root/radiance/ray/src/common/bsdf_m.c
Revision: 3.30
Committed: Sun Apr 5 01:32:01 2015 UTC (10 years, 3 months ago) by greg
Changes since 3.29: +8 -8 lines
Added color rendering to tensor tree and minor fixes to Klems color rendering
2 static const char RCSid[] = "$Id: bsdf_m.c,v 3.29 2015/04/02 16:40:32 greg Exp $";
5 * bsdf_m.c
6 *
7 * Definitions supporting BSDF matrices
8 *
9 * Created by Greg Ward on 2/2/11.
10 * Copyright 2011 Anyhere Software. All rights reserved.
11 *
12 */
13
14 #define _USE_MATH_DEFINES
15 #include "rtio.h"
16 #include <math.h>
17 #include <ctype.h>
18 #include "ezxml.h"
19 #include "bsdf.h"
20 #include "bsdf_m.h"
21
22 /* Function return codes */
23 #define RC_GOOD 1
24 #define RC_FAIL 0
25 #define RC_FORMERR (-1)
26 #define RC_DATERR (-2)
27 #define RC_UNSUPP (-3)
28 #define RC_INTERR (-4)
29 #define RC_MEMERR (-5)
30
31 ANGLE_BASIS abase_list[MAXABASES] = {
32 {
33 "LBNL/Klems Full", 145,
34 { {0., 1},
35 {5., 8},
36 {15., 16},
37 {25., 20},
38 {35., 24},
39 {45., 24},
40 {55., 24},
41 {65., 16},
42 {75., 12},
43 {90., 0} }
44 }, {
45 "LBNL/Klems Half", 73,
46 { {0., 1},
47 {6.5, 8},
48 {19.5, 12},
49 {32.5, 16},
50 {46.5, 20},
51 {61.5, 12},
52 {76.5, 4},
53 {90., 0} }
54 }, {
55 "LBNL/Klems Quarter", 41,
56 { {0., 1},
57 {9., 8},
58 {27., 12},
59 {46., 12},
60 {66., 8},
61 {90., 0} }
62 }
63 };
64
65 int nabases = 3; /* current number of defined bases */
66
67 C_COLOR mtx_RGB_prim[3]; /* our RGB primaries */
68 float mtx_RGB_coef[3]; /* corresponding Y coefficients */
69
70 enum {mtx_Y, mtx_X, mtx_Z}; /* matrix components (mtx_Y==0) */
71
72 /* check if two real values are near enough to equal */
73 static int
74 fequal(double a, double b)
75 {
76 if (b != 0)
77 a = a/b - 1.;
78 return (a <= 1e-6) & (a >= -1e-6);
79 }
80
81 /* convert error to standard BSDF code */
82 static SDError
83 convert_errcode(int ec)
84 {
85 switch (ec) {
86 case RC_GOOD:
87 return SDEnone;
88 case RC_FORMERR:
89 return SDEformat;
90 case RC_DATERR:
91 return SDEdata;
92 case RC_UNSUPP:
93 return SDEsupport;
94 case RC_INTERR:
95 return SDEinternal;
96 case RC_MEMERR:
97 return SDEmemory;
98 }
99 return SDEunknown;
100 }
101
102 /* allocate a BSDF matrix of the given size */
103 static SDMat *
104 SDnewMatrix(int ni, int no)
105 {
106 SDMat *sm;
107
108 if ((ni <= 0) | (no <= 0)) {
109 strcpy(SDerrorDetail, "Empty BSDF matrix request");
110 return NULL;
111 }
112 sm = (SDMat *)malloc(sizeof(SDMat) + (ni*no - 1)*sizeof(float));
113 if (sm == NULL) {
114 sprintf(SDerrorDetail, "Cannot allocate %dx%d BSDF matrix",
115 ni, no);
116 return NULL;
117 }
118 memset(sm, 0, sizeof(SDMat)-sizeof(float));
119 sm->ninc = ni;
120 sm->nout = no;
121
122 return sm;
123 }
124
125 /* Free a BSDF matrix */
126 void
127 SDfreeMatrix(void *ptr)
128 {
129 SDMat *mp = (SDMat *)ptr;
130
131 if (mp->chroma != NULL) free(mp->chroma);
132 free(ptr);
133 }
134
135 /* Get vector for this angle basis index (front exiting) */
136 int
137 fo_getvec(FVECT v, double ndxr, void *p)
138 {
139 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
140 int ndx = (int)ndxr;
141 double randX = ndxr - ndx;
142 double rx[2];
143 int li;
144 double pol, azi, d;
145
146 if ((ndxr < 0) | (ndx >= ab->nangles))
147 return RC_FAIL;
148 for (li = 0; ndx >= ab->lat[li].nphis; li++)
149 ndx -= ab->lat[li].nphis;
150 SDmultiSamp(rx, 2, randX);
151 pol = M_PI/180.*( (1.-rx[0])*ab->lat[li].tmin +
152 rx[0]*ab->lat[li+1].tmin );
153 azi = 2.*M_PI*(ndx + rx[1] - .5)/ab->lat[li].nphis;
154 v[2] = d = cos(pol);
155 d = sqrt(1. - d*d); /* sin(pol) */
156 v[0] = cos(azi)*d;
157 v[1] = sin(azi)*d;
158 return RC_GOOD;
159 }
160
161 /* Get index corresponding to the given vector (front exiting) */
162 int
163 fo_getndx(const FVECT v, void *p)
164 {
165 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
166 int li, ndx;
167 double pol, azi;
168
169 if (v == NULL)
170 return -1;
171 if ((v[2] < 0) | (v[2] > 1.))
