root/radiance/ray/src/common/bsdf_m.c
Revision: 3.37
Committed: Fri Jan 5 21:00:24 2018 UTC (7 years, 6 months ago) by greg
Fix for C++ compilers, which don't like "typedef const struct"
2 static const char RCSid[] = "$Id: bsdf_m.c,v 3.36 2016/10/14 00:54:21 greg Exp $";
5 * bsdf_m.c
6 *
7 * Definitions supporting BSDF matrices
8 *
9 * Created by Greg Ward on 2/2/11.
10 * Copyright 2011 Anyhere Software. All rights reserved.
11 *
12 */
13
14 #define _USE_MATH_DEFINES
15 #include "rtio.h"
16 #include <math.h>
17 #include <ctype.h>
18 #include "ezxml.h"
19 #include "bsdf.h"
20 #include "bsdf_m.h"
21
22 /* Function return codes */
23 #define RC_GOOD 1
24 #define RC_FAIL 0
25 #define RC_FORMERR (-1)
26 #define RC_DATERR (-2)
27 #define RC_UNSUPP (-3)
28 #define RC_INTERR (-4)
29 #define RC_MEMERR (-5)
30
31 ANGLE_BASIS abase_list[MAXABASES] = {
32 {
33 "LBNL/Klems Full", 145,
34 { {0., 1},
35 {5., 8},
36 {15., 16},
37 {25., 20},
38 {35., 24},
39 {45., 24},
40 {55., 24},
41 {65., 16},
42 {75., 12},
43 {90., 0} }
44 }, {
45 "LBNL/Klems Half", 73,
46 { {0., 1},
47 {6.5, 8},
48 {19.5, 12},
49 {32.5, 16},
50 {46.5, 20},
51 {61.5, 12},
52 {76.5, 4},
53 {90., 0} }
54 }, {
55 "LBNL/Klems Quarter", 41,
56 { {0., 1},
57 {9., 8},
58 {27., 12},
59 {46., 12},
60 {66., 8},
61 {90., 0} }
62 }
63 };
64
65 int nabases = 3; /* current number of defined bases */
66
67 C_COLOR mtx_RGB_prim[3]; /* our RGB primaries */
68 float mtx_RGB_coef[3]; /* corresponding Y coefficients */
69
70 enum {mtx_Y, mtx_X, mtx_Z}; /* matrix components (mtx_Y==0) */
71
72 /* check if two real values are near enough to equal */
73 static int
74 fequal(double a, double b)
75 {
76 if (b != 0)
77 a = a/b - 1.;
78 return (a <= 1e-6) & (a >= -1e-6);
79 }
80
81 /* convert error to standard BSDF code */
82 static SDError
83 convert_errcode(int ec)
84 {
85 switch (ec) {
86 case RC_GOOD:
87 return SDEnone;
88 case RC_FORMERR:
89 return SDEformat;
90 case RC_DATERR:
91 return SDEdata;
92 case RC_UNSUPP:
93 return SDEsupport;
94 case RC_INTERR:
95 return SDEinternal;
96 case RC_MEMERR:
97 return SDEmemory;
98 }
99 return SDEunknown;
100 }
101
102 /* allocate a BSDF matrix of the given size */
103 static SDMat *
104 SDnewMatrix(int ni, int no)
105 {
106 SDMat *sm;
107
108 if ((ni <= 0) | (no <= 0)) {
109 strcpy(SDerrorDetail, "Empty BSDF matrix request");
110 return NULL;
111 }
112 sm = (SDMat *)malloc(sizeof(SDMat) + (ni*no - 1)*sizeof(float));
113 if (sm == NULL) {
114 sprintf(SDerrorDetail, "Cannot allocate %dx%d BSDF matrix",
115 ni, no);
116 return NULL;
117 }
118 memset(sm, 0, sizeof(SDMat)-sizeof(float));
119 sm->ninc = ni;
120 sm->nout = no;
121
122 return sm;
123 }
124
125 /* Free a BSDF matrix */
126 void
127 SDfreeMatrix(void *ptr)
128 {
129 SDMat *mp = (SDMat *)ptr;
130
131 if (mp->chroma != NULL) free(mp->chroma);
132 free(ptr);
133 }
134
135 /* compute square of real value */
136 static double sq(double x) { return x*x; }
137
138 /* Get vector for this angle basis index (front exiting) */
139 int
140 fo_getvec(FVECT v, double ndxr, void *p)
141 {
142 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
143 int ndx = (int)ndxr;
144 double randX = ndxr - ndx;
145 double rx[2];
146 int li;
147 double azi, d;
148
149 if ((ndxr < 0) | (ndx >= ab->nangles))
150 return RC_FAIL;
151 for (li = 0; ndx >= ab->lat[li].nphis; li++)
152 ndx -= ab->lat[li].nphis;
153 SDmultiSamp(rx, 2, randX);
154 d = (1. - rx[0])*sq(cos(M_PI/180.*ab->lat[li].tmin)) +
155 rx[0]*sq(cos(M_PI/180.*ab->lat[li+1].tmin));
156 v[2] = d = sqrt(d); /* cos(pol) */
157 azi = 2.*M_PI*(ndx + rx[1] - .5)/ab->lat[li].nphis;
158 d = sqrt(1. - d*d); /* sin(pol) */
159 v[0] = cos(azi)*d;
160 v[1] = sin(azi)*d;
161 return RC_GOOD;
162 }
163
164 /* Get index corresponding to the given vector (front exiting) */
165 int
166 fo_getndx(const FVECT v, void *p)
167 {
168 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
169 int li, ndx;
170 double pol, azi;
171
172 if (v == NULL)
173 return -1;
174 if ((v[2] < 0) | (v[2] > 1.))
