--- ray/src/common/bsdf_m.c 2011/02/24 20:14:26 3.8 +++ ray/src/common/bsdf_m.c 2011/04/27 20:03:25 3.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_m.c,v 3.8 2011/02/24 20:14:26 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_m.c,v 3.15 2011/04/27 20:03:25 greg Exp $"; #endif /* * bsdf_m.c @@ -81,12 +81,12 @@ static int nabases = 3; /* current number of defined b static int fequal(double a, double b) { - if (b != .0) + if (b != 0) a = a/b - 1.; return (a <= 1e-6) & (a >= -1e-6); } -/* returns the name of the given tag */ +/* Returns the name of the given tag */ #ifdef ezxml_name #undef ezxml_name static char * @@ -98,7 +98,7 @@ ezxml_name(ezxml_t xml) } #endif -/* returns the given tag's character content or empty string if none */ +/* Returns the given tag's character content or empty string if none */ #ifdef ezxml_txt #undef ezxml_txt static char * @@ -159,14 +159,16 @@ SDnewMatrix(int ni, int no) /* get vector for this angle basis index (front exiting) */ static int -fo_getvec(FVECT v, int ndx, double randX, void *p) +fo_getvec(FVECT v, double ndxr, void *p) { - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + int ndx = (int)ndxr; + double randX = ndxr - ndx; double rx[2]; int li; double pol, azi, d; - if ((ndx < 0) | (ndx >= ab->nangles)) + if ((ndxr < 0) | (ndx >= ab->nangles)) return RC_FAIL; for (li = 0; ndx >= ab->lat[li].nphis; li++) ndx -= ab->lat[li].nphis; @@ -185,13 +187,13 @@ fo_getvec(FVECT v, int ndx, double randX, void *p) static int fo_getndx(const FVECT v, void *p) { - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + ANGLE_BASIS *ab = (ANGLE_BASIS *)p; int li, ndx; double pol, azi, d; if (v == NULL) return -1; - if ((v[2] < .0) | (v[2] > 1.0)) + if ((v[2] < 0) | (v[2] > 1.)) return -1; pol = 180.0/M_PI*acos(v[2]); azi = 180.0/M_PI*atan2(v[1], v[0]); @@ -237,9 +239,9 @@ io_getohm(int ndx, void *p) /* get vector for this angle basis index (back incident) */ static int -bi_getvec(FVECT v, int ndx, double randX, void *p) +bi_getvec(FVECT v, double ndxr, void *p) { - if (!fo_getvec(v, ndx, randX, p)) + if (!fo_getvec(v, ndxr, p)) return RC_FAIL; v[0] = -v[0]; @@ -264,9 +266,9 @@ bi_getndx(const FVECT v, void *p) /* get vector for this angle basis index (back exiting) */ static int -bo_getvec(FVECT v, int ndx, double randX, void *p) +bo_getvec(FVECT v, double ndxr, void *p) { - if (!fo_getvec(v, ndx, randX, p)) + if (!fo_getvec(v, ndxr, p)) return RC_FAIL; v[2] = -v[2]; @@ -289,9 +291,9 @@ bo_getndx(const FVECT v, void *p) /* get vector for this angle basis index (front incident) */ static int -fi_getvec(FVECT v, int ndx, double randX, void *p) +fi_getvec(FVECT v, double ndxr, void *p) { - if (!fo_getvec(v, ndx, randX, p)) + if (!fo_getvec(v, ndxr, p)) return RC_FAIL; v[0] = -v[0]; @@ -350,7 +352,7 @@ load_angle_basis(ezxml_t wab) "ThetaBounds"), "LowerTheta"))), abase_list[nabases].lat[i].tmin)) { sprintf(SDerrorDetail, "Theta values disagree in '%s'", - abname); + abname); return RC_DATERR; } abase_list[nabases].nangles += @@ -360,7 +362,7 @@ load_angle_basis(ezxml_t wab) (abase_list[nabases].lat[i].nphis == 1 && abase_list[nabases].lat[i].tmin > FTINY)) { sprintf(SDerrorDetail, "Illegal phi count in '%s'", - abname); + abname); return RC_DATERR; } } @@ -416,12 +418,15 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) int i; /* allocate BSDF component */ sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection")); + if (!sdata) + return RC_FAIL; /* * Remember that front and back are reversed from WINDOW 6 orientations + * Favor their "Front" (incoming light) since that's more often valid */ - if ((tfront = !strcasecmp(sdata, "Transmission Back")) || - (sd->tf == NULL && - !strcasecmp(sdata, "Transmission Front"))) { + tfront = !strcasecmp(sdata, "Transmission Back"); + if (!strcasecmp(sdata, "Transmission Front") || + tfront & (sd->tf == NULL)) { if (sd->tf != NULL) SDfreeSpectralDF(sd->tf); if ((sd->tf = SDnewSpectralDF(1)) == NULL) @@ -504,7 +509,7 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) df->comp[0].dist = dp; df->comp[0].func = &SDhandleMtx; /* read BSDF data */ - sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData")); + sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData")); if (!sdata || !