--- ray/src/common/bsdf_m.c 2011/02/24 20:14:26 3.8 +++ ray/src/common/bsdf_m.c 2011/04/08 18:13:48 3.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_m.c,v 3.8 2011/02/24 20:14:26 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_m.c,v 3.9 2011/04/08 18:13:48 greg Exp $"; #endif /* * bsdf_m.c @@ -86,7 +86,7 @@ fequal(double a, double b) return (a <= 1e-6) & (a >= -1e-6); } -/* returns the name of the given tag */ +/* Returns the name of the given tag */ #ifdef ezxml_name #undef ezxml_name static char * @@ -98,7 +98,7 @@ ezxml_name(ezxml_t xml) } #endif -/* returns the given tag's character content or empty string if none */ +/* Returns the given tag's character content or empty string if none */ #ifdef ezxml_txt #undef ezxml_txt static char * @@ -159,14 +159,16 @@ SDnewMatrix(int ni, int no) /* get vector for this angle basis index (front exiting) */ static int -fo_getvec(FVECT v, int ndx, double randX, void *p) +fo_getvec(FVECT v, double ndxr, void *p) { - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + int ndx = (int)ndxr; + double randX = ndxr - ndx; double rx[2]; int li; double pol, azi, d; - if ((ndx < 0) | (ndx >= ab->nangles)) + if ((ndxr < 0) | (ndx >= ab->nangles)) return RC_FAIL; for (li = 0; ndx >= ab->lat[li].nphis; li++) ndx -= ab->lat[li].nphis; @@ -185,7 +187,7 @@ fo_getvec(FVECT v, int ndx, double randX, void *p) static int fo_getndx(const FVECT v, void *p) { - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + ANGLE_BASIS *ab = (ANGLE_BASIS *)p; int li, ndx; double pol, azi, d; @@ -237,9 +239,9 @@ io_getohm(int ndx, void *p) /* get vector for this angle basis index (back incident) */ static int -bi_getvec(FVECT v, int ndx, double randX, void *p) +bi_getvec(FVECT v, double ndxr, void *p) { - if (!fo_getvec(v, ndx, randX, p)) + if (!fo_getvec(v, ndxr, p)) return RC_FAIL; v[0] = -v[0]; @@ -264,9 +266,9 @@ bi_getndx(const FVECT v, void *p) /* get vector for this angle basis index (back exiting) */ static int -bo_getvec(FVECT v, int ndx, double randX, void *p) +bo_getvec(FVECT v, double ndxr, void *p) { - if (!fo_getvec(v, ndx, randX, p)) + if (!fo_getvec(v, ndxr, p)) return RC_FAIL; v[2] = -v[2]; @@ -289,9 +291,9 @@ bo_getndx(const FVECT v, void *p) /* get vector for this angle basis index (front incident) */ static int -fi_getvec(FVECT v, int ndx, double randX, void *p) +fi_getvec(FVECT v, double ndxr, void *p) { - if (!fo_getvec(v, ndx, randX, p)) + if (!fo_getvec(v, ndxr, p)) return RC_FAIL; v[0] = -v[0]; @@ -418,10 +420,11 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection")); /* * Remember that front and back are reversed from WINDOW 6 orientations + * Favor their "Front" (incoming light) since that's more often valid */ - if ((tfront = !strcasecmp(sdata, "Transmission Back")) || - (sd->tf == NULL && - !strcasecmp(sdata, "Transmission Front"))) { + tfront = !strcasecmp(sdata, "Transmission Back"); + if (!strcasecmp(sdata, "Transmission Front") || + tfront & (sd->tf == NULL)) { if (sd->tf != NULL) SDfreeSpectralDF(sd->tf); if ((sd->tf = SDnewSpectralDF(1)) == NULL) @@ -795,7 +798,7 @@ SDsampMtxCDist(FVECT outVec, double randX, const SDCDs randX = (randX*maxval - mcd->carr[ilower]) / (double)(mcd->carr[iupper] - mcd->carr[ilower]); /* convert index to vector */ - if ((*mcd->ob_vec)(outVec, i, randX, mcd->ob_priv)) + if ((*mcd->ob_vec)(outVec, i+randX, mcd->ob_priv)) return SDEnone; strcpy(SDerrorDetail, "BSDF sampling fault"); return SDEinternal;