175 return -1;
176 pol = 180.0/M_PI*Acos(v[2]);
177 azi = 180.0/M_PI*atan2(v[1], v[0]);
178 if (azi < 0.0) azi += 360.0;
179 for (li = 1; ab->lat[li].tmin <= pol; li++)
180 if (!ab->lat[li].nphis)
181 return -1;
182 --li;
183 ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5);
184 if (ndx >= ab->lat[li].nphis) ndx = 0;
185 while (li--)
186 ndx += ab->lat[li].nphis;
187 return ndx;
188 }
189
190 /* Get projected solid angle for this angle basis index (universal) */
191 double
192 io_getohm(int ndx, void *p)
193 {
194 static void *last_p = NULL;
195 static int last_li = -1;
196 static double last_ohm;
197 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
198 int li;
199 double theta, theta1;
200
201 if ((ndx < 0) | (ndx >= ab->nangles))
202 return -1.;
203 for (li = 0; ndx >= ab->lat[li].nphis; li++)
204 ndx -= ab->lat[li].nphis;
205 if ((p == last_p) & (li == last_li)) /* cached latitude? */
206 return last_ohm;
207 last_p = p;
208 last_li = li;
209 theta = M_PI/180. * ab->lat[li].tmin;
210 theta1 = M_PI/180. * ab->lat[li+1].tmin;
211 return last_ohm = M_PI*(sq(cos(theta)) - sq(cos(theta1))) /
212 (double)ab->lat[li].nphis;
213 }
214
215 /* Get vector for this angle basis index (back incident) */
216 int
217 bi_getvec(FVECT v, double ndxr, void *p)
218 {
219 if (!fo_getvec(v, ndxr, p))
220 return RC_FAIL;
221
222 v[0] = -v[0];
223 v[1] = -v[1];
224 v[2] = -v[2];
225
226 return RC_GOOD;
227 }
228
229 /* Get index corresponding to the vector (back incident) */
230 int
231 bi_getndx(const FVECT v, void *p)
232 {
233 FVECT v2;
234
235 v2[0] = -v[0];
236 v2[1] = -v[1];
237 v2[2] = -v[2];
238
239 return fo_getndx(v2, p);
240 }
241
242 /* Get vector for this angle basis index (back exiting) */
243 int
244 bo_getvec(FVECT v, double ndxr, void *p)
245 {
246 if (!fo_getvec(v, ndxr, p))
247 return RC_FAIL;
248
249 v[2] = -v[2];
250
251 return RC_GOOD;
252 }
253
254 /* Get index corresponding to the vector (back exiting) */
255 int
256 bo_getndx(const FVECT v, void *p)
257 {
258 FVECT v2;
259
260 v2[0] = v[0];
261 v2[1] = v[1];
262 v2[2] = -v[2];
263
264 return fo_getndx(v2, p);
265 }
266
267 /* Get vector for this angle basis index (front incident) */
268 int
269 fi_getvec(FVECT v, double ndxr, void *p)
270 {
271 if (!fo_getvec(v, ndxr, p))
272 return RC_FAIL;
273
274 v[0] = -v[0];
275 v[1] = -v[1];
276
277 return RC_GOOD;
278 }
279
280 /* Get index corresponding to the vector (front incident) */
281 int
282 fi_getndx(const FVECT v, void *p)
283 {
284 FVECT v2;
285
286 v2[0] = -v[0];
287 v2[1] = -v[1];
288 v2[2] = v[2];
289
290 return fo_getndx(v2, p);
291 }
292
293 /* Get color or grayscale value for BSDF for the given direction pair */
294 int
295 mBSDF_color(float coef[], const SDMat *dp, int i, int o)
296 {
297 C_COLOR cxy;
298
299 coef[0] = mBSDF_value(dp, i, o);
300 if (dp->chroma == NULL)
301 return 1; /* grayscale */
302
303 c_decodeChroma(&cxy, mBSDF_chroma(dp,i,o));
304 c_toSharpRGB(&cxy, coef[0], coef);
305 coef[0] *= mtx_RGB_coef[0];
306 coef[1] *= mtx_RGB_coef[1];