172 return -1;
173 pol = 180.0/M_PI*Acos(v[2]);
174 azi = 180.0/M_PI*atan2(v[1], v[0]);
175 if (azi < 0.0) azi += 360.0;
176 for (li = 1; ab->lat[li].tmin <= pol; li++)
177 if (!ab->lat[li].nphis)
178 return -1;
179 --li;
180 ndx = (int)((1./360.)*azi*ab->lat[li].nphis + 0.5);
181 if (ndx >= ab->lat[li].nphis) ndx = 0;
182 while (li--)
183 ndx += ab->lat[li].nphis;
184 return ndx;
185 }
186
187 /* compute square of real value */
188 static double sq(double x) { return x*x; }
189
190 /* Get projected solid angle for this angle basis index (universal) */
191 double
192 io_getohm(int ndx, void *p)
193 {
194 static int last_li = -1;
195 static double last_ohm;
196 ANGLE_BASIS *ab = (ANGLE_BASIS *)p;
197 int li;
198 double theta, theta1;
199
200 if ((ndx < 0) | (ndx >= ab->nangles))
201 return -1.;
202 for (li = 0; ndx >= ab->lat[li].nphis; li++)
203 ndx -= ab->lat[li].nphis;
204 if (li == last_li) /* cached latitude? */
205 return last_ohm;
206 last_li = li;
207 theta = M_PI/180. * ab->lat[li].tmin;
208 theta1 = M_PI/180. * ab->lat[li+1].tmin;
209 return last_ohm = M_PI*(sq(cos(theta)) - sq(cos(theta1))) /
210 (double)ab->lat[li].nphis;
211 }
212
213 /* Get vector for this angle basis index (back incident) */
214 int
215 bi_getvec(FVECT v, double ndxr, void *p)
216 {
217 if (!fo_getvec(v, ndxr, p))
218 return RC_FAIL;
219
220 v[0] = -v[0];
221 v[1] = -v[1];
222 v[2] = -v[2];
223
224 return RC_GOOD;
225 }
226
227 /* Get index corresponding to the vector (back incident) */
228 int
229 bi_getndx(const FVECT v, void *p)
230 {
231 FVECT v2;
232
233 v2[0] = -v[0];
234 v2[1] = -v[1];
235 v2[2] = -v[2];
236
237 return fo_getndx(v2, p);
238 }
239
240 /* Get vector for this angle basis index (back exiting) */
241 int
242 bo_getvec(FVECT v, double ndxr, void *p)
243 {
244 if (!fo_getvec(v, ndxr, p))
245 return RC_FAIL;
246
247 v[2] = -v[2];
248
249 return RC_GOOD;
250 }
251
252 /* Get index corresponding to the vector (back exiting) */
253 int
254 bo_getndx(const FVECT v, void *p)
255 {
256 FVECT v2;
257
258 v2[0] = v[0];
259 v2[1] = v[1];
260 v2[2] = -v[2];
261
262 return fo_getndx(v2, p);
263 }
264
265 /* Get vector for this angle basis index (front incident) */
266 int
267 fi_getvec(FVECT v, double ndxr, void *p)
268 {
269 if (!fo_getvec(v, ndxr, p))
270 return RC_FAIL;
271
272 v[0] = -v[0];
273 v[1] = -v[1];
274
275 return RC_GOOD;
276 }
277
278 /* Get index corresponding to the vector (front incident) */
279 int
280 fi_getndx(const FVECT v, void *p)
281 {
282 FVECT v2;
283
284 v2[0] = -v[0];
285 v2[1] = -v[1];
286 v2[2] = v[2];
287
288 return fo_getndx(v2, p);
289 }
290
291 /* Get color or grayscale value for BSDF for the given direction pair */
292 int
293 mBSDF_color(float coef[], const SDMat *dp, int i, int o)
294 {
295 C_COLOR cxy;
296
297 coef[0] = mBSDF_value(dp, i, o);
298 if (dp->chroma == NULL)
299 return 1; /* grayscale */
300
301 c_decodeChroma(&cxy, dp->chroma[o*dp->ninc + i]);
302 c_toSharpRGB(&cxy, coef[0], coef);
303 coef[0] *= mtx_RGB_coef[0];
304 coef[1] *= mtx_RGB_coef[1];
