsupport;
115 case RC_INTERR:
116 return SDEinternal;
117 case RC_MEMERR:
118 return SDEmemory;
119 }
120 return SDEunknown;
121 }
122
123 /* Allocate a BSDF matrix of the given size */
124 static SDMat *
125 SDnewMatrix(int ni, int no)
126 {
127 SDMat *sm;
128
129 if ((ni <= 0) | (no <= 0)) {
130 strcpy(SDerrorDetail, "Empty BSDF matrix request");
131 return NULL;
132 }
133 sm = (SDMat *)malloc(sizeof(SDMat) + (ni*no - 1)*sizeof(float));
134 if (sm == NULL) {
135 sprintf(SDerrorDetail, "Cannot allocate %dx%d BSDF matrix",
136 ni, no);
137 return NULL;
138 }
139 memset(sm, 0, sizeof(SDMat)-sizeof(float));
140 sm->ninc = ni;
141 sm->nout = no;
142
143 return sm;
144 }
145
146 /* Free a BSDF matrix */
147 #define SDfreeMatrix free
148
149 /* get vector for this angle basis index (front exiting) */
150 static int
151 fo_getvec(FVECT v, double ndxr, void *p)
152 {
153 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
154 int ndx = (int)ndxr;
155 double randX = ndxr - ndx;
156 double rx[2];
157 int li;
158 double pol, azi, d;
159
160 if ((ndxr < 0) | (ndx >= ab->nangles))
161 return RC_FAIL;
162 for (li = 0; ndx >= ab->lat[li].nphis; li++)
163 ndx -= ab->lat[li].nphis;
164 SDmultiSamp(rx, 2, randX);
165 pol = M_PI/180.*( (1.-rx[0])*ab->lat[li].tmin +
166 rx[0]*ab->lat[li+1].tmin );
167 azi = 2.*M_PI*(ndx + rx[1] - .5)/ab->lat[li].nphis;
168 v[2] = d = cos(pol);
169 d = sqrt(1. - d*d); /* sin(pol) */
170 v[0] = cos(azi)*d;
171 v[1] = sin(azi)*d;
172 return RC_GOOD;
173 }
174
175 /* get index corresponding to the given vector (front exiting) */
176 static int
177 fo_getndx(const FVECT v, void *p)
178 {
179 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
180 int li, ndx;
181 double pol, azi;
182
183 if (v == NULL)
184 return -1;
185 if ((v[2] < 0) | (v[2] > 1.))
186 return -1;
187 pol = 180.0/M_PI*acos(v[2]);
188 azi = 180.0/M_PI*atan2(v[1], v[0]);
189 if (azi < 0.0) azi += 360.0;
190 for (li = 1; ab->lat[li].tmin <= pol; li++)
191 if (!ab->lat[li].nphis)
192 return -1;
193 --li;
194 ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5);
195 if (ndx >= ab->lat[li].nphis) ndx = 0;
196 while (li--)
197 ndx += ab->lat[li].nphis;
198 return ndx;
199 }
200
201 /* compute square of real value */
202 static double sq(double x) { return x*x; }
203
204 /* get projected solid angle for this angle basis index (universal) */
205 static double
206 io_getohm(int ndx, void *p)
207 {
208 static int last_li = -1;
209 static double last_ohm;
210 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
211 int li;
212 double theta, theta1;
213
214 if ((ndx < 0) | (ndx >= ab->nangles))
215 return -1.;
216 for (li = 0; ndx >= ab->lat[li].nphis; li++)
217 ndx -= ab->lat[li].nphis;
218 if (li == last_li) /* cached latitude? */
219 return last_ohm;
220 last_li = li;
221 theta = M_PI/180. * ab->lat[li].tmin;
222 theta1 = M_PI/180. * ab->lat[li+1].tmin;
223 return last_ohm = M_PI*(sq(cos(theta)) - sq(cos(theta1))) /
224 (double)ab->lat[li].nphis;
225 }
226
227 /* get vector for this angle basis index (back incident) */
228 static int
229 bi_getvec(FVECT v, double ndxr, void *p)
230 {
231 if (!fo_getvec(v, ndxr, p))
232 return RC_FAIL;
233
234 v[0] = -v[0];
235 v[1] = -v[1];
236 v[2] = -v[2];
237
238 return RC_GOOD;
239 }
240