*sdata) { sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'", sd->name); @@ -518,7 +523,7 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) sd->name); return RC_FORMERR; } - while (*sdnext && isspace(*sdnext)) + while (isspace(*sdnext)) sdnext++; if (*sdnext == ',') sdnext++; if (rowinc) { @@ -543,6 +548,10 @@ subtract_min(SDMat *sm) for (i = n; --i; ) if (sm->bsdf[i] < minv) minv = sm->bsdf[i]; + + if (minv <= FTINY) + return .0; + for (i = n; i--; ) sm->bsdf[i] -= minv; @@ -568,7 +577,7 @@ extract_diffuse(SDValue *dv, SDSpectralDF *df) c_cmix(&dv->spec, dv->cieY, &dv->spec, ymin, &df->comp[n].cspec[0]); dv->cieY += ymin; } - df->maxHemi -= dv->cieY; /* adjust minimum hemispherical */ + df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */ /* make sure everything is set */ c_ccvt(&dv->spec, C_CSXY+C_CSSPEC); } @@ -577,12 +586,11 @@ extract_diffuse(SDValue *dv, SDSpectralDF *df) SDError SDloadMtx(SDData *sd, ezxml_t wtl) { - ezxml_t wld, wdb; - int rowIn; - struct BSDF_data *dp; - char *txt; - int rval; - + ezxml_t wld, wdb; + int rowIn; + char *txt; + int rval; + /* basic checks and data ordering */ txt = ezxml_txt(ezxml_child(ezxml_child(wtl, "DataDefinition"), "IncidentDataStructure")); if (txt == NULL || !*txt) { @@ -601,12 +609,12 @@ SDloadMtx(SDData *sd, ezxml_t wtl) sd->name); return SDEsupport; } - /* get angle basis */ + /* get angle basis */ rval = load_angle_basis(ezxml_child(ezxml_child(wtl, "DataDefinition"), "AngleBasis")); if (rval < 0) return convert_errcode(rval); - /* load BSDF components */ + /* load BSDF components */ for (wld = ezxml_child(wtl, "WavelengthData"); wld != NULL; wld = wld->next) { if (strcasecmp(ezxml_txt(ezxml_child(wld,"Wavelength")), @@ -617,21 +625,25 @@ SDloadMtx(SDData *sd, ezxml_t wtl) if ((rval = load_bsdf_data(sd, wdb, rowIn)) < 0) return convert_errcode(rval); } - /* separate diffuse components */ + /* separate diffuse components */ extract_diffuse(&sd->rLambFront, sd->rf); extract_diffuse(&sd->rLambBack, sd->rb); extract_diffuse(&sd->tLamb, sd->tf); - /* return success */ + /* return success */ return SDEnone; } /* Get Matrix BSDF value */ static int SDgetMtxBSDF(float coef[SDmaxCh], const FVECT outVec, - const FVECT inVec, const void *dist) + const FVECT inVec, SDComponent *sdc) { - const SDMat *dp = (const SDMat *)dist; + const SDMat *dp; int i_ndx, o_ndx; + /* check arguments */ + if ((coef == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL) + || (dp = (SDMat *)sdc->dist) == NULL) + return 0; /* get angle indices */ i_ndx = mBSDF_incndx(dp, inVec); o_ndx = mBSDF_outndx(dp, outVec); @@ -646,23 +658,28 @@ SDgetMtxBSDF(float coef[SDmaxCh], const FVECT outVec, return 1; /* XXX monochrome for now */ } -/* Query solid angle for vector */ +/* Query solid angle for vector(s) */ static SDError -SDqueryMtxProjSA(double *psa, const FVECT vec, int qflags, const void *dist) +SDqueryMtxProjSA(double *psa, const FVECT v1, const RREAL *v2, + int qflags, SDComponent *sdc) { - const SDMat *dp = (const SDMat *)dist; + const SDMat *dp; double inc_psa, out_psa; /* check arguments */ - if ((psa == NULL) | (vec == NULL) | (dp == NULL)) + if ((psa == NULL) | (v1 == NULL) | (sdc == NULL) || + (dp = (SDMat *)sdc->dist) == NULL) return SDEargument; + if (v2 == NULL) + v2 = v1; /* get projected solid angles */ - inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, vec)); - out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, vec)); + out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v1)); + inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v2)); + if ((v1 != v2) & (out_psa <= 0) & (inc_psa <= 0)) { + inc_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v2)); + out_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v1)); + } switch (qflags) { /* record based on flag settings */ - case SDqueryVal: - psa[0] = .0; - /* fall through */ case SDqueryMax: if (inc_psa > psa[0]) psa[0] = inc_psa; @@ -670,20 +687,24 @@ SDqueryMtxProjSA(double *psa, const FVECT vec, int qfl psa[0] = out_psa; break; case SDqueryMin+SDqueryMax: - if (inc_psa > psa[0]) + if (inc_psa > psa[1]) psa[1] = inc_psa; - if (out_psa > psa[0]) + if (out_psa > psa[1]) psa[1] = out_psa; /* fall through */ + case SDqueryVal: + if (qflags == SDqueryVal) + psa[0] = M_PI; + /* fall through */ case SDqueryMin: - if ((inc_psa > .0) & (inc_psa < psa[0])) + if ((inc_psa > 0) & (inc_psa < psa[0])) psa[0] = inc_psa; - if ((out_psa > .0) & (out_psa < psa[0])) + if ((out_psa > 0) & (out_psa < psa[0])) psa[0] = out_psa; break; } /* make sure it's legal */ - return (psa[0] <= .0) ? SDEinternal : SDEnone; + return (psa[0] <= 0) ? SDEinternal : SDEnone; } /* Compute new cumulative distribution from BSDF */ @@ -721,12 +742,13 @@ make_cdist(SDMatCDst *cd, const FVECT inVec, SDMat *dp static const SDCDst * SDgetMtxCDist(const FVECT inVec, SDComponent *sdc) { - SDMat *dp = (SDMat *)sdc->dist; + SDMat *dp; int reverse; SDMatCDst myCD; SDMatCDst *cd, *cdlast; /* check arguments */ - if ((inVec == NULL) | (dp == NULL)) + if ((inVec == NULL) | (sdc == NULL) || + (dp = (SDMat *)sdc->dist) == NULL) return NULL; memset(&myCD, 0, sizeof(myCD)); myCD.indx = mBSDF_incndx(dp, inVec); @@ -745,17 +767,15 @@ SDgetMtxCDist(const FVECT inVec, SDComponent *sdc) reverse = 1; } cdlast = NULL; /* check for it in cache list */ - for (cd = (SDMatCDst *)sdc->cdList; - cd != NULL; cd = (SDMatCDst *)cd->next) { + for (cd = (SDMatCDst *)sdc->cdList; cd != NULL; + cdlast = cd, cd = (SDMatCDst *)cd->next) if (cd->indx == myCD.indx && (cd->calen == myCD.calen) & (cd->ob_priv == myCD.ob_priv) & (cd->ob_vec == myCD.ob_vec)) break; - cdlast = cd; - } if (cd == NULL) { /* need to allocate new entry */ cd = (SDMatCDst *)malloc(sizeof(SDMatCDst) + - myCD.calen*sizeof(myCD.carr[0])); + sizeof(myCD.carr[0])*myCD.calen); if (cd == NULL) return NULL; *cd = myCD; /* compute cumulative distribution */ @@ -775,14 +795,14 @@ SDgetMtxCDist(const FVECT inVec, SDComponent *sdc) /* Sample cumulative distribution */ static SDError -SDsampMtxCDist(FVECT outVec, double randX, const SDCDst *cdp) +SDsampMtxCDist(FVECT ioVec, double randX, const SDCDst *cdp) { const unsigned maxval = ~0; const SDMatCDst *mcd = (const SDMatCDst *)cdp; const unsigned target = randX*maxval; int i, iupper, ilower; /* check arguments */ - if ((outVec == NULL) | (mcd == NULL)) + if ((ioVec == NULL) | (mcd == NULL)) return SDEargument; /* binary search to find index */ ilower = 0; iupper = mcd->calen; @@ -795,9 +815,9 @@ SDsampMtxCDist(FVECT outVec, double randX, const SDCDs randX = (randX*maxval - mcd->carr[ilower]) / (double)(mcd->carr[iupper] - mcd->carr[ilower]); /* convert index to vector */ - if ((*mcd->ob_vec)(outVec, i, randX, mcd->ob_priv)) + if ((*mcd->ob_vec)(ioVec, i+randX, mcd->ob_priv)) return SDEnone; - strcpy(SDerrorDetail, "BSDF sampling fault"); + strcpy(SDerrorDetail, "Matrix BSDF sampling fault"); return SDEinternal; }