305 coef[2] *= mtx_RGB_coef[2];
306 return 3; /* RGB color */
307 }
308
309 /* load custom BSDF angle basis */
310 static int
311 load_angle_basis(ezxml_t wab)
312 {
313 char *abname = ezxml_txt(ezxml_child(wab, "AngleBasisName"));
314 ezxml_t wbb;
315 int i;
316
317 if (!abname || !*abname)
318 return RC_FAIL;
319 for (i = nabases; i--; )
320 if (!strcasecmp(abname, abase_list[i].name))
321 return RC_GOOD; /* assume it's the same */
322 if (nabases >= MAXABASES) {
323 sprintf(SDerrorDetail, "Out of angle bases reading '%s'",
324 abname);
325 return RC_INTERR;
326 }
327 strcpy(abase_list[nabases].name, abname);
328 abase_list[nabases].nangles = 0;
329 for (i = 0, wbb = ezxml_child(wab, "AngleBasisBlock");
330 wbb != NULL; i++, wbb = wbb->next) {
331 if (i >= MAXLATS) {
332 sprintf(SDerrorDetail, "Too many latitudes for '%s'",
333 abname);
334 return RC_INTERR;
335 }
336 abase_list[nabases].lat[i+1].tmin = atof(ezxml_txt(
337 ezxml_child(ezxml_child(wbb,
338 "ThetaBounds"), "UpperTheta")));
339 if (!i)
340 abase_list[nabases].lat[0].tmin = 0;
341 else if (!fequal(atof(ezxml_txt(ezxml_child(ezxml_child(wbb,
342 "ThetaBounds"), "LowerTheta"))),
343 abase_list[nabases].lat[i].tmin)) {
344 sprintf(SDerrorDetail, "Theta values disagree in '%s'",
345 abname);
346 return RC_DATERR;
347 }
348 abase_list[nabases].nangles +=
349 abase_list[nabases].lat[i].nphis =
350 atoi(ezxml_txt(ezxml_child(wbb, "nPhis")));
351 if (abase_list[nabases].lat[i].nphis <= 0 ||
352 (abase_list[nabases].lat[i].nphis == 1 &&
353 abase_list[nabases].lat[i].tmin > FTINY)) {
354 sprintf(SDerrorDetail, "Illegal phi count in '%s'",
355 abname);
356 return RC_DATERR;
357 }
358 }
359 abase_list[nabases++].lat[i].nphis = 0;
360 return RC_GOOD;
361 }
362
363 /* compute min. proj. solid angle and max. direct hemispherical scattering */
364 static int
365 get_extrema(SDSpectralDF *df)
366 {
367 SDMat *dp = (SDMat *)df->comp[0].dist;
368 double *ohma;
369 int i, o;
370 /* initialize extrema */
371 df->minProjSA = M_PI;
372 df->maxHemi = .0;
373 ohma = (double *)malloc(dp->nout*sizeof(double));
374 if (ohma == NULL)
375 return RC_MEMERR;
376 /* get outgoing solid angles */
377 for (o = dp->nout; o--; )
378 if ((ohma[o] = mBSDF_outohm(dp,o)) < df->minProjSA)
379 df->minProjSA = ohma[o];
380 /* compute hemispherical sums */
381 for (i = dp->ninc; i--; ) {
382 double hemi = .0;
383 for (o = dp->nout; o--; )
384 hemi += ohma[o] * mBSDF_value(dp, i, o);
385 if (hemi > df->maxHemi)
386 df->maxHemi = hemi;
387 }
388 free(ohma);
389 /* need incoming solid angles, too? */
390 if ((dp->ib_ohm != dp->ob_ohm) | (dp->ib_priv != dp->ob_priv)) {
391 double ohm;
392 for (i = dp->ninc; i--; )
393 if ((ohm = mBSDF_incohm(dp,i)) < df->minProjSA)
394 df->minProjSA = ohm;
395 }
396 return (df->maxHemi <= 1.01);
397 }
398
399 /* load BSDF distribution for this wavelength */
400 static int
401 load_bsdf_data(SDData *sd, ezxml_t wdb, int ct, int rowinc)
402 {
403 SDSpectralDF *df;
404 SDMat *dp;
405 char *sdata;
406 int inbi, outbi;