307 coef[2] *= mtx_RGB_coef[2];
308 return 3; /* RGB color */
309 }
310
311 /* load custom BSDF angle basis */
312 static int
313 load_angle_basis(ezxml_t wab)
314 {
315 char *abname = ezxml_txt(ezxml_child(wab, "AngleBasisName"));
316 ezxml_t wbb;
317 int i;
318
319 if (!abname || !*abname)
320 return RC_FAIL;
321 for (i = nabases; i--; )
322 if (!strcasecmp(abname, abase_list[i].name))
323 return RC_GOOD; /* assume it's the same */
324 if (nabases >= MAXABASES) {
325 sprintf(SDerrorDetail, "Out of angle bases reading '%s'",
326 abname);
327 return RC_INTERR;
328 }
329 strcpy(abase_list[nabases].name, abname);
330 abase_list[nabases].nangles = 0;
331 for (i = 0, wbb = ezxml_child(wab, "AngleBasisBlock");
332 wbb != NULL; i++, wbb = wbb->next) {
333 if (i >= MAXLATS) {
334 sprintf(SDerrorDetail, "Too many latitudes for '%s'",
335 abname);
336 return RC_INTERR;
337 }
338 abase_list[nabases].lat[i+1].tmin = atof(ezxml_txt(
339 ezxml_child(ezxml_child(wbb,
340 "ThetaBounds"), "UpperTheta")));
341 if (!i)
342 abase_list[nabases].lat[0].tmin = 0;
343 else if (!fequal(atof(ezxml_txt(ezxml_child(ezxml_child(wbb,
344 "ThetaBounds"), "LowerTheta"))),
345 abase_list[nabases].lat[i].tmin)) {
346 sprintf(SDerrorDetail, "Theta values disagree in '%s'",
347 abname);
348 return RC_DATERR;
349 }
350 abase_list[nabases].nangles +=
351 abase_list[nabases].lat[i].nphis =
352 atoi(ezxml_txt(ezxml_child(wbb, "nPhis")));
353 if (abase_list[nabases].lat[i].nphis <= 0 ||
354 (abase_list[nabases].lat[i].nphis == 1 &&
355 abase_list[nabases].lat[i].tmin > FTINY)) {
356 sprintf(SDerrorDetail, "Illegal phi count in '%s'",
357 abname);
358 return RC_DATERR;
359 }
360 }
361 abase_list[nabases++].lat[i].nphis = 0;
362 return RC_GOOD;
363 }
364
365 /* compute min. proj. solid angle and max. direct hemispherical scattering */
366 static int
367 get_extrema(SDSpectralDF *df)
368 {
369 SDMat *dp = (SDMat *)df->comp[0].dist;
370 double *ohma;
371 int i, o;
372 /* initialize extrema */
373 df->minProjSA = M_PI;
374 df->maxHemi = .0;
375 ohma = (double *)malloc(dp->nout*sizeof(double));
376 if (ohma == NULL)
377 return RC_MEMERR;
378 /* get outgoing solid angles */
379 for (o = dp->nout; o--; )
380 if ((ohma[o] = mBSDF_outohm(dp,o)) < df->minProjSA)
381 df->minProjSA = ohma[o];
382 /* compute hemispherical sums */
383 for (i = dp->ninc; i--; ) {
384 double hemi = .0;
385 for (o = dp->nout; o--; )
386 hemi += ohma[o] * mBSDF_value(dp, i, o);
387 if (hemi > df->maxHemi)
388 df->maxHemi = hemi;
389 }
390 free(ohma);
391 /* need incoming solid angles, too? */
392 if ((dp->ib_ohm != dp->ob_ohm) | (dp->ib_priv != dp->ob_priv)) {
393 double ohm;
394 for (i = dp->ninc; i--; )
395 if ((ohm = mBSDF_incohm(dp,i)) < df->minProjSA)
396 df->minProjSA = ohm;
397 }
398 return (df->maxHemi <= 1.01);
399 }
400
401 /* load BSDF distribution for this wavelength */
402 static int
403 load_bsdf_data(SDData *sd, ezxml_t wdb, int ct, int rowinc)
404 {
405 SDSpectralDF *df;
406 SDMat *dp;
407 char *sdata;
408 int inbi, outbi;
409 int i;