241 /* get index corresponding to the vector (back incident) */
242 static int
243 bi_getndx(const FVECT v, void *p)
244 {
245 FVECT v2;
246
247 v2[0] = -v[0];
248 v2[1] = -v[1];
249 v2[2] = -v[2];
250
251 return fo_getndx(v2, p);
252 }
253
254 /* get vector for this angle basis index (back exiting) */
255 static int
256 bo_getvec(FVECT v, double ndxr, void *p)
257 {
258 if (!fo_getvec(v, ndxr, p))
259 return RC_FAIL;
260
261 v[2] = -v[2];
262
263 return RC_GOOD;
264 }
265
266 /* get index corresponding to the vector (back exiting) */
267 static int
268 bo_getndx(const FVECT v, void *p)
269 {
270 FVECT v2;
271
272 v2[0] = v[0];
273 v2[1] = v[1];
274 v2[2] = -v[2];
275
276 return fo_getndx(v2, p);
277 }
278
279 /* get vector for this angle basis index (front incident) */
280 static int
281 fi_getvec(FVECT v, double ndxr, void *p)
282 {
283 if (!fo_getvec(v, ndxr, p))
284 return RC_FAIL;
285
286 v[0] = -v[0];
287 v[1] = -v[1];
288
289 return RC_GOOD;
290 }
291
292 /* get index corresponding to the vector (front incident) */
293 static int
294 fi_getndx(const FVECT v, void *p)
295 {
296 FVECT v2;
297
298 v2[0] = -v[0];
299 v2[1] = -v[1];
300 v2[2] = v[2];
301
302 return fo_getndx(v2, p);
303 }
304
305 /* load custom BSDF angle basis */
306 static int
307 load_angle_basis(ezxml_t wab)
308 {
309 char *abname = ezxml_txt(ezxml_child(wab, "AngleBasisName"));
310 ezxml_t wbb;
311 int i;
312
313 if (!abname || !*abname)
314 return RC_FAIL;
315 for (i = nabases; i--; )
316 if (!strcasecmp(abname, abase_list[i].name))
317 return RC_GOOD; /* assume it's the same */
318 if (nabases >= MAXABASES) {
319 sprintf(SDerrorDetail, "Out of angle bases reading '%s'",
320 abname);
321 return RC_INTERR;
322 }
323 strcpy(abase_list[nabases].name, abname);
324 abase_list[nabases].nangles = 0;
325 for (i = 0, wbb = ezxml_child(wab, "AngleBasisBlock");
326 wbb != NULL; i++, wbb = wbb->next) {
327 if (i >= MAXLATS) {
328 sprintf(SDerrorDetail, "Too many latitudes for '%s'",
329 abname);
330 return RC_INTERR;
331 }
332 abase_list[nabases].lat[i+1].tmin = atof(ezxml_txt(
333 ezxml_child(ezxml_child(wbb,
334 "ThetaBounds"), "UpperTheta")));
335 if (!i)
336 abase_list[nabases].lat[0].tmin = 0;
337 else if (!fequal(atof(ezxml_txt(ezxml_child(ezxml_child(wbb,
338 "ThetaBounds"), "LowerTheta"))),
339 abase_list[nabases].lat[i].tmin)) {
340 sprintf(SDerrorDetail, "Theta values disagree in '%s'",
341 abname);
342 return RC_DATERR;
343 }
344 abase_list[nabases].nangles +=
345 abase_list[nabases].lat[i].nphis =
346 atoi(ezxml_txt(ezxml_child(wbb, "nPhis")));
347 if (abase_list[nabases].lat[i].nphis <= 0 ||
348 (abase_list[nabases].lat[i].nphis == 1 &&
349 abase_list[nabases].lat[i].tmin > FTINY)) {
350 sprintf(SDerrorDetail, "Illegal phi count in '%s'",
351 abname);
352 return RC_DATERR;
353 }
354 }
355 abase_list[nabases++].lat[i].nphis = 0;
356 return RC_GOOD;
357 }
358
359 /* compute min. proj. solid angle and max. direct hemispherical scattering */
360 static int
361 get_extrema(SDSpectralDF *df)
362 {
363 SDMat *dp = (SDMat *)df->comp[0].dist;
364 double *ohma;
365 int i, o;
366 /* initialize extrema */
367 df->minProjSA = M_PI;
368 df->maxHemi = .0;
369 ohma = (double *)malloc(dp->nout*sizeof(double));
370 if (ohma == NULL)
371 return RC_MEMERR;
372 /* get outgoing solid angles */