407 int i;
408 /* allocate BSDF component */
409 sdata = ezxml_txt(ezxml_child(wdb, "WavelengthDataDirection"));
410 if (!sdata)
411 return RC_FAIL;
412 /*
413 * Remember that front and back are reversed from WINDOW 6 orientations
414 */
415 if (!strcasecmp(sdata, "Transmission Front")) {
416 if (sd->tb == NULL && (sd->tb = SDnewSpectralDF(3)) == NULL)
417 return RC_MEMERR;
418 df = sd->tb;
419 } else if (!strcasecmp(sdata, "Transmission Back")) {
420 if (sd->tf == NULL && (sd->tf = SDnewSpectralDF(3)) == NULL)
421 return RC_MEMERR;
422 df = sd->tf;
423 } else if (!strcasecmp(sdata, "Reflection Front")) {
424 if (sd->rb == NULL && (sd->rb = SDnewSpectralDF(3)) == NULL)
425 return RC_MEMERR;
426 df = sd->rb;
427 } else if (!strcasecmp(sdata, "Reflection Back")) {
428 if (sd->rf == NULL && (sd->rf = SDnewSpectralDF(3)) == NULL)
429 return RC_MEMERR;
430 df = sd->rf;
431 } else
432 return RC_FAIL;
433 /* free previous matrix if any */
434 if (df->comp[ct].dist != NULL) {
435 SDfreeMatrix(df->comp[ct].dist);
436 df->comp[ct].dist = NULL;
437 }
438 /* get angle bases */
439 sdata = ezxml_txt(ezxml_child(wdb,"ColumnAngleBasis"));
440 if (!sdata || !*sdata) {
441 sprintf(SDerrorDetail, "Missing column basis for BSDF '%s'",
442 sd->name);
443 return RC_FORMERR;
444 }
445 for (inbi = nabases; inbi--; )
446 if (!strcasecmp(sdata, abase_list[inbi].name))
447 break;
448 if (inbi < 0) {
449 sprintf(SDerrorDetail, "Undefined ColumnAngleBasis '%s'", sdata);
450 return RC_FORMERR;
451 }
452 sdata = ezxml_txt(ezxml_child(wdb,"RowAngleBasis"));
453 if (!sdata || !*sdata) {
454 sprintf(SDerrorDetail, "Missing row basis for BSDF '%s'",
455 sd->name);
456 return RC_FORMERR;
457 }
458 for (outbi = nabases; outbi--; )
459 if (!strcasecmp(sdata, abase_list[outbi].name))
460 break;
461 if (outbi < 0) {
462 sprintf(SDerrorDetail, "Undefined RowAngleBasis '%s'", sdata);
463 return RC_FORMERR;
464 }
465 /* allocate BSDF matrix */
466 dp = SDnewMatrix(abase_list[inbi].nangles, abase_list[outbi].nangles);
467 if (dp == NULL)
468 return RC_MEMERR;
469 dp->ib_priv = &abase_list[inbi];
470 dp->ob_priv = &abase_list[outbi];
471 if (df == sd->tf) {
472 dp->ib_vec = &fi_getvec;
473 dp->ib_ndx = &fi_getndx;
474 dp->ob_vec = &bo_getvec;
475 dp->ob_ndx = &bo_getndx;
476 } else if (df == sd->tb) {
477 dp->ib_vec = &bi_getvec;
478 dp->ib_ndx = &bi_getndx;
479 dp->ob_vec = &fo_getvec;
480 dp->ob_ndx = &fo_getndx;
481 } else if (df == sd->rf) {
482 dp->ib_vec = &fi_getvec;
483 dp->ib_ndx = &fi_getndx;
484 dp->ob_vec = &fo_getvec;
485 dp->ob_ndx = &fo_getndx;
486 } else /* df == sd->rb */ {
487 dp->ib_vec = &bi_getvec;
488 dp->ib_ndx = &bi_getndx;
489 dp->ob_vec = &bo_getvec;
490 dp->ob_ndx = &bo_getndx;
491 }
492 dp->ib_ohm = &io_getohm;
493 dp->ob_ohm = &io_getohm;
494 df->comp[ct].dist = dp;
495 df->comp[ct].func = &SDhandleMtx;
496 /* read BSDF data */
497 sdata = ezxml_txt(ezxml_child(wdb, "ScatteringData"));
498 if (!sdata || !*sdata) {
499 sprintf(SDerrorDetail, "Missing BSDF ScatteringData in '%s'",