410 /* allocate BSDF component */
411 sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection"));
412 if (!sdata)
413 return RC_FAIL;
414 /*
415 * Remember that front and back are reversed from WINDOW 6 orientations
416 */
417 if (!strcasecmp(sdata, "Transmission Front")) {
418 if (sd->tb == NULL && (sd->tb = SDnewSpectralDF(3)) == NULL)
419 return RC_MEMERR;
420 df = sd->tb;
421 } else if (!strcasecmp(sdata, "Transmission Back")) {
422 if (sd->tf == NULL && (sd->tf = SDnewSpectralDF(3)) == NULL)
423 return RC_MEMERR;
424 df = sd->tf;
425 } else if (!strcasecmp(sdata, "Reflection Front")) {
426 if (sd->rb == NULL && (sd->rb = SDnewSpectralDF(3)) == NULL)
427 return RC_MEMERR;
428 df = sd->rb;
429 } else if (!strcasecmp(sdata, "Reflection Back")) {
430 if (sd->rf == NULL && (sd->rf = SDnewSpectralDF(3)) == NULL)
431 return RC_MEMERR;
432 df = sd->rf;
433 } else
434 return RC_FAIL;
435 /* free previous matrix if any */
436 if (df->comp[ct].dist != NULL) {
437 SDfreeMatrix(df->comp[ct].dist);
438 df->comp[ct].dist = NULL;
439 }
440 /* get angle bases */
441 sdata = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis"));
442 if (!sdata || !*sdata) {
443 sprintf(SDerrorDetail, "Missing column basis for BSDF '%s'",
444 sd->name);
445 return RC_FORMERR;
446 }
447 for (inbi = nabases; inbi--; )
448 if (!strcasecmp(sdata, abase_list[inbi].name))
449 break;
450 if (inbi < 0) {
451 sprintf(SDerrorDetail, "Undefined ColumnAngleBasis '%s'", sdata);
452 return RC_FORMERR;
453 }
454 sdata = ezxml_txt(ezxml_child(wdb,"RowAngleBasis"));
455 if (!sdata || !*sdata) {
456 sprintf(SDerrorDetail, "Missing row basis for BSDF '%s'",
457 sd->name);
458 return RC_FORMERR;
459 }
460 for (outbi = nabases; outbi--; )
461 if (!strcasecmp(sdata, abase_list[outbi].name))
462 break;
463 if (outbi < 0) {
464 sprintf(SDerrorDetail, "Undefined RowAngleBasis '%s'", sdata);
465 return RC_FORMERR;
466 }
467 /* allocate BSDF matrix */
468 dp = SDnewMatrix(abase_list[inbi].nangles, abase_list[outbi].nangles);
469 if (dp == NULL)
470 return RC_MEMERR;
471 dp->ib_priv = &abase_list[inbi];
472 dp->ob_priv = &abase_list[outbi];
473 if (df == sd->tf) {
474 dp->ib_vec = &fi_getvec;
475 dp->ib_ndx = &fi_getndx;
476 dp->ob_vec = &bo_getvec;
477 dp->ob_ndx = &bo_getndx;
478 } else if (df == sd->tb) {
479 dp->ib_vec = &bi_getvec;
480 dp->ib_ndx = &bi_getndx;
481 dp->ob_vec = &fo_getvec;
482 dp->ob_ndx = &fo_getndx;
483 } else if (df == sd->rf) {
484 dp->ib_vec = &fi_getvec;
485 dp->ib_ndx = &fi_getndx;
486 dp->ob_vec = &fo_getvec;
487 dp->ob_ndx = &fo_getndx;
488 } else /* df == sd->rb */ {
489 dp->ib_vec = &bi_getvec;
490 dp->ib_ndx = &bi_getndx;
491 dp->ob_vec = &bo_getvec;
492 dp->ob_ndx = &bo_getndx;
493 }
494 dp->ib_ohm = &io_getohm;
495 dp->ob_ohm = &io_getohm;
496 df->comp[ct].dist = dp;
497 df->comp[ct].func = &SDhandleMtx;
498 /* read BSDF data */
499 sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData"));
500 if (!sdata || !*sdata) {
501 sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'",
502 sd->name);
