Minor improvements to direct specular sampling
Removed unnecessary restriction on reciprocity
Fixed bug for MING32 and non-square matrices, allowing multiple angle bases
Minor compile fixes
Fixes for Windows and bug fix in bsdf_m.c
Initial untested variable-resolution BSDF
Fix from last change
Bug fixes to last change
Partial implementation of variable-resolution BSDFs
Fixes to last change -- tested
Fixed interface for determining BSDF solid angles
Fixed issue with coordinate orientation for front transmission
Corrected notion of "front" and "back" to coincide with surface normals
Fixes to BSDF including blurring of angle boundaries
Minor changes and fixes -- first working version of BSDF material
Minor fixes and adjustments
Added missing RCS tags