500 sd->name);
501 return RC_FORMERR;
502 }
503 for (i = 0; i < dp->ninc*dp->nout; i++) {
504 char *sdnext = fskip(sdata);
505 double val;
506 if (sdnext == NULL) {
507 sprintf(SDerrorDetail,
508 "Bad/missing BSDF ScatteringData in '%s'",
509 sd->name);
510 return RC_FORMERR;
511 }
512 while (isspace(*sdnext))
513 sdnext++;
514 if (*sdnext == ',') sdnext++;
515 if ((val = atof(sdata)) < 0)
516 val = 0; /* don't allow negative values */
517 if (rowinc) {
518 int r = i/dp->nout;
519 int c = i - r*dp->nout;
520 mBSDF_value(dp,r,c) = val;
521 } else
522 dp->bsdf[i] = val;
523 sdata = sdnext;
524 }
525 return (ct == mtx_Y) ? get_extrema(df) : RC_GOOD;
526 }
527
528 /* copy our RGB (x,y) primary chromaticities */
529 static void
530 copy_RGB_prims(C_COLOR cspec[])
531 {
532 if (mtx_RGB_coef[1] < .001) { /* need to initialize */
533 int i = 3;
534 while (i--) {
535 float rgb[3];
536 rgb[0] = rgb[1] = rgb[2] = .0f;
537 rgb[i] = 1.f;
538 mtx_RGB_coef[i] = c_fromSharpRGB(rgb, &mtx_RGB_prim[i]);
539 }
540 }
541 memcpy(cspec, mtx_RGB_prim, sizeof(mtx_RGB_prim));
542 }
543
544 /* encode chromaticity if XYZ -- reduce to one channel in any case */
545 static SDSpectralDF *
546 encode_chroma(SDSpectralDF *df)
547 {
548 SDMat *mpx, *mpy, *mpz;
549 int n;
550
551 if (df == NULL || df->ncomp != 3)
552 return df;
553
554 mpy = (SDMat *)df->comp[mtx_Y].dist;
555 if (mpy == NULL) {
556 free(df);
557 return NULL;
558 }
559 mpx = (SDMat *)df->comp[mtx_X].dist;
560 mpz = (SDMat *)df->comp[mtx_Z].dist;
561 if (mpx == NULL || (mpx->ninc != mpy->ninc) | (mpx->nout != mpy->nout))
562 goto done;
563 if (mpz == NULL || (mpz->ninc != mpy->ninc) | (mpz->nout != mpy->nout))
564 goto done;
565 mpy->chroma = (C_CHROMA *)malloc(sizeof(C_CHROMA)*mpy->ninc*mpy->nout);
566 if (mpy->chroma == NULL)
567 goto done; /* XXX punt */
568 /* encode chroma values */
569 for (n = mpy->ninc*mpy->nout; n--; ) {
570 const double sum = mpx->bsdf[n] + mpy->bsdf[n] + mpz->bsdf[n];
571 C_COLOR cxy;
572 if (sum > .0)
573 c_cset(&cxy, mpx->bsdf[n]/sum, mpy->bsdf[n]/sum);
574 else
575 c_cset(&cxy, 1./3., 1./3.);
576 mpy->chroma[n] = c_encodeChroma(&cxy);
577 }
578 done: /* free X & Z channels */
579 if (mpx != NULL) SDfreeMatrix(mpx);
580 if (mpz != NULL) SDfreeMatrix(mpz);
581 if (mpy->chroma == NULL) /* grayscale after all? */
582 df->comp[0].cspec[0] = c_dfcolor;
583 else /* else copy RGB primaries */
584 copy_RGB_prims(df->comp[0].cspec);
585 df->ncomp = 1; /* return resized struct */
586 return (SDSpectralDF *)realloc(df, sizeof(SDSpectralDF));
587 }
588
589 /* subtract minimum (diffuse) scattering amount from BSDF */
590 static double
591 subtract_min(C_COLOR *cs, SDMat *sm)
592 {
593 const int ncomp = 1 + 2*(sm->chroma != NULL);
594 float min_coef[3], coef[3];
595 int i, o, c;
596
597 min_coef[0] = min_coef[1] = min_coef[2] = FHUGE;
598 for (i = 0; i < sm->ninc; i++)
599 for (o = 0; o < sm->nout; o++) {
600 c = mBSDF_color(coef, sm, i, o);
601 while (c--)
602 if (coef[c] < min_coef[c])
603 min_coef[c] = coef[c];
604 }
