--- ray/src/common/bsdf_m.c 2011/02/19 23:42:09 3.5 +++ ray/src/common/bsdf_m.c 2011/04/20 14:44:05 3.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: bsdf_m.c,v 3.5 2011/02/19 23:42:09 greg Exp $"; +static const char RCSid[] = "$Id: bsdf_m.c,v 3.11 2011/04/20 14:44:05 greg Exp $"; #endif /* * bsdf_m.c @@ -81,12 +81,12 @@ static int nabases = 3; /* current number of defined b static int fequal(double a, double b) { - if (b != .0) + if (b != 0) a = a/b - 1.; return (a <= 1e-6) & (a >= -1e-6); } -/* returns the name of the given tag */ +/* Returns the name of the given tag */ #ifdef ezxml_name #undef ezxml_name static char * @@ -98,7 +98,7 @@ ezxml_name(ezxml_t xml) } #endif -/* returns the given tag's character content or empty string if none */ +/* Returns the given tag's character content or empty string if none */ #ifdef ezxml_txt #undef ezxml_txt static char * @@ -157,16 +157,18 @@ SDnewMatrix(int ni, int no) /* Free a BSDF matrix */ #define SDfreeMatrix free -/* get vector for this angle basis index */ +/* get vector for this angle basis index (front exiting) */ static int -ab_getvec(FVECT v, int ndx, double randX, void *p) +fo_getvec(FVECT v, double ndxr, void *p) { - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + int ndx = (int)ndxr; + double randX = ndxr - ndx; double rx[2]; int li; double pol, azi, d; - if ((ndx < 0) | (ndx >= ab->nangles)) + if ((ndxr < 0) | (ndx >= ab->nangles)) return RC_FAIL; for (li = 0; ndx >= ab->lat[li].nphis; li++) ndx -= ab->lat[li].nphis; @@ -181,17 +183,17 @@ ab_getvec(FVECT v, int ndx, double randX, void *p) return RC_GOOD; } -/* get index corresponding to the given vector */ +/* get index corresponding to the given vector (front exiting) */ static int -ab_getndx(const FVECT v, void *p) +fo_getndx(const FVECT v, void *p) { - ANGLE_BASIS *ab = (ANGLE_BASIS *)p; + ANGLE_BASIS *ab = (ANGLE_BASIS *)p; int li, ndx; double pol, azi, d; if (v == NULL) return -1; - if ((v[2] < .0) | (v[2] > 1.0)) + if ((v[2] < 0) | (v[2] > 1.)) return -1; pol = 180.0/M_PI*acos(v[2]); azi = 180.0/M_PI*atan2(v[1], v[0]); @@ -210,9 +212,9 @@ ab_getndx(const FVECT v, void *p) /* compute square of real value */ static double sq(double x) { return x*x; } -/* get projected solid angle for this angle basis index */ +/* get projected solid angle for this angle basis index (universal) */ static double -ab_getohm(int ndx, void *p) +io_getohm(int ndx, void *p) { static int last_li = -1; static double last_ohm; @@ -235,13 +237,11 @@ ab_getohm(int ndx, void *p) (double)ab->lat[li].nphis; } -/* get reverse vector for this angle basis index */ +/* get vector for this angle basis index (back incident) */ static int -ab_getvecR(FVECT v, int ndx, double randX, void *p) +bi_getvec(FVECT v, double ndxr, void *p) { - int na = (*(ANGLE_BASIS *)p).nangles; - - if (!ab_getvec(v, ndx, randX, p)) + if (!fo_getvec(v, ndxr, p)) return RC_FAIL; v[0] = -v[0]; @@ -251,9 +251,9 @@ ab_getvecR(FVECT v, int ndx, double randX, void *p) return RC_GOOD; } -/* get index corresponding to the reverse vector */ +/* get index corresponding to the vector (back incident) */ static int -ab_getndxR(const FVECT v, void *p) +bi_getndx(const FVECT v, void *p) { FVECT v2; @@ -261,9 +261,60 @@ ab_getndxR(const FVECT v, void *p) v2[1] = -v[1]; v2[2] = -v[2]; - return ab_getndx(v2, p); + return fo_getndx(v2, p); } +/* get vector for this angle basis index (back exiting) */ +static int +bo_getvec(FVECT v, double ndxr, void *p) +{ + if (!fo_getvec(v, ndxr, p)) + return RC_FAIL; + + v[2] = -v[2]; + + return RC_GOOD; +} + +/* get index corresponding to the vector (back exiting) */ +static int +bo_getndx(const FVECT v, void *p) +{ + FVECT v2; + + v2[0] = v[0]; + v2[1] = v[1]; + v2[2] = -v[2]; + + return fo_getndx(v2, p); +} + +/* get vector for this angle basis index (front incident) */ +static int +fi_getvec(FVECT v, double ndxr, void *p) +{ + if (!fo_getvec(v, ndxr, p)) + return RC_FAIL; + + v[0] = -v[0]; + v[1] = -v[1]; + + return RC_GOOD; +} + +/* get index corresponding to the vector (front incident) */ +static int +fi_getndx(const FVECT v, void *p) +{ + FVECT v2; + + v2[0] = -v[0]; + v2[1] = -v[1]; + v2[2] = v[2]; + + return fo_getndx(v2, p); +} + /* load custom BSDF angle basis */ static int load_angle_basis(ezxml_t wab) @@ -362,28 +413,35 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) SDSpectralDF *df; SDMat *dp; char *sdata; + int tfront; int inbi, outbi; int i; /* allocate BSDF component */ sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection")); - if (!strcasecmp(sdata, "Transmission Front")) { + /* + * Remember that front and back are reversed from WINDOW 6 orientations + * Favor their "Front" (incoming light) since that's more often valid + */ + tfront = !strcasecmp(sdata, "Transmission Back"); + if (!strcasecmp(sdata, "Transmission Front") || + tfront & (sd->tf == NULL)) { if (sd->tf != NULL) SDfreeSpectralDF(sd->tf); if ((sd->tf = SDnewSpectralDF(1)) == NULL) return RC_MEMERR; df = sd->tf; } else if (!strcasecmp(sdata, "Reflection Front")) { - if (sd->rf != NULL) - SDfreeSpectralDF(sd->rf); - if ((sd->rf = SDnewSpectralDF(1)) == NULL) - return RC_MEMERR; - df = sd->rf; - } else if (!strcasecmp(sdata, "Reflection Back")) { - if (sd->rb != NULL) + if (sd->rb != NULL) /* note back-front reversal */ SDfreeSpectralDF(sd->rb); if ((sd->rb = SDnewSpectralDF(1)) == NULL) return RC_MEMERR; df = sd->rb; + } else if (!strcasecmp(sdata, "Reflection Back")) { + if (sd->rf != NULL) /* note front-back reversal */ + SDfreeSpectralDF(sd->rf); + if ((sd->rf = SDnewSpectralDF(1)) == NULL) + return RC_MEMERR; + df = sd->rf; } else return RC_FAIL; /* XXX should also check "ScatteringDataType" for consistency? */ @@ -421,28 +479,35 @@ load_bsdf_data(SDData *sd, ezxml_t wdb, int rowinc) dp->ib_priv = &abase_list[inbi]; dp->ob_priv = &abase_list[outbi]; if (df == sd->tf) { - dp->ib_vec = &ab_getvecR; - dp->ib_ndx = &ab_getndxR; - dp->ob_vec = &ab_getvec; - dp->ob_ndx = &ab_getndx; + if (tfront) { + dp->ib_vec = &fi_getvec; + dp->ib_ndx = &fi_getndx; + dp->ob_vec = &bo_getvec; + dp->ob_ndx = &bo_getndx; + } else { + dp->ib_vec = &bi_getvec; + dp->ib_ndx = &bi_getndx; + dp->ob_vec = &fo_getvec; + dp->ob_ndx = &fo_getndx; + } } else if (df == sd->rf) { - dp->ib_vec = &ab_getvec; - dp->ib_ndx = &ab_getndx; - dp->ob_vec = &ab_getvec; - dp->ob_ndx = &ab_getndx; + dp->ib_vec = &fi_getvec; + dp->ib_ndx = &fi_getndx; + dp->ob_vec = &fo_getvec; + dp->ob_ndx = &fo_getndx; } else /* df == sd->rb */ { - dp->ib_vec = &ab_getvecR; - dp->ib_ndx = &ab_getndxR; - dp->ob_vec = &ab_getvecR; - dp->ob_ndx = &ab_getndxR; + dp->ib_vec = &bi_getvec; + dp->ib_ndx = &bi_getndx; + dp->ob_vec = &bo_getvec; + dp->ob_ndx = &bo_getndx; } - dp->ib_ohm = &ab_getohm; - dp->ob_ohm = &ab_getohm; + dp->ib_ohm = &io_getohm; + dp->ob_ohm = &io_getohm; df->comp[0].cspec[0] = c_dfcolor; /* XXX monochrome for now */ df->comp[0].dist = dp; df->comp[0].func = &SDhandleMtx; /* read BSDF data */ - sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData")); + sdata = ezxml_txt(ezxml_child(wdb,"ScatteringData")); if (!sdata || !*sdata) { sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'", sd->name); @@ -586,16 +651,23 @@ SDgetMtxBSDF(float coef[SDmaxCh], const FVECT outVec, /* Query solid angle for vector */ static SDError -SDqueryMtxProjSA(double *psa, const FVECT vec, int qflags, const void *dist) +SDqueryMtxProjSA(double *psa, const FVECT v1, const RREAL *v2, + int qflags, const void *dist) { const SDMat *dp = (const SDMat *)dist; double inc_psa, out_psa; /* check arguments */ - if ((psa == NULL) | (vec == NULL) | (dp == NULL)) + if ((psa == NULL) | (v1 == NULL) | (dp == NULL)) return SDEargument; + if (v2 == NULL) + v2 = v1; /* get projected solid angles */ - inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, vec)); - out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, vec)); + out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v1)); + inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v2)); + if ((out_psa <= 0) & (inc_psa <= 0)) { + inc_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v2)); + out_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v1)); + } switch (qflags) { /* record based on flag settings */ case SDqueryVal: @@ -614,14 +686,14 @@ SDqueryMtxProjSA(double *psa, const FVECT vec, int qfl psa[1] = out_psa; /* fall through */ case SDqueryMin: - if ((inc_psa > .0) & (inc_psa < psa[0])) + if ((inc_psa > 0) & (inc_psa < psa[0])) psa[0] = inc_psa; - if ((out_psa > .0) & (out_psa < psa[0])) + if ((out_psa > 0) & (out_psa < psa[0])) psa[0] = out_psa; break; } /* make sure it's legal */ - return (psa[0] <= .0) ? SDEinternal : SDEnone; + return (psa[0] <= 0) ? SDEinternal : SDEnone; } /* Compute new cumulative distribution from BSDF */ @@ -733,7 +805,7 @@ SDsampMtxCDist(FVECT outVec, double randX, const SDCDs randX = (randX*maxval - mcd->carr[ilower]) / (double)(mcd->carr[iupper] - mcd->carr[ilower]); /* convert index to vector */ - if ((*mcd->ob_vec)(outVec, i, randX, mcd->ob_priv)) + if ((*mcd->ob_vec)(outVec, i+randX, mcd->ob_priv)) return SDEnone; strcpy(SDerrorDetail, "BSDF sampling fault"); return SDEinternal;