373 for (o = dp->nout; o--; )
374 if ((ohma[o] = mBSDF_outohm(dp,o)) < df->minProjSA)
375 df->minProjSA = ohma[o];
376 /* compute hemispherical sums */
377 for (i = dp->ninc; i--; ) {
378 double hemi = .0;
379 for (o = dp->nout; o--; )
380 hemi += ohma[o] * mBSDF_value(dp, i, o);
381 if (hemi > df->maxHemi)
382 df->maxHemi = hemi;
383 }
384 free(ohma);
385 /* need incoming solid angles, too? */
386 if ((dp->ib_ohm != dp->ob_ohm) | (dp->ib_priv != dp->ob_priv)) {
387 double ohm;
388 for (i = dp->ninc; i--; )
389 if ((ohm = mBSDF_incohm(dp,i)) < df->minProjSA)
390 df->minProjSA = ohm;
391 }
392 return (df->maxHemi <= 1.01);
393 }
394
395 /* load BSDF distribution for this wavelength */
396 static int
397 load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc)
398 {
399 SDSpectralDF *df;
400 SDMat *dp;
401 char *sdata;
402 int inbi, outbi;
403 int i;
404 /* allocate BSDF component */
405 sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection"));
406 if (!sdata)
407 return RC_FAIL;
408 /*
409 * Remember that front and back are reversed from WINDOW 6 orientations
410 */
411 if (!strcasecmp(sdata, "Transmission Front")) {
412 if (sd->tb != NULL)
413 SDfreeSpectralDF(sd->tb);
414 if ((sd->tb = SDnewSpectralDF(1)) == NULL)
415 return RC_MEMERR;
416 df = sd->tb;
417 } else if (!strcasecmp(sdata, "Transmission Back")) {
418 if (sd->tf != NULL)
419 SDfreeSpectralDF(sd->tf);
420 if ((sd->tf = SDnewSpectralDF(1)) == NULL)
421 return RC_MEMERR;
422 df = sd->tf;
423 } else if (!strcasecmp(sdata, "Reflection Front")) {
424 if (sd->rb != NULL)
425 SDfreeSpectralDF(sd->rb);
426 if ((sd->rb = SDnewSpectralDF(1)) == NULL)
427 return RC_MEMERR;
428 df = sd->rb;
429 } else if (!strcasecmp(sdata, "Reflection Back")) {
430 if (sd->rf != NULL)
431 SDfreeSpectralDF(sd->rf);
432 if ((sd->rf = SDnewSpectralDF(1)) == NULL)
433 return RC_MEMERR;
434 df = sd->rf;
435 } else
436 return RC_FAIL;
437 /* XXX should also check "ScatteringDataType" for consistency? */
438 /* get angle bases */
439 sdata = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis"));
440 if (!sdata || !*sdata) {
441 sprintf(SDerrorDetail, "Missing column basis for BSDF '%s'",
442 sd->name);
443 return RC_FORMERR;
444 }
445 for (inbi = nabases; inbi--; )
446 if (!strcasecmp(sdata, abase_list[inbi].name))
447 break;
448 if (inbi < 0) {
449 sprintf(SDerrorDetail, "Undefined ColumnAngleBasis '%s'", sdata);
450 return RC_FORMERR;
451 }
452 sdata = ezxml_txt(ezxml_child(wdb,"RowAngleBasis"));
453 if (!sdata || !*sdata) {
454 sprintf(SDerrorDetail, "Missing row basis for BSDF '%s'",
455 sd->name);
456 return RC_FORMERR;
457 }
458 for (outbi = nabases; outbi--; )
459 if (!strcasecmp(sdata, abase_list[outbi].name))
460 break;
461 if (outbi < 0) {
462 sprintf(SDerrorDetail, "Undefined RowAngleBasis '%s'", sdata);
463 return RC_FORMERR;
464 }
465 /* allocate BSDF matrix */
466 dp = SDnewMatrix(abase_list[inbi].nangles, abase_list[outbi].nangles);
467 if (dp == NULL)
468 return RC_MEMERR;
469 dp->ib_priv = &abase_list[inbi];
470 dp->ob_priv = &abase_list[outbi];
471 if (df == sd->tf) {
472 dp->ib_vec = &fi_getvec;
473 dp->ib_ndx = &fi_getndx;
474 dp->ob_vec = &bo_getvec;
475 dp->ob_ndx = &bo_getndx;
476 } else if (df == sd->tb) {
477 dp->ib_vec = &bi_getvec;
478 dp->ib_ndx = &bi_getndx;