503 return RC_FORMERR;
504 }
505 for (i = 0; i < dp->ninc*dp->nout; i++) {
506 char *sdnext = fskip(sdata);
507 double val;
508 if (sdnext == NULL) {
509 sprintf(SDerrorDetail,
510 "Bad/missing BSDF ScatteringData in '%s'",
511 sd->name);
512 return RC_FORMERR;
513 }
514 while (isspace(*sdnext))
515 sdnext++;
516 if (*sdnext == ',') sdnext++;
517 if ((val = atof(sdata)) < 0)
518 val = 0; /* don't allow negative values */
519 if (rowinc) {
520 int r = i/dp->nout;
521 int c = i - r*dp->nout;
522 mBSDF_value(dp,r,c) = val;
523 } else
524 dp->bsdf[i] = val;
525 sdata = sdnext;
526 }
527 return (ct == mtx_Y) ? get_extrema(df) : RC_GOOD;
528 }
529
530 /* copy our RGB (x,y) primary chromaticities */
531 static void
532 copy_RGB_prims(C_COLOR cspec[])
533 {
534 if (mtx_RGB_coef[1] < .001) { /* need to initialize */
535 int i = 3;
536 while (i--) {
537 float rgb[3];
538 rgb[0] = rgb[1] = rgb[2] = .0f;
539 rgb[i] = 1.f;
540 mtx_RGB_coef[i] = c_fromSharpRGB(rgb, &mtx_RGB_prim[i]);
541 }
542 }
543 memcpy(cspec, mtx_RGB_prim, sizeof(mtx_RGB_prim));
544 }
545
546 /* encode chromaticity if XYZ -- reduce to one channel in any case */
547 static SDSpectralDF *
548 encode_chroma(SDSpectralDF *df)
549 {
550 SDMat *mpx, *mpy, *mpz;
551 int n;
552
553 if (df == NULL || df->ncomp != 3)
554 return df;
555
556 mpy = (SDMat *)df->comp[mtx_Y].dist;
557 if (mpy == NULL) {
558 free(df);
559 return NULL;
560 }
561 mpx = (SDMat *)df->comp[mtx_X].dist;
562 mpz = (SDMat *)df->comp[mtx_Z].dist;
563 if (mpx == NULL || (mpx->ninc != mpy->ninc) | (mpx->nout != mpy->nout))
564 goto done;
565 if (mpz == NULL || (mpz->ninc != mpy->ninc) | (mpz->nout != mpy->nout))
566 goto done;
567 mpy->chroma = (C_CHROMA *)malloc(sizeof(C_CHROMA)*mpy->ninc*mpy->nout);
568 if (mpy->chroma == NULL)
569 goto done; /* XXX punt */
570 /* encode chroma values */
571 for (n = mpy->ninc*mpy->nout; n--; ) {
572 const double sum = mpx->bsdf[n] + mpy->bsdf[n] + mpz->bsdf[n];
573 C_COLOR cxy;
574 if (sum > .0)
575 c_cset(&cxy, mpx->bsdf[n]/sum, mpy->bsdf[n]/sum);
576 else
577 c_cset(&cxy, 1./3., 1./3.);
578 mpy->chroma[n] = c_encodeChroma(&cxy);
579 }
580 done: /* free X & Z channels */
581 if (mpx != NULL) SDfreeMatrix(mpx);
582 if (mpz != NULL) SDfreeMatrix(mpz);
583 if (mpy->chroma == NULL) /* grayscale after all? */
584 df->comp[0].cspec[0] = c_dfcolor;
585 else /* else copy RGB primaries */
586 copy_RGB_prims(df->comp[0].cspec);
587 df->ncomp = 1; /* return resized struct */
588 return (SDSpectralDF *)realloc(df, sizeof(SDSpectralDF));
589 }
590
591 /* subtract minimum (diffuse) scattering amount from BSDF */
592 static double
593 subtract_min(C_COLOR *cs, SDMat *sm)
594 {
595 const int ncomp = 1 + 2*(sm->chroma != NULL);
596 float min_coef[3], ymin, coef[3];
597 int i, o, c;
598
599 min_coef[0] = min_coef[1] = min_coef[2] = FHUGE;
600 for (i = 0; i < sm->ninc; i++)
601 for (o = 0; o < sm->nout; o++) {
602 c = mBSDF_color(coef, sm, i, o);
603 while (c--)
604 if (coef[c] < min_coef[c])
605 min_coef[c] = coef[c];
606 }
607 ymin = 0;
608 for (c = ncomp; c--; )