605 for (c = ncomp; c--; )
606 if (min_coef[c] > FTINY)
607 break;
608 if (c < 0)
609 return .0;
610 if (ncomp == 1) { /* subtract grayscale minimum */
611 for (i = sm->ninc*sm->nout; i--; )
612 sm->bsdf[i] -= min_coef[0];
613 *cs = c_dfcolor;
614 return min_coef[0]*M_PI;
615 }
616 /* else subtract colored minimum */
617 for (i = 0; i < sm->ninc; i++)
618 for (o = 0; o < sm->nout; o++) {
619 C_COLOR cxy;
620 c = mBSDF_color(coef, sm, i, o);
621 while (c--)
622 coef[c] = (coef[c] - min_coef[c]) /
623 mtx_RGB_coef[c];
624 if (c_fromSharpRGB(coef, &cxy) > 1e-5)
625 sm->chroma[o*sm->ninc + i] = c_encodeChroma(&cxy);
626 mBSDF_value(sm,i,o) -= min_coef[0]+min_coef[1]+min_coef[2];
627 }
628 /* return colored minimum */
629 for (i = 3; i--; )
630 coef[i] = min_coef[i]/mtx_RGB_coef[i];
631 c_fromSharpRGB(coef, cs);
632
633 return (min_coef[0]+min_coef[1]+min_coef[2])*M_PI;
634 }
635
636 /* Extract and separate diffuse portion of BSDF & convert color */
637 static SDSpectralDF *
638 extract_diffuse(SDValue *dv, SDSpectralDF *df)
639 {
640
641 df = encode_chroma(df); /* reduce XYZ to Y + chroma */
642 if (df == NULL || df->ncomp <= 0) {
643 dv->spec = c_dfcolor;
644 dv->cieY = .0;
645 return df;
646 }
647 /* subtract minimum value */
648 dv->cieY = subtract_min(&dv->spec, (SDMat *)df->comp[0].dist);
649 df->maxHemi -= dv->cieY; /* adjust maximum hemispherical */
650 /* make sure everything is set */
651 c_ccvt(&dv->spec, C_CSXY+C_CSSPEC);
652 return df;
653 }
654
655 /* Load a BSDF matrix from an open XML file */
656 SDError
657 SDloadMtx(SDData *sd, ezxml_t wtl)
658 {
659 ezxml_t wld, wdb;
660 int rowIn;
661 char *txt;
662 int rval;
663 /* basic checks and data ordering */
664 txt = ezxml_txt(ezxml_child(ezxml_child(wtl,
665 "DataDefinition"), "IncidentDataStructure"));
666 if (txt == NULL || !*txt) {
667 sprintf(SDerrorDetail,
668 "BSDF \"%s\": missing IncidentDataStructure",
669 sd->name);
670 return SDEformat;
671 }
672 if (!strcasecmp(txt, "Rows"))
673 rowIn = 1;
674 else if (!strcasecmp(txt, "Columns"))
675 rowIn = 0;
676 else {
677 sprintf(SDerrorDetail,
678 "BSDF \"%s\": unsupported IncidentDataStructure",
679 sd->name);
680 return SDEsupport;
681 }
682 /* get angle bases */
683 for (wld = ezxml_child(ezxml_child(wtl, "DataDefinition"), "AngleBasis");
684 wld != NULL; wld = wld->next) {
685 rval = load_angle_basis(wld);
686 if (rval < 0)
687 return convert_errcode(rval);
688 }
689 /* load BSDF components */
690 for (wld = ezxml_child(wtl, "WavelengthData");
691 wld != NULL; wld = wld->next) {
692 const char *cnm = ezxml_txt(ezxml_child(wld,"Wavelength"));
693 int ct = -1;
694 if (!strcasecmp(cnm, "Visible"))
695 ct = mtx_Y;
696 else if (!strcasecmp(cnm, "CIE-X"))
697 ct = mtx_X;
698 else if (!strcasecmp(cnm, "CIE-Z"))
699 ct = mtx_Z;
700 else
701 continue;
702 for (wdb = ezxml_child(wld, "WavelengthDataBlock");
703 wdb != NULL; wdb = wdb->next)
704 if ((rval = load_bsdf_data(sd, wdb, ct, rowIn)) < 0)
705 return convert_errcode(rval);
706 }
707 /* separate diffuse components */