479 dp->ob_vec = &fo_getvec;
480 dp->ob_ndx = &fo_getndx;
481 } else if (df == sd->rf) {
482 dp->ib_vec = &fi_getvec;
483 dp->ib_ndx = &fi_getndx;
484 dp->ob_vec = &fo_getvec;
485 dp->ob_ndx = &fo_getndx;
486 } else /* df == sd->rb */ {
487 dp->ib_vec = &bi_getvec;
488 dp->ib_ndx = &bi_getndx;
489 dp->ob_vec = &bo_getvec;
490 dp->ob_ndx = &bo_getndx;
491 }
492 dp->ib_ohm = &io_getohm;
493 dp->ob_ohm = &io_getohm;
494 df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */
495 df->comp[0].dist = dp;
496 df->comp[0].func = &SDhandleMtx;
497 /* read BSDF data */
498 sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData"));
499 if (!sdata || !*sdata) {
500 sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'",
501 sd->name);
502 return RC_FORMERR;
503 }
504 for (i = 0; i < dp->ninc*dp->nout; i++) {
505 char *sdnext = fskip(sdata);
506 if (sdnext == NULL) {
507 sprintf(SDerrorDetail,
508 "Bad/missing BSDF ScatteringData in '%s'",
509 sd->name);
510 return RC_FORMERR;
511 }
512 while (isspace(*sdnext))
513 sdnext++;
514 if (*sdnext == ',') sdnext++;
515 if (rowinc) {
516 int r = i/dp->nout;
517 int c = i - r*dp->nout;
518 mBSDF_value(dp,r,c) = atof(sdata);
519 } else
520 dp->bsdf[i] = atof(sdata);
521 sdata = sdnext;
522 }
523 return get_extrema(df);
524 }
525
526 /* Subtract minimum (diffuse) scattering amount from BSDF */
527 static double
528 subtract_min(SDMat *sm)
529 {
530 float minv = sm->bsdf[0];
531 int n = sm->ninc*sm->nout;
532 int i;
533
534 for (i = n; --i; )
535 if (sm->bsdf[i] < minv)
536 minv = sm->bsdf[i];
537
538 if (minv <= FTINY)
539 return .0;
540
541 for (i = n; i--; )
542 sm->bsdf[i] -= minv;
543
544 return minv*M_PI; /* be sure to include multiplier */
545 }
546
547 /* Extract and separate diffuse portion of BSDF */
548 static void
549 extract_diffuse(SDValue *dv, SDSpectralDF *df)
550 {
551 int n;
552
553 if (df == NULL || df->ncomp <= 0) {
554 dv->spec = c_dfcolor;
555 dv->cieY = .0;
556 return;
557 }
558 dv->spec = df->comp[0].cspec[0];
559 dv->cieY = subtract_min((SDMat *)df->comp[0].dist);
560 /* in case of multiple components */
561 for (n = df->ncomp; --n; ) {
562 double ymin = subtract_min((SDMat *)df->comp[n].dist);
563 c_cmix(&dv->spec, dv->cieY, &dv->spec, ymin, &df->comp[n].cspec[0]);
564 dv->cieY += ymin;
565 }
566 df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */
567 /* make sure everything is set */
568 c_ccvt(&dv->spec, C_CSXY+C_CSSPEC);
569 }
570
571 /* Load a BSDF matrix from an open XML file */
572 SDError
573 SDloadMtx(SDData *sd, ezxml_t wtl)
574 {
575 ezxml_t wld, wdb;
576 int rowIn;
577 char *txt;
578 int rval;
579 /* basic checks and data ordering */
580 txt = ezxml_txt(ezxml_child(ezxml_child(wtl,
581 "DataDefinition"), "IncidentDataStructure"));
582 if (txt == NULL || !*txt) {
583 sprintf(SDerrorDetail,
584 "BSDF \"%s\": missing IncidentDataStructure",
585 sd->name);
586 return SDEformat;
587 }
588 if (!strcasecmp(txt, "Rows"))
589 rowIn = 1;
590 else if (!strcasecmp(txt, "Columns"))
591 rowIn = 0;
592 else {
593 sprintf(SDerrorDetail,
594 "BSDF \"%s\": unsupported IncidentDataStructure",
595 sd->name);
596 return SDEsupport;
597 }
598 /* get angle bases */
599 for (wld = ezxml_child(ezxml_child(wtl, "DataDefinition"), "AngleBasis");
600 wld != NULL; wld = wld->next) {