609 ymin += min_coef[c];
610 if (ymin <= .01/M_PI) /* not worth bothering about? */
611 return .0;
612 if (ncomp == 1) { /* subtract grayscale minimum */
613 for (i = sm->ninc*sm->nout; i--; )
614 sm->bsdf[i] -= ymin;
615 *cs = c_dfcolor;
616 return M_PI*ymin;
617 }
618 /* else subtract colored minimum */
619 for (i = 0; i < sm->ninc; i++)
620 for (o = 0; o < sm->nout; o++) {
621 C_COLOR cxy;
622 c = mBSDF_color(coef, sm, i, o);
623 while (c--)
624 coef[c] = (coef[c] - min_coef[c]) /
625 mtx_RGB_coef[c];
626 if (c_fromSharpRGB(coef, &cxy) > 1e-5)
627 mBSDF_chroma(sm,i,o) = c_encodeChroma(&cxy);
628 mBSDF_value(sm,i,o) -= ymin;
629 }
630 /* return colored minimum */
631 for (i = 3; i--; )
632 coef[i] = min_coef[i]/mtx_RGB_coef[i];
633 c_fromSharpRGB(coef, cs);
634
635 return M_PI*ymin;
636 }
637
638 /* Extract and separate diffuse portion of BSDF & convert color */
639 static SDSpectralDF *
640 extract_diffuse(SDValue *dv, SDSpectralDF *df)
641 {
642
643 df = encode_chroma(df); /* reduce XYZ to Y + chroma */
644 if (df == NULL || df->ncomp <= 0) {
645 dv->spec = c_dfcolor;
646 dv->cieY = .0;
647 return df;
648 }
649 /* subtract minimum value */
650 dv->cieY = subtract_min(&dv->spec, (SDMat *)df->comp[0].dist);
651 df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */
652 /* make sure everything is set */
653 c_ccvt(&dv->spec, C_CSXY+C_CSSPEC);
654 return df;
655 }
656
657 /* Load a BSDF matrix from an open XML file */
658 SDError
659 SDloadMtx(SDData *sd, ezxml_t wtl)
660 {
661 ezxml_t wld, wdb;
662 int rowIn;
663 char *txt;
664 int rval;
665 /* basic checks and data ordering */
666 txt = ezxml_txt(ezxml_child(ezxml_child(wtl,
667 "DataDefinition"), "IncidentDataStructure"));
668 if (txt == NULL || !*txt) {
669 sprintf(SDerrorDetail,
670 "BSDF \"%s\": missing IncidentDataStructure",
671 sd->name);
672 return SDEformat;
673 }
674 if (!strcasecmp(txt, "Rows"))
675 rowIn = 1;
676 else if (!strcasecmp(txt, "Columns"))
677 rowIn = 0;
678 else {
679 sprintf(SDerrorDetail,
680 "BSDF \"%s\": unsupported IncidentDataStructure",
681 sd->name);
682 return SDEsupport;
683 }
684 /* get angle bases */
685 for (wld = ezxml_child(ezxml_child(wtl, "DataDefinition"), "AngleBasis");
686 wld != NULL; wld = wld->next) {
687 rval = load_angle_basis(wld);
688 if (rval < 0)
689 return convert_errcode(rval);
690 }
691 /* load BSDF components */
692 for (wld = ezxml_child(wtl, "WavelengthData");
693 wld != NULL; wld = wld->next) {
694 const char *cnm = ezxml_txt(ezxml_child(wld,"Wavelength"));
695 int ct = -1;
696 if (!strcasecmp(cnm, "Visible"))
697 ct = mtx_Y;
698 else if (!strcasecmp(cnm, "CIE-X"))
699 ct = mtx_X;
700 else if (!strcasecmp(cnm, "CIE-Z"))
701 ct = mtx_Z;
702 else
703 continue;
704 for (wdb = ezxml_child(wld, "WavelengthDataBlock");
705 wdb != NULL; wdb = wdb->next)
706 if ((rval = load_bsdf_data(sd, wdb, ct, rowIn)) < 0)
707 return convert_errcode(rval);
708 }
709 /* separate diffuse components */
710 sd->rf = extract_diffuse(&sd->rLambFront, sd->rf);