708 sd->rf = extract_diffuse(&sd->rLambFront, sd->rf);
709 sd->rb = extract_diffuse(&sd->rLambBack, sd->rb);
710 if (sd->tf != NULL)
711 sd->tf = extract_diffuse(&sd->tLamb, sd->tf);
712 if (sd->tb != NULL)
713 sd->tb = extract_diffuse(&sd->tLamb, sd->tb);
714 /* return success */
715 return SDEnone;
716 }
717
718 /* Get Matrix BSDF value */
719 static int
720 SDgetMtxBSDF(float coef[SDmaxCh], const FVECT outVec,
721 const FVECT inVec, SDComponent *sdc)
722 {
723 const SDMat *dp;
724 int i_ndx, o_ndx;
725 /* check arguments */
726 if ((coef == NULL) | (outVec == NULL) | (inVec == NULL) | (sdc == NULL)
727 || (dp = (SDMat *)sdc->dist) == NULL)
728 return 0;
729 /* get angle indices */
730 i_ndx = mBSDF_incndx(dp, inVec);
731 o_ndx = mBSDF_outndx(dp, outVec);
732 /* try reciprocity if necessary */
733 if ((i_ndx < 0) & (o_ndx < 0)) {
734 i_ndx = mBSDF_incndx(dp, outVec);
735 o_ndx = mBSDF_outndx(dp, inVec);
736 }
737 if ((i_ndx < 0) | (o_ndx < 0))
738 return 0; /* nothing from this component */
739
740 return mBSDF_color(coef, dp, i_ndx, o_ndx);
741 }
742
743 /* Query solid angle for vector(s) */
744 static SDError
745 SDqueryMtxProjSA(double *psa, const FVECT v1, const RREAL *v2,
746 int qflags, SDComponent *sdc)
747 {
748 const SDMat *dp;
749 double inc_psa, out_psa;
750 /* check arguments */
751 if ((psa == NULL) | (v1 == NULL) | (sdc == NULL) ||
752 (dp = (SDMat *)sdc->dist) == NULL)
753 return SDEargument;
754 if (v2 == NULL)
755 v2 = v1;
756 /* get projected solid angles */
757 out_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v1));
758 inc_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v2));
759 if ((v1 != v2) & (out_psa <= 0) & (inc_psa <= 0)) {
760 inc_psa = mBSDF_outohm(dp, mBSDF_outndx(dp, v2));
761 out_psa = mBSDF_incohm(dp, mBSDF_incndx(dp, v1));
762 }
763
764 switch (qflags) { /* record based on flag settings */
765 case SDqueryMax:
766 if (inc_psa > psa[0])
767 psa[0] = inc_psa;
768 if (out_psa > psa[0])
769 psa[0] = out_psa;
770 break;
771 case SDqueryMin+SDqueryMax:
772 if (inc_psa > psa[1])
773 psa[1] = inc_psa;
774 if (out_psa > psa[1])
775 psa[1] = out_psa;
776 /* fall through */
777 case SDqueryVal:
778 if (qflags == SDqueryVal)
779 psa[0] = M_PI;
780 /* fall through */
781 case SDqueryMin:
782 if ((inc_psa > 0) & (inc_psa < psa[0]))
783 psa[0] = inc_psa;
784 if ((out_psa > 0) & (out_psa < psa[0]))
785 psa[0] = out_psa;
786 break;
787 }
788 /* make sure it's legal */
789 return (psa[0] <= 0) ? SDEinternal : SDEnone;
790 }
791
792 /* Compute new cumulative distribution from BSDF */
793 static int
794 make_cdist(SDMatCDst *cd, const FVECT inVec, SDMat *dp, int rev)
795 {
796 const unsigned maxval = ~0;
797 double *cmtab, scale;
798 int o;
799
800 cmtab = (double *)malloc((cd->calen+1)*sizeof(double));
801 if (cmtab == NULL)
802 return 0;
803 cmtab[0] = .0;
804 for (o = 0; o < cd->calen; o++) {
805 if (rev)
806 cmtab[o+1] = mBSDF_value(dp, o, cd->indx) *
807 (*dp->ib_ohm)(o, dp->ib_priv);
808 else
809 cmtab[o+1] = mBSDF_value(dp, cd->indx, o) *