601 rval = load_angle_basis(wld);
602 if (rval < 0)
603 return convert_errcode(rval);
604 }
605 /* load BSDF components */
606 for (wld = ezxml_child(wtl, "WavelengthData");
607 wld != NULL; wld = wld->next) {
608 if (strcasecmp(ezxml_txt(ezxml_child(wld,"Wavelength")),
609 "Visible"))
610 continue; /* just visible for now */
611 for (wdb = ezxml_child(wld, "WavelengthDataBlock");
612 wdb != NULL; wdb = wdb->next)
613 if ((rval = load_bsdf_data(sd, wdb, rowIn)) < 0)
614 return convert_errcode(rval);
615 }
616 /* separate diffuse components */
617 extract_diffuse(&sd->rLambFront, sd->rf);
618 extract_diffuse(&sd->rLambBack, sd->rb);
619 extract_diffuse(&sd->tLamb, (sd->tf != NULL) ? sd->tf : sd->tb);
620 /* return success */
621 return SDEnone;
622 }
623
624 /* Get Matrix BSDF value */
625 static int
626 SDgetMtxBSDF(float coef[SDmaxCh], const FVECT outVec,
627 const FVECT inVec, SDComponent *sdc)
628 {
629 const SDMat *dp;
630 int i_ndx, o_ndx;
631 /* check arguments */
632 if ((coef == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL)
633 || (dp = (SDMat *)sdc->dist) == NULL)
634 return 0;
635 /* get angle indices */
636 i_ndx = mBSDF_incndx(dp, inVec);
637 o_ndx = mBSDF_outndx(dp, outVec);
638 /* try reciprocity if necessary */
639 if ((i_ndx < 0) & (o_ndx < 0)) {
640 i_ndx = mBSDF_incndx(dp, outVec);
641 o_ndx = mBSDF_outndx(dp, inVec);
642 }
643 if ((i_ndx < 0) | (o_ndx < 0))
644 return 0; /* nothing from this component */
645 coef[0] = mBSDF_value(dp, i_ndx, o_ndx);
646 return 1; /* XXX monochrome for now */
647 }
648
649 /* Query solid angle for vector(s) */
650 static SDError
651 SDqueryMtxProjSA(double *psa, const FVECT v1, const RREAL *v2,
652 int qflags, SDComponent *sdc)
653 {
654 const SDMat *dp;
655 double inc_psa, out_psa;
656 /* check arguments */
657 if ((psa == NULL) | (v1 == NULL) | (sdc == NULL) ||
658 (dp = (SDMat *)sdc->dist) == NULL)
659 return SDEargument;
660 if (v2 == NULL)
661 v2 = v1;
662 /* get projected solid angles */
663 out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v1));
664 inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v2));
665 if ((v1 != v2) & (out_psa <= 0) & (inc_psa <= 0)) {
666 inc_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v2));
667 out_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v1));
668 }
669
670 switch (qflags) { /* record based on flag settings */
671 case SDqueryMax:
672 if (inc_psa > psa[0])
673 psa[0] = inc_psa;
674 if (out_psa > psa[0])
675 psa[0] = out_psa;
676 break;
677 case SDqueryMin+SDqueryMax:
678 if (inc_psa > psa[1])
679 psa[1] = inc_psa;
680 if (out_psa > psa[1])
681 psa[1] = out_psa;
682 /* fall through */
683 case SDqueryVal:
684 if (qflags == SDqueryVal)
685 psa[0] = M_PI;
686 /* fall through */
687 case SDqueryMin:
688 if ((inc_psa > 0) & (inc_psa < psa[0]))
689 psa[0] = inc_psa;
690 if ((out_psa > 0) & (out_psa < psa[0]))
691 psa[0] = out_psa;
692 break;
693 }
694 /* make sure it's legal */
695 return (psa[0] <= 0) ? SDEinternal : SDEnone;
696 }
697
698 /* Compute new cumulative distribution from BSDF */
699 static int
700 make_cdist(SDMatCDst *cd, const FVECT inVec, SDMat *dp, int rev)
701 {
702 const unsigned maxval = ~0;
703 double *cmtab, scale;
704 int o;
705
706 cmtab = (double *)malloc((cd->calen+1)*sizeof(double));