711 sd->rb = extract_diffuse(&sd->rLambBack, sd->rb);
712 if (sd->tf != NULL)
713 sd->tf = extract_diffuse(&sd->tLamb, sd->tf);
714 if (sd->tb != NULL)
715 sd->tb = extract_diffuse(&sd->tLamb, sd->tb);
716 /* return success */
717 return SDEnone;
718 }
719
720 /* Get Matrix BSDF value */
721 static int
722 SDgetMtxBSDF(float coef[SDmaxCh], const FVECT outVec,
723 const FVECT inVec, SDComponent *sdc)
724 {
725 const SDMat *dp;
726 int i_ndx, o_ndx;
727 /* check arguments */
728 if ((coef == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL)
729 || (dp = (SDMat *)sdc->dist) == NULL)
730 return 0;
731 /* get angle indices */
732 i_ndx = mBSDF_incndx(dp, inVec);
733 o_ndx = mBSDF_outndx(dp, outVec);
734 /* try reciprocity if necessary */
735 if ((i_ndx < 0) & (o_ndx < 0)) {
736 i_ndx = mBSDF_incndx(dp, outVec);
737 o_ndx = mBSDF_outndx(dp, inVec);
738 }
739 if ((i_ndx < 0) | (o_ndx < 0))
740 return 0; /* nothing from this component */
741
742 return mBSDF_color(coef, dp, i_ndx, o_ndx);
743 }
744
745 /* Query solid angle for vector(s) */
746 static SDError
747 SDqueryMtxProjSA(double *psa, const FVECT v1, const RREAL *v2,
748 int qflags, SDComponent *sdc)
749 {
750 const SDMat *dp;
751 double inc_psa, out_psa;
752 /* check arguments */
753 if ((psa == NULL) | (v1 == NULL) | (sdc == NULL) ||
754 (dp = (SDMat *)sdc->dist) == NULL)
755 return SDEargument;
756 if (v2 == NULL)
757 v2 = v1;
758 /* get projected solid angles */
759 out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v1));
760 inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v2));
761 if ((v1 != v2) & (out_psa <= 0) & (inc_psa <= 0)) {
762 inc_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v2));
763 out_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v1));
764 }
765
766 switch (qflags) { /* record based on flag settings */
767 case SDqueryMax:
768 if (inc_psa > psa[0])
769 psa[0] = inc_psa;
770 if (out_psa > psa[0])
771 psa[0] = out_psa;
772 break;
773 case SDqueryMin+SDqueryMax:
774 if (inc_psa > psa[1])
775 psa[1] = inc_psa;
776 if (out_psa > psa[1])
777 psa[1] = out_psa;
778 /* fall through */
779 case SDqueryVal:
780 if (qflags == SDqueryVal)
781 psa[0] = M_PI;
782 /* fall through */
783 case SDqueryMin:
784 if ((inc_psa > 0) & (inc_psa < psa[0]))
785 psa[0] = inc_psa;
786 if ((out_psa > 0) & (out_psa < psa[0]))
787 psa[0] = out_psa;
788 break;
789 }
790 /* make sure it's legal */
791 return (psa[0] <= 0) ? SDEinternal : SDEnone;
792 }
793
794 /* Compute new cumulative distribution from BSDF */
795 static int
796 make_cdist(SDMatCDst *cd, const FVECT inVec, SDMat *dp, int rev)
797 {
798 const unsigned maxval = ~0;
799 double *cmtab, scale;
800 int o;
801
802 cmtab = (double *)malloc((cd->calen+1)*sizeof(double));
803 if (cmtab == NULL)
804 return 0;
805 cmtab[0] = .0;
806 for (o = 0; o < cd->calen; o++) {
807 if (rev)
808 cmtab[o+1] = mBSDF_value(dp, o, cd->indx) *
809 (*dp->ib_ohm)(o, dp->ib_priv);
810 else
811 cmtab[o+1] = mBSDF_value(dp, cd->indx, o) *
812 (*dp->ob_ohm)(o, dp->ob_priv);
813 cmtab[o+1] += cmtab[o];
814 }