810 (*dp->ob_ohm)(o, dp->ob_priv);
811 cmtab[o+1] += cmtab[o];
812 }
813 cd->cTotal = cmtab[cd->calen];
814 scale = (double)maxval / cd->cTotal;
815 cd->carr[0] = 0;
816 for (o = 1; o < cd->calen; o++)
817 cd->carr[o] = scale*cmtab[o] + .5;
818 cd->carr[cd->calen] = maxval;
819 free(cmtab);
820 return 1;
821 }
822
823 /* Get cumulative distribution for matrix BSDF */
824 static const SDCDst *
825 SDgetMtxCDist(const FVECT inVec, SDComponent *sdc)
826 {
827 SDMat *dp;
828 int reverse;
829 SDMatCDst myCD;
830 SDMatCDst *cd, *cdlast;
831 /* check arguments */
832 if ((inVec == NULL) | (sdc == NULL) ||
833 (dp = (SDMat *)sdc->dist) == NULL)
834 return NULL;
835 memset(&myCD, 0, sizeof(myCD));
836 myCD.indx = mBSDF_incndx(dp, inVec);
837 if (myCD.indx >= 0) {
838 myCD.ob_priv = dp->ob_priv;
839 myCD.ob_vec = dp->ob_vec;
840 myCD.calen = dp->nout;
841 reverse = 0;
842 } else { /* try reciprocity */
843 myCD.indx = mBSDF_outndx(dp, inVec);
844 if (myCD.indx < 0)
845 return NULL;
846 myCD.ob_priv = dp->ib_priv;
847 myCD.ob_vec = dp->ib_vec;
848 myCD.calen = dp->ninc;
849 reverse = 1;
850 }
851 cdlast = NULL; /* check for it in cache list */
852 for (cd = (SDMatCDst *)sdc->cdList; cd != NULL;
853 cdlast = cd, cd = cd->next)
854 if (cd->indx == myCD.indx && (cd->calen == myCD.calen) &
855 (cd->ob_priv == myCD.ob_priv) &
856 (cd->ob_vec == myCD.ob_vec))
857 break;
858 if (cd == NULL) { /* need to allocate new entry */
859 cd = (SDMatCDst *)malloc(sizeof(SDMatCDst) +
860 sizeof(myCD.carr[0])*myCD.calen);
861 if (cd == NULL)
862 return NULL;
863 *cd = myCD; /* compute cumulative distribution */
864 if (!make_cdist(cd, inVec, dp, reverse)) {
865 free(cd);
866 return NULL;
867 }
868 cdlast = cd;
869 }
870 if (cdlast != NULL) { /* move entry to head of cache list */
871 cdlast->next = cd->next;
872 cd->next = (SDMatCDst *)sdc->cdList;
873 sdc->cdList = (SDCDst *)cd;
874 }
875 return (SDCDst *)cd; /* ready to go */
876 }
877
878 /* Sample cumulative distribution */
879 static SDError
880 SDsampMtxCDist(FVECT ioVec, double randX, const SDCDst *cdp)
881 {
882 const unsigned maxval = ~0;
883 const SDMatCDst *mcd = (const SDMatCDst *)cdp;
884 const unsigned target = randX*maxval;
885 int i, iupper, ilower;
886 /* check arguments */
887 if ((ioVec == NULL) | (mcd == NULL))
888 return SDEargument;
889 /* binary search to find index */
890 ilower = 0; iupper = mcd->calen;
891 while ((i = (iupper + ilower) >> 1) != ilower)
892 if (target >= mcd->carr[i])
893 ilower = i;
894 else
895 iupper = i;
896 /* localize random position */
897 randX = (randX*maxval - mcd->carr[ilower]) /
898 (double)(mcd->carr[iupper] - mcd->carr[ilower]);
899 /* convert index to vector */
900 if ((*mcd->ob_vec)(ioVec, i+randX, mcd->ob_priv))
901 return SDEnone;
902 strcpy(SDerrorDetail, "Matrix BSDF sampling fault");
903 return SDEinternal;
904 }
905
906 /* Fixed resolution BSDF methods */
907 SDFunc SDhandleMtx = {
908 &SDgetMtxBSDF,
909 &SDqueryMtxProjSA,
910 &SDgetMtxCDist,
911 &SDsampMtxCDist,
912 &SDfreeMatrix,
913 };