707 if (cmtab == NULL)
708 return 0;
709 cmtab[0] = .0;
710 for (o = 0; o < cd->calen; o++) {
711 if (rev)
712 cmtab[o+1] = mBSDF_value(dp, o, cd->indx) *
713 (*dp->ib_ohm)(o, dp->ib_priv);
714 else
715 cmtab[o+1] = mBSDF_value(dp, cd->indx, o) *
716 (*dp->ob_ohm)(o, dp->ob_priv);
717 cmtab[o+1] += cmtab[o];
718 }
719 cd->cTotal = cmtab[cd->calen];
720 scale = (double)maxval / cd->cTotal;
721 cd->carr[0] = 0;
722 for (o = 1; o < cd->calen; o++)
723 cd->carr[o] = scale*cmtab[o] + .5;
724 cd->carr[cd->calen] = maxval;
725 free(cmtab);
726 return 1;
727 }
728
729 /* Get cumulative distribution for matrix BSDF */
730 static const SDCDst *
731 SDgetMtxCDist(const FVECT inVec, SDComponent *sdc)
732 {
733 SDMat *dp;
734 int reverse;
735 SDMatCDst myCD;
736 SDMatCDst *cd, *cdlast;
737 /* check arguments */
738 if ((inVec == NULL) | (sdc == NULL) ||
739 (dp = (SDMat *)sdc->dist) == NULL)
740 return NULL;
741 memset(&myCD, 0, sizeof(myCD));
742 myCD.indx = mBSDF_incndx(dp, inVec);
743 if (myCD.indx >= 0) {
744 myCD.ob_priv = dp->ob_priv;
745 myCD.ob_vec = dp->ob_vec;
746 myCD.calen = dp->nout;
747 reverse = 0;
748 } else { /* try reciprocity */
749 myCD.indx = mBSDF_outndx(dp, inVec);
750 if (myCD.indx < 0)
751 return NULL;
752 myCD.ob_priv = dp->ib_priv;
753 myCD.ob_vec = dp->ib_vec;
754 myCD.calen = dp->ninc;
755 reverse = 1;
756 }
757 cdlast = NULL; /* check for it in cache list */
758 for (cd = (SDMatCDst *)sdc->cdList; cd != NULL;
759 cdlast = cd, cd = cd->next)
760 if (cd->indx == myCD.indx && (cd->calen == myCD.calen) &
761 (cd->ob_priv == myCD.ob_priv) &
762 (cd->ob_vec == myCD.ob_vec))
763 break;
764 if (cd == NULL) { /* need to allocate new entry */
765 cd = (SDMatCDst *)malloc(sizeof(SDMatCDst) +
766 sizeof(myCD.carr[0])*myCD.calen);
767 if (cd == NULL)
768 return NULL;
769 *cd = myCD; /* compute cumulative distribution */
770 if (!make_cdist(cd, inVec, dp, reverse)) {
771 free(cd);
772 return NULL;
773 }
774 cdlast = cd;
775 }
776 if (cdlast != NULL) { /* move entry to head of cache list */
777 cdlast->next = cd->next;
778 cd->next = (SDMatCDst *)sdc->cdList;
779 sdc->cdList = (SDCDst *)cd;
780 }
781 return (SDCDst *)cd; /* ready to go */
782 }
783
784 /* Sample cumulative distribution */
785 static SDError
786 SDsampMtxCDist(FVECT ioVec, double randX, const SDCDst *cdp)
787 {
788 const unsigned maxval = ~0;
789 const SDMatCDst *mcd = (const SDMatCDst *)cdp;
790 const unsigned target = randX*maxval;
791 int i, iupper, ilower;
792 /* check arguments */
793 if ((ioVec == NULL) | (mcd == NULL))
794 return SDEargument;
795 /* binary search to find index */
796 ilower = 0; iupper = mcd->calen;
797 while ((i = (iupper + ilower) >> 1) != ilower)
798 if (target >= mcd->carr[i])
799 ilower = i;
800 else
801 iupper = i;
802 /* localize random position */
803 randX = (randX*maxval - mcd->carr[ilower]) /
804 (double)(mcd->carr[iupper] - mcd->carr[ilower]);
805 /* convert index to vector */
806 if ((*mcd->ob_vec)(ioVec, i+randX, mcd->ob_priv))
807 return SDEnone;
808 strcpy(SDerrorDetail, "Matrix BSDF sampling fault");
809 return SDEinternal;
810 }
811
812 /* Fixed resolution BSDF methods */
813 SDFunc SDhandleMtx = {
814 &SDgetMtxBSDF,
815 &SDqueryMtxProjSA,
816 &SDgetMtxCDist,
817 &SDsampMtxCDist,
818 &SDfreeMatrix,
819 };