815 cd->cTotal = cmtab[cd->calen];
816 scale = (double)maxval / cd->cTotal;
817 cd->carr[0] = 0;
818 for (o = 1; o < cd->calen; o++)
819 cd->carr[o] = scale*cmtab[o] + .5;
820 cd->carr[cd->calen] = maxval;
821 free(cmtab);
822 return 1;
823 }
824
825 /* Get cumulative distribution for matrix BSDF */
826 static const SDCDst *
827 SDgetMtxCDist(const FVECT inVec, SDComponent *sdc)
828 {
829 SDMat *dp;
830 int reverse;
831 SDMatCDst myCD;
832 SDMatCDst *cd, *cdlast;
833 /* check arguments */
834 if ((inVec == NULL) | (sdc == NULL) ||
835 (dp = (SDMat *)sdc->dist) == NULL)
836 return NULL;
837 memset(&myCD, 0, sizeof(myCD));
838 myCD.indx = mBSDF_incndx(dp, inVec);
839 if (myCD.indx >= 0) {
840 myCD.ob_priv = dp->ob_priv;
841 myCD.ob_vec = dp->ob_vec;
842 myCD.calen = dp->nout;
843 reverse = 0;
844 } else { /* try reciprocity */
845 myCD.indx = mBSDF_outndx(dp, inVec);
846 if (myCD.indx < 0)
847 return NULL;
848 myCD.ob_priv = dp->ib_priv;
849 myCD.ob_vec = dp->ib_vec;
850 myCD.calen = dp->ninc;
851 reverse = 1;
852 }
853 cdlast = NULL; /* check for it in cache list */
854 /* PLACE MUTEX LOCK HERE FOR THREAD-SAFE */
855 for (cd = (SDMatCDst *)sdc->cdList; cd != NULL;
856 cdlast = cd, cd = cd->next)
857 if (cd->indx == myCD.indx && (cd->calen == myCD.calen) &
858 (cd->ob_priv == myCD.ob_priv) &
859 (cd->ob_vec == myCD.ob_vec))
860 break;
861 if (cd == NULL) { /* need to allocate new entry */
862 cd = (SDMatCDst *)malloc(sizeof(SDMatCDst) +
863 sizeof(myCD.carr[0])*myCD.calen);
864 if (cd == NULL)
865 return NULL;
866 *cd = myCD; /* compute cumulative distribution */
867 if (!make_cdist(cd, inVec, dp, reverse)) {
868 free(cd);
869 return NULL;
870 }
871 cdlast = cd;
872 }
873 if (cdlast != NULL) { /* move entry to head of cache list */
874 cdlast->next = cd->next;
875 cd->next = (SDMatCDst *)sdc->cdList;
876 sdc->cdList = (SDCDst *)cd;
877 }
878 /* END MUTEX LOCK */
879 return (SDCDst *)cd; /* ready to go */
880 }
881
882 /* Sample cumulative distribution */
883 static SDError
884 SDsampMtxCDist(FVECT ioVec, double randX, const SDCDst *cdp)
885 {
886 const unsigned maxval = ~0;
887 const SDMatCDst *mcd = (const SDMatCDst *)cdp;
888 const unsigned target = randX*maxval;
889 int i, iupper, ilower;
890 /* check arguments */
891 if ((ioVec == NULL) | (mcd == NULL))
892 return SDEargument;
893 /* binary search to find index */
894 ilower = 0; iupper = mcd->calen;
895 while ((i = (iupper + ilower) >> 1) != ilower)
896 if (target >= mcd->carr[i])
897 ilower = i;
898 else
899 iupper = i;
900 /* localize random position */
901 randX = (randX*maxval - mcd->carr[ilower]) /
902 (double)(mcd->carr[iupper] - mcd->carr[ilower]);
903 /* convert index to vector */
904 if ((*mcd->ob_vec)(ioVec, i+randX, mcd->ob_priv))
905 return SDEnone;
906 strcpy(SDerrorDetail, "Matrix BSDF sampling fault");
907 return SDEinternal;
908 }
909
910 /* Fixed resolution BSDF methods */
911 const SDFunc SDhandleMtx = {
912 &SDgetMtxBSDF,
913 &SDqueryMtxProjSA,
914 &SDgetMtxCDist,
915 &SDsampMtxCDist,
916 &SDfreeMatrix,
917 };
